11-05-2016, 08:33 | #1 (permalink) |
No Life Poster Join Date: May 2014 Location: Peshwar, Pakistan
Member: 2192793 Status: Offline Thanks Meter: 188 | Jaydi sir plz help about qualcomm mobiles Here i want to mention a very common problem for new users now a days that they cant connect qualcomm mobiles to CM2QLM, means how to connect mobile (boot keys). in software its says hold volume up and volume down to connect the mobile but it's not work, but i have seen here several reports that they have read and write the flash like Qmobile Z8 or Z9 and Lenovo A6000 etc. . . We will very thanks full to you if you or some one else share the video to guide the users. Thanks in advance |
11-05-2016, 08:55 | #2 (permalink) |
No Life Poster Join Date: Mar 2014 Location: Rawalpindi, Pakistan
Member: 2138570 Status: Offline Sonork: 100.1611495 Thanks Meter: 301 | hi to all brothers who don't able to work with qualcome tool these steps you have to do i faced same connecting porblem then first 1) (USBDeview_x86_BIT_v2.60_tehnotone.com) download and uninstall all qualcomm hs-usb qdloader 9008 drivers 2) restart pc 3) ( EmergencyDownloadDriver.msi) install this 4) (WinUsbCoInstallers.msi) install this 5) (WinUsbCompatIdInstaller.msi) install this 6) (WinUsbDriversExt.msi) install this 7) restart pc 9) press and hold vol- + vol+ and connect USB cable and wait to install drivers after these steps it will connet 1000% |
The Following 3 Users Say Thank You to Ismail khan1978 For This Useful Post: |
11-05-2016, 10:04 | #3 (permalink) |
No Life Poster Join Date: Jun 2014 Location: Infinity Box Team
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | 1 install Emergency Mode Drivers Download From Infinity Support Named InfinityBox_update_CM2QLM_Drivers_v1.00.7z 2 after download and install open path/directory C:\InfinityBox\CM2QLM\Drivers 3 install EmergencyDownloadDriver.exe 4 open cm2 qualcomm exe and do select and run which operation you want to do 5 power off mobile pres volume up and down @ same time and insert usb cable Hope It's Clear |
11-05-2016, 11:44 | #4 (permalink) | |
Registered User Join Date: Nov 2013 Location: Somewhere
Member: 2072293 Status: Offline Thanks Meter: 9 | Quote:
mobile connect but showing 9008 driver. | |
11-05-2016, 12:47 | #5 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Read Manual from C:\InfinityBox\CM2QLM\docs folder. Install new driver (v1.02) from support, restart pc and try to connect again. You can also manually update 9008 driver to Emergency driver. Br. Infinity Box Support Team. |
11-05-2016, 13:30 | #6 (permalink) | |
how i can manual update 9008 driver to Emergency driver ? one more step could help for me. | |
11-05-2016, 17:16 | #8 (permalink) |
Member: 2072293 Status: Offline Thanks Meter: 9 | How I can give path to PC for select emergency driver ? Right click an d select update driver PC asking a path but where I get folder for emergency driver ? |
11-05-2016, 17:37 | #9 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | After you install drivers - choose select from installed ones , find Universal Serial Bus and select Microsoft/Nokia Emergency/QHSUSB_BULK. |
The Following 3 Users Say Thank You to JayDi For This Useful Post: |
11-07-2016, 07:55 | #13 (permalink) |
No Life Poster Join Date: Sep 2015 Location: Earth
Member: 2455344 Status: Offline Sonork: Ask me Thanks Meter: 420 | DRiver Decided Where To put Phone Either FASt boot Or EDL mod when device attached on USB port , drivers install on PC RAM, You uninstall Them from Device manager , but they still in RAM, and re attach device they come back From RAM removing From RAM you must restart PC , Use driver uninstaller Program from Google.com remove all Qualcom Driver one to all NOTE: many Manufacture use Qualcomn Driver For Fast boot, like Motorola , QPST tool , Try To remove all of them , then restart PC Fresh Install Driver From Support then Try ... |
11-07-2016, 08:05 | #15 (permalink) | |
No Life Poster Join Date: Dec 2013 Location: India
Member: 2082450 Status: Offline Thanks Meter: 1,454 | Quote:
Why did you shared wrong info here?? Yes, show me a picture, where the drivers are installed on ram??? | |
The Following User Says Thank You to chandanps18 For This Useful Post: |
