sonyericsson j110i outgoing incoming calls ERROR j110 outgoing incomming call error 1) free trick for infinity user connect problem connect fone with out bettery i write eeprom from support sp unlock repair formate setting but i cant call out the fone was already unlocked error in call here is repair log COM2 [VCP2] selected module v1.32 Device: Sony-Ericsson-J110i "advanced chip detection" active Action: repair Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! loading... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 89886200010001:89886200000000 flash: Intel Intel std [def 003Fx010000 0008x002000] 4Mb software version: 039C-000 software version: KIM-5- Check hardware done Read data ... reading Sony-Ericsson-J110i_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-J110i_eeprom_calibration-1_20090413-015531.6AE.bin Read data done Check data ... Check data done Write ... .........data prepared Ok flash: 89886200010001:89886200000000 Write: eeprom Write done Finished, time used: 124 sec Remove/Install battery now ! plz help thanks in advance\ br yasermalik |
Hello, Sorry, I do not understand well. Did you solved the problem after you write repair eeprom and make "Repair" operation ? |
i post repair opreation bcuz i seen lot of post they all say repair option not working problem is still there i want a good and tested saloution thanks in advance br yasermalik |
