08-14-2010, 11:56 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: saqi mobiles pirmahal pakistan Age: 37
Member: 780173 Status: Offline Sonork: 100.1594488 Thanks Meter: 912 | sonyerission x6 china copy i have x6 its problem is hanging i format it full mode first i read backup full flash and format it set is on the dead mode i not see the any button write full flash i lode this backup file on the firmware and flash it its flash log COM3 [VCP0] selected module v3.20 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware _fullflash_20100810-195303.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:5503:0003 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98004900000002:18A59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: 98004900000002:18A59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #02 in region #00... flash: 98004900000002:18A59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #03 in region #00... flash: 98004900000002:18A59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 98004900000002:18A59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: 98004900000002:18A59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 it's time to stop: 18B09FA518B09FA518B09FA518B09FA518B09FA518B09FA5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 00E00000 flash: 98004900000002:18A59F00000000 checking area [00000000]: 00080000-00FFFFFF... ffs/eeprom found near: 00760000 Detected ffs/eeprom address is non-standard: 00760000 Posible reasons: 1. ffs/eeprom is Ok but address is non-standard 2. ffs/eeprom is damaged and can't be detected 3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make full flash backup for emergency case 3. repeat required operation Are you sure that detected ffs/eeprom address is correct ? autodetected ffs/eeprom address confirmed by user: 00760000 detecting ffs/eeprom size... ffs/eeprom size: 008A0000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00760000-00FFFFFF firmware area: 00000000-0075FFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: _ffs... file saved: C:\Documents and Settings\saqi mobiles\My Documents\_ffs_20100814-145046.B0E.bin flash: 98004900000002:18A59F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < ffs/eeprom address can not be detected, value from database assigned: 00760000/008A0000 sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent detecting startup code area #2... startup code area #2 is absent Area: Firmware flash: 98004900000002:18A59F00000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done Finished, time used: 22 min 6 sec Remove/Install battery now ! i check it with battery & supply but i not power on i check his read detail infomation its show this COM3 [VCP0] selected module v3.20 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: read/check information ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:5503:0003 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98004900000002:18A59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: 98004900000002:18A59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #02 in region #00... flash: 98004900000002:18A59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #03 in region #00... flash: 98004900000002:18A59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 98004900000002:18A59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: 98004900000002:18A59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 it's time to stop: 18B09FA518B09FA518B09FA518B09FA518B09FA518B09FA5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF detecting ffs/eeprom structure pass 1... .................................................. ...... ffs/eeprom: can't detect record name location error: ffs/eeprom detection failed: element #1 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished detecting firmware version... .................................................. .............. .................................................. .............. done warning: can not detect firmware version if software freez: make "Find firmware version (slow process)" unchecked and repeat operation. detecting firmware build... .................................................. .............. .................................................. .............. done detecting product-id... .................................................. .............. done detecting languages... .................................................. .............. error: can't detect language parameter #1 warning: can not detect language names if software freez: make "Find language names (slow process)" unchecked and repeat operation. Finished, time used: 2 min 14 sec Remove/Install battery now ! plz help me his soultion advance thanks |
The Following User Says Thank You to saqi160 For This Useful Post: |
08-14-2010, 13:33 | #4 (permalink) | |
Member: 780173 Status: Offline Sonork: 100.1594488 Thanks Meter: 912 | Quote:
_fullflash_20100810-195303.B0M.bin - 4shared.com - online file sharing and storage - download | |
08-14-2010, 13:35 | #5 (permalink) |
Member: 780173 Status: Offline Sonork: 100.1594488 Thanks Meter: 912 | plz sir check it and post the solution |
08-14-2010, 17:59 | #6 (permalink) |
Freak Poster Join Date: Jan 2009
Member: 950629 Status: Offline Thanks Meter: 105 | warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) warning: can not detect firmware version To solve your problem Do flowing. 1. Go to the Setting tab.... 1.0. Select Enhanced security fix method 1.1. select Advance chip detection method 2. Go to the Flash tab 2.1 click Load Firmware and load your full backup file. 2.2 select repair "Code CRC Check Error" 2.3 click Write and wait until flashing done. 3. After Flashing completed, insert battery to the phone and press and hold power button for 2 min. If not successful, download the firmware flash file and ffs flash file from support area and flash them as described above.(to flash ffs click "Load Eeprom/ffs" ) Hope you will Success.. |
The Following User Says Thank You to mswmkm For This Useful Post: |
08-15-2010, 07:16 | #7 (permalink) | |
thanks for replay i write with this proseser but problem not solve flash log COM3 [VCP0] selected module v3.20 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware _fullflash_20100810-195303.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! enhanced security fix enabled ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:5503:0003 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98004900000002:18A59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: 98004900000002:18A59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #02 in region #00... flash: 98004900000002:18A59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #03 in region #00... flash: 98004900000002:18A59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 98004900000002:18A59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: 98004900000002:18A59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 it's time to stop: 18B09FA518B09FA518B09FA518B09FA518B09FA518B09FA5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: _ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\_ffs_20100815-105150.B0E.bin flash: 98004900000002:18A59F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Code CRC check error fix... firmware do not have "Code CRC check error" area Special operation Done ====> Write ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < ffs/eeprom address can not be detected, value from database assigned: 00E00000/00200000 sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent detecting startup code area #2... startup code area #2 is absent Area: Firmware flash: 98004900000002:18A59F00000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done Finished, time used: 13 min 51 sec Remove/Install battery now ! info log COM3 [VCP0] selected module v3.20 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware _fullflash_20100810-195303.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! enhanced security fix enabled ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:5503:0003 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98004900000002:18A59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: 98004900000002:18A59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #02 in region #00... flash: 98004900000002:18A59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #03 in region #00... flash: 98004900000002:18A59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 98004900000002:18A59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: 98004900000002:18A59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 it's time to stop: 18B09FA518B09FA518B09FA518B09FA518B09FA518B09FA5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: _ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\_ffs_20100815-105150.B0E.bin flash: 98004900000002:18A59F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Code CRC check error fix... firmware do not have "Code CRC check error" area Special operation Done ====> Write ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < ffs/eeprom address can not be detected, value from database assigned: 00E00000/00200000 sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent detecting startup code area #2... startup code area #2 is absent Area: Firmware flash: 98004900000002:18A59F00000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done Finished, time used: 13 min 51 sec Remove/Install battery now ! prodect manger u and your team can not make the its files with full flash backup plz replay | |
08-15-2010, 11:07 | #8 (permalink) |
Member: 780173 Status: Offline Sonork: 100.1594488 Thanks Meter: 912 | i am waiting brothers .................................. |
08-15-2010, 11:11 | #9 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! your flash file looks like damaged. this ussually hapends if flash IC is soldered badly I succeeded to extract flash file version: HEXING25_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_ W08_12_120 I belive that you must resolder flash IC first. after that find same working phone or mentioned above flash file |
08-15-2010, 11:20 | #10 (permalink) | |
thanks for replay sir i tri it resolder the flash ic thanks sir | |
08-16-2010, 05:21 | #11 (permalink) | |
Member: 950629 Status: Offline Thanks Meter: 105 | Quote:
GD luck. | |
08-17-2010, 10:57 | #12 (permalink) |
Member: 780173 Status: Offline Sonork: 100.1594488 Thanks Meter: 912 | hi to all brothers i resolder flash IC first. and flash it with backup flash log COM3 [VCP0] selected module v3.20 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware _fullflash_20100810-195303.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:5503:0003 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98004900000002:18A59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: 98004900000002:18A59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #02 in region #00... flash: 98004900000002:18A59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #03 in region #00... flash: 98004900000002:18A59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 98004900000002:18A59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: 98004900000002:18A59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 it's time to stop: 18B09FA518B09FA518B09FA518B09FA518B09FA518B09FA5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 00E00000 flash: 98004900000002:18A59F00000000 checking area [00000000]: 00080000-00FFFFFF... ffs/eeprom found near: 00760000 Detected ffs/eeprom address is non-standard: 00760000 Posible reasons: 1. ffs/eeprom is Ok but address is non-standard 2. ffs/eeprom is damaged and can't be detected 3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make full flash backup for emergency case 3. repeat required operation Are you sure that detected ffs/eeprom address is correct ? autodetected ffs/eeprom address confirmed by user: 00760000 detecting ffs/eeprom size... ffs/eeprom size: 008A0000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00760000-00FFFFFF firmware area: 00000000-0075FFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: _ffs... file saved: C:\Documents and Settings\kashish\My Documents\_ffs_20100817-023519.B0E.bin flash: 98004900000002:18A59F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < ffs/eeprom address can not be detected, value from database assigned: 00760000/008A0000 sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent detecting startup code area #2... startup code area #2 is absent Area: Firmware flash: 98004900000002:18A59F00000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done Finished, time used: 24 min 17 sec Remove/Install battery now ! info log COM3 [VCP0] selected module v3.20 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: read/check information ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:5503:0003 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98004900000002:18A59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: 98004900000002:18A59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #02 in region #00... flash: 98004900000002:18A59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #03 in region #00... flash: 98004900000002:18A59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 98004900000002:18A59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: 98004900000002:18A59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 it's time to stop: 18B09FA518B09FA518B09FA518B09FA518B09FA518B09FA5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF detecting ffs/eeprom structure pass 1... .................................................. ...... ffs/eeprom: can't detect record name location error: ffs/eeprom detection failed: element #1 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished detecting firmware version... .................................................. .............. .................................................. .............. done warning: can not detect firmware version if software freez: make "Find firmware version (slow process)" unchecked and repeat operation. detecting firmware build... .................................................. .............. .................................................. .............. done detecting product-id... .................................................. .............. done detecting languages... .................................................. .............. error: can't detect language parameter #1 warning: can not detect language names if software freez: make "Find language names (slow process)" unchecked and repeat operation. Finished, time used: 2 min 12 sec Remove/Install battery now ! problem not solve i was see this file on support aria HEXING25_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_ W08_12_120 but it not in plz send me this file firmware,and epprom plz thank for advance |
08-17-2010, 14:16 | #13 (permalink) | |
plz help me sir .................... | |
08-17-2010, 20:00 | #14 (permalink) |
Member: 950629 Status: Offline Thanks Meter: 105 | this is not a file problem. it is a hardware faulty. U can check flash ic damaged or not by this method. 1. power on phone through power supply. 2. measure how much current show in the meeter when press power on. Flash IC faulty shown like this *phone get high current instantly during power on pressed and drop instantly when release power button. |
SIM COPYING WITH ELVIS | jj008 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-28-2001 11:22 |
7110 V4.88 how to copy good flash?? | allecor | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 03-27-2001 17:40 |
Who have 5110 5.11 EEPROM copy | Joeman | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 01-16-2001 08:56 |
Unlock 1&2 ; Copying a unlocked 6150 | renvanokel | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 06-24-1999 06:25 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
