sos 1 Attachment(s) i need the n95 slider pinouts plz i tried every thing but it didn't work and i even damaged my box twice from the wrong pinouts would you plz help me and see the pictures |
1,5 GND 6 RX 7 TX 12 VCC This is with the Chinese pin count beginning from the left |
:mad::mad::mad: |
the connector type is 1*12 mini and about the box i managed to repair it if someone need help i can do it |
I asked you because of it.The pinout I posted is for 2*6 connector type. |
if u open the fone u wil see 5 pionts on the pcb but the problem is this no mantion which 1 is gnd,tx,rx,+v,pwr use multimeter and yours brain u can got the pinouts if u have n e problem pm me |
the gnd is the first pin and the (+) is the last pin and there is no other gnd pins i tried every thing and even checked it with the multimeter and i found the pins but no use the box wont read it what about the vcc or vpp do i have to use it and how? |
hello! 3 unknown pins giving us just 6 possible combinations of tx/rx. connect box ground pin to phone GND point and try all 6 combinations of tx/rx. this can be done less than in 5min |
am despert i told that i tried every thing even i found two pins on the bord it looks like the correct tx/rx and it's writtin down besides every one of them the rj54tx/rj45rx and this way worked for alot of phones but it din'dt work for 10 devices n95 what should i do should i tell my customers that i can't handle it |
sweety i already told you that i tried every thing am not lazy but nothing worked thats the fact |
hey foxi , i have the same problem as you ! tested all pinouts but no succed . if you found some thing share it with me please . |
wher is the great support i used to know am dying here gyus |
Due to a lot of different models with the same name but absolutely different hardware, bottom connectors and different pinouts we recommend you to make detailed description of model, attach phone photo, phone bottom connector photo and information about Gnd and Charge pins on phone bottom connector. After you have this information prepared, please, check the next detailed description how to get pinout for your model: use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle.txt if not helps, please read: http:///vbb/showpo...36&postcount=7 if not helps, please read: http:///vbb/showthread.php?t=433447 |
phone bottom connector_1x12_mini ___________________________ / 1 2 3 4 5 6 7 8 9 10 11 12\ ----------------------------- phone pin 1 ground connect to box pin 7 or 8 phone pin 6 tx connect to box pin 3 rx phone pin 7 rx connect to box pin 2 tx tested by me working 100% |
