11-17-2020, 17:39 | #286 (permalink) | |
Member: 1043909 Status: Offline Thanks Meter: 60,861 | Quote:
order canceled, credits refunded. Please follow this instruction to get it done - https://forum.gsmhosting.com/vbb/f29...l#post14268996 | |
11-17-2020, 17:50 | #287 (permalink) |
No Life Poster Join Date: Jan 2014 Location: CUBA Age: 32
Member: 2108610 Status: Offline Thanks Meter: 379 | ZTE Blade A5 2019 Operation : SP Unlock [ v2.09 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : ZTE : ZTE_BLADE_A5_A7_[2019] Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0004 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : True FDL : Control transfered! Boot Done! Device info : Patch Level : PPR1.180610.011 Display ID : TEL_MX_ZTE_Blade_A5_2019V2.0 Ver. Incmt : 20190423.155234 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2019-04-01 Build Time : 23.04.2019 Product Model : ZTE Blade A5 2019 Product Brand : ZTE Product Name : ZTE_Blade_A5_2019 Product Device : P963F30 Product Manfct : ZTE Product Info : P963F30 Product Name : s9863a1h10_go_32b_Natv Product Device : s9863a1h10_go_32b Product Board : lucyzh Board Platform : sp9863a NVMng : SecurityInfo IMEI[1] : IMEI[2] : IMEI[3] : SEC : SLS:2, SKS:0, SKV:0 SLStatus : 0C Device not locked! Done! Elapsed: 00:00:45 |
The Following User Says Thank You to yosbel182us For This Useful Post: |
11-17-2020, 17:54 | #288 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
Make sure imei's inside same as on sticker, repair if need and make factory reset. If it after some tool or erased - bad luck at all. | |
11-17-2020, 18:07 | #289 (permalink) | |
Authentication error:05 authentication failed <== this means you entered wrong usernae or password | |
11-17-2020, 19:46 | #294 (permalink) |
Junior Member Join Date: Oct 2018 Location: Mozambique
Member: 2870921 Status: Offline Thanks Meter: 0 | Card found : 01CD03D3 , v0146 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.09 Load IDBase v8331 Ok! Operation : SP Unlock [ v2.09 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : ZTE : ZTE Blade L130 Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0004 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : True FDL : Control transfered! Boot Done! >>> Error : Device NOT INITIALIZED ! Initialize it first via "IDENTIFY" ! >>> Make sure you have made "IDENTIFY" first! Reconnect Power/Cable! Operation : Identify [ v2.09 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : ZTE : ZTE Blade L130 Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... >>> ERROR : FLASH FDL NOT started! >>> Error : Fail to boot FDL! >>> Unsupported device with selected fdl or settings! Change settings! Reconnect Power/Cable! |
11-17-2020, 20:13 | #297 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,861 | |
