SP7731E QMobile I8I 2019 8.1.0 Read Flash Don Operation : Read FW [ v2.01 ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Device info : Patch Level : OPM2.171019.012 Display ID : OPM2.171019.012 release-keys Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2019-02-05 Build Time : 1550555934 Product Model : QMobile i8i 2019 Product Info : i8i 2019 Product Brand : QMobile Product Name : i8i_2019 Product Device : i8i_2019 Product Model : i8i 2019 Product Model : I8I2019 Product Manfct : QMobile Product Board : i8i-2019 Board Platform : sp7731e VlnrLevel : 0x00 SP7731E__QMobile__I8I2019__8.1.0__OPM2.171019.012_ _i8i_2019 Read : prodnv.img ExtSparse : Compression ratio : 28% Read : miscdata.bin Read : recovery.img Read : tos.bin Read : sml.bin Read : u-boot.bin Read : boot_logo.bmp Read : fastboot_logo.bmp Read : nvitem_w.bin Make : persist.img Read : gnssmodem.bin Read : gnssbdmodem.bin Read : modem_wcn.img Read : modem_w.bin Read : deltanv_w.bin Read : gdsp_w.bin Read : pm_sys.bin Read : boot.img Read : system.img ExtSparse : Compression ratio : 91% Make : cache.img Read : vendor.img ExtSparse : Compression ratio : 48% Read : vbmeta.img Make : userdata.img Read : u-boot-spl.bin Android Info saved : _Android_info.txt Reconnect Power/Cable! download without password |
download link https://drive.google.com/file/d/14AF...ew?usp=sharing |
file write error reading ok write error Quote:
PMTMng : Load PMT PMTMng : 0x20 PMTMng : Update PMT Ok! FSIMG : prodnv.img CODE : recovery.img ERASE : MISC CODE : tos.bin Failed to update block! ERROR : 0000008E:00000000FF7F0000 INT : WAIT TIMEOUT! DEVICE PROBLEM or WRONG FDL! Error : Flashing failed! Check previous message for more info! Reconnect Power/Cable! Flashing finished! Reconnect Power/Cable! Done! Elapsed: 00:06:44 |
backup flashing not support at the moment '''''''''''' |
yes you are right ............... |
Hi sir, can be flashed now....... Operation : Flash Firmware [ v2.03 ] Setting : Update NVRAM : False Setting : Force NVRAM : False Setting : Update PMT : True 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... ProtoEx : Fail to enable Forced FlashWrite! FDL : Control transfered! Boot Done! PMTMng : Load PMT PMTMng : 0x20 PMTMng : Update PMT Ok! FSIMG : prodnv.img CODE : recovery.img ERASE : MISC CODE : tos.bin CODE : tos.bin CODE : sml.bin CODE : sml.bin UBOOT : u-boot.bin UBOOT : u-boot.bin ERASE : UBOOT_LOG CODE : boot_logo.bmp CODE : fastboot_logo.bmp ERASE : FLASH_W FSIMG : persist.img CODE : gnssmodem.bin CODE : gnssbdmodem.bin CODE : modem_wcn.img CODE : modem_w.bin CODE : deltanv_w.bin CODE : gdsp_w.bin CODE : pm_sys.bin CODE : boot.img FSIMG : system.img FSIMG : cache.img FSIMG : vendor.img CODE : vbmeta.img CODE : vbmeta.img FSIMG : userdata.img UBOOT : u-boot-spl.bin Flashing finished! Reconnect Power/Cable! Done! Elapsed: 00:05:11 Thanks Br, Raja |
SAME PROBLEM PMTMng : Load PMT PMTMng : 0x20 PMTMng : Update PMT Ok! FSIMG : prodnv.img CODE : recovery.img ERASE : MISC CODE : tos.bin Failed to update block! ERROR : 0000008E:00000000FF7F0000 INT : WAIT TIMEOUT! DEVICE PROBLEM or WRONG FDL! Error : Flashing failed! Check previous message for more info! Reconnect Power/Cable! Flashing finished! Reconnect Power/Cable! Done! |
Then select in Main/Platform tab 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS Then repeat flashing. What a result? |
cannot flash same error |
do u found any solution if yes plz informe thanks |
