10-16-2014, 13:00 | #2 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Hello, SPD6500,6530,6531 - supported. And other also. Check news and updates thread - there a lot of info , which help you find answers on all your questions. http://forum.gsmhosting.com/vbb/f296...3/index66.html |
10-16-2014, 13:09 | #3 (permalink) |
No Life Poster Join Date: May 2008 Location: saqi mobiles pirmahal pakistan Age: 37
Member: 780173 Status: Offline Sonork: 100.1594488 Thanks Meter: 912 | thanks to reply but i connect 6530a chip but its not connect with infinity box its say check your cable i use rx tx cable here is set info its connect with volcano Waiting for phone's response, press the Power on the phone. Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Spreadtrum Boot Block version 1.2 CPU TYPE:SC6530 [65300000] FLASH ID: 00C8006000170000 Flash Type:[GD] 25LG64bWL Size:0x1000000(16MB) |
10-16-2014, 13:22 | #4 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | You can use any box as com port. Or USB. But need use modified cable or bootkey. More info inside DOC's folder in CM2SPD installation folder. |
The Following User Says Thank You to Dzirt For This Useful Post: |
10-17-2014, 20:11 | #6 (permalink) | |
No Life Poster Join Date: Apr 2008 Location: India
Member: 1039903 Status: Offline Thanks Meter: 2,040 | Quote:
I have a dout. Do u have really infinity box or only abovementioned china box Bcz u had not post any CM2 logs but China box logs Post the error logs it will help us to help u I think u got the point as ur old | |
10-18-2014, 07:28 | #7 (permalink) | |
Member: 780173 Status: Offline Sonork: 100.1594488 Thanks Meter: 912 | Quote:
hi brother i know what i do i have infinty box i face a problem then i post i have for china many boxes and i dont think i tell you here is screen short | |
10-18-2014, 08:11 | #8 (permalink) | |
hi sir i connect the set with rx tx but not success its connect with usb ok Card found: S/N 7******** Chinese Miracle II [SPD module] v 1.00 Operation : Check/Read Info [ v1.00 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 24 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6530 , FDLStat : 0000 [0] Flash DIE : 00C8 0060 0017 0000 [0] Flash VEN : GigaDevice , GD25LQ64 [0] Flash CAP : 00800000 [1] Flash DIE : 00C8 0060 0017 0000 [1] Flash VEN : GigaDevice , GD25LQ64 [1] Flash CAP : 00800000 Done! Elapsed: 00:00:27 Reconnect Power/Cable! i read docs folder files i am not success to connect with rx tx | |
