IQA_SHAHEEN | 12-05-2018 20:33 | Quote:
Originally Posted by IQA_SHAHEEN
(Post 13449353)
I know yellowboss you are smarter than us but trust the words anyway here are logs Code:
========================= Start =========================
12/2/2018 / 8:07:04 PM
Card found: S/N : D17BA77C , v0137
Chinese Miracle II [SPD module] v 1.27
Set mode to : SP [SC773x] eMMC [Android 6.x]
Start at : [12/2/2018 / 8:10:25 PM]
Operation : Check/Read Info [ v1.27 ]
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
-> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key
3. Insert cable
==== Wait for phone...
Device boot not done
Check Drivers
Try again
Reconnect Power/Cable!
Finish at : [12/2/2018 / 8:11:04 PM]
Start at : [12/2/2018 / 8:11:09 PM]
3. Insert cable
Phone found! [ 3 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
Boot failed!
DS : Loader start failed! Wrong Model selection!
Boot failed!
Finish at : [12/2/2018 / 8:11:51 PM]
Set mode to : SP [SC773x] eMMC [Generic 4.x-5.0]
Start at : [12/2/2018 / 8:12:19 PM]
3. Insert cable
Check Drivers
Try again
Finish at : [12/2/2018 / 8:12:58 PM]
Start at : [12/2/2018 / 8:13:07 PM]
3. Insert cable
Check Drivers
Try again
Finish at : [12/2/2018 / 8:13:48 PM]
Start at : [12/2/2018 / 8:16:55 PM]
3. Insert cable
Check Drivers
Try again
Finish at : [12/2/2018 / 8:17:35 PM]
Start at : [12/2/2018 / 8:17:40 PM]
3. Insert cable
Check Drivers
Try again
Finish at : [12/2/2018 / 8:18:20 PM]
Start at : [12/2/2018 / 8:19:11 PM]
3. Insert cable
Phone found! [ 3 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Finish at : [12/2/2018 / 8:19:34 PM]
Set mode to : SP [SC773x] eMMC [Android 5.x]
Set mode to : [AltLDR] SP [SC773x] eMMC [Android 5.x]
Start at : [12/2/2018 / 8:20:11 PM]
3. Insert cable
Phone found! [ 3 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Finish at : [12/2/2018 / 8:20:47 PM]
Set mode to : [AltLDR] SP [SC773x] eMMC [Android 6.x]
Start at : [12/2/2018 / 8:26:23 PM]
3. Insert cable
Phone found! [ 3 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Finish at : [12/2/2018 / 8:27:17 PM]
Set mode to : [AltLDR] SP [SC983x] eMMC [Generic Android 6.x]
Start at : [12/2/2018 / 8:30:04 PM]
3. Insert cable
Check Drivers
Try again
Finish at : [12/2/2018 / 8:30:04 PM]
Start at : [12/2/2018 / 8:30:09 PM]
3. Insert cable
Check Drivers
Try again
Finish at : [12/2/2018 / 8:30:51 PM]
Start at : [12/2/2018 / 8:31:00 PM]
3. Insert cable
Phone found! [ 3 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Finish at : [12/2/2018 / 8:31:44 PM]
Set mode to : [AltLDR] SP [SC983x] eMMC [Generic Android 5.x]
Set mode to : SP [SC983x] eMMC [Generic Android 5.x]
Start at : [12/2/2018 / 8:32:22 PM]
3. Insert cable
Phone found! [ 3 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Finish at : [12/2/2018 / 8:33:35 PM]
Start at : [12/2/2018 / 8:33:56 PM]
3. Insert cable
Phone found! [ 3 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Finish at : [12/2/2018 / 8:34:50 PM]
Set mode to : [AltLDR] SP [SC9820] eMMC [Generic]
Start at : [12/2/2018 / 8:35:30 PM]
3. Insert cable
Phone found! [ 3 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Finish at : [12/2/2018 / 8:36:22 PM]
Set mode to : SP [SC983x] eMMC [Generic Android 7.x]
Start at : [12/2/2018 / 8:56:31 PM]
3. Insert cable
Phone found! [ 3 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Finish at : [12/2/2018 / 8:58:05 PM]
12/2/2018 / 9:01:20 PM
Set mode to : SP [SC983x] eMMC [Generic Android 6.x]
Start at : [12/2/2018 / 9:01:56 PM]
3. Insert cable
Phone found! [ 3 ]
Open Port Failed!
Finish at : [12/2/2018 / 9:02:13 PM]
Start at : [12/2/2018 / 9:02:19 PM]
3. Insert cable
Phone found! [ 3 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Finish at : [12/2/2018 / 9:03:33 PM]
Start at : [12/2/2018 / 9:09:07 PM]
3. Insert cable
Phone found! [ 3 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Finish at : [12/2/2018 / 9:10:59 PM]
Start at : [12/2/2018 / 9:11:22 PM]
Operation : Format File System / Reset Settings [ v1.27 ]
Settings : SmartFormat is On
2. Insert cable
3. In case of SVC init problems - connect with hold "VolDown" button!
Check Drivers
Try again
Finish at : [12/2/2018 / 9:12:00 PM]
Start at : [12/2/2018 / 9:12:05 PM]
2. Insert cable
Check Drivers
Try again
Finish at : [12/2/2018 / 9:12:43 PM]
Start at : [12/2/2018 / 9:12:48 PM]
2. Insert cable
Check Drivers
Try again
Finish at : [12/2/2018 / 9:13:26 PM]
Start at : [12/2/2018 / 9:24:10 PM]
2. Insert cable
Phone found! [ 3 ]
Port Opened
Sync...
Normal Mode init
Sync...
12/2/2018 / 9:28:27 PM
12/2/2018 / 9:38:26 PM
Start at : [12/2/2018 / 9:39:22 PM]
2. Insert cable
Phone found! [ 3 ]
Port Opened
Sync...
Normal Mode init
Sync...
12/2/2018 / 9:42:53 PM
Set mode to : SPD6530_SPD6500
Start at : [12/2/2018 / 9:46:23 PM]
3. Insert cable
Check Drivers
Try again
Finish at : [12/2/2018 / 9:47:02 PM]
Start at : [12/2/2018 / 9:47:11 PM]
3. Insert cable
Phone found! [ 3 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Finish at : [12/2/2018 / 9:49:10 PM]
Start at : [12/2/2018 / 9:51:09 PM]
3. Insert cable
Check Drivers
Try again
Finish at : [12/2/2018 / 9:51:50 PM]
Start at : [12/2/2018 / 9:52:19 PM]
3. Insert cable
Check Drivers
Try again
Finish at : [12/2/2018 / 9:53:00 PM]
Start at : [12/2/2018 / 9:53:58 PM]
3. Insert cable
Phone found! [ 3 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Finish at : [12/2/2018 / 9:55:27 PM]
Start at : [12/2/2018 / 9:56:00 PM]
3. Insert cable
Phone found! [ 3 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Finish at : [12/2/2018 / 9:58:15 PM]
Start at : [12/2/2018 / 9:58:42 PM]
3. Insert cable
Phone found! [ 3 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Finish at : [12/2/2018 / 10:00:35 PM]
Set mode to : [AltLDR] SP [SC983x] eMMC [Generic Android 7.x]
Start at : [12/2/2018 / 10:00:58 PM]
3. Insert cable
Phone found! [ 3 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Finish at : [12/2/2018 / 10:02:00 PM]
12/2/2018 / 10:06:12 PM
12/2/2018 / 11:36:16 PM
Start at : [12/2/2018 / 11:41:14 PM]
3. Insert cable
Phone found! [ 3 ]
Open Port Failed!
Finish at : [12/2/2018 / 11:41:25 PM]
Start at : [12/2/2018 / 11:41:29 PM]
3. Insert cable
Phone found! [ 3 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Finish at : [12/2/2018 / 11:43:08 PM]
Set mode to : SP [SC5735] eMMC [Generic]
Start at : [12/2/2018 / 11:43:42 PM]
3. Insert cable
Phone found! [ 3 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Finish at : [12/2/2018 / 11:45:47 PM]
Start at : [12/2/2018 / 11:46:09 PM]
2. Insert cable
Phone found! [ 3 ]
Port Opened
Sync...
Normal Mode init
Sync...
12/2/2018 / 11:59:29 PM
Set mode to : SP [SC983x] eMMC [Generic Android 5.x] Br
iqa_shaheen:eek: | Quote:
Originally Posted by Shani3
(Post 13449661)
Card found: S/N :
3. Insert cable
Phone found! [ 322 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
3. Insert cable
Check Drivers
Try again
3. Insert cable
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
3. Insert cable
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
3. Insert cable
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
3. Insert cable
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
3. Insert cable
Check Drivers
Try again
Set mode to : SP SC77xx [Model Select]
3. Insert cable
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Set mode to : [AltLDR] SP [SC5735] eMMC [Generic]
3. Insert cable
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Set mode to : SP [SC773x] eMMC [Android 6.x] | Quote:
Originally Posted by YellowBoss
(Post 13448290)
You Are smart but you have forgot to copy/paste software operation log text.
please mr IQA_SHAHEEN reply | Are You There Mr YellowBoss
Iqa_shaheen |
