Old 12-02-2018, 20:17   #1 (permalink)
IQA_SHAHEEN's Avatar
Member: 1453428
Sonork: 100.1596919
Thanks Meter: 146
Spd 9830a
SPD 9830A is there any support by cm2 to said processor i have ikon ik7108 tablet checked on all cpu settings of sc9830 but not connecting plz reply team specially jaYdi bro
Iqa_shaheen
The Following User Says Thank You to IQA_SHAHEEN For This Useful Post:
Old 12-03-2018, 03:16   #2 (permalink)
kamal_singla's Avatar
Member: 2211790
Thanks Meter: 5,118
Iqa_shaheen
Hi
Generic cpu should be supported
Select 98xx cpu from list and try
also can try with tick alternative ldr metnod
and if u have factory file just load in flash tab do service
In all case post logs must with brand/model number
The Following User Says Thank You to kamal_singla For This Useful Post:
Old 12-03-2018, 12:33   #3 (permalink)
Member: 1453428
Sonork: 100.1596919
Thanks Meter: 146
Originally Posted by kamal_singla View Post
Hi
You Are smart but i have already checked all settings but no results and if you have factory firmware of ikon ik-7108 plz share it here
please mr jaydi reply
Iqa_shaheen
Old 12-03-2018, 20:29   #4 (permalink)
Member: 1043909
Thanks Meter: 60,921
Iqa_shaheen
You Are smart but you have forgot to copy/paste software operation log text.
please mr IQA_SHAHEEN reply
The Following 2 Users Say Thank You to YellowBoss For This Useful Post:
Old 12-04-2018, 14:02   #5 (permalink)
Member: 1453428
Sonork: 100.1596919
Thanks Meter: 146
I know yellowboss you are smarter than us but trust the words anyway here are logs
========================= Start =========================
                 12/2/2018 / 8:07:04 PM
Card found: S/N : D17BA77C , v0137
Chinese Miracle II  [SPD module] v 1.27
Set mode to : SP [SC773x] eMMC [Android 6.x]
Start  at : [12/2/2018 / 8:10:25 PM]
Operation : Check/Read Info [ v1.27 ]
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
 -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key
3. Insert cable
 ====  Wait for phone...
Device boot not done
Check Drivers
Try again
Reconnect Power/Cable!
Finish at : [12/2/2018 / 8:11:04 PM]
Start  at : [12/2/2018 / 8:11:09 PM]
3. Insert cable
Phone found! [ 3 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
Boot failed!
DS : Loader start failed! Wrong Model selection!
Boot failed!
Finish at : [12/2/2018 / 8:11:51 PM]
Set mode to : SP [SC773x] eMMC [Generic 4.x-5.0]
Start  at : [12/2/2018 / 8:12:19 PM]
3. Insert cable
Check Drivers
Try again
Finish at : [12/2/2018 / 8:12:58 PM]
Start  at : [12/2/2018 / 8:13:07 PM]
3. Insert cable
Check Drivers
Try again
Finish at : [12/2/2018 / 8:13:48 PM]
Start  at : [12/2/2018 / 8:16:55 PM]
3. Insert cable
Check Drivers
Try again
Finish at : [12/2/2018 / 8:17:35 PM]
Start  at : [12/2/2018 / 8:17:40 PM]
3. Insert cable
Check Drivers
Try again
Finish at : [12/2/2018 / 8:18:20 PM]
Start  at : [12/2/2018 / 8:19:11 PM]
3. Insert cable
Phone found! [ 3 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Finish at : [12/2/2018 / 8:19:34 PM]
Set mode to : SP [SC773x] eMMC [Android 5.x]
Set mode to : [AltLDR] SP [SC773x] eMMC [Android 5.x]
Start  at : [12/2/2018 / 8:20:11 PM]
3. Insert cable
Phone found! [ 3 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Finish at : [12/2/2018 / 8:20:47 PM]
Set mode to : [AltLDR] SP [SC773x] eMMC [Android 6.x]
Start  at : [12/2/2018 / 8:26:23 PM]
3. Insert cable
Phone found! [ 3 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Finish at : [12/2/2018 / 8:27:17 PM]
Set mode to : [AltLDR] SP [SC983x] eMMC [Generic Android 6.x]
Start  at : [12/2/2018 / 8:30:04 PM]
3. Insert cable
Check Drivers
Try again
Finish at : [12/2/2018 / 8:30:04 PM]
Start  at : [12/2/2018 / 8:30:09 PM]
3. Insert cable
Check Drivers
Try again
Finish at : [12/2/2018 / 8:30:51 PM]
Start  at : [12/2/2018 / 8:31:00 PM]
3. Insert cable
Phone found! [ 3 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Finish at : [12/2/2018 / 8:31:44 PM]
Set mode to : [AltLDR] SP [SC983x] eMMC [Generic Android 5.x]
Set mode to : SP [SC983x] eMMC [Generic Android 5.x]
Start  at : [12/2/2018 / 8:32:22 PM]
3. Insert cable
Phone found! [ 3 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Finish at : [12/2/2018 / 8:33:35 PM]
Start  at : [12/2/2018 / 8:33:56 PM]
3. Insert cable
Phone found! [ 3 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Finish at : [12/2/2018 / 8:34:50 PM]
Set mode to : [AltLDR] SP [SC9820] eMMC [Generic]
Start  at : [12/2/2018 / 8:35:30 PM]
3. Insert cable
Phone found! [ 3 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Finish at : [12/2/2018 / 8:36:22 PM]
Set mode to : SP [SC983x] eMMC [Generic Android 7.x]
Start  at : [12/2/2018 / 8:56:31 PM]
3. Insert cable
Phone found! [ 3 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Finish at : [12/2/2018 / 8:58:05 PM]
                 12/2/2018 / 9:01:20 PM
Set mode to : SP [SC983x] eMMC [Generic Android 6.x]
Start  at : [12/2/2018 / 9:01:56 PM]
3. Insert cable
Phone found! [ 3 ]
Open Port Failed!
Finish at : [12/2/2018 / 9:02:13 PM]
Start  at : [12/2/2018 / 9:02:19 PM]
3. Insert cable
Phone found! [ 3 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Finish at : [12/2/2018 / 9:03:33 PM]
Start  at : [12/2/2018 / 9:09:07 PM]
3. Insert cable
Phone found! [ 3 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Finish at : [12/2/2018 / 9:10:59 PM]
Start  at : [12/2/2018 / 9:11:22 PM]
Operation : Format File System / Reset Settings [ v1.27 ]
Settings : SmartFormat is On
2. Insert cable
3. In case of SVC init problems - connect with hold "VolDown" button!
Check Drivers
Try again
Finish at : [12/2/2018 / 9:12:00 PM]
Start  at : [12/2/2018 / 9:12:05 PM]
2. Insert cable
Check Drivers
Try again
Finish at : [12/2/2018 / 9:12:43 PM]
Start  at : [12/2/2018 / 9:12:48 PM]
2. Insert cable
Check Drivers
Try again
Finish at : [12/2/2018 / 9:13:26 PM]
Start  at : [12/2/2018 / 9:24:10 PM]
2. Insert cable
Phone found! [ 3 ]
Port Opened
Sync...
Normal Mode init
Sync...
                 12/2/2018 / 9:28:27 PM
                 12/2/2018 / 9:38:26 PM
Start  at : [12/2/2018 / 9:39:22 PM]
2. Insert cable
Phone found! [ 3 ]
Port Opened
Sync...
Normal Mode init
Sync...
                 12/2/2018 / 9:42:53 PM
Set mode to : SPD6530_SPD6500
Start  at : [12/2/2018 / 9:46:23 PM]
3. Insert cable
Check Drivers
Try again
Finish at : [12/2/2018 / 9:47:02 PM]
Start  at : [12/2/2018 / 9:47:11 PM]
3. Insert cable
Phone found! [ 3 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Finish at : [12/2/2018 / 9:49:10 PM]
Start  at : [12/2/2018 / 9:51:09 PM]
3. Insert cable
Check Drivers
Try again
Finish at : [12/2/2018 / 9:51:50 PM]
Start  at : [12/2/2018 / 9:52:19 PM]
3. Insert cable
Check Drivers
Try again
Finish at : [12/2/2018 / 9:53:00 PM]
Start  at : [12/2/2018 / 9:53:58 PM]
3. Insert cable
Phone found! [ 3 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Finish at : [12/2/2018 / 9:55:27 PM]
Start  at : [12/2/2018 / 9:56:00 PM]
3. Insert cable
Phone found! [ 3 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Finish at : [12/2/2018 / 9:58:15 PM]
Start  at : [12/2/2018 / 9:58:42 PM]
3. Insert cable
Phone found! [ 3 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Finish at : [12/2/2018 / 10:00:35 PM]
Set mode to : [AltLDR] SP [SC983x] eMMC [Generic Android 7.x]
Start  at : [12/2/2018 / 10:00:58 PM]
3. Insert cable
Phone found! [ 3 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Finish at : [12/2/2018 / 10:02:00 PM]
                 12/2/2018 / 10:06:12 PM
                 12/2/2018 / 11:36:16 PM
Start  at : [12/2/2018 / 11:41:14 PM]
3. Insert cable
Phone found! [ 3 ]
Open Port Failed!
Finish at : [12/2/2018 / 11:41:25 PM]
Start  at : [12/2/2018 / 11:41:29 PM]
3. Insert cable
Phone found! [ 3 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Finish at : [12/2/2018 / 11:43:08 PM]
Set mode to : SP [SC5735] eMMC [Generic]
Start  at : [12/2/2018 / 11:43:42 PM]
3. Insert cable
Phone found! [ 3 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Finish at : [12/2/2018 / 11:45:47 PM]
Start  at : [12/2/2018 / 11:46:09 PM]
2. Insert cable
Phone found! [ 3 ]
Port Opened
Sync...
Normal Mode init
Sync...
                 12/2/2018 / 11:59:29 PM
iqa_shaheen
Old 12-04-2018, 15:51   #6 (permalink)
Shani3's Avatar
Member: 1582572
Sonork: 100.1609641
Thanks Meter: 573
Card found: S/N :
3. Insert cable
Phone found! [ 322 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
3. Insert cable
Check Drivers
Try again
3. Insert cable
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
3. Insert cable
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
3. Insert cable
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
3. Insert cable
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
3. Insert cable
Check Drivers
Try again
Set mode to : SP SC77xx [Model Select]
3. Insert cable
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Set mode to : [AltLDR] SP [SC5735] eMMC [Generic]
3. Insert cable
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Old 12-05-2018, 20:33   #7 (permalink)
Member: 1453428
Sonork: 100.1596919
Thanks Meter: 146
3. Insert cable
Check Drivers
Try again
3. Insert cable
Phone found! [ 3 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
3. Insert cable
Check Drivers
Try again
3. Insert cable
Check Drivers
Try again
3. Insert cable
Check Drivers
Try again
3. Insert cable
Check Drivers
Try again
3. Insert cable
Phone found! [ 3 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
3. Insert cable
Phone found! [ 3 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
3. Insert cable
Phone found! [ 3 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
3. Insert cable
Check Drivers
Try again
3. Insert cable
Check Drivers
Try again
3. Insert cable
Phone found! [ 3 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
3. Insert cable
Phone found! [ 3 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
3. Insert cable
Phone found! [ 3 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
3. Insert cable
Phone found! [ 3 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
3. Insert cable
Phone found! [ 3 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
3. Insert cable
Phone found! [ 3 ]
Open Port Failed!
3. Insert cable
Phone found! [ 3 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
3. Insert cable
Phone found! [ 3 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
2. Insert cable
Check Drivers
Try again
2. Insert cable
Check Drivers
Try again
2. Insert cable
Check Drivers
Try again
2. Insert cable
Phone found! [ 3 ]
Port Opened
Sync...
Normal Mode init
Sync...
2. Insert cable
Phone found! [ 3 ]
Port Opened
Sync...
Normal Mode init
Sync...
3. Insert cable
Check Drivers
Try again
3. Insert cable
Phone found! [ 3 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
3. Insert cable
Check Drivers
Try again
3. Insert cable
Check Drivers
Try again
3. Insert cable
Phone found! [ 3 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
3. Insert cable
Phone found! [ 3 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
3. Insert cable
Phone found! [ 3 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
3. Insert cable
Phone found! [ 3 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
3. Insert cable
Phone found! [ 3 ]
Open Port Failed!
3. Insert cable
Phone found! [ 3 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
3. Insert cable
Phone found! [ 3 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
2. Insert cable
Phone found! [ 3 ]
Port Opened
Sync...
Normal Mode init
Sync...
iqa_shaheen
Originally Posted by Shani3 View Post
Card found: S/N :
3. Insert cable
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
3. Insert cable
Check Drivers
Try again
3. Insert cable
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
3. Insert cable
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
3. Insert cable
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
3. Insert cable
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
3. Insert cable
Check Drivers
Try again
3. Insert cable
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
3. Insert cable
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Are You There Mr YellowBoss
Iqa_shaheen
Old 12-07-2018, 13:53   #8 (permalink)
Member: 1453428
Sonork: 100.1596919
Thanks Meter: 146
please reply Mr Jaydi & YellowBoss
Iqa_shaheen
Old 12-08-2018, 12:59   #9 (permalink)
Member: 1453428
Sonork: 100.1596919
Thanks Meter: 146
Is there any one in infinity how can reply me
br
iqa_shaheen
Old 12-08-2018, 16:00   #10 (permalink)
Member: 1453428
Sonork: 100.1596919
Thanks Meter: 146
Originally Posted by jonny12345 View Post
mr shaheen sc9830a not supported by cm2 the only way to operate use miracle box the one and only best box in the world...therfore sorry mr yellowboss for appreciation of other box.....
May Be Mr Jonny12345 you are right thats why Mr YellowBoss is scared to answer my question
br
iqa_shaheen
Old 12-08-2018, 16:57   #11 (permalink)
Member: 2211790
Thanks Meter: 5,118
Hi
Seems this is 9830 with sign based and atm not supported with cm2
Old 12-08-2018, 16:58   #12 (permalink)
Member: 2211790
Thanks Meter: 5,118
Better you promote your loved tool somewhere else not here
Old 12-09-2018, 14:00   #13 (permalink)
Member: 1453428
Sonork: 100.1596919
Thanks Meter: 146
i am not promoting any other tool i am asking a question with simple words i am a user of infinity from 2009 and not using other tools i am requesting our coders to develop the solutions for latest phones in market as other team developed already as they are not smarter than our coders
br
iqa_shaheen
Old 06-12-2019, 19:39   #14 (permalink)
Member: 1453428
Sonork: 100.1596919
Thanks Meter: 146
my mistake its sc9832a plz give any solution for this
regards
iqa_shaheen
Old 10-18-2020, 10:48   #15 (permalink)
Member: 601566
Sonork: 100.1637134
Thanks Meter: 551
Card found : 8B6E7F7D , v0145
Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.06
Load IDBase v8331 Ok!
Operation : Identify [ v2.06 ]
BootMode : FLASH
1. Power off device, wait 10-15 seconds
2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- )
3. Insert cable in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : 0_SC9832E_BASE : SC9832E_eMMC_1GB_SS
Sending Init Boot ...
Boot sent!
Kick FDL ...
ERROR : FDL NOT started!
Error : Fail to boot FDL!
Unsupported device with selected fdl or settings! Change settings!
BootMode : FLASH
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : 0_SC983x_BASE : SC9832A_eMMC_1GB_NS
Boot sent!
Kick FDL ...
Page generated in 0.37843 seconds with 8 queries
