11-23-2015, 10:03 | #1 (permalink) |
No Life Poster Join Date: Sep 2006 Location: ---> Hope
Member: 355782 Status: Offline Thanks Meter: 1,265 | SPD firmware Read/Write Manual [1.06 or later] Requirements : 1. WinXP , Win7, Win8x or Win10 OS 2. Installed ADB drivers ( can be used ANY package , from support, or already installed on PC from any brand ) 3. Charged to 50% or more battery 4. Normal USB cable , without BootMode ( short pin ) , without HUB and etc. Read firmware : Open CM2SPD ( version 1.06 or newer ) Select Need CPU in settings Go to “Flash” Tab Press “Read Firmware *PAC+” button If you select correct settings and follow requirements part, you will see “Save” conformation dialog. Select path, where you want to save firmware After path selection – SW will ask about wait, until phone boot. Now is required : Wait until phone fully power on Go to Settings – About -> tap 5-8 times on “Build Number” , until message about success “Developer mode” is appear ( if Developer Mode already enabled in settings – skip that step ) Go to Settings – Developer Options. Enable USB Debug. Install ADB drivers, if need. You can install ANY adb driver on Android Debug Bridge device in “Device Manager”. It will work with ANY ADB driver. After drivers installed – re-insert USB cable. In some cases it required. Press OK only, after you done ALL steps! After success connect to device – program will ask about allow debug (Secure ADB) – press on Phone/Tablet “Allow/OK” button , then press “Ok” button in SPD module conformation window. After success connection SPD module will ask to hold BOTH volume keys and press Ok after. Hold keys until phone will start booting. In case of problem with reboot – fast re-insert battery, while holding volume keys ( or press “Reset” button, if it tablet ) After just wait, until reading will be finished. It takes from 35 up to 70 minutes, depending on PC configuration and Phone/Tablet HW. After read will be finished – Phone/Tablet will reboot. Firmware read finished! Flash Firmware : There is NO any special requirements, except select in filter “CM2FlashFiles : PAC SC” file type, on “PAC” selection button. After just press “Flash” button and connect phone. Wait , until flashing will be finished. Note: Manual also inside of software pack. This post is for those who always ignore the manual and burst with posts. wBw, Nasir Javed |
The Following 8 Users Say Thank You to Nasir Mobiles For This Useful Post: |
11-23-2015, 10:12 | #3 (permalink) | |
Member: 355782 Status: Offline Thanks Meter: 1,265 | Quote:
you need another prepared firmware or working phone for reading FW. | |
The Following User Says Thank You to Nasir Mobiles For This Useful Post: |
11-23-2015, 11:26 | #4 (permalink) | ||
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
Need working phone to make working FW. There is no reason read FW from faulty phone. It possible, but have NO reason at all. It not MTK phones, they completely different from them and have own vision to much things. | ||
The Following 4 Users Say Thank You to JayDi For This Useful Post: |
11-24-2015, 13:54 | #11 (permalink) | |||
No Life Poster Join Date: Feb 2011 Location: ( United States Of Islam ) Age: 35
Member: 1519396 Status: Offline Sonork: 100.1612702 Thanks Meter: 1,951 | Quote:
Nasir brother you mean phone with on or usb debugging mode or usb mod phone with off mod ?? | |||
