03-16-2008, 07:14 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Georgia GE
Member: 162473 Status: Offline Sonork: Not have Thanks Meter: 592 | SPD: Spreadtrum test report software version: 1.06 cable type: 1x18 (L18A) platform: SPD: Spreadtrum searching adapter at COM6... adapter found, version: 2000 pins: 18, plainsoftware version: 1.06 cable type: 1x18 (L18A) platform: SPD: Spreadtrum searching adapter at COM6... adapter found, version: 2000 pins: 18, plain power cycles: 1 activation cycles: 10 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now (not required but recommended) ! detecting pins... Rx:12 result: Rx:12 Tx:13 time required: 55 sec Power On ! COM6 [VCP0] selected Device: SC6600M NAND Checking data, wait... advanced flash detection enabled Action: read flash Boot... Press and HOLD Power button now ! waiting for ignition... initial answer received waiting for boot answer... magic: STBP size: 20(bytes) total size: 120(bytes) time stamp: 0x4124a158 current os: 0 num of os: 1 os info size: 100(bytes) os offset: 20(bytes) OS infomation: name: description: version: offset: 32(sectors) size: 4522(sectors) waiting for boot code... Ok Connecting, wait... waiting for boot code... Failed error: can't run preloader Boot Fail Finished, time used: 8 sec Remove/Install battery now ! |
03-17-2008, 13:23 | #4 (permalink) | |
No Life Poster Join Date: Oct 2005 Location: ALGERIA™ Age: 45
Member: 192681 Status: Offline Sonork: 100.106870 Thanks Meter: 5,082 | Quote:
ZT V100 key up connector 18 pin 1|------------------|18 GND :6/7/9/14/18 Rx : 12 Tx : 13 ---------------------- COM4 [VCP0] selected Device: SC6600M NAND Checking data, wait... advanced flash detection enabled Action: read eeprom Boot... Press and HOLD Power button now ! waiting for ignition... initial answer received waiting for boot answer... magic: STBP size: 20(bytes) total size: 120(bytes) time stamp: 0x41418a1c current os: 0 num of os: 1 os info size: 100(bytes) os offset: 20(bytes) OS infomation: name: description: version: offset: 32(sectors) size: 4522(sectors) waiting for boot code... Ok Connecting, wait... waiting for boot code... Failed error: can't run preloader Boot Fail Finished, time used: 28 sec Remove/Install battery now ! tested with low & high speed read eeprom / full flash >> same error. | |
03-17-2008, 14:12 | #5 (permalink) |
No Life Poster Join Date: Jul 2005 Location: France Age: 48
Member: 165812 Status: Offline Sonork: 100:1627635 Thanks Meter: 4,267 | i got the same here COM3 selected Device: SC6600M NAND Checking data, wait... advanced flash detection enabled Action: read flash Boot... Press and HOLD Power button now ! waiting for ignition... initial answer received waiting for boot answer... magic: STBP size: 20(bytes) total size: 120(bytes) time stamp: 0x4785fdea current os: 0 num of os: 1 os info size: 100(bytes) os offset: 20(bytes) OS infomation: name: description: version: offset: 32(sectors) size: 4522(sectors) waiting for boot code... Ok Connecting, wait... waiting for boot code... Failed error: can't run preloader Boot Fail Finished, time used: 7 sec Remove/Install battery now ! |
03-17-2008, 14:18 | #6 (permalink) | |
Member: 162473 Status: Offline Sonork: Not have Thanks Meter: 592 | Quote:
and TX RX GND | |
03-17-2008, 14:19 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @allal123 Thanks a lot ! As I can see on picture CPU name is SC6600R. Please, double check it (if you still have phone on hands). @tsarkh Could you, please, open phone (if possible) and tell me CPU and Flash chip names (or make a PCB photo). Thank you ! |
03-17-2008, 14:44 | #9 (permalink) | |
Member: 192681 Status: Offline Sonork: 100.106870 Thanks Meter: 5,082 | [QUOTE] Quote:
LATEST V100 TV/FM/BLUETOOTH/MP-3 PLAYER HANDSET WITH VENDOR WARRANTY cect zt v100 link cect zt v100 link | |
Infinity Box Pin-finder adapter test report | ezzis | Infinity-Box | 790 | 07-04-2015 22:03 |
<< Blue 354x Test Report with Infinity >> | zeel_zeel | Infinity-Box | 6 | 06-01-2010 13:06 |
Bug reports, Test Reports, Suggestions and Comments all welcome here | NFF Box Team | Nokia Fault Finder Box | 40 | 09-05-2008 14:20 |
ET-BOX_1_59.zip with kg110 test report | TURNING POINT | ET-BoX | 1 | 02-18-2008 21:18 |
Nsdongle v3.8.0 test reports | Elco | NSPRO | 23 | 11-01-2005 18:03 |
