04-02-2009, 09:52 | #1 (permalink) |
No Life Poster Join Date: Apr 2005 Location: Life Of Paradise
Member: 140477 Status: Offline Sonork: 100.1658502 Thanks Meter: 426 | Spice s-410 cant unlock module v2.69 Device: Spice-S410 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6205:8B00]... CPU: MT6205 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 detection finished identification#1 protocol ver: 04 ver. sw 1: STANDARD_PCB01_GSM_MT6205B_DN.KACS410_ATL_EN_HI_4_ 02_518.BIN ver. sw 2: KACS410_ATL_EN_HI_4.02_518, 00000000 ffs offset/size: 00380000/00080000 detect device identification#2... detection phase #1... . detect device identification#2 finished sim-lock status: unknown Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: eeprom[STANDARD_PCB01_GSM_MT6205B_DN.KACS410_ATL_EN_HI_4_ 02_518.BIN]... file saved: C:\Program Files\InfinityBox\MModule\eeprom[STANDARD_PCB01_GSM_MT6205B_DN.KACS410_ATL_EN_HI_4_ 02_518.BIN]_20090402-135507.B0E.bin flash: 01227E221A2201:18E59F00000000 Backup required data Done Patch required data ... detection procedure, wait... detection procedure completed Patch required data Done Special operation ... detecting additional parameters... ................ error: additional parameters detection failed Special operation Done Write ... flash: 01227E221A2201:18E59F00000000 Write: eeprom Write Done Finalization ... Finalization Done Finished, time used: 53 sec Remove/Install battery now ! CANT UNLOCK |
The Following User Says Thank You to Tajammul For This Useful Post: |
04-02-2009, 10:08 | #2 (permalink) |
Member: 140477 Status: Offline Sonork: 100.1658502 Thanks Meter: 426 | spice s410 unlock succfully i flash phone with file do ffs format set Spice-S410_STANDARD_PCB01_GSM_MT6205B_DN[1].KACS410_INA_EN_HI_4_02_330_En_Hindi.B0M in infinity support |
04-02-2009, 11:21 | #4 (permalink) |
No Life Poster Join Date: Oct 2007 Location: india
Member: 618404 Status: Offline Thanks Meter: 311 | How to unlock Spice-S410: 1. make "smart safe" unlock 2. if phone is still locked: make "standard" unlock 3. if phone is still locked: 3.1. flash phone with Spice-S410_STANDARD_PCB01_GSM_MT6205B_DN.KACS410_INA_EN_ HI_4_02_330_En_Hindi 3.2. make "format ffs" 3.3. restore original imei wbr. rajesh ch. |
The Following 2 Users Say Thank You to rajesh_ch For This Useful Post: |
06-22-2009, 01:47 | #6 (permalink) | |
Insane Poster Join Date: Apr 2009
Member: 1006867 Status: Offline Sonork: mahto Thanks Meter: 10 | Quote:
06-22-2009, 20:49 | #7 (permalink) | |
If phone can not be detected by software this mean that you have a problems with cable, so you need to double check your cable, probably you need to swap rx/tx wires. | |
12-14-2010, 14:18 | #8 (permalink) | |
No Life Poster Join Date: Oct 2007 Location: chennai Age: 38
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | Quote:
1.first you do make format (ffs:complete mode) must be select before click format 2. restore that orginal imei (take from back case) That’s solved | |
cant unloak spice s 410 | madeena | Infinity-Box | 35 | 04-02-2009 12:19 |
Spice S-410 unlock : Success | zeel_zeel | Infinity-Box | 0 | 11-24-2007 11:27 |
spice s-410 how to unlock ?? | kalpeshoza | Multi-box LITE | 3 | 10-04-2007 15:19 |
cant unlock spice s-410 | rathore_telecom | Infinity-Box | 0 | 07-03-2007 13:41 |
Spice S 410 How to unlock | amit agrawal | Infinity-Box | 2 | 06-15-2007 15:43 |
