01-21-2010, 22:31 | #2 (permalink) | |
Try to make "format ffs" in "complete" mode. Also, what was with phone when you have got it ? It may be that phone has damaged hardware but not a software problem. | |
01-29-2010, 16:16 | #5 (permalink) |
Freak Poster Join Date: Jun 2008 Age: 36
Member: 794428 Status: Offline Thanks Meter: 80 | COM21 [VCP7] selected module v3.03 Device: Spice-S590 Checking data, wait... advanced flash detection enabled Action: write flash write: Firmware 3506FM_INA_PCB01_GPRS_MT6223P_S00.KAA3506FM_INA_EN _HI_0_95_112_16m_En_Hi.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs enhanced security fix enabled ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:B4D1:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.81FF9 2D0.[3506FM_INA_PCB01_GPRS_MT6223P_S00.KAA3506FM_INA_EN _HI_0_95_112.BIN_DC950DCA].rpl rom info detection finished device-id: 81FF92D0 rom info ver: 04 sw version: 3506FM_INA_PCB01_GPRS_MT6223P_S00.KAA3506FM_INA_EN _HI_0_95_112.BIN project-id: KAA3506FM_INA_EN_HI_0.95.112, CA0D95DC code offset: 00000000 ffs offset/size [01]: 00B00000/00500000 rom info structure: 2nd [enhanced] generation TCL-ID is absent ffs/eeprom address assigned: 00B00000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed file saved: C:\Program Files\InfinityBox\MModule\backup_security\Spice-S590_3506FM_INA_PCB01_GPRS_MT6223P_S00.KAA3506FM_I NA_EN_HI_0_95_112__system_log_81FF92D0_DC950DCA_20 100129-210504.B0X.bin Area: Firmware flash: EC257E25082501:29EA0000000000 Write: Firmware sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Spice-S590_3506FM_INA_PCB01_GPRS_MT6223P_S00.KAA3506FM_I NA_EN_HI_0_95_112__system_log_81FF92D0_DC950DCA_20 100129-211220.B0X.bin Finished, time used: 7 min 48 sec Remove/Install battery now ! |
01-29-2010, 16:20 | #6 (permalink) |
Member: 794428 Status: Offline Thanks Meter: 80 | COM21 [VCP7] selected module v3.03 Device: Spice-S590 Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") Do you want to make ffs/eeprom backup before format ? enhanced security fix enabled ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:B4D1:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.81FF9 2D0.[3506FM_INA_PCB01_GPRS_MT6223P_S00.KAA3506FM_INA_EN _HI_0_95_112.BIN_DC950DCA].rpl rom info detection finished device-id: 81FF92D0 rom info ver: 04 sw version: 3506FM_INA_PCB01_GPRS_MT6223P_S00.KAA3506FM_INA_EN _HI_0_95_112.BIN project-id: KAA3506FM_INA_EN_HI_0.95.112, CA0D95DC code offset: 00000000 ffs offset/size [01]: 00B00000/00500000 rom info structure: 2nd [enhanced] generation TCL-ID is absent ffs/eeprom address assigned: 00B00000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: EC257E25082501:29EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: EC257E25082501:29EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Spice-S590_3506FM_INA_PCB01_GPRS_MT6223P_S00.KAA3506FM_I NA_EN_HI_0_95_112__system_log_81FF92D0_DC950DCA_20 100129-211833.B0X.bin Finished, time used: 1 min 7 sec Remove/Install battery now ! PHONE ONLE WELCOME LOGO freez |
08-19-2010, 06:51 | #8 (permalink) |
No Life Poster Join Date: May 2005 Location: India Age: 37
Member: 145082 Status: Offline Thanks Meter: 798 | same problem with me the phone went dead after flashing i have flashed both the flash files in the support area... and have written the eeprom but no help.... what could be done i have recieved the phone on from customer the problem was the phone says user busy when recieving an incoming call |
08-19-2010, 07:08 | #9 (permalink) |
Member: 145082 Status: Offline Thanks Meter: 798 | COM6 [VCP0] selected module v3.52 Device: Spice-S590 Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") Do you want to make ffs/eeprom backup before format ? ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:B0D9:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22212201:29EA0000000000 flash: Amd AMD/Fujitsu std [def 0080x020000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... slowest Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [protected] type, 1 record(s) TCL-ID is absent startup code area #1 record #1 is damaged, recalculation required rom info detection finished device-id: A17FD270 rom info ver: 04 sw version: 3506FM_INA_PCB01_GPRS_MT6223P_S00.KAA3506FM_INA_EN _HI_0_95_112.BIN project-id: KAA3506FM_INA_EN_HI_0.95.112, CA0D95DC code offset: 00000000 ffs offset/size [01]: 00B00000/00500000 rom info structure: 2nd [protected] type, 1 record(s) TCL-ID is absent ffs/eeprom address assigned: 00B00000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: Spice-S590_3506FM_INA_PCB01_GPRS_MT6223P_S00.KAA3506FM_I NA_EN_HI_0_95_112__ffs... file saved: C:\Program Files\InfinityBox\MModule\Spice-S590_3506FM_INA_PCB01_GPRS_MT6223P_S00.KAA3506FM_I NA_EN_HI_0_95_112__ffs_20100819-112705.B0E.bin flash: 01227E22212201:29EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 01227E22212201:29EA0000000000 Finalization Done Finished, time used: 17 min 17 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
08-20-2010, 14:39 | #13 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | For sure it's an Infinity-Box: www.infinity-box.com |
spice s590 no incoming ...done | neetika99 | Infinity-Box | 9 | 10-11-2014 04:04 |
spice s590 user lock rest successfully | sabby_singh | Infinity-Box | 15 | 08-05-2011 20:40 |
spice s590 set dead | yahoo.mobiles | Infinity-Box | 1 | 01-06-2010 19:16 |
spice s640 flashing time this error come | arunamobile | Multi-Box | 4 | 08-07-2007 14:51 |
