11-07-2011, 17:30 | #1 (permalink) |
No Life Poster Join Date: Dec 2007 Location: Uttar Pradesh India
Member: 656277 Status: Offline Thanks Meter: 187 | spice s600 dead by infinity plz help m |
11-08-2011, 07:12 | #5 (permalink) | |
Member: 656277 Status: Offline Thanks Meter: 187 | Quote:
firstly formate set here is log COM9 [VCP0] selected module v4.02 Device: Spice-S600 Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6217:8A00]... CPU: MT6217 high speed boot On boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98001B00000009:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < ffs/eeprom address can not be detected, value from database assigned: 00880000/00780000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: Spice-S600__ffs... file saved: C:\InfinityBox\MModule\Spice-S600__ffs_20111107-153346.B0E.bin flash: 98001B00000009:29EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98001B00000009:18654D00000000 Finalization Done Finished, time used: 16 min 0 sec Remove/Install battery now ! after download flash file then flash the set here is log COM9 [VCP0] selected module v4.02 Device: Spice-S600 Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware Spice-S600_P50017.05161210F.E1_G16_HW_Oct2004_17ST_Nov-15-2006_En.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6217:8A00]... CPU: MT6217 high speed boot On boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98001B00000009:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < ffs/eeprom address can not be detected, value from database assigned: 00880000/00780000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: Spice-S600__ffs... file saved: C:\InfinityBox\MModule\Spice-S600__ffs_20111107-154949.B0E.bin Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Area: Firmware flash: 98001B00000009:29EA0000000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done Finished, time used: 28 min 33 sec Remove/Install battery now ! plz guide m | |
11-08-2011, 10:37 | #6 (permalink) |
Member: 656277 Status: Offline Thanks Meter: 187 | firstly formate set here is log COM9 [VCP0] selected module v4.02 Device: Spice-S600 Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6217:8A00]... CPU: MT6217 high speed boot On boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98001B00000009:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < ffs/eeprom address can not be detected, value from database assigned: 00880000/00780000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: Spice-S600__ffs... file saved: C:\InfinityBox\MModule\Spice-S600__ffs_20111107-153346.B0E.bin flash: 98001B00000009:29EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98001B00000009:18654D00000000 Finalization Done Finished, time used: 16 min 0 sec Remove/Install battery now ! after download flash file then flash the set here is log COM9 [VCP0] selected module v4.02 Device: Spice-S600 Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware Spice-S600_P50017.05161210F.E1_G16_HW_Oct2004_17ST_Nov-15-2006_En.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6217:8A00]... CPU: MT6217 high speed boot On boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98001B00000009:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < ffs/eeprom address can not be detected, value from database assigned: 00880000/00780000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: Spice-S600__ffs... file saved: C:\InfinityBox\MModule\Spice-S600__ffs_20111107-154949.B0E.bin Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Area: Firmware flash: 98001B00000009:29EA0000000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done Finished, time used: 28 min 33 sec Remove/Install battery now ! plz guide m |
11-08-2011, 17:09 | #8 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | For sure you have made wrong thread name. Phone was dead not by Infinity-Box but phone was dead by you. Your first and main fault: you did not made full flash backup before flash/format operation. Now tell me, what is exact text from phone back label ? What is exact phone model name ? |
11-08-2011, 18:03 | #10 (permalink) | |
set is Spice s600 S/N Go5A61100AABJ01 any solution ???? | |
11-08-2011, 18:15 | #11 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | 1. charge battery with external power supply !!! 2. flash phone with Spice-S600_P50017.05161210D.E1_G16_HW_Oct2004_15ST_May-29-2006_En.B0M.bin Spice-S600_repair_eeprom_01.B0E.bin 3. if no luck, flash with Spice-S600_P50017.05161210F.E1_G16_HW_Oct2004_17ST_Nov-15-2006_En.B0M.bin Spice-S600_repair_eeprom_01.B0E.bin 4. if no luck, flash with Spice-S600N_G72_HW_Oct2004_P50017.05161210H.S1_01ST_Aug-3-2007_En.B0M.bin Spice-S600N_eeprom_01.B0E.bin 5. if no luck, flash with Spice-S600N_G72_HW_Oct2004_P50017.05161210H.S1_05ST_Jan-7-2008_En.B0M.bin Spice-S600N_eeprom_01.B0E.bin |
11-09-2011, 03:21 | #12 (permalink) | |
but bro. wher i find these 2 flash file because only 2 flash file avalable in support area Spice-S600N_G72_HW_Oct2004_P50017.05161210H.S1_01ST_Aug-3-2007_En.B0M.bin Spice-S600N_G72_HW_Oct2004_P50017.05161210H.S1_05ST_Jan-7-2008_En.B0M.bin plz help m | |
I have 5.28 unlocker by cable. | GreEn | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 15 | 07-13-2000 21:57 |
5.28 working solution by eeprom 24x16 | SLO/EU | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 06-22-2000 15:55 |
nokia nse-spv8 by zulea | rothmanns | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-12-2000 07:52 |
have nokia lock 2 solution by cable | oskarcore | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-29-1999 22:49 |
