03-06-2009, 06:15 | #1 (permalink) |
No Life Poster Join Date: Sep 2007 Location: india
Member: 588837 Status: Offline Thanks Meter: 146 | k220i...inactive sim....fixed action taken=formatt ffs all ok done...working perfect.here r logs COM1 [VCP0] selected module v1.30 Device: Sony-Ericsson-K220i "advanced chip detection" active Action: reset settings Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! loading... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 01227E22212200:92EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb software version: R1AA008 software version: CXC1250818 version flex: CDA102807/30 imei: ############## Check hardware done Read data ... reading Sony-Ericsson-K220i_##############_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-K220i_35619701102754_eeprom_calibration-1_20090306-103006.80E.bin reading Sony-Ericsson-K220i_##############_eeprom_calibration-2... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-K220i_##############_eeprom_calibration-2_20090306-103015.80E.bin Read data done Check data ... Check data done Write ... flash: 01227E22212200:46237300000000 Erase: ffs Write done Finished, time used: 48 sec Remove/Install battery now ! |
The Following User Says Thank You to neetika99 For This Useful Post: |
03-06-2009, 16:34 | #2 (permalink) | |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Quote:
Each test report with attached logs is very important for us so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type) and what is possible problems (so we will be able to fix it) and successfully done work. | |
03-20-2009, 15:09 | #3 (permalink) |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 44
Member: 265133 Status: Offline Thanks Meter: 286 | thanks neetika99 and infinity team today i resolved the k220i INACTIVE SIM heres is the log COM7 [VCP0] selected Device: Sony-Ericsson K220i "advanced chip detection" active Action: reset Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! loading... Boot done Check connection... Check connection done Set baud... 115200 Set baud done Check hardware... flash: 01227E22212200:92EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb version sw: R1AA008 version sw: CXC1250818 version flex: CDA102807/30 imei: *************** Check hardware done Read data... reading Sony-Ericsson K220i_**************_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\backup_Sony-Ericsson K220i_35619701128602_eeprom_calibration-1_20090320-192524.80E.bin reading Sony-Ericsson K220i_**************_eeprom_calibration-2... file saved: C:\Program Files\InfinityBox\HModule\backup_Sony-Ericsson K220i_35619701128602_eeprom_calibration-2_20090320-192536.80E.bin reading Sony-Ericsson K220i_3***********_ffs... file saved: C:\Program Files\InfinityBox\HModule\backup_Sony-Ericsson K220i_************_ffs_20090320-193141.80E.bin Read data done Check data... Check data done Writing... flash: 01227E22212200:46237300000000 Erase: ffs Writing done Finished, time used: 450 sec Remove/Install battery now ! |
The Following User Says Thank You to murthyy For This Useful Post: |
SE K220i turning off fixed by EEPROM repair! | kiwiboi | Infinity-Box | 2 | 02-07-2013 02:13 |
inactive sim an all sim cards after unlock | gonads | Seking Server | 3 | 10-17-2008 21:15 |
k220i inactive sim help urgent!!!! | Miftah_Lutfi | Sony Ericsson | 3 | 01-19-2008 20:04 |
K700i inactive sim | xloaderen | Cruiser Suite | 7 | 10-03-2005 12:13 |
S700 inactive sim | mcsqd1 | Sony Ericsson | 1 | 08-23-2005 10:20 |
