spice s600 show enter phone lock code when press sp unlock button message show Press and HOLD Power button now after press power button set on and not boot plese help |
wbr. rajesh ch |
which sp unlocking settin you use can tell us stan1comm |
If phone can not be detected by software it's 99.9% cable or port selection problem. Double check your cable, probably you need to swap Rx <-> tx wires. Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell: http://www.infinity-box.com/download...shell_v126.jpg Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 |
u will also find rx tx marked on pcb of spice s600 try to solder wires directly then try flashing i flashed many phones by soldering the wires directly to the pcb pinout post reply |
