11-30-2008, 11:11 | #1 (permalink) |
Cheater -Don't Deal with him- Join Date: Nov 2007 Location: In the web Age: 37
Member: 622382 Status: Offline Thanks Meter: 201 | sprint 7700 set pinout need |
The Following 2 Users Say Thank You to shaheb_anl For This Useful Post: |
11-30-2008, 15:17 | #6 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Bangladesh
Member: 621121 Status: Offline Thanks Meter: 366 | here log of sprint 7700 COM10 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read NOR flash Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:5103:0001 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 460800 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.30707DAF.[AHONG25_06B_PCB01_GPRS_MT6225_S00.A11+_V07_12_52_H 24.BIN_DF8E786C].rpl ==================== New firmware detected: AHONG25_06B_PCB01_GPRS_MT6225_S00.A11+_V07_12_52_H 24.BIN - make "Read full flash" operation - send "backup_system_log_..." file to support: [email protected] - send flash backup file(s) to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished device-id: 30707DAF identification#1 protocol ver: 04 ver. sw1: AHONG25_06B_PCB01_GPRS_MT6225_S00.A11+_V07_12_52_H 24.BIN ver. sw2: A11+_V07.12.52.H24, 93877120 ffs offset/size: 00C00000/00400000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00C00000 flash: 98004900000002:18E59F00000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00C00000 detecting eeprom/ffs size... eeprom/ffs size: 00400000 ffs chip: 00 eeprom/ffs area: 00000000:00C00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [flash[AHONG25_06B_PCB01_GPRS_MT6225_S00.A11+_V07_12_52_H 24.BIN]]... file saved: E:\Infinity\Flash file\Read\Sprint\flash[AHONG25_06B_PCB01_GPRS_MT6225_S00.A11+_V07_12_52_H 24.BIN]_20080803-170506.B0M.bin file saved: C:\Program Files\InfinityBox\ChineseMiracle\system_log_30707D AF_AHONG25_06B_PCB01_GPRS_MT6225_S00.A11+_V07_12_5 2_H24.BIN_DF8E786C_20080803-170547.B0X.bin Finished, time used: 724 sec Remove/Install battery now ! Last edited by alamgir80; 11-30-2008 at 15:23. |
The Following User Says Thank You to alamgir80 For This Useful Post: |
11-30-2008, 15:20 | #7 (permalink) |
Member: 621121 Status: Offline Thanks Meter: 366 | here another cpu sprint 7700 COM8 [VCP0] selected module v2.65 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read NOR flash Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6217:8A00]... CPU: MT6217 high speed boot enabled boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 98004900000002:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 921600 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 98004900000002:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset assigned: 00E00000 flash: 98004900000002:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00800000 Detected eeprom/ffs address is non-standard: 00800000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? autodetected eeprom/ffs address[00800000] confirmed by user detecting eeprom/ffs size... eeprom/ffs size: 00800000 ffs chip: 00 eeprom/ffs area: 00000000:00800000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading: flash... file saved: E:\Infinity\Flash file\Read\Sprint\6217\flash_20081027-181538.B0M.bin Finished, time used: 686 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to alamgir80 For This Useful Post: |
ple send sprint 7700 rx tx pinout | MR.MAMUN | Chinese Models & Cloned Phones | 1 | 08-22-2009 12:32 |
i need pinout maximas ex65 or sprint 7700 | gopalhot | Chinese Models & Cloned Phones | 3 | 07-03-2009 07:23 |
Sprint 7700 flash file need | hasanphone | CPF-BOX Ⅱ | 2 | 02-17-2009 14:53 |
sprint 7700 flash file need | shaheb_anl | Chinese Models & Cloned Phones | 2 | 11-30-2008 13:22 |
need Sprint 7700 com port driver | tkowsar | Various | 0 | 10-14-2007 13:24 |
