12-01-2021, 16:49 | #1 (permalink) |
Freak Poster Join Date: Feb 2015
Member: 2349975 Status: Offline Thanks Meter: 51 | Spt box installation Serial Number (S/N): 00002EXXXXX8852B (11884) ==> Box owner: Pastor Good ==> Box owner e-mail: [email protected] ==> Reseller: Gsmserver ==> Connecting to http://register.sptbox.info/... Searching Dongle... Dongle found ==> Result: 2021.12.01 15:38:32 129.205.113.61 : index : Serial [00002EXXXXX8852B, 11884] should be Authorized by Reseller ! Wrong reply from server: 2021.12.01 15:38:32 129.205.113.61 : index : Serial [00002EXXXXX8852B, 11884] should be Authorized by Reseller ! Contact to [email protected] Failed: 00002Exxxxx8852B How do I go about solving this problem? Is it to by a new license for 10 inifniity credits. If yes, can I use my SPT Box with it? |
12-01-2021, 20:09 | #2 (permalink) |
No Life Poster Join Date: Jun 2010 Age: 14
Member: 1315677 Status: Offline Thanks Meter: 1,437 | I had formatted several times my pc and i hhad not this issue at all. Even in the spt folder there is not any license file. My spt is activated on the infinity box. Anyway, maybe you should try the activator 1.11 to build the user.ini, it is located in \sptbox\activator Code: ==> S/N: 000050A9D64xxxxx (20649) ==> Box owner: Lxxxxx Aishur ==> Box owner e-mail: [email protected] ==> Reseller: infiniy ==> Connecting to http://register.sptbox.info/... searching dongle... dongle found ==> Result: [000050A9D64xxxxxx2] Active=0468A9B711A6B263 Activation file saved: D:\__GSM\SPT\Activator\user.ini searching dongle... dongle found Firmware: 0004, HWID: 00032A7CFF02xxxxx SPT-Box Serial Number (S/N): 000050A9D6xxxxxx (20649) Done: 000050A9D64xxxxx Copy file user.ini to folder with SPT-Box software ! |
12-01-2021, 22:01 | #3 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
In fact SPT box (as box) has no relation to Infinity. We support users with "SPT activation for Infinity" only. But I think "SPT-Box S/N Authorize" should fix your issue. Good case - you will get box working, worst case - you will get 10 credits back to your IOS account. | |
12-02-2021, 15:32 | #4 (permalink) | |
Member: 2349975 Status: Offline Thanks Meter: 51 | Quote:
NOTED. Will try SPT Box website. | |
12-02-2021, 16:55 | #5 (permalink) | |
Thanks for this information. Can I install current SPT setup and use in my pc with windows 10 OS? | |
12-03-2021, 12:33 | #6 (permalink) | |
Thank you Aishur, just installed spt version 20.4.8 to my windows 10 and it failed to work and it worked on my windows 7 32bit. Is there a higher version than this that can work with my box? | |
