ST 60 and Benq E61 dead by infy helo team... i'v E61 and St 60 with hang logo..so i try to reset factory still same problem,finally i try to backup eeprom n fullflash,n then i flash with new firmware.BUt phone's dead,i try to flash again but always message error.And try flash with backup file still erroe message. Whats can i do again ???? please infy team can help me,so explain to me detail file to use repair this. thanks before |
Hello, Don't you think that it's good idea to post log text here ? Also, if phones was initially hangs and can't be flashed you have a big reason to check phone hardware, f.e. water inside etc. So my advice: first check phone hardware, charge battery and only then try to flash phone again ! |
What do you Think with this problem? Hardware or Software? COM5 [VCP0] selected Device: BenQ E61 Checking data, wait... Action: flash write Write: Firmware Skip: Flex Skip: Language Pack Skip: Eeprom Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... error: unknown flash chip: 401A:EA00:3FFD:EA00 error: unknown flash chip: 38A4:0000:AD3C:012C error: unknown flash chip: 65FD:7D43:33E5:5D74 Check Space Fail Finished, time used: 14 sec Remove/Install battery now ! |
Hello, It maybe hardware problem and software problem too (we was informed about similar problem for some working similar phones but never for BenQ). What is current phone state ? Is it good working or dead phone ? |
