04-14-2019, 13:05 | #1 (permalink) |
Freak Poster Join Date: Nov 2013 Location: Deira, Dubai
Member: 2062071 Status: Offline Sonork: 100.1663486 Thanks Meter: 60 | starmobile fs evo1 Need Unlock Solution Code: Operation : Check/Read Info [ v1.27 ] Normal Normal , 1 : Power On phone. Insert USB cable ( Normal USB cable ) Service Service , 1 : Insert USB cable ( Use adapter or special cable ) Service , 2 : Insert battery Service , 3 : If boot not start - press 'Power' button shortly ==== Wait for phone... Phone found! [ 396 ] Port Opened Sync... Normal Mode init Sync... Phone Initial Info : Platform : MOCORTM_15C_W17.26.2_P1_Debug Project : sc9820w_cp1 HWInfo : sc9820w_modem Phone Security Info : IMEI [1] : 033393XXXXXXXXX IMEI [2] : 033393XXXXXXXXX BT_ADDR : 000000000000 Done Reconnect Power/Cable! |
04-14-2019, 16:48 | #3 (permalink) | |
Member: 2062071 Status: Offline Sonork: 100.1663486 Thanks Meter: 60 | Quote:
Read Info Logs Code: Phone found! [ 396 ] Port Opened Sync... InitSvc Done Wait for phone... Sync... Phone Initial Info : Platform : MOCORTM_15C_W17.26.2_P1_Debug Project : sc9820w_cp1 HWInfo : sc9820w_modem Phone Security Info : IMEI [1] : 033393xxxxxxxxx IMEI [2] : 033393xxxxxxxxx BT_ADDR : 000000000000 Done Code: Start at : [4/14/2019 / 07:03:04 PM] Operation : Check/Read Info [ v1.27 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 72 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot didn't start! Check model selection! Boot Error! Break Reconnect Power/Cable! | |
The Following User Says Thank You to imrankhaliq For This Useful Post: |
04-23-2019, 10:06 | #5 (permalink) |
Major Poster Join Date: Sep 2010 Location: Dubai Age: 35
Member: 1390266 Status: Offline Sonork: 100.1668465 Thanks Meter: 6 | Init bus... VCC: 3.3 V, VCCQ: 3.0 V Bus: 4 bit (HS SDR 52MHz) Access mode: sector mode Power supply: dual-voltage (1.70-1.95V, 2.7-3.6V) Card/BGA: BGA (Discrete embedded) - High density MMC Manufacturer ID: 0x11 (Toshiba) Product name: 004GE0 (0x303034474530), rev: 0x01, serial number: 0x99D623C6 Manufacturing date: Feb 2015 CID: 11010030 30344745 300199D6 23C622C6 CSD: D05E0032 0F5903FF FFFFFFE7 924000E2 EXT_CSD revision: 1.6 (MMC v4.5, v4.51) Partition info: Boot1: 2048 KiB Boot2: 2048 KiB RPMB: 512 KiB User area: 3.69 GiB(3,959,422,976 bytes) Cache size: 4 MiB Hardware reset function: 1 Partition configuration: 0x00 No boot acknowledge is sent (default) Device is not boot-enabled (default) Partitioning support: 0x07 Device support partitioning feature Device can have enhanced technological features Device partitioning possible Boot configuration protection: 0x00 Boot bus conditions: 0x00 Boot area write protection: 0x00 Power-on write protection: possible Permanent write protection: possible Lock status: not locked EXT_CSD backup saved to "\\%BACKUPS%\004GE0_99D623C6.ext_csd" ANDROID System Info: platform: sc8830, cpu abi: armeabi-v7a manufacturer: Starmobile board: Starmobile FS Evo1, name: Starmobile FS Evo1 brand: Starmobile, model: Starmobile FS Evo1 build id: KTU84P, version: 5.1.1 Lollipop (Starmobile_FS_Evo1_V09_09292017 ) build description: sp9820w_6c20-user 4.4.4 KTU84P eng.jackwu.20170929.144024 test-keys Internal storage: 3.13 GiB crypto state: unencrypted |
