Old 12-15-2016, 08:32   #1 (permalink)
shazzmob's Avatar
Member: 2327602
Sonork: 100.1620953
Thanks Meter: 276
Exclamation help please qmobile s2 giving this error
Operation : Flash Erase [ v1.58 ]
Wait for phone...
Phone found! [ 110 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x94
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A4838473165050798F1E885B235
Initialize Memory ...
[DA_ERROR] : DRAM Configure failed!
ErroCode : 0xC40B0000
EMICFG_RET_FAILED
CodeDefine : DA_DEVICE_NOT_FOUND
Boot Error!
Operation Failed
Elapsed: 00:00:23
Reconnect Power/Cable!
Old 12-15-2016, 09:27   #2 (permalink)
shazzmob's Avatar
Member: 2327602
Sonork: 100.1620953
Thanks Meter: 276
anybody can solved this problem ???
Old 12-15-2016, 09:56   #3 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Hello,
What is condition of the phone?
Connect phone without pressing any keys and try again.
Br.
Infinity Box Support Team.
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post:
Old 12-15-2016, 13:29   #4 (permalink)
shazzmob's Avatar
Member: 2327602
Sonork: 100.1620953
Thanks Meter: 276
brother set damage i ask to customer
thanks for reply
Old 12-15-2016, 13:36   #5 (permalink)
mcclinic's Avatar
Member: 593876
Thanks Meter: 302
hw check "failed read only" show?
Wait for phone...
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
EMICFG_RET_FAILED
Boot Error!
Operation Failed
Elapsed: 00:00:23
yes, this is emmc problem, flash ic damage.
Old 12-15-2016, 16:00   #6 (permalink)
Member: 2083112
Thanks Meter: 6
Just open the phone and pres emmc with duble tape then flash
problem solved
Old 12-17-2016, 07:51   #7 (permalink)
shazzmob's Avatar
Member: 2327602
Sonork: 100.1620953
Thanks Meter: 276
problem solved thanks brothers
Old 11-11-2019, 11:56   #8 (permalink)
Member: 1689739
Sonork: 100.1608775
Thanks Meter: 164
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 157 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
eMMC Flash : 65646F4D204D4F5212A0000006154445
[WARNING] : MEMORY_eMMC_VALIDATE_FAILED
ErroCode : 0x2003
EMICFG_NOT_FOUND
TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT!
Boot Error!
Operation Failed
Elapsed: 00:00:26
piz solotion this error
Page generated in 0.17381 seconds with 8 queries
