strange error in micromax x360 http://img585.imageshack.us/img585/6...11102444am.jpg when i m flashing x360 i m getting this error. set history hangs after 3 mins. here is the logs COM9 [VCP0] selected module v3.62 Device: Micromax-X360 Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware Micromax-X360_TINNO25_08B_GEMINI_PCB01_GPRS_MT6225_S00.E808 _PR1_V9_0_INDIA_2009-12-11_En.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:940F:000F status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:09EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: [standard] type (07) TCL-ID is absent rom info detection finished rom info ver: 07 sw version: TINNO25_08B_GEMINI_PCB01_GPRS_MT6225_S00.E808_PR1_ V9_0_INDIA.BIN project-id: E808_PR1_V9.0_India, 00000000 code offset: 00020000 ffs offset/size [01]: 00E00000/001F0000 rom info structure: [standard] type (07) TCL-ID is absent ffs/eeprom address assigned: 00E00000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished security area (sec info, hash) size is incorrect: FFFFFFFF security area (sec info, cust) can not be unpacked product id: ? area1 is invalid area2 is invalid area3 is valid area4 is invalid searching sec info#2... . search sec info#2 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: Micromax-X360_TINNO25_08B_GEMINI_PCB01_GPRS_MT6225_S00.E808 _PR1_V9_0_INDIA__ffs... file saved: C:\Program Files\InfinityBox\MModule\Micromax-X360_TINNO25_08B_GEMINI_PCB01_GPRS_MT6225_S00.E808 _PR1_V9_0_INDIA__ffs_20110215-102055.B0E.bin Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... search sec info#1 finished searching sec info#2... . search sec info#2 finished usb bootloader (file) is present: 00020000 rom info relocation detected startup code area #1 check... done Area: Firmware flash: 01227E22202200:09EA0000000000 Write: Firmware usb bootloader (file) is present: 00020000 rom info relocation detected sec info (fast) detection... searching sec info#1... search sec info#1 finished searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected error: relocation table offset is unknown error: relocation table offset is unknown error: jump table is not found or incorrect, can't detect customization version error: can't calculate security area (sec info, cust), existing data will be used Check support area for updates ! security area (sec info, cust) calculation done security area (sec info, hash) calculation... version is not found in database: TINNO25_08B_GEMINI_PCB01_GPRS_MT6225_S00.E808_PR1_ V9_0_INDIA.BIN use default security area (sec info, hash) pattern error: can't assign default hash address range for ffs 00E00000/00003FA0 error: security area (sec info, hash) size is too small: 0000 error: can't calculate security area (sec info, hash) Write Done ====> Finalization ... Finalization Done Finished, time used: 8 min 57 sec Remove/Install battery now ! |
team please help me how to solve this error ............. |
hello! try with latest MModule available on support site |
Please, try to use ChineseMiracle software for this phone, everything should be done without any problems. |
