Old 04-11-2008, 21:24   #1 (permalink)
Member: 702472
Thanks Meter: 18
strangle second sim pb
hello
gsm people somebody show some soluytion about this pb?
After format operation N95 2sim the secxond sim can't release call again.I mean that I can't cut call with sim number two
Tell me what to do
best regard
Old 04-12-2008, 10:44   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
please explane more detailed:
which phone parts you formatted, what formating method and in which sequece (which one you formatted first, which second)
Old 04-12-2008, 18:17   #3 (permalink)
Member: 702472
Thanks Meter: 18
I do safe format for the first mcu 6226 I try the complet but no match
the pinout is 3-rx 5-tx 6-gnd but i can't the secon mcu i try the pinout 2 rx 4tx but no answer the connector is 2....6 mini
Old 04-12-2008, 20:42   #4 (permalink)
Member: 148515
hello!
i think you must find proper pinout for second MCU.
i can advice you to exclude from search pins : 3,5,6
and on all others measure volatge.
second CPu pins will have voltage near 2,7-2,8 volts
after you get connection- format second part and restore IMEI if needed
Old 04-14-2008, 11:05   #5 (permalink)
Member: 702472
Thanks Meter: 18
i will try andv post the result
Old 04-15-2008, 12:36   #6 (permalink)
Member: 702472
Thanks Meter: 18
I find the pinout and format both cpu and does not on again
Is any thing to resolve thi?
Old 04-15-2008, 12:41   #7 (permalink)
GSMSERVE's Avatar
Member: 80990
Sonork: 100.1583974
Thanks Meter: 312
Please post your log here we can halp you .
Old 04-15-2008, 21:24   #8 (permalink)
Member: 702472
Thanks Meter: 18
I don't back up before format it I had also the same file on support area but don't phone one
Old 04-15-2008, 21:32   #9 (permalink)
Member: 130995
Thanks Meter: 35,227
Try to use another file with similar firmware version.
Old 04-15-2008, 22:08   #10 (permalink)
Member: 702472
Thanks Meter: 18
MTK26-05c-DS500DA-TRFAE PCB01-GPRS MT6226 SO1 MAUI-05C-W06 16
THIS MY FILE
HELP ME CHOOSING AN OTHER ONE LIKE YOU SAID
THANK
Old 04-15-2008, 22:09   #11 (permalink)
Member: 130995
Hello,
Try to use filkes with version like "MTK26-05C...."
Old 04-15-2008, 22:16   #12 (permalink)
Member: 702472
Thanks Meter: 18
I like your disponibility i will try in 10 hour and poste result
thank favorite box
Old 04-16-2008, 11:45   #13 (permalink)
Member: 702472
Thanks Meter: 18
hello $
i try MtK26 files and i get message
error:unknown fir,user action required
1download latest sofware from support and try again
Old 04-16-2008, 15:00   #14 (permalink)
Member: 130995
Originally Posted by asco777 View Post
hello $
Yes, please, download latest software and try again.
Old 04-16-2008, 17:08   #15 (permalink)
Member: 702472
Thanks Meter: 18
I TRY General mobile file and the phone on but the keypad is not the same then i put an other mtk26 and my phone on
the pb of releasing is till there again i mean i can make call with 2 sim but i can't cut it
i will return it to the owner
thank for your help
3660 insert sim pb pls help??? proxy_gsm WD2 & APE (Symbian Phones) 8 09-10-2011 11:03
j600e insert sim pb mehdi123 Samsung Hardware Repair 1 11-13-2008 18:09
sim verrou without sim pb broda SMTi 2 10-21-2008 18:52
---trend t500 dual sim second sim is not working any solution--- makkah mobile Infinity-Box 1 09-12-2008 09:26
Motorola V60i insert sim pb pls help??? proxy_gsm Motorola P2k 3 01-06-2004 09:09
Page generated in 0.20816 seconds with 9 queries
