03-20-2010, 12:47 | #1 (permalink) | |
Junior Member Join Date: Sep 2009
Member: 1125745 Status: Offline Thanks Meter: 0 | Struggling with Infinity Box. I am trying to flash some Chinese iphone i9's however when i load the infinity box and select the "Chinese iphone">>>"i9" it says: Quote:
I cannot find the phone flash files to download. Also i am not sure why this folder is empty in the first place. Only reason i can see, is that upon setting up the Infinity box it says "Disc space required - 70Gb" I thought this was a mistake. Can it really use 70Gb??? IF this is correct then that is the problem as i dont have enough space left on my pc. Could someone confirm? Any help at all would be appreciated, i am on a bit of a deadline here. Many Thanks. | |
03-20-2010, 13:14 | #2 (permalink) |
Member: 1125745 Status: Offline Thanks Meter: 0 | Ok i think i have found where i need to get the files. From a thread on here. GSM Products Support - ChineseMiracle - GSM Library, The main Database for Cellular Mobile Phone professionals How do i know which one is for the i9? |
03-21-2010, 16:12 | #3 (permalink) | |
Member: 1043909 Status: Offline Thanks Meter: 60,861 | Quote:
Disk space required for exe files is 200Mb. Flash files (about 95Gb zipped) can be found in Infinity-Box support area or at CD/DVD (158 CD disks required or 24 DVD disks required) if your reseller provide it (but I do not think so due to all users download required files from support area). Here is an instruction how to get required flash files: Infinity-Box Also read this: http://forum.gsmhosting.com/vbb/f425...t-site-499453/ | |
03-22-2010, 13:39 | #4 (permalink) |
Member: 1125745 Status: Offline Thanks Meter: 0 | Hi, Thank you for that. I am still getting the same error when i have downloaded the Chinese Miracle.exe files. Information is not found in database, see more here: 1. C:\Program Files\InfinityBox\pinout\ 2. C:\Program Files\InfinityBox\pinout\ChineseMiracle\ The files are on my pc, they just seem to be empty??? Because of this i cannot go any further. When i try to "Read detailed info" it just hangs for ages until i give up. |
03-22-2010, 14:25 | #5 (permalink) |
Member: 1125745 Status: Offline Thanks Meter: 0 | Struggling to find which flash file i need, if i can figure this "read info" I have gone into Factory mode on the i9 3G and the build/serial no is strange. It is MT012345678901234567 :S |
03-22-2010, 16:21 | #6 (permalink) | |
03-22-2010, 16:27 | #8 (permalink) |
Member: 1125745 Status: Offline Thanks Meter: 0 | Ok i now have loads of files in this folder C:\Program Files\InfinityBox\pinout\ChineseMiracle I need to flash this phone. But first i am trying to "Read detailed info" as shown here: http://forum.gsmhosting.com/vbb/f425...t-site-499453/ Because i need to find the Flash file name. But it wont read the phone info. I dont know why. |
03-22-2010, 16:52 | #9 (permalink) | |
To read an information from phone you have to use correct pinout. | |
03-22-2010, 18:47 | #11 (permalink) | |
It's impossible to include several thousands of different cables in box package, so only widely used cables was included. Anyway, you can use your own cable easily (it may me that it will be little bit hard first time but after first time you will be able to make it easily). Also you can use Infinity-Box PinFinder - it's a special hardware for automatic pinout detection and for manual pinout selection for many phones. Infinity-Box Also, I did not understand well what cable you talk about exactly ? Please, read this instruction about own cables: FAQ: Frequently Asked Questions, cables/pinouts, supported models - GSM-Forum | |
03-22-2010, 20:45 | #13 (permalink) | |
So if you want to flash phone you have to start from correct pinout detection. | |
03-22-2010, 21:06 | #14 (permalink) |
Member: 1125745 Status: Offline Thanks Meter: 0 | Ok Thank you I need to find the correct lead then. As it still will not recognise any of the phones via this method either... I have tried to register on here Infinity-Home (this is the box i have) and it tells me "INVALID SERIAL NUMBER" I am starting to worry i have been sent a dodgy box Goin to contact Infinity via the site to check. I really appreciate all your help YellowBoss . |
03-23-2010, 06:43 | #15 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,531 | hello! please write about your problem to [email protected] include box and pinfinder serial numbers |
kg130 unlock with seccess with infinity box | zinoubinabil | Infinity-Box | 2 | 01-09-2008 16:04 |
J120 i can not be unlock with infinity box with last update | leroi | Infinity-Box | 3 | 11-09-2007 11:12 |
i Can't Unlock G51E with Infinity Box | flechazo | Infinity-Box | 1 | 07-09-2005 14:47 |
Is possible to Nec 342i with Infinity Box? | gsm flying free | Infinity-Box | 3 | 04-29-2005 18:40 |
