<<Succes fullunlocked HI-sldr with infinity and pin finder>> only the pinout on the infinity box Shell is not correct http://www.plaatjesupload.nl/bekijk/...663269-520.jpg ==== log: [26-2-2009 15:53:10] ==== COM2 [VCP0] selected module v2.65 Device: Fly-Hi-SLDR Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6219:8B02:8B01]... CPU: MT6219 detected CPU: MT6226MA chip: 0031:1EC1:A352 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: B0001D00000000:B0001D00000000 flash: Sharp Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 detection finished identification#1 protocol ver: 04 ver. sw 1: SL900A_KPN_PCB01_GPRS_MT6226M_S01.SL900A_05C_W06_0 8_MP_V72_F2.BIN ver. sw 2: SL900A.05C.W06.08.MP.V72.F2, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . detect device identification#2 finished sim-lock status: unknown Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: eeprom[SL900A_KPN_PCB01_GPRS_MT6226M_S01.SL900A_05C_W06_0 8_MP_V72_F2.BIN]... file saved: C:\Program Files\InfinityBox\MModule\eeprom[SL900A_KPN_PCB01_GPRS_MT6226M_S01.SL900A_05C_W06_0 8_MP_V72_F2.BIN]_20090226-155717.B0E.bin flash: B0001D00000000:B0001D00000000 Backup required data Done Patch required data ... detection procedure, wait... detection procedure completed Patch required data Done Special operation ... detecting additional parameters... ................................. flash: B0001D00000000:B0001D00000000 flash: B0001D00000000:B0001D00000000 Write: area 0/1 ............................... additional parameters detected Ok Special operation Done Write ... flash: B0001D00000000:B0001D00000000 Write: eeprom Write Done Finalization ... Finalization Done Finished, time used: 505 sec Remove/Install battery now ! |
can you please upload the correct pinout thanks |
6 rx 13 tx cable L14B |
thank you for the info |
