08-30-2008, 08:11 | #1 (permalink) |
No Life Poster Join Date: Apr 2005 Location: PAKISTAN Age: 45
Member: 133436 Status: Offline Sonork: 100.1577364 Thanks Meter: 191 | Succesfully Flashed ALC. OT-C701x thanks for the nice software, i successfully flashed Alcated C701x which was hanging on the startup LOGO. here is the log. Code: ==== log opened: [29/8/2008 12:28:08 PM] ==== Loading file v.02... C701X-2AMISI1_XC19DR25_JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_06A_W06_52_SP1_V24_2007-10-22_simfree_En_De_Cro_Serbian_Slovenian.B0M.bin loaded identification#1 protocol ver: 05 ver. sw1: JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_06A_W06_52_SP1_V24.BIN ver. sw2: MAUI.06A.W06.52.SP1.V24, A3E13074 You have loaded file with security features enabled. detecting languages... Languages: En El De Sh Sl COM1 [VCP0] selected Device: Alcatel OT-C701X, OT-C701A Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: write NOR flash "smart write" active "format ffs" active write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs enhanced security fix enabled Boot... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... error: can't detect CPU id Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 4 sec Remove/Install battery now ! COM1 [VCP0] selected Device: Alcatel OT-C701X, OT-C701A Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: write NOR flash "smart write" active "format ffs" active write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs enhanced security fix enabled Boot... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing[6226:8A03:8A02]... CPU: MT6226 chip: 0031:D121:A000 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22302200:2BEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x008000 00FEx020000 0004x008000] 32Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 460800 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.AEFCCD56.[JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_06A_W06_52_SP1_V17.BIN_49C9B029].rpl identification#1 detection finished device-id: AEFCCD56 identification#1 protocol ver: 05 ver. sw1: JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_06A_W06_52_SP1_V17.BIN ver. sw2: MAUI.06A.W06.52.SP1.V17, D64F36B6 ffs offset/size: 01200000/00E00000 detect device identification#2... detection phase #1... detect device identification#2 finished Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [eeprom[JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_06A_W06_52_SP1_V17.BIN]]... warning: wrong data size at 0x01115000, retry... warning: wrong data size at 0x01115000, retry... warning: wrong data size at 0x01115000, retry... warning: wrong data size at 0x01115000, retry... warning: wrong data size at 0x01115000, retry... warning: wrong data size at 0x01115000, retry... warning: wrong data size at 0x01115000, retry... warning: wrong data size at 0x01115000, retry... warning: wrong data size at 0x01115000, retry... error: too many retries during read operation Probably errors exist during flash read operation. Do you want to repeat read operation ? operation canceled by user file saved: C:\Program Files\InfinityBox\MModule\backup_eeprom[JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_06A_W06_52_SP1_V17.BIN]_20080829-123456.B0E.bin Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... security area#1 calculation... error: security area#1 communication fault You can flash phone now but can't finalize it. In most cases phone can NOT power-on normally. Do you want to write flash anyway ? operation cancelled by user file saved: C:\Program Files\InfinityBox\MModule\backup_system_log_AEFCCD56_JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_06A_W06_52_SP1_V17.BIN_49C9B029_20080829-123516.B0X.bin Finished, time used: 130 sec Remove/Install battery now ! COM1 [VCP0] selected Device: Alcatel OT-C701X, OT-C701A Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: write NOR flash write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs enhanced security fix enabled Boot... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing[6226:8A03:8A02]... CPU: MT6226 chip: 0031:D121:A000 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22302200:2BEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x008000 00FEx020000 0004x008000] 32Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 460800 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.AEFCCD56.[JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_06A_W06_52_SP1_V17.BIN_49C9B029].rpl identification#1 detection finished device-id: AEFCCD56 identification#1 protocol ver: 05 ver. sw1: JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_06A_W06_52_SP1_V17.BIN ver. sw2: MAUI.06A.W06.52.SP1.V17, D64F36B6 ffs offset/size: 01200000/00E00000 detect device identification#2... detection phase #1... detect device identification#2 finished Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [eeprom[JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_06A_W06_52_SP1_V17.BIN]]... file saved: C:\Program Files\InfinityBox\MModule\backup_eeprom[JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_06A_W06_52_SP1_V17.BIN]_20080829-124657.B0E.bin Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... security area#1 calculation... done file saved: C:\Program Files\InfinityBox\MModule\backup_system_log_AEFCCD56_JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_06A_W06_52_SP1_V17.BIN_49C9B029_20080829-124709.B0X.bin Area: Firmware flash: 01227E22302200:2BEA0000000000 Write: Firmware detect device identification#2... detection phase #1... detect device identification#2 finished security area#3 calculation... customization: CC19DR25 customization area adjusted: CC19DR25 done flash: 01227E22302200:2BEA0000000000 flash: 01227E22302200:2BEA0000000000 Write: security area#3 security area#3 calculation done security area#2 calculation... ..................counter: 01 done flash: 01227E22302200:2BEA0000000000 flash: 01227E22302200:2BEA0000000000 Write: security area#2 security area#2 calculation done Write Done Finalization... Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_system_log_AEFCCD56_JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_06A_W06_52_SP1_V17.BIN_49C9B029_20080829-130238.B0X.bin Finished, time used: 1633 sec Remove/Install battery now ! Take Care ENJOY |
OT C701x code reset? | abdoune | Alcatel TCL Phones and New Models | 10 | 03-06-2011 12:30 |
dead ot-c701x after flash | melgsm | Infinity-Box | 2 | 08-05-2008 13:40 |
Ot-c701x/a Pinout Error | A-Razzaz | Infinity-Box | 3 | 04-19-2008 07:26 |
Alcatel OT-C701X, OT-C701A info | GSM_BB5 | Infinity-Box | 0 | 04-15-2008 18:43 |
Alcatel Ot-c701x Unlock | Nasmi | FuriousGold | 2 | 08-15-2007 20:11 |
