04-14-2018, 19:19 | #316 (permalink) | |
No Life Poster Join Date: Feb 2011 Location: Android Modding
Member: 1507693 Status: Offline Thanks Meter: 131 | Quote:
Which phone are you trying to service? Search for the DA of that phone on Support, if you can't find it, then you can try other DA, it is not like the latest uploaded file can do ALL phones, NO SIR!! You have to try many DA until you find the one that works for your phone | |
04-14-2018, 20:29 | #317 (permalink) |
No Life Poster Join Date: Feb 2005 Location: GSM WORLD
Member: 118520 Status: Offline Thanks Meter: 3,551 | Hello I would like to say always post original infinity da file logs this logs is after da change and you using da file which is coded for MT6735/MT6735M so it will not work some old MT6580 work but not new MT6580 and one more thing I would like to say MT6580 new da file is not on iOS support area Good Luck |
The Following User Says Thank You to gracy_elec For This Useful Post: |
04-17-2018, 06:19 | #319 (permalink) |
Insane Poster Join Date: Aug 2014
Member: 2234872 Status: Offline Thanks Meter: 4 | i need hisense f10 boot file plz i did not find even on support area plz upload any one i alredy tested many files but no sucess here is log, 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 15 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:04 Reconnect Power/Cable! |
04-21-2018, 18:21 | #320 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | COOLPAD 8297 (INFINIX HOT V4 CLONE) Card found : S/N : A6936825 , v0136 Chinese Miracle II [MTK module] v 1.58 Start at : [4/21/2018 / 5:57:54 PM] Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 21 ] Sync... Inital Boot Ok! BB_CPU_PID : 6592 BB_CPU_NME : [MediaTek] MT6592_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : 00110000 Boot Error! Operation Failed Elapsed: 00:00:12 Reconnect Power/Cable! PLEASE HELP ME FOR DA FILE |
04-23-2018, 18:10 | #321 (permalink) |
Insane Poster Join Date: Dec 2004 Location: Peru Callao Age: 45
Member: 100918 Status: Offline Thanks Meter: 13 | EKS S5US frp Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 15 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:02 Reconnect Power/Cable! |
04-23-2018, 18:40 | #322 (permalink) | |
Freak Poster Join Date: Jul 2017
Member: 2739340 Status: Offline Thanks Meter: 74 | Quote:
04-27-2018, 13:55 | #323 (permalink) |
Freak Poster Join Date: Sep 2006 Location: morrocco
Member: 345974 Status: Offline Thanks Meter: 23 | 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 14 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.2017-06-20.16:16 Sending and initialize DA ... [DA_ERROR] : 00007017 Boot Error! Operation Failed Elapsed: 00:00:05 Reconnect Power/Cable! Last edited by elbasri73; 04-27-2018 at 14:04. |
05-02-2018, 11:57 | #324 (permalink) |
Major Poster Join Date: May 2009
Member: 1037764 Status: Offline Sonork: AQEEL22 Thanks Meter: 1 | Card found : S/N : CD543F2F , v0135 Chinese Miracle II [MTK module] v 1.58 Scatter Load Ok , BaseBand : MT6580 , Project : d5110_qmobile , Storage : EMMC Files found : 9 , Set to Flash : 8 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 47 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9C NAND Flash : NOT INSTALLED eMMC Flash : NOT INSTALLED Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0xC40B0000 EMICFG_RET_FAILED CodeDefine : DA_DEVICE_NOT_FOUND Boot Error! Operation Failed Elapsed: 00:00:21 Reconnect Power/Cable! what is this prob please help |
05-03-2018, 19:35 | #327 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | tools for DA files - http://forum.gsmhosting.com/vbb/f296...-58-a-2394792/ reports and suggestions are welcome |
05-05-2018, 10:10 | #328 (permalink) |
Major Poster Join Date: Jan 2012 Location: Karachi Pakistan
Member: 1712187 Status: Offline Thanks Meter: 8 | Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 199 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : BROM [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2122 EMICFG_NOT_ACCEPTED_CONFIG Boot Error! Operation Failed Elapsed: 00:00:26 Reconnect Power/Cable! |
05-05-2018, 10:29 | #329 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | HELLO @khanjan YOUR PHONE CPU ALLREADY SUPPORT IN NEW UPDATE HERE IS THE LINK DOWNLOAD AND INSTALL THE NEW UPDATE SETUP CONNECT PHONE AND POST SUCCESS LOGS LINK : http://dl1.infinity-box.com/download...T2_v2.00-r2.7z GOOD LUCK |
05-07-2018, 14:13 | #330 (permalink) | |
No Life Poster Join Date: Aug 2003 Location: Mars Age: 40
Member: 38084 Status: Offline Thanks Meter: 115 | Quote:
can i use this loader for TAG-L01? | |
