successfully reparid no lenience to produce COM6 [VCP0] selected module v3.31 Device: Autodetect 6253 NOR Checking data, wait... Action: write flash write: Firmware GOLDDRAGON53_JAVA_12832_09A_PCB01_GPRS_MT6253_S00. GD1110_V04_TX_IT32DE_QCIF_L3_V11__firmware_2011060 4-131542.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs No licensed to produce fix... No licensed to produce done nor area detection... interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6253:8A02:8A00 status: FF bbchip bl ver: FE NOR flash id[0093]: 0089:890300000000 [INTEL] PF38F30xxM0x1xx chip size: 16Mb otp status/size: S_DA_NOR_OTP_EXIST/00000108 NAND flash chip: not installed internal RAM size: 00020000 external RAM: absent done Set baudrate (921600)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 00000000/00000000 detect sec ro... detect custom parameters... detect project-id... project-id: GD1110_V04_TX_IT32DE_QCIF_L3_V11 detect NOR info... number of areas/bytes to read: 1:00050000 reading (HW_STORAGE_NOR)... TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: GOLDDRAGON53_JAVA_12832_09A_PCB01_GPRS_MT6253_S00. GD1110_V04_TX_IT32DE_QCIF_L3_V11.BIN project-id: GD1110_V04_TX_IT32DE_QCIF_L3_V11, 00000000 code offset: 00000000 ffs offset/size [02]: 00E00000/00200000 rom info structure: [standard] type (07) TCL-ID is absent ===> done ==================== New firmware found (v.3.31, database date: 29.05.2011): GOLDDRAGON53_JAVA_12832_09A_PCB01_GPRS_MT6253_S00. GD1110_V04_TX_IT32DE_QCIF_L3_V11.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== area size: 16Mb number of areas/bytes to read: 1:01000000 reading (HW_STORAGE_NOR)... file saved: D:\INFINTIY\V2.19C\ChineseMiracle\GOLDDRAGON53_JAV A_12832_09A_PCB01_GPRS_MT6253_S00.GD1110_V04_TX_IT 32DE_QCIF_L3_V11__fullflash_20110604-133536.B0M.bin startup code area #1 check... done number of cores: 1 loading files... number of areas: 1 done write... write core... Disconnect... done Finished, time used: 13 min 20 sec Remove/Install battery now ! |
ALSO UPLOAD THIS FILE HERE https://rapidshare.com/files/4630122...133536.B0M.bin |
