01-27-2009, 12:22 | #1 (permalink) |
No Life Poster Join Date: May 2005 Location: Bulgaria Age: 49
Member: 142632 Status: Offline Sonork: 100.1589012 Thanks Meter: 459 | Successfully unlock and flash ALCATEL C701X COM3 [VCP0] selected module v2.62 Device: Alcatel-C701X, C701A Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active "format ffs" active write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A03:8A02]... CPU: MT6226 chip: 0031:F018:A000 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E22302200:2BEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x008000 00FEx020000 0004x008000] 32Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 230400 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.A76DD EB4.[JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_06A_W06_52_SP 1_V17.BIN_0D326A39].rpl identification#1 detection finished device-id: A76DDEB4 identification#1 protocol ver: 05 ver. sw 1: JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_06A_W06_52_SP 1_V17.BIN ver. sw 2: MAUI.06A.W06.52.SP1.V17, C695CDF2 ffs offset/size: 01200000/00E00000 detect device identification#2... detection phase #1... detect device identification#2 finished sim-lock status: enabled Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... original imei: 35320501xxxxxx Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... security area (code #1) calculation... done file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_l og_A76DDEB4_JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_0 6A_W06_52_SP1_V17.BIN_0D326A39_20090127-120937.B0X.bin Area: Firmware flash: 01227E22302200:2BEA0000000000 Write: Firmware detect device identification#2... detection phase #1... detect device identification#2 finished security area (code #3, part #2) calculation... customization: CC19BN23 done flash: 01227E22302200:2BEA0000000000 flash: 01227E22302200:2BEA0000000000 Write: security area (code #3, part #2) security area (code #3, part #2) calculation done security area (code #3, part #1) calculation... ..................security area (code #3, part #1) detecting size... security area (code #3, part #1) detecting parameters... security area (code #3, part #1) encoding... done flash: 01227E22302200:2BEA0000000000 flash: 01227E22302200:2BEA0000000000 Write: security area (code #3, part #1) security area (code #3, part #1) calculation done Write Done Finalization ... formatting... flash: 01227E22302200:2BEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_l og_A76DDEB4_JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_0 6A_W06_52_SP1_V17.BIN_0D326A39_20090127-123104.B0X.bin Finished, time used: 1321 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to Umbabaraumba For This Useful Post: |
01-27-2009, 13:42 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @Umbabaraumba Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems (so we will be able to fix it) and successfully done work. |
successful unlock and Flash S5233A by Ust pro 10.0.00 | hack team | UST Pro II | 24 | 06-02-2010 13:09 |
Successfully unlock and flash ALCATEL C701X But no network | khawar | Infinity-Box | 9 | 12-12-2009 11:49 |
successful unlocked and corect flashing c905 | delchoni | SETool2 | 0 | 05-19-2009 13:30 |
SUCCESFULLY UNLOCK AND FLASH virgin Alcatel-S621X | makkah mobile | Infinity-Box | 1 | 03-02-2009 14:54 |
alcatel e801 unlock and flash file needed | burraq | FuriousGold | 1 | 01-26-2009 11:05 |
