09-26-2014, 12:39 | #19741 (permalink) |
No Life Poster Join Date: Jul 2004 Location: UNITED KINGDOM Age: 44
Member: 74415 Status: Offline Sonork: gsm.zone Thanks Meter: 339 | 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Processing DA stage NAND_ID : 00000000000000000000 eMMC_ID : 7901004D4D43303447450774D31C31C9 DA Stat : v4.2 on BBID : 0x88 NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0000 , [SAMSUNG] K9F5608Q0C [NAND] : FLASH_DIE : 0000 0000 0000 0000 0000 [NAND] : FLASH_LEN : 0x00000000 NAND not supported yet INT RAM : 0x00000000 EXT RAM : 0x00000000 BOOT TYPE : DONE SOC VERIFY : 00 Boot Ok! Boot Error! Operation Failed Elapsed: 00:00:45 Reconnect Power/Cable! |
09-26-2014, 12:42 | #19742 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | KARIM GSM-ZONE , something wrong with initialization. Remove battery. charge it at least to 50% then try again. If problems still exist - reboot PC and try again. |
The Following User Says Thank You to Dzirt For This Useful Post: |
09-26-2014, 12:56 | #19745 (permalink) |
Member: 74415 Status: Offline Sonork: gsm.zone Thanks Meter: 339 | to be honest i never use to work with chinese platform,so yes its been erased and flashed with wrong fw and i need help to fix it , br karim |
09-26-2014, 13:04 | #19746 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | In log I see erased preloader. Currently I collect DB for RAMINIT for such cases. Leave phone for 2-3 days on hands and we will play with it more after |
09-26-2014, 20:08 | #19747 (permalink) |
Freak Poster Join Date: Oct 2011 Location: Almoradi (ALICANTE) . SPAIN
Member: 1677266 Status: Offline Thanks Meter: 90 | nokia 220 dual sim flash done --- Insert USB cable now! --- Wait for phone... Phone found! [ 271 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : 036F66EFB889655A103979C8BCCE1BDD BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x000E Project ID : Rivendell.10.03.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Rivendell.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00A60000-0x00FF3FFF , LEN : 0x00594000 SecureDecrypt : RM-969_ROM_eMP_13.00.11 SecureDecrypt : RM-969_VIVA_eMP_13.00.11 SecureDecrypt : RM-969_LANG_PACK_ROM_AE_eMP_13.00.11 SecureDecrypt : RM-969_CUSTPACK_ROM_AE_EURO_IT_eMP_13.00.11 SecureDecrypt : RM-969_JUMP_TABLE_AE_EURO_IT_eMP_13.00.11 OVRLP : 000069B900000001 PHPID : Rivendell.10.03.11.p1 OVRLP : 00004DF900000001 [ERROR] : DA_CBR_NOT_FOUND DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok ERASE_MAUI_INFO : 0x00040000 WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-969_ROM_eMP_13.00.11 Write : RM-969_LANG_PACK_ROM_AE_eMP_13.00.11 Write : RM-969_CUSTPACK_ROM_AE_EURO_IT_eMP_13.00.11 Write : RM-969_JUMP_TABLE_AE_EURO_IT_eMP_13.00.11 Write : RM-969_VIVA_eMP_13.00.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-969_ROM_eMP_13.00.11 [VERIFY] DONE : RM-969_LANG_PACK_ROM_AE_eMP_13.00.11 [VERIFY] DONE : RM-969_CUSTPACK_ROM_AE_EURO_IT_eMP_13.00.11 [VERIFY] DONE : RM-969_JUMP_TABLE_AE_EURO_IT_eMP_13.00.11 [VERIFY] DONE : RM-969_VIVA_eMP_13.00.11 CODE_VERIFY : Ok FORMAT FFS : skipped Rebooting phone now Flashing done! Total flash time : 00:02:08 Reboot phone Ok Connect phone on selected interface... |
The Following User Says Thank You to Movileuropa For This Useful Post: |
09-27-2014, 04:23 | #19748 (permalink) |
No Life Poster Join Date: Aug 2006 Location: BHARAT
Member: 327043 Status: Offline Sonork: 100.1587811 Thanks Meter: 1,514 | 1 question if set come for gmail id ask and dont want touch users data what shuld i need to do ? formate with 1 catch ?? 2 formate with UDA ?? or both ?? i need safe custmer data and also want remove gmail lock ps: also want stop button in gui |
09-27-2014, 06:26 | #19750 (permalink) | |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Quote:
MT6261 support will be added in some of next version. | |
09-27-2014, 09:11 | #19751 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Chinese Miracle-2 (Release) Reports: SPD/Spreadtrum Dear Friends, Please, post here your test reports with Chinese Miracle-2 (Release) SPD/Spreadtrum software. If you can not run Chinese-Miracle-2 software: - Please read instruction: http://forum.gsmhosting.com/vbb/f296...ocess-1865047/ Last edited by YellowBoss; 11-22-2015 at 20:34. |
09-28-2014, 10:39 | #19752 (permalink) |
No Life Poster Join Date: May 2008 Location: hall road pakistan
Member: 782530 Status: Offline Thanks Meter: 8,136 | Q mobile E4 Dead Recovery with other Box Flashfile here is logs... Load File File_Info : WBG1307QM_0202_PCB01_gprs_MT6250_S00.1307QM_0202_V 0766.bin FileVersion : 1307QM_0202_V0766 Load File Ok Operation : Flash [ v1.00 ] ======= Flash Files set for flashing : [ MCU ] : WBG1307QM_0202_PCB01_GPRS_MT6250_S00.1307QM_0202_V 0766.BIN 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 13 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : F4D70DB23AB4528CB3077A0044D2AC19 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C200 2500 3600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00DB , [MX] MX25U3235E [0] : FLASH_DIE : 00C2 0025 0036 0000 [0] : FLASH_LEN : 0x00400000 SDS : 0x00000000 , 0x00000000 File_Info : WBG1307QM_0202_PCB01_gprs_MT6250_S00.1307QM_0202_V 0766.bin FileVersion : 1307QM_0202_V0766 Flash now Erase region , wait ... Write data , wait ... Write : WBG1307QM_0202_PCB01_GPRS_MT6250_S00.1307QM_0202_V 0766.BIN Done! Elapsed: 00:00:48 Reconnect Power/Cable! |
The Following 4 Users Say Thank You to FullFlashPak For This Useful Post: |
09-28-2014, 10:45 | #19753 (permalink) |
No Life Poster Join Date: Apr 2007 Location: BIRMINGHAM UNITED KINGDOM Age: 34
Member: 488632 Status: Offline Thanks Meter: 391 | DORO EASYPHONE 410GSM UNLOCKED COM3 [VCP0] selected module v4.46 Device: Doro-PhoneEasy-410gsm Checking data, wait... Operation: SP-unlock unlock method: smart fast interface: META_DLL_v6.1108.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... done Release Power button now ! BaseBand chip version: MT6223, E05 ECO version: DSP firmware version: 2000.00.00 DSP patch version: 1.0 S/W version: SHELL_S09_2V8_DORO410_L14EN_202_100521_MCP128+32_B T_FM_SMS H/W board version: CKT23D_08A_HW Melody version Melody V0.0 Version: SHELL_S09_2V8_DORO410_L14EN_202_100521_MCP128+32_B T_FM_SMS 80 byte(s) read imei #1: 35759603154857707810 191 byte(s) read 38 byte(s) read preparing new data... writing data... 179 byte(s) read 972 byte(s) read preparing new data... writing data... verifying... verification Ok Shutdown... done Finished, time used: 26 sec Remove/Install battery now ! |
The Following User Says Thank You to yasermalik For This Useful Post: |
09-28-2014, 10:47 | #19754 (permalink) |
Member: 488632 Status: Offline Thanks Meter: 391 | DORO EASYPHONE 410 gsm unlocked using rx tx under bettery DORO EASYPHONE 410GSM UNLOCKED COM3 [VCP0] selected module v4.46 Device: Doro-PhoneEasy-410gsm Checking data, wait... Operation: SP-unlock unlock method: smart fast interface: META_DLL_v6.1108.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... done Release Power button now ! BaseBand chip version: MT6223, E05 ECO version: DSP firmware version: 2000.00.00 DSP patch version: 1.0 S/W version: SHELL_S09_2V8_DORO410_L14EN_202_100521_MCP128+32_B T_FM_SMS H/W board version: CKT23D_08A_HW Melody version Melody V0.0 Version: SHELL_S09_2V8_DORO410_L14EN_202_100521_MCP128+32_B T_FM_SMS 80 byte(s) read imei #1: 35759603154857707810 191 byte(s) read 38 byte(s) read preparing new data... writing data... 179 byte(s) read 972 byte(s) read preparing new data... writing data... verifying... verification Ok Shutdown... done Finished, time used: 26 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to yasermalik For This Useful Post: |
09-28-2014, 11:12 | #19755 (permalink) | |||
Member: 782530 Status: Offline Thanks Meter: 8,136 | Voice V160 Dead Recovery done Info Logs... Quote:
The Following 3 Users Say Thank You to FullFlashPak For This Useful Post: |
