Old 05-05-2018, 13:26   #49486 (permalink)
Member: 2643730
Thanks Meter: 1,115
Itel it5623 file readed by cm2 exculsive
Operation : Read Flash [ v1.58 ]
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 48 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6260_S0000
BB_CPU_SN : DF8BF1F1511EE0D42CD13E58A06704AD
BROM Protocol Version : 05
Setting...
Setting done , result code 0x000E
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
InitRes : 00000000
DEV[0] : C800 6000 1700 0000
DEV[1] : 0000 0000 0000 0000
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x00ED , [GigaDevice] GD25LQ64
[0] : FLASH_DIE : 00C8 0060 0017 0000
[0] : FLASH_LEN : 0x00800000
INT_RAM : 0x0000D000
EXT_RAM : 0x00800000
Reading Flash Content now ...
Read Flash now
Read Ok , 8388608 bytes read
Check and collect compile info
File_Info : UL281_IT5623_PCB01_gprs_MT6260_S00.IT5623-UL281-ENHIPAGU-IN-20161222.bin
FileVersion : it5623-UL281-EnHiPaGu-IN-20161222
[ScatCFG] : MT6260 / it5623-UL281-EnHiPaGu-IN-20161222 / NOR , SF
Firmware saved to : C:\InfinityBox\CM2MTK\Read_out\UL281_IT5623_PCB01_ gprs_MT6260_S00\
Done!
Elapsed: 00:00:32
Reconnect Power/Cable!
Old 05-05-2018, 13:35   #49487 (permalink)
alamgarh's Avatar
Member: 358694
Sonork: 100.1597323
Thanks Meter: 994
Mobicel C1 Code Read Done
2. Press and hold BootKey ( Skip, if use BootCable )
3. Insert battery
==== Wait for phone...
Phone found! [ 1119 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending boot ...
Boot Sent , starting...
Boot Ver : Spreadtrum Boot Block version 1.2
Boot Ok
CPU ID : 6531 , FDLStat : 0100
[0] Flash DIE : 00EF 0040 0016 0000
[0] Flash VEN : Winbond , W25Q32
[0] Flash CAP : 00400000
Check data... Can take some time
User Code : 232082
Done!
Elapsed: 00:00:07
Old 05-05-2018, 14:27   #49488 (permalink)
Member: 583492
Thanks Meter: 125
Smile Honor TIT-AL00 sucessfully frp removed
Card found : S/N : 540A98D8 , v0136
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 189 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BB_CPU_NME : [MediaTek] MT6735_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x93
NAND Flash : NOT INSTALLED
eMMC Flash : 484A01906532474157280705B531C714
Initialize Memory ...
DRAM configured from IDB!
DRAM initialize passed!
DRAM size : 0x40000000
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , e2GA
[eMMC] : FLASH_CID : 90014A48414732650507285714C7C3B5
[eMMC] : FLASH_LEN : 0x00000003AB800000
[eMMC] : FLASH_UCP : 15032 MiB [eMMC 16 GiB]
DEV RID : 0x2C5CACCAF2C20ABBC3AAC489D88DD7FA
INT RAM : 0x00020000
EXT RAM : 0x40000000 [1 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand : HONOR
ProdName : TIT-AL00
ProdModel : TIT-AL00
Device : HWTIT-L6735
AndroidVer: 5.1
MTKxCPU : MT6735
MTKxPRJ : ALPS.L1.MP3.V2_ONTIM6735.66T.L1_P91
SECURITY :
IMEI_SW [1] : 869313022398702
IMEI_SW [2] : 869313027144309
BTMAC Addr : 84BE526785FD
WiFi MAC : 84BE5265FF5D
MODEM :
BaseBand : MT6735_S00_MOLY_LR9_W1444_MD_LWTG_MP_V16_P24_1_lwg _2
EXTRA :
LCD : Not info available
LCD Res : 1280x720
TOUCH [0] : GT1XX
CAM [0] : ov13850OF_mipi_raw
CAM [1] : ov5670OF_mipi_raw
CAM [2] : ov13850QT_mipi_raw
CAM [3] : ov5670SE_mipi_raw
CAM [4] : ov13850TR_mipi_raw
MODEM : mt6735_sp_lwg_dsds_c2kirat_prod mt6735_phone_md3_irat_cnom_prod mt6735_sp_lwg_dsds_c2kirat_prod2
LOCALE : en_US zh_CN zh_TW hi_IN
Done!
Elapsed: 00:00:16
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Done!
Elapsed: 00:00:17
The Following User Says Thank You to afhaan For This Useful Post:
Old 05-05-2018, 19:36   #49489 (permalink)
Member: 2671513
Thanks Meter: 121
IRIS NEXT G : info + read flash + read nvram ok
Wait for phone...
Phone found! [ 9 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 524E011336394A31CF54104E3D3BEEC0
[WARNING] : MEMORY_eMMC_VALIDATE_FAILED
[eMMC] : FLASH_VEN : 0x13 , OEM : 014E
[eMMC] : FLASH_INF : [NOT_IN_BASE] , N69J1
[eMMC] : FLASH_CID : 13014E52314A39364E1054CFC0EE223D
[eMMC] : FLASH_LEN : 0x00000003AB400000
[eMMC] : FLASH_UCP : 15028 MiB [eMMC 16 GiB]
DEV RID : 0x0D434F4DFAA58EA9420B7317762336B3
EXT RAM : 0x80000000 [2 GiB]
SOC VERIFY : C1
Boot Ok!
Brand : IRIS
ProdName : NEXT_G
ProdModel : NEXT G
Device : hct6735m_35gu_l1
AndroidVer: 5.1
MTKxCPU : MT6735
MTKxPRJ : IRIS_NEXT_G_V1.002
SECURITY :
IMEI_SW [1] : 35786xxxxxxxxxx
IMEI_SW [2] : 35786xxxxxxxxxx
BTMAC Addr : 04xxxxxxxxxx
WiFi MAC : 04xxxxxxxxxx
MODEM :
BaseBand : MT6735_S00_MOLY_LR9_W1444_MD_LWTG_MP_V16_P34_1_lwg _n
EXTRA :
LCD Res : 1280x720
TOUCH [0] : GT1XX
CAM [0] : imx219_mipi_raw
CAM [1] : gc2355_mipi_raw
MODEM : t823_hct6753_65c_l1-lwg_dsds-_fdd3m137820
LOCALE : fr_FR el_GR en_US zh_CN zh_TW es_ES pt_BR ru_RU de_DE tr_TR vi_VN ms_MY in_ID th_TH it_IT ar_EG hi_IN bn_IN ur_PK fa_IR pt_PT nl_NL hu_HU tl_PH ro_RO cs_CZ ko_KR km_KH iw_IL my_MM pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB hy_AM zh_HK et_EE ja_JP kk_KZ sr_RS sl_SI ca_ES
Done!
Elapsed: 00:00:10
Wait for phone...
Phone found! [ 9 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
xGPT : Normalize settings Ok!
Brand : IRIS
ProdName : NEXT_G
ProdModel : NEXT G
AndroidVer: 5.1
MTKxCPU : MT6735
[Read Ok] : preloader_hct6735m_35gu_l1.bin
[Read Ok] : lk.bin
[Read Ok] : boot.img
[Read Ok] : recovery.img
[Read Ok] : logo.bin
[Read Ok] : secro.img
[Read Ok] : tz1.img
[Read Ok] : tz2.img
[Read Ok] : system.img
[Read Ok] : cache.img
[Read Ok] : userdata.img
[ScatCFG] : MT6735M / V1.1.2 / hct6735m_35gu_l1 / EMMC
Android Info saved
MAUI Meta DB saved
HWConfig Info saved
FW Size : 1837 MiB
Scatter saved to : H:\cm2 dump\iris next g\MT6735__IRIS__NEXT_G__hct6735m_35gu_l1__5.1__IRI S_NEXT_G_V1.002\
All done!
Done!
Elapsed: 00:07:12
Operation : Read NVRAM [ v1.58 ]
Wait for phone...
Phone found! [ 9 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
[Info] : BaseBand : MT6735_S00_MOLY_LR9_W1444_MD_LWTG_MP_V16_P34_1_lwg _n
NVM Read Ok, MT6735_S00_MOLY_LR9_W1444_MD_LWTG_MP_V16_P34_1_lwg _n_eMMC.spnv
Done!
Elapsed: 00:01:00
Old 05-05-2018, 19:58   #49490 (permalink)
Member: 2671513
Thanks Meter: 121
IRIS NEXT G+ : info + read flash + read nvram ok
Wait for phone...
Phone found! [ 9 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 520001154D423158E01E0742BF8925C2
[eMMC] : FLASH_INF : [SAMSUNG] , BMB1X
[eMMC] : FLASH_CID : 150100525831424D42071EE0C22573BF
[eMMC] : FLASH_LEN : 0x0000000747C00000
[eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB]
DEV RID : 0x0D434F4D459B469DCCFC80837E44236F
EXT RAM : 0xC0000000 [3 GiB]
SOC VERIFY : C1
Boot Ok!
Brand : NEXT G+
ProdName : NEXT_G+
ProdModel : NEXT G+
Device : hct6753_65u_m0
AndroidVer: 6.0
MTKxCPU : MT6735
MTKxPRJ : IRIS_NEXT_G+_V2.6
SECURITY :
IMEI_SW [1] : 35693xxxxxxxxxx
IMEI_SW [2] : 35693xxxxxxxxxx
BTMAC Addr : FAxxxxxxxxxx
WiFi MAC : 000000000000
MODEM :
BaseBand : MT6735_S00_MOLY_LR9_W1444_MD_LWTG_MP_V79_P15_1_lwg _n
EXTRA :
LCD Res : 1280x720
TOUCH [0] : GT1XX
CAM [0] : ov13850_mipi_raw
CAM [1] : sp5507_mipi_raw
MODEM : t823_hct6753_65t_m0-lwg_dsds-_3m_gsm4p_w1_8_fdd1_3_7_8_20
LOCALE : fr_FR en_US zh_CN zh_TW es_ES pt_BR ru_RU de_DE tr_TR vi_VN ms_MY in_ID th_TH it_IT ar_EG hi_IN bn_IN ur_PK fa_IR pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ ko_KR km_KH iw_IL my_MM pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB hy_AM zh_HK et_EE ja_JP kk_KZ sr_RS sl_SI ca_ES
Done!
Elapsed: 00:00:27
Wait for phone...
Phone found! [ 9 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Brand : NEXT G+
ProdName : NEXT_G+
ProdModel : NEXT G+
AndroidVer: 6.0
MTKxCPU : MT6735
[Read Ok] : preloader_hct6753_65u_m0.bin
[Read Ok] : lk.bin
[Read Ok] : tz1.img
[Read Ok] : tz2.img
[ScatCFG] : MT6753 / V1.1.2 / hct6753_65u_m0 / EMMC
Android Info saved
MAUI Meta DB saved
HWConfig Info saved
FW Size : 2610 MiB
Scatter saved to : H:\cm2 dump\iris next g+\MT6735__NEXT_G+__NEXT_G+__hct6753_65u_m0__6.0__ IRIS_NEXT_G+_V2.6\
All done!
Done!
Elapsed: 00:10:42
Wait for phone...
Phone found! [ 9 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
[Info] : BaseBand : MT6735_S00_MOLY_LR9_W1444_MD_LWTG_MP_V79_P15_1_lwg _n
NVM Read Ok, MT6735_S00_MOLY_LR9_W1444_MD_LWTG_MP_V79_P15_1_lwg _n_eMMC.spnv
Done!
Elapsed: 00:00:35
Old 05-05-2018, 20:29   #49491 (permalink)
sgreenphone's Avatar
Member: 1513870
Thanks Meter: 46
SmartPhone Iris IS-4 reset pattern unlock done successfully
Start at : [05/05/2018 / 20:07:06]
Wait for phone...
Phone found! [ 48 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x88
eMMC Flash : 7001005331303030340882691EAA33AB
[eMMC] : FLASH_VEN : 0x70 , OEM : 0100
[eMMC] : FLASH_INF : [KINGSTON] , 40001
[eMMC] : FLASH_CID : 7001005331303030340882691EAA33AB
[eMMC] : FLASH_LEN : 0x00000000E4000000
[eMMC] : FLASH_UCP : 3648 MiB [eMMC 4 GiB]
DEV RID : 0x37EF17FC96AD08C5602AF1B83A0807C0
EXT RAM : 0x20000000 [512 MiB]
SOC VERIFY : C1
Boot Ok!
Foufadoudounounou
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:25
Finish at : [05/05/2018 / 20:07:32]
Old 05-06-2018, 03:32   #49492 (permalink)
abikarki's Avatar
Member: 2670396
Thanks Meter: 125
MT6735__Tecno_Camon__I__Tecno__IN5__H3721A-N-180104V12__MOLY.LR9..W1444.MD.LWTG.MP.V110.5.P38_F irmware_Read_With_CM2_BY_Abinash
Wait for phone...
Phone found! [ 7 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
SecCfgVal : 0x05000000
BromVer : 0x00FF
BLVersion : 0x0001
BootLdrSS : LOCKED with CERT
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v3.3001.2017/12/28.11:39_396299
Running DA ver.4.2 on BBID : 0x9B
eMMC Flash : 484A019061344742C443A5328BAEBA8E
[eMMC] : FLASH_INF : [HYNIX] , 2a4GB
[eMMC] : FLASH_CID : 90014A484247346132A543C48EBA158B
DEV RID : 0x444A22FCEE08F4E9EF19E5E1BD373F50
SOC VERIFY : C1
Boot Ok!
[Read Ok] : preloader_rlk6737t_65_n.bin
[Read Ok] : lk.bin
[Read Ok] : tz1.img
[Read Ok] : tz2.img
[ScatCFG] : MT6735 / V1.1.2 / rlk6737t_65_n / EMMC
Android Info saved
HWConfig Info saved
FW Size : 4020 MiB
Scatter saved to : C:\Users\GSM-Abinash\Desktop\New folder\MT6735__Tecno_IN5_Tecno_IN5_H3721A-N-180104V12_
MOLY.LR9..W1444.MD.LWTG.MP.V110.5.P38\
All done!
Done!
Elapsed: 00:17:16
Old 05-06-2018, 04:34   #49493 (permalink)
Member: 2536582
Thanks Meter: 34
qmobile m6 mt6755 frp done.
Card found : S/N : BAFB6697 , v0136
Wait for phone...
Phone found! [ 22 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6755
BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
DAgent configured successfully
Connection agent : PRELOADER
Link with DAgent established
[eMMC] : FLASH_INF : [SAMSUNG] , BM41C
[eMMC] : FLASH_CID : 150100524331344D42074E53CEB4B359
[eMMC] : FLASH_LEN : 0x0000000E8F800000
[eMMC] : FLASH_UCP : 59640 MiB [eMMC 128 GiB]
DEV RID : 0xC2AD5285FFC17CF105FA0D91A95D3D8B
INT RAM : 0x00000000
[NAND] : FLASH : NOT INSTALLED
[UFSM] : FLASH : NOT INSTALLED
[HSUSB] : MODE : HIGH-SPEED
Boot Ok!
Clear Ok!
Clear PVL ( PrivacyLock )
Clear Ok!
Done!
Elapsed: 00:00:11
The Following User Says Thank You to shahid1982 For This Useful Post:
Old 05-06-2018, 05:08   #49494 (permalink)
Crazy Poster
Member: 1145249
Sonork: djjeff 25
Thanks Meter: 7
Thumbs up oppo f5 done
Operation : Identify [ v2.00 r2 ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek USB Port (COM9)
MODE : BOOTROM
PORT : 9
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001
TYPE : MODERN RAPHAEL
BROM : SecLevel : 0x000000E5
BROM : SecMode : SBC+SDA
BROM : BOOTROM
BROM : SLA
BROM : SLA Passed!
AGENT : Look for suitable BootChain in DA ...
AGENT : DA_PL_CRYPTO.bin
AGENT : Found MT6763
AGENT : MTK_DOWNLOAD_AGENT
BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
DA : EXT_RAM NOT initialized!
EMI : DEV : MT6763
EMI : SRC : preloader_oppo6763_17031.bin
EMI : CNT : 000F
EMI : [00] : DRAM : EXTERNAL DRAM [LP/DDR4] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 0 B ]
EMI : [01] : eMCP : eMMC+LP/DDR4 , ID : 150100444836444D42 : VEN : SAMSUNG | DEV : DH6DMB : RAM : [ 4.00 GB ]
EMI : [02] : eMCP : eMMC+LP/DDR3 , ID : 150100525836344D42 : VEN : SAMSUNG | DEV : RX64MB : RAM : [ 4.00 GB ]
EMI : [03] : eMCP : eMMC+LP/DDR3 , ID : 150100524836344142 : VEN : SAMSUNG | DEV : RH64AB : RAM : [ 4.00 GB ]
EMI : [04] : eMCP : eMMC+LP/DDR4 , ID : 150100334836434D42 : VEN : SAMSUNG | DEV : 3H6CMB : RAM : [ 6.00 GB ]
EMI : [05] : eMCP : eMMC+LP/DDR3 , ID : 150100524836344D42 : VEN : SAMSUNG | DEV : RH64MB : RAM : [ 4.00 GB ]
EMI : [06] : eMCP : eMMC+LP/DDR3 , ID : 150100474436424D42 : VEN : SAMSUNG | DEV : GD6BMB : RAM : [ 3.00 GB ]
EMI : [07] : eMCP : eMMC+LP/DDR3 , ID : 150100475836424D42 : VEN : SAMSUNG | DEV : GX6BMB : RAM : [ 3.00 GB ]
EMI : [08] : eMCP : eMMC+LP/DDR3 , ID : 150100474536424D42 : VEN : SAMSUNG | DEV : GE6BMB : RAM : [ 3.00 GB ]
EMI : [09] : eMCP : eMMC+LP/DDR3 , ID : 150100524436344D42 : VEN : SAMSUNG | DEV : RD64MB : RAM : [ 4.00 GB ]
EMI : [0A] : eMCP : eMMC+LP/DDR3 , ID : 13014E53304A394237 : VEN : UNKNOWN | DEV : S0J9B7 : RAM : [ 3.00 GB ]
EMI : [0B] : DRAM : EXTERNAL DRAM [LP/DDR3] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4.00 GB ]
EMI : [0C] : DRAM : EXTERNAL DRAM [LP/DDR4] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4.00 GB ]
EMI : [0D] : DRAM : EXTERNAL DRAM [LP/DDR3] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 3.00 GB ]
EMI : [0E] : DRAM : EXTERNAL DRAM [LP/DDR4] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 6.00 GB ]
EMI : Init EMI from PRELOADER
EMI : EXT_RAM CFG Passed!
DA : BOOT to 2nd DA ...
DA : 2ND stage confirmed!
DA : SYNC with DA passed!
DA : Receiving HW info
SRAM: 0x00040000 [ 256.00 KB ]
DRAM: 0xC0000000 [ 3.00 GB ]
EMMC: 150100525836344D42034DCCC4EB74EF
EMMC: VEN : SAMSUNG | OEM : 01 | DEV : RX64MB
EMMC:
BOOT1 : 0x00400000 [ 4.00 MB ]
BOOT2 : 0x00400000 [ 4.00 MB ]
RPMB : 0x00400000 [ 4.00 MB ]
USER : 0x747C00000 [ 29.12 GB ]
CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000
RNID : BC799162BBB626A78D986D0352D9BEF4
DA : USB : HIGH-SPEED
Boot done!
Patch Level : N6F26Q
Ver. CodeName : REL
Ver. Release : 7.1.1
Sec. Patch : 2017-12-05
Build Time : 1516160346
Product Manfct : OPPO
Board Platform : mt6763
Product Model : OPPO CPH1723
Product Brand : OPPO
Product Name : CPH1723
Product Device : M6763A
Product Board : full_oppo6763_17031
Product Info : oppo6763_17031
SW Version : A.18
SW OTA Version : M6763A_11.A.18_0180_201801171019
SW OTA Name : CPH1723EX_11_A.18_180117
Display ID : CPH1723EX_11_A.18_180117
Kernel Info : 4.4.22-G201801171019
Done!
Elapsed: 00:00:20
Operation : Reset Settings/Format FS [ v2.00 r2 ]
MODE : BOOTROM
PORT : 9
BROM : Init BROM
BROM init passed!
BROM : BOOTROM
BROM : SLA
BROM : SLA Passed!
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : DEV : MT6763
EMI : CNT : 000F
EMMC:
Boot done!
ERR : 0xC002002A
ERR : SEC_IMG_TYPE_MISMATCH
ERR : 0x00001000|0x00001000
Error : Failed erase block!
Try select another format mode!
MODE : BOOTROM
PORT : 9
BROM : Init BROM
BROM init passed!
BROM : BOOTROM
BROM : SLA
BROM : SLA Passed!
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : DEV : MT6763
EMI : CNT : 000F
EMMC:
Boot done!
Format Ok : USERDATA
Format Ok : CACHE
Format Ok : RESET PROTECTION
Done!
Elapsed: 00:00:30
The Following 4 Users Say Thank You to djjeff 25 For This Useful Post:
Old 05-06-2018, 07:07   #49495 (permalink)
gsmgold_10's Avatar
Member: 1085634
Sonork: 1001650032
Thanks Meter: 46
thateamnks cm tool
USB Conf : mtp,adb
Sys USB : mtp,adb
FS Crypt : unencrypted
OEM Unlck : 1
Done!
Elapsed: 00:00:06
Operation : Reset FRP (ADB) [ v1.03 ]
Waiting for device in ADB mode ...
1. Connect device, enable 'DEVELOPER MODE' and 'USB DEBUG', if need!
2. Insert USB cable, accept AUTH on PhoneScreen, if software ask!
Connect Ok!
Device : j5xnltejv
Model : SM-J510F
FRP reset passed! Make FACTORY RESET from menu!
Done!
Elapsed: 00:00:11
thateamnks cm tool
Old 05-06-2018, 07:10   #49496 (permalink)
gsmgold_10's Avatar
Member: 1085634
Sonork: 1001650032
Thanks Meter: 46
thanks cm tool
USB Conf : mtp,adb
Sys USB : mtp,adb
OEM Unlck : 1
Done!
Elapsed: 00:00:06
Connect Ok!
Device : j5xnltejv
Model : SM-J510F
Done!
Elapsed: 00:00:11
Thanks cm tool team
Old 05-06-2018, 08:27   #49497 (permalink)
azhergoga007's Avatar
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Qmobile M95 SPD77xx Dead Set Re Alive Done By Flashing With Infinity CM2
Loading : last.pac
CRVersion : BP_R1.0.0
PacCPUinfo : SC7730_UMS
PacVersion : m95
FastCheck : 0x005360DB6E
Loading files ...
File : fdl1.bin
File : fdl2.bin
File : nvitem.bin
File : nvitem_wcn.bin
File : prodnv.img
File : u-boot-spl-16k.bin
File : SC7702_sc7731g_band128_SC2662H.bin
File : DSP_DM_G2.bin
File : SC8800G_x30g_wcn_dts_modem.bin
File : boot.img
File : recovery.img
File : system
File : userdata.img
File : hong1.bmp
File : hd720_kpoc_charge.bmp
File : cache.img
File : u-boot.bin
File : SC7730_UMS.xml
Load Ok!
Operation : Flash [ v1.27 ]
======= Flash
Files set for flashing :
[ MCU ] : last.pac
PacVersion : m95
File : fdl1.bin
File : fdl2.bin
File : nvitem.bin
File : prodnv.img
File : boot.img
File : recovery.img
File : system
File : userdata.img
File : hong1.bmp
File : cache.img
File : u-boot.bin
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
-> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key
3. Insert cable
Phone found! [ 268 ]
Port Opened
Sync...
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
PickUp loaders from pac
FDL Ready!
Boot Ver : Spreadtrum Boot Block version 1.1
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
PMTManager : Load 0x17 records
PMTManager : PMT Update Ok!
Flashing now
[FlashProc] : CODE
Current ID : PRODNV
Current File : prodnv.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID : ERASEUBOOT
Current Part : uboot
[FlashProc] : Ok!
[FlashProc] : BOOTCODE
Current ID : SPLLOADER
Current File : u-boot-spl-16k.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : MODEM_W
Current File : SC7702_sc7731g_band128_SC2662H.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : DSP_W
Current File : DSP_DM_G2.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : MODEM_WCN
Current File : SC8800G_x30g_wcn_dts_modem.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : BOOT
Current File : boot.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : RECOVERY
Current File : recovery.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : SYSTEM
Current File : system
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : USERDATA
Current File : userdata.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : BOOTLOGO
Current File : hong1.bmp
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : FASTBOOT_LOGO
Current File : hd720_kpoc_charge.bmp
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID : FLASH
Current Part : wruntimenv1
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID : FLASH_WCN
Current Part : wcnruntimenv1
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : CACHE
Current File : cache.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID : ERASEMISC
Current Part : misc
[FlashProc] : Ok!
Current ID : UBOOTLOADER
Current File : u-boot.bin
Flashing now ...
[FlashProc] : Ok!
Elapsed: 00:04:38
Old 05-06-2018, 09:16   #49498 (permalink)
Crazy Poster
Member: 874424
Thanks Meter: 15
Oppo a83 pattern lock frp lock
OPPO A83 PATTERN LOCK AND FRP LOCK DONE BY CM2 MTK MODULE VER 2.00 R2 SELECT OPPO F5 BOOT THEN GO TO SEVICE OPTION SELCT FULL FACTORY FORCED+FRP CONNECT PHONE IN OFF CONDITION PRESS VOLUME UP+DOWN JOB DONE IN 10 SECONDS ONLY THANKS CM2 TEAM FOR SUPPORT!
https://postimg.cc/image/z4su89yvr/
The Following User Says Thank You to iinsboy2 For This Useful Post:
Old 05-06-2018, 09:32   #49499 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Qmobile I5 MT6580 Full Momery Fix Done Only Formate With Infinity CM2
Card found : S/N : A19EC787 , v0136
Wait for phone...
Phone found! [ 8 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BB_CPU_NME : [MediaTek] MT6582_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x87
eMMC Flash : 90014A4834473164040501A180C25105
[eMMC] : FLASH_INF : [HYNIX] , d1G4
[eMMC] : FLASH_CID : 90014A4834473164040501A180C25105
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID : 0xD9C8F395B508CA85F5B55E6AA3205534
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:23
The Following User Says Thank You to azhergoga007 For This Useful Post:
Old 05-06-2018, 09:35   #49500 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Lenovo A1000 SPD77xx Logo Stuck Recover By Only Formate With Ininity CM2
Card found: S/N : A19EC787 , v0136
Chinese Miracle II [SPD module] v 1.27
Set mode to : SP [SC773x] eMMC [Generic 4.x-5.0]
Operation : Format File System / Reset Settings [ v1.27 ]
Settings : SmartFormat is On
3. Insert cable
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Boot Ver : SPRD 773x eMMC loader v3 Infinity
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
Detected eMMC Flash , Structure detect Ok!
eMMC phone detected! Will use 'Safe Format' mode!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Prepare Ok! Format Ok!
Don't touch phone, until it fully bootup to "Welcome Screen"!
Done!
Elapsed: 00:00:20
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Page generated in 0.94777 seconds with 11 queries
