Old 07-21-2018, 07:23   #51421 (permalink)
azhergoga007's Avatar
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Qmobile X30 MT6572 Hanging Probelam Fix Only Formate With Infinity CM2
Card found : S/N : A19EC787 , v0137
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 193 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x88
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A483447326111017D28E8807243
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , a2G4
[eMMC] : FLASH_CID : 90014A483447326111017D28E8807243
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID : 0xD9C8F3952EF7B2D37F370F85F9F85891
INT RAM : 0x00020000
EXT RAM : 0x20000000 [512 MiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:25
Reconnect Power/Cable!
The Following User Says Thank You to azhergoga007 For This Useful Post:
Old 07-21-2018, 08:32   #51422 (permalink)
Member: 442808
Thanks Meter: 195
Sucessfully Flash Samsung J2 Pro
Firmware Version: 0101
Phone found on COM11
Phone In Download mode...
Port open Ok!
LOKE received!
Prepare Ok!
Enter Setup...
Setup Done!
Try download PIT...
Download PIT Ok!
Start flashing!
Flashing spl.img
Flashing sboot.bin
Flashing sboot2.bin
Flashing param.lfs
Flashing boot.img
Flashing recovery.img
Flashing system.img
Flashing cache.img
Flashing hidden.img
Flashing SPRDWDSP.img
Flashing SPRDCP.img
Flashing SPRDGDSP.img
Flashing SPRDLTEDSP.img
Flashing nvitem.bin
Flashing PM_sharkl_arm7.bin
Flashing done
Reboot phone...
Phone Disconnected
The Following User Says Thank You to situ_saraf For This Useful Post:
Old 07-21-2018, 08:40   #51423 (permalink)
Akhtar Ali Jatt's Avatar
Member: 953334
Sonork: 100.1614005
Thanks Meter: 15,420
Smile Qmobile C10 User Code Reset Done
Set mode to : SPD6531
Operation : Format File System / Reset Settings [ v1.27 ]
Settings : SmartFormat is On
1. Remove battery. Insert USB cable
2. Press and hold BootKey ( Skip, if use BootCable )
3. Insert battery
==== Wait for phone...
Phone found! [ 243 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending boot ...
Boot Sent , starting...
Boot Ver : Spreadtrum Boot Block version 1.2
Boot Ok
CPU ID : 6531 , FDLStat : 0100
[0] Flash DIE : 00EF 0040 0016 0000
[0] Flash VEN : Winbond , W25Q32
[0] Flash CAP : 00400000
Verify data... Can take some time
Init Ok, formatting DIN area ...
Format Block Done!
Done!
Elapsed: 00:00:08
Old 07-21-2018, 08:47   #51424 (permalink)
Member: 1505730
Sonork: 100.1618029
Thanks Meter: 207
disko mate 7 firmware read done
Phone found! [ 4 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ok
[0] Flash DIE : 00EF 0060 0018 0000
[0] Flash VEN : Winbond , W25Q128
[0] Flash CAP : 01000000
Read Flash Content
Read Ok , collect info
Platform : MOCOR_12B_6531.W13.07_Release
Project : SC6716_PDA
HWInfo : SC6716_PDA
Compile : 07-09-2015 14:09:06
Set FileInfo :
Model Vendor : spd6531
Model Name : disko
Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_01000000_MO COR_12B_6531.W13.07_Release_07092015140906__spd653 1-disko.bin
Done!
Elapsed: 00:01:48
The Following User Says Thank You to bikku.gupta For This Useful Post:
Old 07-21-2018, 09:16   #51425 (permalink)
Member: 1280685
Thanks Meter: 59
Thumbs up Vivo Y71 1801 Pattern Lock
Dev Info:
Operation : Identify [ v1.16 ]
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
ID_BLOCK_I : SnapDragon 425 [MSM8917]
ID_BLOCK_S : C7BF8D6B
ID_BLOCK_L : D40328CB56D91634C02840D24E6DC192
ID_BLOCK_L : 98DD57AA5AA88F3899D62A7BD4380D4F
Use CM2 Internal Loader
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8917 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ]
ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200
Storage : MFR : 0x90 , VENDOR : HYNIX , NAME : HAG4a2
Boot Ok!
Brand     : vivo
ProdName  : msm8937_64
ProdModel : vivo 1724
Device    : msm8937_64
AndroidVer: 8.1.0
Manufact. : vivo
SysPatch  : OPM1.171019.011
DevComTime: 6/15/2018 12:05:07 PM
USERData : ENCRYPTED
GCSec    : NORMAL
Done!
Elapsed: 00:00:14
Reset Settings / Format:
Operation : Reset Settings [ v1.16 ]
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
Boot Ok!
Format USER ...
Format CACHE ...
Format Ok!
Remove FRP
Reset Ok!
Done!
Elapsed: 00:00:40
Old 07-21-2018, 10:13   #51426 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Qmobile I8i SPD77xx FRP Reset Done With Infinity CM2
Card found: S/N : A19EC787 , v0137
Chinese Miracle II [SPD module] v 1.27
Set mode to : SP [SC773x] eMMC [Android 6.x]
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
-> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key
3. Insert cable
Phone found! [ 101 ]
Port Opened
Sync...
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SC7731 Crev eMMC Loader v2.0
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
Detected eMMC Flash , Structure detect Ok!
eMMC phone detected! Will use 'Safe Format' mode!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Prepare Ok! Format Ok!
Don't touch phone, until it fully bootup to "Welcome Screen"!
Android 5.x/6.x : Reset FRP Lock
Reset Ok!
Done!
Elapsed: 00:00:22
Old 07-21-2018, 10:46   #51427 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Qmobile M350 Pro MT6580 FRP Reset Done With Infinity CM2
Wait for phone...
Phone found! [ 102 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x94
eMMC Flash : 150100514531334D420DC07B9BCA6435
[eMMC] : FLASH_INF : [SAMSUNG] , BM31E
[eMMC] : FLASH_CID : 150100514531334D420DC07B9BCA6435
[eMMC] : FLASH_LEN : 0x00000003A3E00000
[eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB]
DEV RID : 0xD9C8F395350245CF3AFC84CCB491CCC6
EXT RAM : 0x80000000 [2 GiB]
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:43
Old 07-21-2018, 11:50   #51428 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Haier Jazz Tab J1000 MT6582 FRP Reset Done With King Infinity CM2
Wait for phone...
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 7C0100454D533030383A0F0C0306C2AD
[eMMC] : FLASH_VEN : 0x7C , OEM : 0100
[eMMC] : FLASH_INF : [NOT_IN_BASE] , 800SM
[eMMC] : FLASH_CID : 7C0100454D533030383A0F0C0306C2AD
[eMMC] : FLASH_LEN : 0x00000001CCD80000
[eMMC] : FLASH_UCP : 7373 MiB [eMMC 8 GiB]
DEV RID : 0xD9C8F3958D51C2140E979279DDAF5EE5
EXT RAM : 0x40000000 [1 GiB]
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:49
Old 07-21-2018, 13:11   #51429 (permalink)
Luckey1's Avatar
Member: 2197212
Sonork: N/A
Thanks Meter: 680
Huawei chm-u01 flash
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BB_CPU_NME : [MediaTek] MT6582_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x87
eMMC Flash : 90014A4841473265040201A2C0BF7037
[eMMC] : FLASH_INF : [HYNIX] , e2GA
[eMMC] : FLASH_CID : 90014A4841473265040201A2C0BF7037
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000
[eMMC] : FLASH_LEN : 0x00000003AB800000
[eMMC] : FLASH_UCP : 15032 MiB [eMMC 16 GiB]
DEV RID : 0x53BEF99B40AB658504EE54CD8D56B5DA
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6582 , Project : mbk82_wet_kk , Storage : EMMC
Setting : AFF verify : Disabled
Setting : HW verify : Enabled
BL : Check HW compatibility
BL : Skip checking by User request!
BL : BatteryLevel : 3957 mV
BL : BatteryLevel Ok
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000001400000-0x0000000000100000
Erase : 0x0000000003100000-0x00000001CE600000
Flash Pre-Erase Done, time used : 00:00:04
SecCfg Passed , 1799
BMT remark not need. Will skip
Preloader Download skipped by user request!
PartCount : 0012
Update PMT by user request
Repartition Done!
Use FLN Mode
Processing : Flash Write
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:03:07
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:03:26
Old 07-21-2018, 13:11   #51430 (permalink)
Luckey1's Avatar
Member: 2197212
Sonork: N/A
Thanks Meter: 680
Qmobile s1 flash
======= Flash
Wait for phone...
Phone found! [ 7 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 90014A483847316505071D10C4E85295
[eMMC] : FLASH_INF : [HYNIX] , e1G8
[eMMC] : FLASH_CID : 90014A483847316505071D10C4E85295
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID : 0x53BEF99B86560CEF912BABC34BCF030C
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6582 , Project : s5222 , Storage : EMMC
BL : BatteryLevel : 3943 mV
Erase : 0x0000000000C00000-0x0000000000100000
Erase : 0x0000000002900000-0x00000001CEE00000
Flash Pre-Erase Done, time used : 00:00:05
PartCount : 0012
Repartition Done!
Use FLN Mode
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:03:45
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:04:05
Old 07-21-2018, 13:13   #51431 (permalink)
Luckey1's Avatar
Member: 2197212
Sonork: N/A
Thanks Meter: 680
Huawei y520 u22 formate done
Wait for phone...
Phone found! [ 5 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
Processing DA stage
eMMC Flash : 90014A4834473261110242B0D66013E7
DRAM configured from IDB!
DRAM initialize passed!
DRAM size : 0x20000000
[eMMC] : FLASH_CID : 90014A4834473261110242B0D66013E7
DEV RID : 0x53BEF99BC3C274257A32A7BBD02F928D
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:33
Old 07-21-2018, 13:24   #51432 (permalink)
Member: 2125922
Sonork: 1601402
Thanks Meter: 112
Infinik hot x556 frp rest done with cm2
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6737
BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x93
eMMC Flash : 510001154D33314598B30D427F0821F4
[eMMC] : FLASH_CID : 150100514531334D420DB398F421B37F
DEV RID    : 0x53BEF99B8C90E3D483C67E113324CF0B
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Done!
Elapsed: 00:00:21
Old 07-21-2018, 13:25   #51433 (permalink)
Member: 2125922
Sonork: 1601402
Thanks Meter: 112
Qmobile a290 flash done with cm2 mtk
======= Flash
Wait for phone...
Phone found! [ 7 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 90014A483447326111014196E5AB625F
[eMMC] : FLASH_CID : 90014A483447326111014196E5AB625F
DEV RID    : 0x53BEF99BA6B02A657A453BFE53F16530
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6572 , Project : s5201ap , Storage : EMMC
BL : BatteryLevel : 4080 mV
Erase : 0x0000000002900000-0x00000000E5E00000
Flash Pre-Erase Done, time used : 00:00:10
PartCount : 0012
Repartition Done!
Use FLN Mode
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:02:45
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:03:22
Old 07-21-2018, 13:27   #51434 (permalink)
Member: 2311967
Thanks Meter: 122
Micromax A106 Format Done By Infinity CM2
Wait for phone...
Phone found! [ 5 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 90014A4838473264040501A1F635713B
[eMMC] : FLASH_INF : [HYNIX] , d2G8
[eMMC] : FLASH_CID : 90014A4838473264040501A1F635713B
DEV RID : 0x97F8A39E6DD2EB1FB9460A11E9E0C50E
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:24
The Following 2 Users Say Thank You to webtrack For This Useful Post:
Old 07-21-2018, 13:29   #51435 (permalink)
Member: 2125922
Sonork: 1601402
Thanks Meter: 112
Qmobile s3 flash done with cm2 mtk
======= Flash
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 90014A4834473164040502A1B82C819D
[eMMC] : FLASH_INF : [HYNIX] , d1G4
[eMMC] : FLASH_CID : 90014A4834473164040502A1B82C819D
DEV RID    : 0x53BEF99BD5BE2FCBEFE27E4B18BAB54E
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6582 , Project : wiko , Storage : EMMC
Setting : AFF verify :  Enabled
BL : BatteryLevel : 3702 mV
PartCount : 0012
Repartition Done!
Use FLN Mode
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:02:22
Processing : Verify
Verify Passed : MBR
Verify Passed : EBR1
Verify Passed : UBOOT
Verify Passed : BOOTIMG
Verify Passed : RECOVERY
Verify Passed : SEC_RO
Verify Passed : LOGO
Verify Passed : ANDROID
Verify Passed : CACHE
Verify Passed : USRDATA
Data Verify Done, time used : 00:00:37
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:03:22
:cool:
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Page generated in 0.71725 seconds with 10 queries
