03-18-2019, 06:55 | #57556 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Kv k400 reset password done by cm2 Card found : S/N : 73CA70CC , v0137 Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 8 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CA02 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 3121620BE73452CFB7694DA52EB7AA5C BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0112 , [MXIC] MX25L3291FWJI_09 [0] : FLASH_DIE : 00C2 0020 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 File_Info : HONGYU61M_11C_PCB01_gprs_MT6261_S00.C219H_KW_KV100 _V06_20171219.bin FileVersion : C219H_KW_KV100_V06_20171219 Done! Elapsed: 00:00:08 Reconnect Power/Cable! Operation : Reset UserCode [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 8 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CA02 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 3121620BE73452CFB7694DA52EB7AA5C BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0112 , [MXIC] MX25L3291FWJI_09 [0] : FLASH_DIE : 00C2 0020 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Backup done Read ExtData Sorting ExtData Sort Ok, Rebuild Ok Restore ExtData All done UserCode request removed UserCode set to default ( 0000 or 1122 ) Done! Elapsed: 00:00:13 Reconnect Power/Cable! |
03-18-2019, 07:33 | #57557 (permalink) |
No Life Poster Join Date: May 2008
Member: 770503 Status: Offline Thanks Meter: 1,215 | Symphony V140 Code: Operation : Reset Settings/Format FS [ v2.05 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM8) MODE : BOOTROM PORT : 8 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000001 BROM : SecMode : SBC BROM : BOOTROM MODE : 0_base : BASE_v1844 | Manual : Disabled Fail to disable Dog! AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 460001154D32364E7B31034223A46AF2 DAInf: 4 : 2 : 156 DA : EXT_RAM NOT initialized! eMMC : OK eMMC : 150100464E36324D4203317BF26AA423 NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 EMI : DEV : INFINITY EMI : SRC : INFINITY-BOX_INTERNAL_EMIDB_v0 INIT : 0xBC : LP/DDR3 [ 0x00000000 : [ 0 B ] ] DRAM : DRAM: 0x40000000 [ 1.00 GB ] DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 150100464E36324D4203317BF26AA423 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FN62MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00080000 [ 512.00 KB ] USER : 0x1D2000000 [ 7.28 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : B98A2638462125CDAE3B42F6AF0E0A3 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : FULL-SPEED DA : USB : Change Port Speed PTFN : MediaTek DA USB VCOM (Android) (COM9) MODE : PRELOADER PORT PORT : 9 Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:19 Reconnect Power/Cable! |
03-18-2019, 07:43 | #57558 (permalink) |
No Life Poster Join Date: Sep 2006 Location: ---> Hope
Member: 355782 Status: Offline Thanks Meter: 1,265 | oppo f1s imei repair done. Code: Operation : Repair Security [ v2.05 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM9) MODE : BOOTROM PORT : 9 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000001 BROM : SecMode : SBC BROM : BOOTROM MODE : 0_base : BASE_v1844 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6755 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : INFINITY-BOX_INTERNAL_EMIDB_v0 EMI : CNT : 0008 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: 13014E51334A3937561002DD47DA319 EMMC: VEN : MICRON | OEM : 4E01 | DEV : Q3J97V EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6750 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 9EDA1A00187B39835DCDA6B147573840 DA : USB : FULL-SPEED DA : USB : Change Port Speed PTFN : MediaTek DA USB VCOM (Android) (COM10) MODE : PRELOADER PORT PORT : 10 Boot done! Old Data : IMEI[0] : 86xx IMEI[1] : 86xx NVRAM check : Passed! New Data : IMEI[0] : 35xxxx IMEI[1] : 35xxxx NVM_LID : updated! Update NVRAM ... Update dependencies ... Done! Elapsed: 00:00:17 Reconnect Power/Cable! |
03-18-2019, 08:48 | #57559 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile I6 Metal 1 MT6580 FRP Reset Done With King Infinity CM2 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 258 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 90014A48384731650507326B459743FD Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e1G8 [eMMC] : FLASH_CID : 90014A48384731650507326B459743FD [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xD9C8F3956E93E6F245D03234F5F9C32F INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:37 Reconnect Power/Cable! |
03-18-2019, 09:19 | #57560 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Lava Iris 50 MT6580 FRP Reset Done With King Infinity CM2 Card found : S/N : A19EC787 , v0137 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 131 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100464E36324D4203DBC0B4EEA401 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM26N [eMMC] : FLASH_CID : 150100464E36324D4203DBC0B4EEA401 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xD9C8F39525D0DC1AB54D0CA676CB1969 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:32 Reconnect Power/Cable! |
03-18-2019, 09:19 | #57561 (permalink) |
No Life Poster Join Date: Apr 2016 Location: B A N G L A D E S H
Member: 2556542 Status: Offline Thanks Meter: 1,790 | mango s5 mt6739 secure phone flashing done Code: Operation : Write Flash [ v2.05 ] Repartition : Disabled Flash Verify : Disabled Reg.Pre-Erase : Disabled Verify HW/SW : Disabled SData Backup : Disabled Safe UserData : Disabled Files :19 [FL] : Set : preloader_bird6739tv1_bsp_1g.bin [FL] : Set : recovery.img [FL] : Set : md1img.img [FL] : Set : md1dsp.img [FL] : Set : spmfw.img [FL] : Set : mcupmfw.img [FL] : Set : lk.img [FL] : Set : lk.img [FL] : Set : loader_ext.img [FL] : Set : loader_ext.img [FL] : Set : boot.img [FL] : Set : logo.bin [FL] : Set : odmdtbo.img [FL] : Set : tee.img [FL] : Set : tee.img [FL] : Set : vendor.img [FL] : Set : system.img [FL] : Set : cache.img [FL] : Set : userdata.img [FL] : Total size : 0x57AB99F0 [ 1.37 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : PreLoader USB VCOM Port (COM20) MODE : PRELOADER PORT PORT : 20 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : 0_base : BASE_v1812 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] EMMC: 8801034E4361726420162509452225E3 EMMC: VEN : FORESEE | OEM : 301 | DEV : NCard EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x1D2000000 [ 7.28 GB ] CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 6C8E59EC1A0FD4144DF0C5F7D5520223 DA : USB : HIGH-SPEED Boot done! SEC_DL : False (RAPHAEL) OK SEC_ID : 0x494E46494E495459424F584245535432 [FL] : Flashing now ... Write : PRELOADER Update bootloader backup copy ... Update bootloader backup copy Ok! Write : RECOVERY Write : MD1IMG Write : MD1DSP Write : SPMFW Write : MCUPMFW Write : LK Write : LK2 Write : LOADER_EXT1 Write : LOADER_EXT2 Write : BOOT Write : LOGO Write : ODMDTBO Write : TEE1 Write : TEE2 Write : VENDOR Write : SYSTEM Write : CACHE Write : USERDATA [FL] : Flashing finished! Done! Elapsed: 00:01:25 Reconnect Power/Cable! |
The Following User Says Thank You to kothamamun For This Useful Post: |
03-18-2019, 09:24 | #57562 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile S6s MT6580 FRP Reset Done WIth King Infinity CM2 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 131 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 13014E52314A39364E1054CFC0EE223D [WARNING] : MEMORY_eMMC_VALIDATE_FAILED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x13 , OEM : 014E [eMMC] : FLASH_INF : [NOT_IN_BASE] , N69J1 [eMMC] : FLASH_CID : 13014E52314A39364E1054CFC0EE223D [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB400000 [eMMC] : FLASH_UCP : 15028 MiB [eMMC 16 GiB] DEV RID : 0xD9C8F395BD98E6F11B286EB6696CB955 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:23 Reconnect Power/Cable! |
03-18-2019, 09:28 | #57563 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile M350 MT6580 FRP Reset Done With King Infinity CM2 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 258 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100514531334D420DDA7AC26DC355 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM31E [eMMC] : FLASH_CID : 150100514531334D420DDA7AC26DC355 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xD9C8F3954AD2DF9FE00EC221D5E8D481 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:11 Reconnect Power/Cable! |
03-18-2019, 12:12 | #57564 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | China JiaXin Jx3 MT6572 NAND Logo Stuck Fix Only Formate With King Infinity CM2 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 258 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8B00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : 002C00BC009000550056000000000000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0091 , [Micron] NAND_MT29C4G48MAAHBAAKS_5WT [NAND] : FLASH_DIE : 002C 00BC 0090 0055 0056 0000 0000 [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 0800/0040/01/NIM_Px-2 DEV RID : 0xD9C8F395B7AB5FBA96CA0FEB29BF2D11 INT RAM : 0x00020000 EXT RAM : 0x10000000 [256 MiB] BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:12 Reconnect Power/Cable! |
03-18-2019, 12:26 | #57565 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Motorolla XT1254 QLM FRP Reset Done With King Infinity CM2 Infinity-Box Android Service Tool [AST] v1.03 Operation : Moto ADB Enable [ v1.03 ] Mode : Enable ADB Waiting for NetInterface arrival ... 1. Power off device. Press and hold 'VOL DOWN' and 'POWER ON' buttons 2. Select by 'VOL DOWN' or 'VOL UP' FACTORY MODE , press 'POWER ON' 3. Connect USB cable, when device boot complete! Connect Ok! Waiting ... Trying link with : 192.168.137.2 Connected to device! Device : XT1254 Switching to FACTORY ... Setting Unsecure mode Waiting device ... Connect Ok! Trying link with : 192.168.137.2 Connected to device! Device : XT1254 Setting ADB ... Waiting device ... Connect Ok! Trying link with : 192.168.137.2 Connected to device! Device : XT1254 Setting ADB ... 1. Disconnect cable from device, wait device reboot 2. Make "Reset FRP" 3. Disable "FACTORY MODE" after operations done! Done! Elapsed: 00:00:35 Operation : Reset FRP (ADB) [ v1.03 ] Waiting for device in ADB mode ... 1. Connect device, enable 'DEVELOPER MODE' and 'USB DEBUG', if need! 2. Insert USB cable, accept AUTH on PhoneScreen, if software ask! Connect Ok! Device : quark_verizon Model : XT1254 FRP reset passed! Make FACTORY RESET from menu! -- > MOTO FRP : Don't forget to DISABLE FACTORY MODE! Done! Elapsed: 00:00:17 |
03-18-2019, 12:39 | #57566 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | SeAShark MX2 Operation : Read FullFlash [ v1.27 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 16 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Detected eMMC Flash , Structure detect Ok! [FW_READER] : Prepare Ok! - > Wait phone connected ... Phone found! [ 16 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! - > Wait phone connected ... Phone found! [ 16 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! Model Name : MX2 Model Brand : Seashark Model Device: MX2 AndrVersion : 6.0 BaseBand CPU: SP7731CEB Project Ver : AD198_A_BP311_Seashark_MX2_Battery12_V1.0_20180925 Model Ext : MX2 [Read Mode] : HSUSB : 0x3000 [FW_READER] : Reading Firmware Now ... [Read Ok] : u-boot-spl-16k.bin [Read Ok] : u-boot.bin [Read Ok] : prodnv.img [Read Ok] : sc7731C_CP0_modem.bin [Read Ok] : DSP_DM_Gx.bin [Read Ok] : nvitem_w.bin [Read Ok] : sc8830g_modem_CP2_WCN_Trunk_W17.27.4_Release.bin [Read Ok] : nvitem_wcn.bin [Read Ok] : logo_480x854.bin [Read Ok] : fblogo_480x854.bin [Read Ok] : boot.img [Read Ok] : system.img [Read Ok] : sysinfo.img [Build Ok] : cache.img [Read Ok] : recovery.img [Build Ok] : userdata.img AndroidInfo created Firmware Size : 1878 MiB Saved to : C:\Users\AkhtarAli\Desktop\SP7731CEB_MX2_6.0_AD198 _A_BP311_Seashark_MX2_Battery12_V1.0_20180925_MX2\ Done! Elapsed: 00:05:57 Reconnect Power/Cable! |
03-18-2019, 12:47 | #57567 (permalink) |
Member: 770503 Status: Offline Thanks Meter: 1,215 | SYMPHONY v85 Code: Operation : Flash [ v1.27 ] ======= Flash Files set for flashing : [ MCU ] : SC77xx Infinity Package 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 14 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SPRD 773x eMMC loader v4 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! PMTManager : Load 0x17 records PMTManager : PMT Update Ok! Flashing now Update BootCode : u-boot-spl-16k.bin Write Data ... Write Data Ok! Update BootCode : u-boot.bin Erase block ... Block erase Ok! Write Data ... Write Data Ok! Write FSImage : prodnv.img Write Data ... Write Data Ok! Write CodeData : sc7731g_CP0_modem.bin Write Data ... Write Data Ok! Write CodeData : DSP_DM_Gx.bin Write Data ... Write Data Ok! Erase Block : RuntimeData Erase block ... Block erase Ok! Write CodeData : sc8830g_modem_CP2_WCN_14D_W15.31.1_Release.bin Write Data ... Write Data Ok! Erase Block : RuntimeData Erase block ... Block erase Ok! Write CodeData : logo_540x960.bin Write Data ... Write Data Ok! Write CodeData : fblogo_540x960.bin Write Data ... Write Data Ok! Write CodeData : boot.img Write Data ... Write Data Ok! Write FSImage : system.img Write Data ... Write Data Ok! Write FSImage : cache.img Write Data ... Write Data Ok! Write CodeData : recovery.img Write Data ... Write Data Ok! Erase Block : MISC Erase block ... Block erase Ok! Write FSImage : userdata.img Write Data ... Write Data Ok! Elapsed: 00:08:31 Reconnect Power/Cable! |
03-18-2019, 13:02 | #57568 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Qmobile I6 Metal One Format Done Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 75 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x0000000117FF7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:34 Reconnect Power/Cable! |
03-18-2019, 14:08 | #57570 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | QMOBILE X700i HANG ON LOGO DONE BY CM2 Card found : S/N : 73CA70CC , v0137 Chinese Miracle II [MTK module] v 1.58 Scatter Load Ok , BaseBand : MT6580 , Project : d5110_qmobile , Storage : EMMC Files found : 9 , Set to Flash : 8 Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : QMobile Device Model : d5110_qmobile Device CPU : MT6580 Device IntName : d5110_qmobile Device Version : 5.1 Device Compile : 7/17/2015 12:51:50 PM Device Project : ALPS.L1.MP6.V2_RGK6580.WE.L_P2 Device ExtInfo : QMobile X700i Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 15 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100523832314D4200E003CA6E722B Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM128 [eMMC] : FLASH_CID : 150100523832314D4200E003CA6E722B [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x0CF2E6DE176B77EE19AD1C77DEB15E93 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6580 , Project : d5110_qmobile , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3550 mV BL : [WARNING] : BatteryLevel LOW!!! BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000001C80000-0x0000000003320000 Erase : 0x00000000050A0000-0x000000039DCE0000 Flash Pre-Erase Done, time used : 00:00:08 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_d5110_qmobile.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0014 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : LK Image Flash Ok Flash now : BOOT Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : SECRO Image Flash Ok Flash now : SYSTEM Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USERDATA Image Flash Ok Flash Write Done, time used : 00:08:34 Processing : Verify Verify Passed : LK Verify Passed : BOOT Verify Passed : RECOVERY Verify Passed : LOGO Verify Passed : SECRO Verify Passed : SYSTEM Verify Passed : CACHE Verify Passed : USERDATA Data Verify Done, time used : 00:00:03 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:08:57 Reconnect Power/Cable! |
