Old 03-18-2019, 06:55   #57556 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,773
Kv k400 reset password done by cm2
Card found : S/N : 73CA70CC , v0137
Operation : Check / Read Info [ v1.58 ]
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 8 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CA02
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6261_S0000
BB_CPU_SN : 3121620BE73452CFB7694DA52EB7AA5C
BROM Protocol Version : 05
Setting...
Setting done , result code 0x000E
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x0112 , [MXIC] MX25L3291FWJI_09
[0] : FLASH_DIE : 00C2 0020 0016 0000
[0] : FLASH_LEN : 0x00400000
SDS_INFO : 0x003FE000 , 0x00002000
INT_RAM : 0x0000D000
EXT_RAM : 0x00400000
File_Info : HONGYU61M_11C_PCB01_gprs_MT6261_S00.C219H_KW_KV100 _V06_20171219.bin
FileVersion : C219H_KW_KV100_V06_20171219
Done!
Elapsed: 00:00:08
Reconnect Power/Cable!
Operation : Reset UserCode [ v1.58 ]
Wait for phone...
Phone found! [ 8 ]
Sync...
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CA02
BB_CPU_SW : 0001
BB_CPU_SB : 8000
Setting...
BROM stage done
SOC_VERIFY : 0xC1
Backup done
Read ExtData
Sorting ExtData
Sort Ok, Rebuild Ok
Restore ExtData
All done
UserCode request removed
UserCode set to default ( 0000 or 1122 )
Done!
Elapsed: 00:00:13
Old 03-18-2019, 07:33   #57557 (permalink)
mbiborna's Avatar
Member: 770503
Thanks Meter: 1,215
Symphony V140
Operation : Reset Settings/Format FS [ v2.05 ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek USB Port (COM8)
MODE : BOOTROM
PORT : 8
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
     CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
     TYPE : LEGACY MTK
BROM : SecLevel : 0x00000001
BROM : SecMode  : SBC
BROM : BOOTROM
MODE : 0_base : BASE_v1844 | Manual : Disabled
Fail to disable Dog!
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6580
AGENT : MTK_DOWNLOAD_AGENT
     BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
     DA : AGENT started!
NAND : DEVICE NOT FOUND
NAND : 000000000000000000000000
eMMC : OK
eMMC : 460001154D32364E7B31034223A46AF2
DAInf: 4 : 2 : 156
DA : EXT_RAM NOT initialized!
eMMC : OK
eMMC : 150100464E36324D4203317BF26AA423
     EMI : DEV : INFINITY
     EMI : SRC : INFINITY-BOX_INTERNAL_EMIDB_v0
INIT : 0xBC : LP/DDR3 [ 0x00000000 :  [ 0 B ] ]
DRAM : DRAM: 0x40000000 [ 1.00 GB ]
     DA : DRAM ready!
DA : BOOT to 2nd DA ...
DA : Receiving HW info
        EMMC: 150100464E36324D4203317BF26AA423
        EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FN62MB
        EMMC:
              BOOT1  : 0x00400000 [ 4.00 MB ]
              BOOT2  : 0x00400000 [ 4.00 MB ]
              RPMB   : 0x00080000 [ 512.00 KB ]
              USER   : 0x1D2000000 [ 7.28 GB ]
        SRAM: 0x00020000 [ 128.00 KB ]
        CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
        RNID : B98A2638462125CDAE3B42F6AF0E0A3
 STATUS : BLANK FLASH
 BSTYLE : EMMC FLASH BOOT
DA : USB : FULL-SPEED
DA : USB : Change Port Speed
PTFN : MediaTek DA USB VCOM (Android) (COM9)
MODE : PRELOADER PORT
PORT : 9
Boot done!
Format Ok : RESET PROTECTION
Done!
Elapsed: 00:00:19
Old 03-18-2019, 07:43   #57558 (permalink)
Nasir Mobiles's Avatar
Member: 355782
Thanks Meter: 1,265
oppo f1s imei repair done.
Operation : Repair Security [ v2.05 ]
PTFN : MediaTek USB Port (COM9)
MODE : BOOTROM
PORT : 9
BROM : Init BROM
BROM init passed!
     CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001
     TYPE : MODERN RAPHAEL
BROM : BOOTROM
AGENT : Found MT6755
BROM : DA sent
     DA : AGENT started!
DA : SYNC
     DA : MODE : BROM
     EMI : CNT : 0008
     EMI : Init EMI from INTERNAL DB
     EMI : EXT_RAM CFG Passed!
DA : 2ND stage confirmed!
DA : SYNC with DA passed!
        SRAM: 0x00040000 [ 256.00 KB ]
        DRAM: 0xC0000000 [ 3.00 GB ]
        EMMC: 13014E51334A3937561002DD47DA319
        EMMC: VEN : MICRON | OEM : 4E01 | DEV : Q3J97V
        EMMC:
              RPMB   : 0x00400000 [ 4.00 MB ]
              USER   : 0x747C00000 [ 29.12 GB ]
        CHIP : MT6750 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000
        RNID : 9EDA1A00187B39835DCDA6B147573840
PTFN : MediaTek DA USB VCOM (Android) (COM10)
PORT : 10
Boot done!
Old Data :
IMEI[0] : 86xx
IMEI[1] : 86xx
NVRAM check : Passed!
New Data :
IMEI[0] : 35xxxx
IMEI[1] : 35xxxx
NVM_LID : updated!
Update NVRAM ...
Update dependencies ...
Done!
Elapsed: 00:00:17
Old 03-18-2019, 08:48   #57559 (permalink)
azhergoga007's Avatar
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Qmobile I6 Metal 1 MT6580 FRP Reset Done With King Infinity CM2
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 258 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x94
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A48384731650507326B459743FD
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , e1G8
[eMMC] : FLASH_CID : 90014A48384731650507326B459743FD
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID : 0xD9C8F3956E93E6F245D03234F5F9C32F
INT RAM : 0x00020000
EXT RAM : 0x40000000 [1 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:37
Old 03-18-2019, 09:19   #57560 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Lava Iris 50 MT6580 FRP Reset Done With King Infinity CM2
Card found : S/N : A19EC787 , v0137
Wait for phone...
Phone found! [ 131 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 150100464E36324D4203DBC0B4EEA401
[eMMC] : FLASH_INF : [SAMSUNG] , BM26N
[eMMC] : FLASH_CID : 150100464E36324D4203DBC0B4EEA401
DEV RID : 0xD9C8F39525D0DC1AB54D0CA676CB1969
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:32
Old 03-18-2019, 09:19   #57561 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 1,790
mango s5 mt6739 secure phone flashing done
Operation : Write Flash [ v2.05 ]
Repartition   : Disabled
Flash Verify  : Disabled
Reg.Pre-Erase : Disabled
Verify HW/SW  : Disabled
SData Backup  : Disabled
Safe UserData : Disabled
Files :19
[FL] : Set : preloader_bird6739tv1_bsp_1g.bin
[FL] : Set : recovery.img
[FL] : Set : md1img.img
[FL] : Set : md1dsp.img
[FL] : Set : spmfw.img
[FL] : Set : mcupmfw.img
[FL] : Set : lk.img
[FL] : Set : lk.img
[FL] : Set : loader_ext.img
[FL] : Set : boot.img
[FL] : Set : logo.bin
[FL] : Set : odmdtbo.img
[FL] : Set : tee.img
[FL] : Set : vendor.img
[FL] : Set : system.img
[FL] : Set : cache.img
[FL] : Set : userdata.img
[FL] : Total size : 0x57AB99F0 [ 1.37 GB ]
PTFN : PreLoader USB VCOM Port (COM20)
PORT : 20
PRELOADER : ACK confirmed!
BROM : Init BROM
BROM init passed!
     CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002
BROM : SecLevel : 0x00000000
BROM : SecMode  : PLAIN [+PRL]
BROM : PRELOADER PORT
MODE : 0_base : BASE_v1812 | Manual : Disabled
AGENT : Found MT6739
BROM : DA sent
     DA : AGENT started!
DA : SYNC
     DA : MODE : PRELOADER
DA : EXT_RAM initialized!
        EMMC: 8801034E4361726420162509452225E3
        EMMC: VEN : FORESEE | OEM : 301 | DEV : NCard
        EMMC:
        CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000
        RNID : 6C8E59EC1A0FD4144DF0C5F7D5520223
DA : USB : HIGH-SPEED
Boot done!
SEC_DL : False (RAPHAEL)
OK
SEC_ID : 0x494E46494E495459424F584245535432
[FL] : Flashing now ...
Write : PRELOADER
Update bootloader backup copy ...
Update bootloader backup copy Ok!
Write : RECOVERY
Write : MD1IMG
Write : MD1DSP
Write : SPMFW
Write : MCUPMFW
Write : LK
Write : LK2
Write : LOADER_EXT1
Write : LOADER_EXT2
Write : BOOT
Write : LOGO
Write : ODMDTBO
Write : TEE1
Write : TEE2
Write : VENDOR
Write : SYSTEM
Write : CACHE
Write : USERDATA
[FL] : Flashing finished!
Done!
Elapsed: 00:01:25
The Following User Says Thank You to kothamamun For This Useful Post:
Old 03-18-2019, 09:24   #57562 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Qmobile S6s MT6580 FRP Reset Done WIth King Infinity CM2
Wait for phone...
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 13014E52314A39364E1054CFC0EE223D
[WARNING] : MEMORY_eMMC_VALIDATE_FAILED
[eMMC] : FLASH_VEN : 0x13 , OEM : 014E
[eMMC] : FLASH_INF : [NOT_IN_BASE] , N69J1
[eMMC] : FLASH_CID : 13014E52314A39364E1054CFC0EE223D
[eMMC] : FLASH_LEN : 0x00000003AB400000
[eMMC] : FLASH_UCP : 15028 MiB [eMMC 16 GiB]
DEV RID : 0xD9C8F395BD98E6F11B286EB6696CB955
EXT RAM : 0x80000000 [2 GiB]
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Done!
Elapsed: 00:00:23
Old 03-18-2019, 09:28   #57563 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Qmobile M350 MT6580 FRP Reset Done With King Infinity CM2
Wait for phone...
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 150100514531334D420DDA7AC26DC355
[eMMC] : FLASH_INF : [SAMSUNG] , BM31E
[eMMC] : FLASH_CID : 150100514531334D420DDA7AC26DC355
[eMMC] : FLASH_LEN : 0x00000003A3E00000
[eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB]
DEV RID : 0xD9C8F3954AD2DF9FE00EC221D5E8D481
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Done!
Elapsed: 00:00:11
Old 03-18-2019, 12:12   #57564 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
China JiaXin Jx3 MT6572 NAND Logo Stuck Fix Only Formate With King Infinity CM2
Wait for phone...
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
BB_CPU_EXT : 0xCA01 , 0x8B00 , 0x0000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x88
NAND Flash : 002C00BC009000550056000000000000
eMMC Flash : NOT INSTALLED
NAND FlashIC initialized
[NAND] : FLASH_VEN : 0x0091 , [Micron] NAND_MT29C4G48MAAHBAAKS_5WT
[NAND] : FLASH_DIE : 002C 00BC 0090 0055 0056 0000 0000
[NAND] : FLASH_LEN : 0x20000000
[NAND] : FLASH_EXT : 0800/0040/01/NIM_Px-2
DEV RID : 0xD9C8F395B7AB5FBA96CA0FEB29BF2D11
EXT RAM : 0x10000000 [256 MiB]
BOOT TYPE : NAND_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:12
Old 03-18-2019, 12:26   #57565 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Motorolla XT1254 QLM FRP Reset Done With King Infinity CM2
Infinity-Box Android Service Tool [AST] v1.03
Operation : Moto ADB Enable [ v1.03 ]
Mode : Enable ADB
Waiting for NetInterface arrival ...
1. Power off device. Press and hold 'VOL DOWN' and 'POWER ON' buttons
2. Select by 'VOL DOWN' or 'VOL UP' FACTORY MODE , press 'POWER ON'
3. Connect USB cable, when device boot complete!
Connect Ok!
Waiting ...
Trying link with : 192.168.137.2
Connected to device!
Device : XT1254
Switching to FACTORY ...
Setting Unsecure mode
Waiting device ...
Connect Ok!
Device : XT1254
Setting ADB ...
Waiting device ...
Connect Ok!
Device : XT1254
Setting ADB ...
1. Disconnect cable from device, wait device reboot
2. Make "Reset FRP"
3. Disable "FACTORY MODE" after operations done!
Done!
Elapsed: 00:00:35
Operation : Reset FRP (ADB) [ v1.03 ]
Waiting for device in ADB mode ...
1. Connect device, enable 'DEVELOPER MODE' and 'USB DEBUG', if need!
2. Insert USB cable, accept AUTH on PhoneScreen, if software ask!
Connect Ok!
Device : quark_verizon
Model : XT1254
FRP reset passed! Make FACTORY RESET from menu!
-- > MOTO FRP : Don't forget to DISABLE FACTORY MODE!
Done!
Elapsed: 00:00:17
Old 03-18-2019, 12:39   #57566 (permalink)
Akhtar Ali Jatt's Avatar
Member: 953334
Sonork: 100.1614005
Thanks Meter: 15,424
Smile SeAShark MX2
Operation : Read FullFlash [ v1.27 ]
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
-> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key
3. Insert cable
==== Wait for phone...
Phone found! [ 16 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SC7731 Crev eMMC Loader v2.0
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Detected eMMC Flash , Structure detect Ok!
[FW_READER] : Prepare Ok!
- > Wait phone connected ...
Phone found! [ 16 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Phone found! [ 16 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Model Name : MX2
Model Brand : Seashark
Model Device: MX2
AndrVersion : 6.0
BaseBand CPU: SP7731CEB
Project Ver : AD198_A_BP311_Seashark_MX2_Battery12_V1.0_20180925
Model Ext : MX2
[Read Mode] : HSUSB : 0x3000
[FW_READER] : Reading Firmware Now ...
[Read Ok] : u-boot-spl-16k.bin
[Read Ok] : u-boot.bin
[Read Ok] : prodnv.img
[Read Ok] : sc7731C_CP0_modem.bin
[Read Ok] : DSP_DM_Gx.bin
[Read Ok] : nvitem_w.bin
[Read Ok] : sc8830g_modem_CP2_WCN_Trunk_W17.27.4_Release.bin
[Read Ok] : nvitem_wcn.bin
[Read Ok] : logo_480x854.bin
[Read Ok] : fblogo_480x854.bin
[Read Ok] : boot.img
[Read Ok] : system.img
[Read Ok] : sysinfo.img
[Build Ok] : cache.img
[Read Ok] : recovery.img
[Build Ok] : userdata.img
AndroidInfo created
Firmware Size : 1878 MiB
Saved to : C:\Users\AkhtarAli\Desktop\SP7731CEB_MX2_6.0_AD198 _A_BP311_Seashark_MX2_Battery12_V1.0_20180925_MX2\
Done!
Elapsed: 00:05:57
Old 03-18-2019, 12:47   #57567 (permalink)
mbiborna's Avatar
Member: 770503
Thanks Meter: 1,215
SYMPHONY v85
Operation : Flash [ v1.27 ]
======= Flash
Files set for flashing :
[ MCU ] : SC77xx Infinity Package
3. Insert cable
Phone found! [ 14 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Boot Ver : SPRD 773x eMMC loader v4 Infinity
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
PMTManager : Load 0x17 records
PMTManager : PMT Update Ok!
Flashing now
Update BootCode : u-boot-spl-16k.bin
Write Data ...
Write Data Ok!
Update BootCode : u-boot.bin
Erase block ...
Block erase Ok!
Write Data ...
Write Data Ok!
Write FSImage : prodnv.img
Write Data ...
Write Data Ok!
Write CodeData : sc7731g_CP0_modem.bin
Write Data ...
Write Data Ok!
Write CodeData : DSP_DM_Gx.bin
Write Data ...
Write Data Ok!
Erase Block : RuntimeData
Erase block ...
Block erase Ok!
Write CodeData : sc8830g_modem_CP2_WCN_14D_W15.31.1_Release.bin
Write Data ...
Write Data Ok!
Erase block ...
Block erase Ok!
Write CodeData : logo_540x960.bin
Write Data ...
Write Data Ok!
Write CodeData : fblogo_540x960.bin
Write Data ...
Write Data Ok!
Write CodeData : boot.img
Write Data ...
Write Data Ok!
Write FSImage : system.img
Write Data ...
Write Data Ok!
Write FSImage : cache.img
Write Data ...
Write Data Ok!
Write CodeData : recovery.img
Write Data ...
Write Data Ok!
Erase Block : MISC
Erase block ...
Block erase Ok!
Write FSImage : userdata.img
Write Data ...
Write Data Ok!
Elapsed: 00:08:31
Old 03-18-2019, 13:02   #57568 (permalink)
Member: 953334
Sonork: 100.1614005
Smile Qmobile I6 Metal One Format Done
Operation : Format File System / Reset Settings [ v1.27 ]
Settings : SmartFormat is On
3. Insert cable
Phone found! [ 75 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
eMMC phone detected! Will use 'Safe Format' mode!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Prepare Ok! Format Ok!
Don't touch phone, until it fully bootup to "Welcome Screen"!
Android 5.x/6.x : Reset FRP Lock
Reset Ok!
Done!
Elapsed: 00:00:34
Old 03-18-2019, 14:08   #57569 (permalink)
Member: 635202
Thanks Meter: 10
Unlock solution
please help me unloc nokia lumia
this error image
tell me solution infinity best support
Old 03-18-2019, 14:08   #57570 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,773
QMOBILE X700i HANG ON LOGO DONE BY CM2
Scatter Load Ok , BaseBand : MT6580 , Project : d5110_qmobile , Storage : EMMC
Files found : 9 , Set to Flash : 8
Created by Infinity-Box (c) Chinese Miracle II (c) 2016
Device Brand : QMobile
Device Model : d5110_qmobile
Device CPU : MT6580
Device IntName : d5110_qmobile
Device Version : 5.1
Device Compile : 7/17/2015 12:51:50 PM
Device Project : ALPS.L1.MP6.V2_RGK6580.WE.L_P2
Device ExtInfo : QMobile X700i
Ready to Flash!
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 15 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 150100523832314D4200E003CA6E722B
[eMMC] : FLASH_INF : [SAMSUNG] , BM128
[eMMC] : FLASH_CID : 150100523832314D4200E003CA6E722B
DEV RID : 0x0CF2E6DE176B77EE19AD1C77DEB15E93
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6580 , Project : d5110_qmobile , Storage : EMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : BatteryLevel : 3550 mV
BL : [WARNING] : BatteryLevel LOW!!!
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000001C80000-0x0000000003320000
Erase : 0x00000000050A0000-0x000000039DCE0000
Flash Pre-Erase Done, time used : 00:00:08
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_d5110_qmobile.bin
Preloader Sent , Init passed
PartCount : 0014
Update PMT by user request
Repartition Done!
Use FLN Mode
Processing : Flash Write
Flash now : LK
Image Flash Ok
Flash now : BOOT
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : SECRO
Image Flash Ok
Flash now : SYSTEM
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USERDATA
Image Flash Ok
Flash Write Done, time used : 00:08:34
Processing : Verify
Verify Passed : LK
Verify Passed : BOOT
Verify Passed : RECOVERY
Verify Passed : LOGO
Verify Passed : SECRO
Verify Passed : SYSTEM
Verify Passed : CACHE
Verify Passed : USERDATA
Data Verify Done, time used : 00:00:03
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:08:57
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Page generated in 0.64810 seconds with 11 queries
