Old 11-07-2019, 06:38   #61171 (permalink)
Luckey1's Avatar
Member: 2197212
Sonork: N/A
Thanks Meter: 680
Qmobile dabang power read flash file and format done
Operation : Read Flash [ v1.05 ]
1. Power off device
2. Press and hold BootKey or use BootCable
3. Insert cable and battery in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
BootSource : InternalLibrary
BootVersion : Infinity SCR 6531EFM v2.0 (c)2019
Port speed : 921600
FDL Flash : Control transfered!
Boot Done!
CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ]
Read Flash Ok, Size : 4.00 MiB
QMobile_Dabang Power_V06_20190228
Project Version: SC6531EFM_BAR
MMI Version: SC6531EFM_BAR
BASE Version: BASE_SVN
HW Version: SC6531EFM_BAR
02-28-2019 15:46:27
LOG Version: V1.0.1
Saved to : C:\Users\Luckey1\Desktop\QMobile_Dabang Power_V06_20190228.bin
Done!
Elapsed: 00:00:39
Reconnect Power/Cable!
Operation : Format FileSystem [ v1.05 ]
1. Power off device
Wait for device ...
Device Connected!
BootVersion : SPRD3
Port speed : 921600
Boot Done!
Make backup of sensetive data
Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_196 BD25AA9D5_NVM.nv
Executing FormatFFS ...
Format FFS Done!
Done!
Elapsed: 00:00:22
The Following User Says Thank You to Luckey1 For This Useful Post:
Old 11-07-2019, 07:05   #61172 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,773
Qmobile e5 classic hang on logo done by cm2
Card found : 73CA70CC , v0137
Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.04
SCRD mode : AUTO
SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ]
Operation : Reset Settings [ v1.04 ]
----- > Powered On :
1. Power On device
2. Connect USB cable
3. When device show StorageMode : Press '0' button for a 5 second!
----- > Powered Off :
1. Insert USB cable
2. Wait when device show Charge icon
Wait for device ...
Device Connected!
BOOT_PWR0 : 0x00200000
BOOT_INIT : 0x2D717F15
BOOT_MODE : BOOTROM
Boot_CPU : 0x08090007 : [SPREADTRUM] : SC6533G
MEMD for flsh_spi32m Branch: none
Boot_CS0 : 0x00000000 : SPI : [SPIDEF] : 25Q32 : 0x00400000 [ 4MiB ]
Performing MemoryInit
Selecting RL
Sending RL
Config : MemoryInit
Config : Loader
BOOT_MODE : RLOADER
Boot IV : 0xFBA2A250
Boot done!
Preparing PMT
Verifying PMT
Erasing 1474560 bytes
FileSystem format done!
Done!
Elapsed: 00:00:50
The Following User Says Thank You to A.G.Shahid For This Useful Post:
Old 11-07-2019, 10:23   #61173 (permalink)
Member: 2431049
Sonork: 100.1680262:hunnyck
Thanks Meter: 966
Nokia TA-1010 Flash done
Card found : 8494CDF4 , v0122
Infinity-Box BEST Nokia [HMD] Module [NK2] v1.10
Open VPLfile : TA-1010_059Z1B8_20.14.11.vpl
Description : TA-1010 MH
DeviceType : TA-1010
ProductCode : 059Z1B8
SoftwareVer : 20.14.11
PPM LangPack :
[1] : Gujarati (India)
[2] : Kannada (India)
[3] : Marathi (India)
[4] : Telugu (India)
[5] : Punjabi (India)
[6] : Tamil (India)
[7] : Hindi (India)
[8] : Urdu (Islamic Republic of Pakistan)
[9] : English (United Kingdom)
Load Ok!
Operation : Write FirmWare [ v1.10 ]
Setting : UserData erase : True
Setting : LangPack Only : False
1. Make sure device is powered off. Power off, if need. Wait 10 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : Nokia USB Serial Port (COM153)
MODE : NOKIA USB SERIAL
PORT : 153
BROM : Init BROM
BROM init passed!
CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001
BROM : SECCFG : 0x00000007
BROM : NOKIA USB SERIAL
BROM : 0x05 BL : 0x00
BROM : MEID : 535440B0963727D6EA18B66360DC895B
BROM : Run BootLoader ...
BOOT : Run BL ver. 01
BOOT : 0x05 BL : 0x01
BOOT : WD : 0005
BOOT : RTC : Setup ...
BOOT : RTC : 000E
BOOT : PRJ : N103.30.04.11.p1
BOOT : SWR : 30.04.11
AGENT : Look for suitable BootChain in DA ...
AGENT : DEFAULT AUTO
AGENT : Found MT6261
AGENT : N103.30.04.11.p1
BOOT : Sending 1st DA ...
BOOT : DA sent
BOOT : Transfer control to DA ...
DA : Agent : v03.02 on BBID : 0x8E
NOR: 00C8 : 0060 : 0016 : 0000
NOR: [GigaDevice] GD25LQ32
NOR:
TSIZE : 0x00400000 [ 4.00 MB ]
PSIZE : 0x00400000 [ 4.00 MB ]
STYPE : 0x00000000
FLOTP : DA_NOR_OTP_EXIST
STATUS : OK
BSTYLE : SF_FLASH_BOOT
Boot done!
VPL SoftwareVersion : 20.14.11 [TA-1010]
DEV SoftwareVersion : 30.04.11
SWInfo compare result : VPL SW ( Major version ) is LOWER, than in DEVICE!
Load FlashSet :
MROM : TA-1010_ROM_eMP_20.14.11
LANG : TA-1010_LANG_PACK_ROM_MH_eMP_20.14.11_001
CUST : TA-1010_CUSTPACK_ROM_MH_eMP_20.14.11_001
JUMP : TA-1010_JUMP_TABLE_MH_eMP_20.14.11_001
VIVA : TA-1010_VIVA_eMP_20.14.11
Prepare FlashSet :
DCR : TA-1010_ROM_eMP_20.14.11
DCR : TA-1010_LANG_PACK_ROM_MH_eMP_20.14.11_001
DCR : TA-1010_CUSTPACK_ROM_MH_eMP_20.14.11_001
DCR : TA-1010_JUMP_TABLE_MH_eMP_20.14.11_001
DCR : TA-1010_VIVA_eMP_20.14.11
Prepare Target
SDS : OK : 0x003F8000 : 0x00008000
FFS Format Ok!
Erase Target Flash
Erase done!
Write Target Flash
Write : TA-1010_ROM_eMP_20.14.11
Write : TA-1010_LANG_PACK_ROM_MH_eMP_20.14.11_001
Write : TA-1010_CUSTPACK_ROM_MH_eMP_20.14.11_001
Write : TA-1010_JUMP_TABLE_MH_eMP_20.14.11_001
Write : TA-1010_VIVA_eMP_20.14.11
Write done, waiting target response ...
Write flash done!
Verify Target FlashContent
Verify : TA-1010_ROM_eMP_20.14.11
Verify : TA-1010_LANG_PACK_ROM_MH_eMP_20.14.11_001
Verify : TA-1010_CUSTPACK_ROM_MH_eMP_20.14.11_001
Verify : TA-1010_JUMP_TABLE_MH_eMP_20.14.11_001
Verify : TA-1010_VIVA_eMP_20.14.11
Done!
Elapsed: 00:02:26
The Following User Says Thank You to hunnyck For This Useful Post:
Old 11-07-2019, 11:08   #61174 (permalink)
bhalaygilani's Avatar
Member: 1647864
Thanks Meter: 80
q mobile i8i pro fromat done with cm2spd 1.27
Log is here
Set mode to : SP [SC773x] eMMC [Android 7.x]
Operation : Format File System / Reset Settings [ v1.27 ]
Settings : SmartFormat is On
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
 -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key
3. Insert cable
 ====  Wait for phone...
Phone found! [ 15 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SC773x eMMC Loader v7 InfinityBox
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
Detected eMMC Flash , Structure detect Ok!
eMMC phone detected! Will use 'Safe Format' mode!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Prepare Ok! Format Ok!
Don't touch phone, until it fully bootup to "Welcome Screen"!
Android 5.x/6.x : Reset FRP Lock
Reset Ok!
Done!
Elapsed: 00:00:28
Old 11-07-2019, 11:12   #61175 (permalink)
azhergoga007's Avatar
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Qmobile X11 MT6572 Logo Stuck Fix Only Flashing With King Infinity CM2
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 5 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x88
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A4834473164040503A2677FB19F
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , d1G4
[eMMC] : FLASH_CID : 90014A4834473164040503A2677FB19F
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID : 0xD9C8F39518121D3587852B62AFC3636B
INT RAM : 0x00020000
EXT RAM : 0x20000000 [512 MiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6572 , Project : mtk_android , Storage : EMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : BatteryLevel : 3856 mV
BL : BatteryLevel Ok
BL : Flash Pre-Erase
Total blocks to Erase : 1
Erase : 0x0000000000C00000-0x00000000E7B00000
Flash Pre-Erase Done, time used : 00:00:04
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader.bin
Preloader Sent , Init passed
PartCount : 0012
Update PMT by user request
Repartition Done!
Use FLN Mode
Processing : Flash Write
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : PRO_INFO
Image Flash Ok
Flash now : NVRAM
Image Flash Ok
Flash now : PROTECT_F
Image Flash Ok
Flash now : PROTECT_S
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : MISC
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : EXPDB
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:09:11
Processing : Verify
Verify Passed : MBR
Verify Passed : EBR1
Verify Passed : PRO_INFO
Verify Passed : NVRAM
Verify Passed : PROTECT_F
Verify Passed : PROTECT_S
Verify Passed : UBOOT
Verify Passed : BOOTIMG
Verify Passed : RECOVERY
Verify Passed : SEC_RO
Verify Passed : MISC
Verify Passed : LOGO
Verify Passed : EXPDB
Verify Passed : ANDROID
Verify Passed : CACHE
Verify Passed : USRDATA
Data Verify Done, time used : 00:02:23
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:12:02
Old 11-07-2019, 11:39   #61176 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,773
Vgo tel v11 hang on logo done by cm2
Card found : S/N : 73CA70CC , v0137
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 22 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x94
eMMC Flash : 150100513832334D4200A7D4AAB2C389
[eMMC] : FLASH_INF : [SAMSUNG] , BM328
[eMMC] : FLASH_CID : 150100513832334D4200A7D4AAB2C389
[eMMC] : FLASH_LEN : 0x00000003A3E00000
[eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB]
DEV RID : 0xE6C52A7DE77EE10F86DA65FBAF316B0B
EXT RAM : 0x80000000 [2 GiB]
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:01:11
Old 11-07-2019, 11:44   #61177 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,773
Qmobile xli reset pattern done by cm2
Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.00r2
Operation : Format FS / Reset Settings [ v2.00r2 ]
Mode : Default [ Reset Settings + FRP ]
1. Power off device, wait 10-15 seconds
2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- )
3. Insert cable in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : BQru : BQ-5002G
Sending Init Boot ...
Boot sent!
Kick FDL ...
BootVersion : Spreadtrum Boot Block version 1.1
Protocol setup ...
Port speed : 921600
Sending Flash Boot ...
Boot sent!
Kick FLASH FDL ...
FDL : Control transfered!
Boot Done!
Wipe Ok : UserData
Wipe Ok : Cache
Wipe Ok : FRP
Done!
Elapsed: 00:00:59
Old 11-07-2019, 16:31   #61178 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,999
GFIVE Fire Dead Recaver
SPRD mode : SC6531 : REV : E000 : NOR : [ 4MB ]
Operation : Format FileSystem [ v1.04 ]
1. Power off device
Wait for device ...
Device Connected!
BootVersion : SPRD3
BootVersion : Infinity SCR SC6531E Loader v 1.2
Port speed : 921600
Boot Done!
Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_0F755BBF4881_NVM.nv
Format FFS Done!
Done!
Elapsed: 00:01:16
Old 11-07-2019, 17:43   #61179 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,999
Nokia 3 Frp Reset
Brand     : Unknown
ProdName  : Unknown
ProdModel : Heart
Device    : Unknown
AndroidVer: 8.0.0
MTKxCPU   : MT6737M
MTKxPRJ   : alps-mp-o0.mp1-V3.47_k37mv1.64_P10
Done!
Elapsed: 00:00:15
Wait for phone...
Phone found! [ 11 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6737
BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
SecCfgVal : 0x05000000
BromVer   : 0x00FF
BLVersion : 0x0002
BootLdrSS : LOCKED with CERT
Processing DA stage
DA Select done, will use SecMode DA
Running DA ver.4.2 on BBID : 0x9B
eMMC Flash : 514E011336394A32C205105207C51537
[WARNING] : MEMORY_eMMC_VALIDATE_FAILED
[eMMC] : FLASH_VEN : 0x13 , OEM : 014E
[eMMC] : FLASH_INF : [NOT_IN_BASE] , R69J2
[eMMC] : FLASH_CID : 13014E51324A3936521005C237154407
[eMMC] : FLASH_LEN : 0x00000003AB400000
[eMMC] : FLASH_UCP : 15028 MiB [eMMC 16 GiB]
DEV RID    : 0xD5229C2567937E9951BC55ECDD109F3B
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Done!
Elapsed: 00:00:14
Old 11-07-2019, 20:33   #61180 (permalink)
Member: 87188
Thanks Meter: 227
Doogee MIX FRP succeeded!
Chinese Miracle2 MTK 2.06 Select only Custom DA: http://mark1.uw.hu/DA_PL.rar
(rar will unpack.)
Operation : Reset Settings/Format FS [ v2.06 ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
PTFN : MediaTek PreLoader USB VCOM (Android) (COM28)
MODE : PRELOADER PORT
PORT : 28
Waiting BOOT ack ...
PRELOADER : ACK confirmed!
BROM : Init BROM
BROM init passed!
CHIP : MT6757 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001
TYPE : MODERN RAPHAEL
BROM : SecLevel : 0x00000001
BROM : SecMode : SBC
BROM : PRELOADER PORT
MODE : 0_base : BASE_v1712 | Manual : Enabled
AGENT : DA_PL.bin
AGENT : Found MT6757
AGENT : MTK_DOWNLOAD_AGENT
BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
DA : AGENT started!
DA : SYNC
DA : MODE : PRELOADER
DA : EXT_RAM initialized!
DA : BOOT to 2nd DA ...
DA : 2ND stage confirmed!
DA : SYNC with DA passed!
DA : Receiving HW info
SRAM: 0x00040000 [ 256.00 KB ]
DRAM: 0x80000000 [ 2.00 GB ]
EMMC: 90014A484347386134A202163801644F
EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HCG8a4
EMMC:
BOOT1 : 0x00400000 [ 4.00 MB ]
BOOT2 : 0x00400000 [ 4.00 MB ]
RPMB : 0x00400000 [ 4.00 MB ]
USER : 0xE8F800000 [ 58.24 GB ]
CHIP : MT6757 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 , EVOL : 0x0000
RNID : 69904FC6EFAB7F121CCC5FDCA932CA8B
DA : USB : HIGH-SPEED
Boot done!
Format Ok : RESET PROTECTION
Done!
Elapsed: 00:00:20
Old 11-08-2019, 07:30   #61181 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,773
Qmobile x36 hang on logo done by cm2
Card found: S/N : 73CA70CC , v0137
Chinese Miracle II [SPD module] v 1.27
Operation : Check/Read Info [ v1.27 ]
3. Insert cable
Phone found! [ 26 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FLASH : eMMC Flash , Structure : Ok!
Reading extended info ...
Model Name : QMobile_X36
Model Brand : QMobile
Model Device: QMobile_X36
AndrVersion : 7.0
BaseBand CPU: X36
CompileDate : 9/20/2017 4:27:17 AM
Project Ver : NRD90M
Model Ext : QMobile X36
ExtraInfo : HWInfo not exists, normal phone
Elapsed: 00:00:57
3. Insert cable
Phone found! [ 26 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Reset Ok!
Done!
Elapsed: 00:00:54
Old 11-08-2019, 10:59   #61182 (permalink)
Member: 2788489
Sonork: 1000000.1000
Thanks Meter: 36
nokia 1 frp unlock by cm2
nokia 1 frp lock remove
http://www.youtube.com/watch?v=sUDbw389tjk
The Following 2 Users Say Thank You to kg tel For This Useful Post:
Old 11-08-2019, 13:31   #61183 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,773
Qmobile e2 party hang on logo done by cm2
SCRD mode : AUTO
Operation : Identify [ v1.04 ]
1. Power On device
1. Insert USB cable
Wait for device ...
Device Connected!
BOOT_PWR0 : 0x00600000
BOOT_INIT : 0x81C0024C
BOOT_MODE : DOWNLOAD
BOOT_INTV : 6533G-FPTRUNK-W16.44.2
InternalVersion: g8bec5c4c
Setting BOOTROM mode
BOOT_MODE : BOOTROM
Selecting RL
Sending RL
Config : MemoryInit
Config : Loader
BOOT_MODE : RLOADER
Boot done!
Identify : Code Integrity Check pass!
Device Info Details :
[0] : sc6533g_XS09_H1_Q
[1] : 8809
[2] : 8809e2
[3] : CT8851C
[4] : pasw_hs8292u
[5] : flsh_spi32m
[6] : nv3029e/nv3029g/nv3029h/st7789/gc9304c/gc9305/gc9306/gc9307/otm3208
[7] : bf3a01serial/gc6123/gc6133/sp0821
[8] : rdabt_8809
[9] : rdafm_8809e
[10] : release
[11] : 2018-07-11_17:20:26
[12] : H1_Q_Qmobile_V01
inf_usb-dll:err [_usb_read_async] timeout error
Done!
Elapsed: 00:02:56
1. Power On device
1. Insert USB cable
Wait for device ...
Device Connected!
BOOT_MODE : BOOTROM
Selecting RL
Sending RL
Config : MemoryInit
Config : Loader
BOOT_MODE : RLOADER
Boot done!
Preparing PMT
Verifying PMT
Done!
Elapsed: 00:00:55
Old 11-08-2019, 13:33   #61184 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,773
Rivo m1 hang on logo done by cm2
Set mode to : SP [SC773x] eMMC [Android 6.x]
Infinity SC Firmware Detected
FW Size : 1653 MiB
Load Ok!
File Info
Created by Infinity-Box (c) Chinese Miracle II (c) 2017
Device Brand : M1
Device Model : sp7731c_1h10_32v4
Device CPU : sp7731ceb
Device IntName : sp7731c_1h10_32v4_oversea
Device Version : 6.0
Device Compile : 3/9/2017 11:24:09 AM
Device Project : MRA58K release-keys
Device ExtInfo : M1
Operation : Flash [ v1.27 ]
======= Flash
Files set for flashing :
[ MCU ] : SC77xx Infinity Package
3. Insert cable
Phone found! [ 29 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Boot Ver : SC7731 Crev eMMC Loader v1.0
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
PMTManager : Load 0x21 records
PMTManager : PMT Update Ok!
Flashing now
Update BootCode : u-boot-spl-16k.bin
Write Data ...
Write Data Ok!
Update BootCode : u-boot.bin
Erase block ...
Block erase Ok!
Write Data ...
Write Data Ok!
Write FSImage : prodnv.img
Write Data ...
Write Data Ok!
Write CodeData : sc7731C_CP0_modem.bin
Write Data ...
Write Data Ok!
Write CodeData : DSP_DM_Gx.bin
Write Data ...
Write Data Ok!
Erase Block : RuntimeData
Erase block ...
Block erase Ok!
Write CodeData : sc8830g_modem_CP2_WCN_Trunk_W16.28.5_Release.bin
Write Data ...
Write Data Ok!
Write CodeData : logo_720x1280.bin
Write Data ...
Write Data Ok!
Write CodeData : logo2.bin
Write Data ...
Write Data Ok!
Write CodeData : logo3.bin
Write Data ...
Write Data Ok!
Write CodeData : logo4.bin
Write Data ...
Write Data Ok!
Write CodeData : logo5.bin
Write Data ...
Write Data Ok!
Write CodeData : logo6.bin
Write Data ...
Write Data Ok!
Write CodeData : logo7.bin
Write Data ...
Write Data Ok!
Write CodeData : logo8.bin
Write Data ...
Write Data Ok!
Write CodeData : logo9.bin
Write Data ...
Write Data Ok!
Write CodeData : logo10.bin
Write Data ...
Write Data Ok!
Write CodeData : boot.img
Write Data ...
Write Data Ok!
Write FSImage : system.img
Write Data ...
Write Data Ok!
Erase Block : PERSIST
Erase block ...
Block erase Ok!
Write FSImage : cache.img
Write Data ...
Write Data Ok!
Write CodeData : recovery.img
Write Data ...
Write Data Ok!
Erase Block : MISC
Erase block ...
Block erase Ok!
Write CodeData : sysinfo.img
Write Data ...
Write Data Ok!
Write FSImage : userdata.img
Write Data ...
Write Data Ok!
Elapsed: 00:04:09
Old 11-08-2019, 19:20   #61185 (permalink)
Manikanika81's Avatar
Member: 2897012
Thanks Meter: 400
Itel it5250 read code by cm2
SPRD mode : SC6531 : REV : C000 : NOR : [ 4MB-8MB ]
Operation : Read UserCode [ v1.05 ]
MODE : From Device
1. Power off device
Wait for device ...
Device Connected!
BootVersion : SPRD3
BootVersion : Spreadtrum Boot Block version 1.2
Port speed : 921600
Boot Done!
CS0_MEM : SPI : [FIDELIX] : FM25Q64 : 0x00800000 [ 8MiB ]
Reading data ...
Sorting data ...
STATE : ACTIVE : CODE : 03071998
Done!
Elapsed: 00:00:33
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Page generated in 0.67433 seconds with 11 queries
