11-26-2019, 08:29 | #61352 (permalink) | |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | Quote:
hey... can u pls share the file..? | |
11-26-2019, 09:04 | #61353 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile I9 MT6580 Logo Stuck Formate Done With King Infinity CM2 Card found : S/N : A19EC787 , v0138 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 16 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 110100303034473930519359A7C9C0FF Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 09G40 [eMMC] : FLASH_CID : 110100303034473930519359A7C9C0FF [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB] DEV RID : 0xD9C8F39537C7231F44605B2DF5C45C5A INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:24 Reconnect Power/Cable! |
11-26-2019, 13:17 | #61354 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | LenovoTB3-710F Pattern Read Code: Brand : Lenovo ProdName : LenovoTB3-710F ProdModel : Lenovo TB3-710F Device : TB3-710F AndroidVer: 5.0.1 MTKxCPU : MT8127 MTKxPRJ : TB3-710F_S000007_151015_ROW Done! Elapsed: 00:00:09 Reconnect Power/Cable! Operation : Read Pattern/DP Lock [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 11 ] Sync... Inital Boot Ok! BB_CPU_PID : 8127 BB_CPU_NME : [MediaTek] MT8127_S00 BB_CPU_EXT : 0xCA04 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8D NAND Flash : NOT INSTALLED eMMC Flash : 1101003031364737320051E8B27142E1 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 27G61 [eMMC] : FLASH_CID : 1101003031364737320051E8B27142E1 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB400000 [eMMC] : FLASH_UCP : 15028 MiB [eMMC 16 GiB] DEV RID : 0xD5229C2526F807F6714669936B49DEB9 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading data ... Get Locks ... PatternLock Sequnce : 1478963 Done! Elapsed: 00:00:16 Reconnect Power/Cable! |
11-26-2019, 13:31 | #61355 (permalink) |
No Life Poster Join Date: Apr 2016 Location: B A N G L A D E S H
Member: 2556542 Status: Offline Thanks Meter: 1,790 | Wiko sunny 4 w-k130 firmware backup done world first Code: Operation : Read FW [ v2.03 ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Device info : Patch Level : OPM2.171019.012 Display ID : OPM2.171019.012 release-keys Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2019-06-05 Build Time : 1559298842 Product Info : W_K130 Product Model : W-K130-TMV Product Brand : WIKO Product Name : W-K130-TMV Product Device : W-K130 Product Manfct : WIKO Product Board : k130 Board Platform : sp7731e VlnrLevel : 0x00 SP7731E__WIKO__W-K130-TMV__8.1.0__OPM2.171019.012__W_K130 Read : prodnv.img ExtSparse : Compression ratio : 16% Read : phase.cfg Read : recovery.img Read : tos.bin Read : sml.bin Read : u-boot.bin Read : boot_logo.bmp Read : fastboot_logo.bmp Read : nvitem_w.bin Make : persist.img Read : gnssmodem.bin Read : gnssbdmodem.bin Read : modem_wcn.img Read : modem_w.bin Read : deltanv_w.bin Read : gdsp_w.bin Read : pm_sys.bin Read : boot.img Read : system.img ExtSparse : Compression ratio : 91% Make : cache.img Read : vendor.img ExtSparse : Compression ratio : 81% Read : vbmeta.img Make : userdata.img Read : u-boot-spl.bin Firmware size : 0x660F4944 ( 1.59 GiB ) Android Info saved : _Android_info.txt Reconnect Power/Cable! Done! Elapsed: 00:31:25 |
The Following 4 Users Say Thank You to kothamamun For This Useful Post: |
11-26-2019, 13:34 | #61356 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | QMobile i2_POWER Flash Code: Model Name : i2_POWER Model Brand : QMobile Model Device: i2_POWER AndrVersion : 6.0 BaseBand CPU: SP7731CEA CompileDate : 2016-11-28 8:41:14 AM Project Ver : QMobile_i2_POWER_MP_08_11 Model Ext : QMobile i2 POWER ExtraInfo : HWInfo not exists, normal phone Elapsed: 00:00:28 Reconnect Power/Cable! Infinity SC Firmware Detected FW Size : 2776 MiB Load Ok! File Info Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : QMobile Device Model : i2_POWER Device CPU : sp7731cea Device IntName : i2_POWER Device Version : 6.0 Device Compile : 11/28/2016 8:41:14 AM Device Project : QMobile_i2_POWER_MP_08_11 Device ExtInfo : QMobile i2 POWER Operation : Flash [ v1.27 ] ======= Flash Files set for flashing : [ MCU ] : SC77xx Infinity Package 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 31 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! PMTManager : Load 0x19 records PMTManager : PMT Update Ok! Flashing now Update BootCode : u-boot-spl-16k.bin Write Data ... Write Data Ok! Update BootCode : u-boot.bin Erase block ... Block erase Ok! Write Data ... Write Data Ok! Write FSImage : prodnv.img Write Data ... Write Data Ok! Write CodeData : sc7731C_CP0_modem.bin Write Data ... Write Data Ok! Write CodeData : DSP_DM_Gx.bin Write Data ... Write Data Ok! Erase Block : RuntimeData Erase block ... Block erase Ok! Write CodeData : sc8830g_modem_CP2_WCN_Trunk_W16.23.4_Release.bin Write Data ... Write Data Ok! Erase Block : RuntimeData Erase block ... Block erase Ok! Write CodeData : logo_480x854.bin Write Data ... Write Data Ok! Write CodeData : fblogo_480x854.bin Write Data ... Write Data Ok! Write CodeData : boot.img Write Data ... Write Data Ok! Write FSImage : system.img Write Data ... Write Data Ok! Erase Block : PERSIST Erase block ... Block erase Ok! Write CodeData : sysinfo.img Write Data ... Write Data Ok! Write FSImage : cache.img Write Data ... Write Data Ok! Write CodeData : recovery.img Write Data ... Write Data Ok! Erase Block : MISC Erase block ... Block erase Ok! Write FSImage : userdata.img Write Data ... Write Data Ok! Elapsed: 00:07:41 Reconnect Power/Cable! |
11-26-2019, 14:29 | #61357 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Qmobile x2 hang on logo done by cm2 Card found : S/N : 73CA70CC , v0137 Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 22 ] Sync... Inital Boot Ok! BB_CPU_PID : 6571 BB_CPU_NME : [MediaTek] MT6571_S00 BB_CPU_EXT : 0xCA00 , 0x8D00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8B NAND Flash : 009800BC009000660076001600080000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0011 , [KINGSTON] KTN0403CS_TCR1 [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0016 0008 [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 1000/0040/01/NIM_Px-1 DEV RID : 0x0B9C44DE19C591CE296A6DFF16B806A4 INT RAM : 0x00020000 EXT RAM : 0x10000000 [256 MiB] BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : QMobile ProdName : s3510ap ProdModel : QMobile X2 Device : s3510ap AndroidVer: 4.4.2 MTKxCPU : MT6571 MTKxPRJ : ALPS.KK1.MP7.V1 Done! Elapsed: 00:00:15 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 22 ] Sync... Inital Boot Ok! BB_CPU_PID : 6571 BB_CPU_NME : [MediaTek] MT6571_S00 BB_CPU_EXT : 0xCA00 , 0x8D00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8B NAND Flash : 009800BC009000660076001600080000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0011 , [KINGSTON] KTN0403CS_TCR1 [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0016 0008 [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 1000/0040/01/NIM_Px-1 DEV RID : 0x0B9C44DE19C591CE296A6DFF16B806A4 INT RAM : 0x00020000 EXT RAM : 0x10000000 [256 MiB] BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:15 Reconnect Power/Cable! |
11-26-2019, 14:59 | #61358 (permalink) |
Junior Member Join Date: Nov 2019 Location: Pakistan
Member: 2936988 Status: Offline Sonork: [email protected] Thanks Meter: 29 | Qmobile i5i Frp remove CM2 SPD2 DONE |
The Following 2 Users Say Thank You to Zunair Mobile For This Useful Post: |
11-26-2019, 16:40 | #61359 (permalink) |
Freak Poster Join Date: Nov 2009 Location: waiting for a ticket to ***
Member: 1172662 Status: Offline Sonork: 100.1625907 Thanks Meter: 9 | client version is too old respected team member please solve my problem i am sill waiting last five months Card found : 2014F894 , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.19 Operation : Identify [FTM] [ v1.19 ] -> Old : Power Off Phone, wait 5-10 seconds, Insert USB cable -> New : Power Off Phone, press and hold VOL_DOWN and POWER keys, until FASTBOOT screen appear Wait for phone... Connect Ok! Device Found! Initialize ... Initialize Ok! Dev Model : E1I HW version : 3.0 HW RF_BAND : G_900_1800^W_1_8^L_1_3_5_20_40_41 SW version : E1M-064E-0-00WW-B01 SW serialnm : E1MLH3579E602088 Project DevCode : E1M Bootloader type : RETAIL Security Version : 0004 Done! Elapsed: 00:00:09 Reconnect Power/Cable! Operation : Reset Settings [FTM] [ v1.19 ] -> Old : Power Off Phone, wait 5-10 seconds, Insert USB cable -> New : Power Off Phone, press and hold VOL_DOWN and POWER keys, until FASTBOOT screen appear Wait for phone... Connect Ok! Device Found! Initialize ... Initialize Ok! Looking for SVC package in local database ... SW : E1M-064E-0-00WW-B01 Package : E1M-064I Device : E1I ( E1M ) BLType : RETAIL SecVer : 04 Device authentification ... Processing server operation ... Connecting to server... Connected Authenticating... Authentication error:Server reported error: 05 AUTHENTICATION_FAILED Disconnected Disconnected Finished Error : Device auth failed! Server reported error! Send log and report.log to support! Include device info also! Reconnect Power/Cable! Operation : Reset Settings [FTM] [ v1.19 ] -> Old : Power Off Phone, wait 5-10 seconds, Insert USB cable -> New : Power Off Phone, press and hold VOL_DOWN and POWER keys, until FASTBOOT screen appear Wait for phone... Connect Ok! Device Found! Initialize ... Initialize Ok! Looking for SVC package in local database ... SW : E1M-064E-0-00WW-B01 Package : E1M-064I Device : E1I ( E1M ) BLType : RETAIL SecVer : 04 Device authentification ... Processing server operation ... Connecting to server... Connected Authenticating... Authentication error:Server reported error: 05 AUTHENTICATION_FAILED Disconnected Disconnected Finished Error : Device auth failed! Server reported error! Send log and report.log to support! Include device info also! Reconnect Power/Cable! Operation : Reset Settings [FTM] [ v1.19 ] -> Old : Power Off Phone, wait 5-10 seconds, Insert USB cable -> New : Power Off Phone, press and hold VOL_DOWN and POWER keys, until FASTBOOT screen appear Wait for phone... Connect Ok! Device Found! Initialize ... Initialize Ok! Looking for SVC package in local database ... SW : E1M-064E-0-00WW-B01 Package : E1M-064I Device : E1I ( E1M ) BLType : RETAIL SecVer : 04 Device authentification ... Processing server operation ... Connecting to server... Connected Authenticating... Authenticated Checking Client version... Client version check error:Error: Client version is too old Disconnected Disconnected Finished Error : Device auth failed! Server reported error! Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
11-26-2019, 18:57 | #61360 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | GFIVE_President_Smart_A98 Flash Code: Model Name : revo_6408 Model Brand : GFIVE Model Device: GFIVE AndrVersion : 4.4.2 BaseBand CPU: SP7731GEA_HD CompileDate : 2015-11-27 2:46:32 AM Project Ver : GFIVE_President_Smart_A98-151127 Model Ext : GFIVE_President_Smart_A98 ExtraInfo : HWInfo not exists, normal phone Elapsed: 00:00:41 Reconnect Power/Cable! Loading : SP7731GEA_GFive_new_64+8_RC_151127_B1.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC77xx PacVersion : SP7731GEA_GFive_new_64+8_RC_151127_B1 FastCheck : 0x003AAB4CBE Loading files ... File : fdl1.bin File : fdl2.bin File : nvitem.bin File : wcnnvitem.bin File : prodnv.img File : u-boot-spl-16k.bin File : wmodem.bin File : wdsp.bin File : wcnmodem.bin File : boot.img File : recovery.img File : system.img File : userdata.img File : FWVGA_logo_256_td.bmp File : fastboot_FWVGA_logo_256_td.bmp File : cache.img File : u-boot.bin File : SC77xx.xml Load Ok! Operation : Flash [ v1.27 ] ======= Flash Files set for flashing : [ MCU ] : SP7731GEA_GFive_new_64+8_RC_151127_B1.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC77xx PacVersion : SP7731GEA_GFive_new_64+8_RC_151127_B1 File : fdl1.bin File : fdl2.bin File : nvitem.bin File : wcnnvitem.bin File : prodnv.img File : u-boot-spl-16k.bin File : wmodem.bin File : wdsp.bin File : wcnmodem.bin File : boot.img File : recovery.img File : system.img File : userdata.img File : FWVGA_logo_256_td.bmp File : fastboot_FWVGA_logo_256_td.bmp File : cache.img File : u-boot.bin 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 31 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! PMTManager : Load 0x17 records PMTManager : PMT Update Ok! Flashing now [FlashProc] : CODE Current ID : PRODNV Current File : prodnv.img Flashing now ... [FlashProc] : Ok! [FlashProc] : ERASE Current ID : ERASEUBOOT Current Part : uboot [FlashProc] : Ok! [FlashProc] : BOOTCODE Current ID : SPLLOADER Current File : u-boot-spl-16k.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : MODEM_W Current File : wmodem.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : DSP_W Current File : wdsp.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : MODEM_WCN Current File : wcnmodem.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : BOOT Current File : boot.img Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : RECOVERY Current File : recovery.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : SYSTEM Current File : system.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : USERDATA Current File : userdata.img Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : BOOTLOGO Current File : FWVGA_logo_256_td.bmp Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : FASTBOOT_LOGO Current File : fastboot_FWVGA_logo_256_td.bmp Flashing now ... [FlashProc] : Ok! [FlashProc] : ERASE Current ID : FLASH Current Part : wruntimenv1 [FlashProc] : Ok! [FlashProc] : ERASE Current ID : FLASH_WCN Current Part : wcnruntimenv1 [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : CACHE Current File : cache.img Flashing now ... [FlashProc] : Ok! [FlashProc] : ERASE Current ID : ERASEMISC Current Part : misc [FlashProc] : Ok! [FlashProc] : BOOTCODE Current ID : UBOOTLOADER Current File : u-boot.bin Flashing now ... [FlashProc] : Ok! Elapsed: 00:02:08 Reconnect Power/Cable! |
11-26-2019, 19:09 | #61361 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | GFIVE Falak Dead Recaver Code: Operation : Format FileSystem [ v1.04 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR SC6531E Loader v 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ] Make backup of sensetive data Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_0E8ADFED1A79_NVM.nv Executing FormatFFS ... Format FFS Done! Done! Elapsed: 00:00:24 Reconnect Power/Cable! |
11-27-2019, 10:09 | #61362 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | VgoTel i12 Read User Code Done Operation : Read UserCode [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 10 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 01A98288F60A70DF2E0BBA262C1B59F1 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0112 , [MXIC] MX25L3291FWJI_09 [0] : FLASH_DIE : 00C2 0020 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Read ExtData Sorting ExtData Reading UserCode Active : Yes , Code : 1199 PLock|MobTrack : Not active Done! Elapsed: 00:00:34 Reconnect Power/Cable! |
11-27-2019, 12:22 | #61364 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Voice v50 reset password done by cm2 Card found : 73CA70CC , v0137 Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.04 SCRD mode : AUTO SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ] Operation : Identify [ v1.04 ] ----- > Powered On : 1. Power On device 2. Connect USB cable 3. When device show StorageMode : Press '0' button for a 5 second! ----- > Powered Off : 1. Insert USB cable 2. Wait when device show Charge icon 3. When device show StorageMode : Press '0' button for a 5 second! Wait for device ... Device Connected! BOOT_PWR0 : 0x00600000 BOOT_INIT : 0x81C0024C BOOT_MODE : DOWNLOAD BOOT_INTV : 6533G-FPTRUNK-W16.44.2 InternalVersion: g8bec5c4c Setting BOOTROM mode BOOT_MODE : BOOTROM Boot_CPU : 0x08090007 : [SPREADTRUM] : SC6533G MEMD for flsh_spi32m Branch: none Boot_CS0 : 0x00000000 : SPI : [SPIDEF] : 25Q32 : 0x00400000 [ 4MiB ] Performing MemoryInit Selecting RL Sending RL Config : MemoryInit Config : Loader BOOT_MODE : RLOADER Boot IV : 0xFBA2A250 Boot done! Identify : Code Integrity Check pass! Done! Elapsed: 00:02:49 Reconnect Power/Cable! Operation : Reset Settings [ v1.04 ] ----- > Powered On : 1. Power On device 2. Connect USB cable 3. When device show StorageMode : Press '0' button for a 5 second! ----- > Powered Off : 1. Insert USB cable 2. Wait when device show Charge icon 3. When device show StorageMode : Press '0' button for a 5 second! Wait for device ... Device Connected! BOOT_PWR0 : 0x00600000 BOOT_INIT : 0x81C0024C BOOT_MODE : BOOTROM Boot_CPU : 0x08090007 : [SPREADTRUM] : SC6533G MEMD for flsh_spi32m Branch: none Boot_CS0 : 0x00000000 : SPI : [SPIDEF] : 25Q32 : 0x00400000 [ 4MiB ] Performing MemoryInit Selecting RL Sending RL Config : MemoryInit Config : Loader BOOT_MODE : RLOADER Boot IV : 0xFBA2A250 Boot done! Preparing PMT Verifying PMT Erasing 1474560 bytes FileSystem format done! Done! Elapsed: 00:00:52 Reconnect Power/Cable! |
11-27-2019, 13:04 | #61365 (permalink) |
Freak Poster Join Date: Aug 2008 Location: Tidikelt
Member: 834813 Status: Offline Thanks Meter: 125 | Lg x230 (frp) Code: Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 10 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 460001154D32584E7F32064287B0C006 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM2XN [eMMC] : FLASH_CID : 150100464E58324D4206327F06C0A487 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x032751D207BA1B71CA930F7BA0BB54EC INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:16 Reconnect Power/Cable! |
