Old 03-01-2020, 19:57   #62671 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,999
Infinix HOT4 Frp
Brand     : Infinix
ProdName  : X557A1
ProdModel : Infinix HOT 4
Device    : X557
AndroidVer: 7.0
MTKxCPU   : MT6580
MTKxPRJ   : X557-H807AD-N-190220V181
Done!
Elapsed: 00:00:10
Reconnect Power/Cable!
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 3 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x94
NAND Flash : NOT INSTALLED
eMMC Flash : 150100514531334D420D26D6E07B24BB
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , BM31E
[eMMC] : FLASH_CID : 150100514531334D420D26D6E07B24BB
[eMMC] : FLASH_LEN : 0x00000003A3E00000
[eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB]
DEV RID    : 0xD5229C25A3BDB41F463B47EB0A973FF3
INT RAM    : 0x00020000
EXT RAM    : 0x80000000 [2 GiB]
BOOT TYPE  : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Done!
Elapsed: 00:00:13
The Following User Says Thank You to Tanha0321 For This Useful Post:
Old 03-01-2020, 19:58   #62672 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,999
Infinix X627 Frp
Patch Level    : PPR1.180610.011
Display ID     : X627-H624STXYZAa-P-190923V273
Ver. CodeName  : REL
Ver. Release   : 9
Sec. Patch     : 2019-09-05
Build Time     : 1569207793
Product Model  : Infinix X627
Product Brand  : Infinix
Product Name   : H624
Product Device : Infinix-X627STU
Product Manfct : INFINIX MOBILITY LIMITED
Product Info   : x627_h624
Product Board  : Infinix-X627
Board Platform : mt6761
USERDATA : ENCRYPTED
Operation : Reset Settings/Format FS [ v2.07 ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM3)
MODE : PRELOADER PORT
PORT : 3
Waiting BOOT ack ...
PRELOADER : ACK confirmed!
BROM : Init BROM
BROM init passed!
     CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200
     TYPE : MODERN RAPHAEL
BROM : SecLevel : 0x00000005
BROM : SecMode  : SBC+SDA
BROM : PRELOADER PORT
MODE : INFINIX : SECURE_BASE | Manual : Disabled
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA_SWSEC.bin
AGENT : Found MT6761
AGENT : MTK_DOWNLOAD_AGENT
     BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
     DA : AGENT started!
DA : SYNC
     DA : MODE : PRELOADER
DA : EXT_RAM initialized!
DA : BOOT to 2nd DA ...
DA : 2ND stage confirmed!
DA : SYNC with DA passed!
DA : Receiving HW info
        SRAM: 0x00080000 [ 512.00 KB ]
        DRAM: 0xC0000000 [ 3.00 GB ]
        EMMC: 7001005441323833322316D7BD3E9613
        EMMC: VEN : KINGSTON | OEM : 01 | DEV : TA2832
        EMMC:
              BOOT1  : 0x00400000 [ 4.00 MB ]
              BOOT2  : 0x00400000 [ 4.00 MB ]
              RPMB   : 0x00400000 [ 4.00 MB ]
              USER   : 0x74A000000 [ 29.16 GB ]
        CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000
        RNID : F5B3C522D73BCAF8234BD48F52C5238D
DA : USB : HIGH-SPEED
Boot done!
Format Ok : RESET PROTECTION
Done!
Elapsed: 00:00:21
Old 03-02-2020, 06:20   #62673 (permalink)
Ali idrees's Avatar
Member: 1851480
Sonork: 100.1660354
Thanks Meter: 142
need this firmware
Originally Posted by muzammal mudass View Post
qmobile e600 music v3 mtk 6261 read flash file done by cm2
chinese miracle ii  [mtk module] v 1.58
operation : Read flash [ v1.58 ]
1. Power off phone , remove battery , insert back
2. Insert usb cable. In some cases require hold bootkey ( '*' )
wait for phone...
Phone found! [ 35 ]
sync...
Sync ok, read regs...
Inital regs read done
boot info :
Bb_cpu_id : 6261
bb_cpu_hw : Cb01
bb_cpu_sw : 0001
bb_cpu_sb : 8000
bb_cpu_nm : [mediatek] mt6261_s0000
bb_cpu_sn : 6810a601a0ec6a51746b56ad8c3a8441
brom protocol version : 05
setting...
Setting done , result code 0x000e
brom stage done
seek and prepare downloadagent
downloadagent matching hw found!
Da verify and select done
sending da to target ...
Da_info   : 0xc0 , ver : 3.2 , bbid : 0x8e
soc_verify : 0xc1
boot_style : Sf_flash_boot
nor flash ic initialized
[0] : Flash_ven : 0x0113 , [winbond] sf_w25q32jv
[0] : Flash_die : 00ef 0070 0016 0000
[0] : Flash_len : 0x00300000
sds_info : 0x002fe000 , 0x00002000
int_ram : 0x0000d000
ext_ram : 0x00400000
reading flash content now ...
Read flash now
read ok , 3145728 bytes read
check and collect compile info
file_info   : Fise61m_11c_pcb01_gsm_mt6261_s00.qmobile_e600_music_22_10_2018_v05.bin
fileversion : Qmobile_e600_music_22_10_2018_v05
saved to : C:\infinitybox\cm2mtk\read_out\fise61m_11c_pcb01_gsm_mt6261_s00.qmobile_e600_music_22_10_2018_v05.bin
done!
Elapsed: 00:00:23
reconnect power/cable!
br
muzammal mudassar
need this file plz ....................................... .
Old 03-02-2020, 07:38   #62674 (permalink)
Nadeem Waris's Avatar
Member: 1080718
Sonork: 100.1596539 QQ-2710826805
Thanks Meter: 2,247
Infinix 5010 reset pattern lock done
Operation : Clear UserLocks [Pin/Pwd/Pattern/FVLock/GoogleAcc] [ v1.58 ]
Wait for phone...
Phone found! [ 9 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 150100464536324D4203C25DDAEC64AF
[eMMC] : FLASH_INF : [SAMSUNG] , BM26E
[eMMC] : FLASH_CID : 150100464536324D4203C25DDAEC64AF
DEV RID : 0x033C5217F6866FFED7B7E0D03583A159
EXT RAM : 0x40000000 [1 GiB]
SOC VERIFY : C1
Boot Ok!
LSSDB Ok!
LSSWL Ok!
LSSSH Ok!
LSSNP Ok!
LSSNG Ok!
Security Settings : Clear Ok!
[Info] : That feature NOT RESET "PRIVACY PASSWORD LOCK"! Use separate button!
[Info] : That feature NOT RESET "FRP/GoogleLOCK"! Use separate "FRP" reset!
[Info] : If phone stuck on "Logo" :
1. Wait 2-3 minutes. Power Off phone by long press "Power" button
2. Power On phone again
3. Or wait up to 3-7 minutes, until phone start by itself
4. Also recommended reboot phone twice before start use it
Done!
Elapsed: 00:00:18
The Following 2 Users Say Thank You to Nadeem Waris For This Useful Post:
Old 03-02-2020, 07:39   #62675 (permalink)
Member: 1080718
Thanks Meter: 2,247
PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM7)
PORT : 7
BROM : Init BROM
BROM init passed!
CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
TYPE : LEGACY MTK
MODE : TECNO : LB6 | Manual : Disabled
AGENT : DA_SWSEC.bin
AGENT : Found MT6580
BROM : DA sent
DA : AGENT started!
NAND : DEVICE NOT FOUND
NAND : 000000000000000000000000
eMMC : OK
eMMC : 460001704543424D65272041EF96E9D3
DAInf: 4 : 2 : 156
DA : DRAM ready!
EMMC: 700100464D42434541202765D3E996EF
EMMC: VEN : KINGSTON | OEM : 01 | DEV : FMBCEA
EMMC:
SRAM: 0x00020000 [ 128.00 KB ]
DRAM: 0x80000000 [ 2.00 GB ]
CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
RNID : 49FC8A48D0706664A69060EF628C5E1F
STATUS : BLANK FLASH
BSTYLE : EMMC FLASH BOOT
Boot done!
Format Ok : USERDATA
Done!
Elapsed: 00:00:23
Old 03-02-2020, 10:46   #62676 (permalink)
Freeboy08's Avatar
Member: 1272267
Sonork: 100.1667652
Thanks Meter: 408
Itel s13 privacy code reset done by infinity box
Card found : AB917A5E , v0139
Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.08
Load IDBase v124106 Ok!
Operation : Reset PrivacyLock [ v2.08 ]
PTFN : MediaTek PreLoader USB VCOM (Android) (COM11)
PORT : 11
BROM : Init BROM
BROM init passed!
TYPE : LEGACY MTK
BROM : SecLevel : 0x00000000
BROM : SecMode : PLAIN [+PRL]
MODE : 0_base : BASE_v1952 | Manual : Disabled
AGENT : MTK_AllInOne_DA.bin
BROM : DA sent
DA : AGENT started!
eMMC : OK
eMMC : 460001154D32364EECD40342E97597D0
DAInf: 4 : 2 : 156
DA : DRAM ready!
EMMC: 150100464E36324D4203D4ECD09775E9
EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FN62MB
EMMC:
BOOT1 : 0x00400000 [ 4,00 MB ]
BOOT2 : 0x00400000 [ 4,00 MB ]
RPMB : 0x00080000 [ 512,00 KB ]
USER : 0x1D2000000 [ 7,28 GB ]
SRAM: 0x00020000 [ 128,00 KB ]
DRAM: 0x40000000 [ 1,00 GB ]
RNID : 1F3DED9E3A6DF0EAE022876813140F3E
Boot done!
Backup sensetive data [ 10 ]
Backup path : Backup\MT6580__1F3DED9E3A6DF0EAE022876813140F3E\
[4] Read : NVRAM
[21] Read : NVDATA
[2] Read : PROINFO
[9] Read : LK
[5] Read : PROTECT1
[6] Read : PROTECT2
[7] Read : PERSIST
[0] Read : PRELOADER
Backup done!
Process Block #2
INFO : PrivacyLock reset done!
Done!
Elapsed: 00:00:28
The Following 3 Users Say Thank You to Freeboy08 For This Useful Post:
Old 03-02-2020, 11:29   #62677 (permalink)
Member: 635202
Thanks Meter: 10
U think that GRT donglre activation is FAKE , now i have buy it bit can not registre .
i can't active it i have lost my time and my money .
GRT songle have no support , i write any time no awnser me....
Old 03-02-2020, 12:40   #62678 (permalink)
Member: 2765424
Thanks Meter: 1,039
q infinity E4 frp reset done cm2 SPD2
http://www.youtube.com/watch?v=Tlc4tIrMNeg
The Following 3 Users Say Thank You to taimur-ahmad For This Useful Post:
Old 03-02-2020, 12:43   #62679 (permalink)
Member: 2765424
Thanks Meter: 1,039
Itel A46 L5002 frp reset done.......cm2 SPD2
Itel A46 L5002 frp reset done.....cm2 SPD2
http://www.youtube.com/watch?v=eJXtdHVQuN0
The Following 4 Users Say Thank You to taimur-ahmad For This Useful Post:
Old 03-02-2020, 13:15   #62680 (permalink)
Member: 1527968
Sonork: 100.1651182
Thanks Meter: 483
zte sfr 241 unlock don
COM26 [VCP0] selected
module v4.48
Device: SFR-241
Checking data, wait...
Operation: SP-unlock
unlock method: smart fast
interface: META_DLL_v6.1108.00
Connect...
Connecting...
done
Release Power button now !
BaseBand chip version: MT6225, E05
ECO version:
DSP firmware version: 2006.06.14
DSP patch version: 1.0
S/W version: X670_V1_Z2_FRES_BFFA105
H/W board version: ZTEMT25_07A_HW_A
Melody version Melody V0.0
Version: X670_V1_Z2_FRES_BFFA105
44 byte(s) read
imei #1: 358895030454988F7810
157 byte(s) read
166 byte(s) read
preparing new data...
writing data...
warning: NVRAM write (0002) failed
145 byte(s) read
972 byte(s) read
writing data...
verifying...
verification Ok
Shutdown...
done
Finished, time used: 19 sec
Remove/Install battery now !
The Following 3 Users Say Thank You to alimobile279 For This Useful Post:
Old 03-02-2020, 16:10   #62681 (permalink)
Member: 1677653
Thanks Meter: 2,769
Tecno f1 frp reset done
Card found : A6936825 , v0140
Load IDBase v120125 Ok!
Update configuration ...
Socket Error # 11001
Host not found.
Update failed! Check settings and/or internet connection!
Operation : Identify [ v2.08 ]
PTFN : MediaTek PreLoader USB VCOM (Android) (COM18)
PORT : 18
BROM : Init BROM
BROM init passed!
TYPE : LEGACY MTK
BROM : DA sent
DA : AGENT started!
eMMC : OK
eMMC : 45000170454538484F160138ED6571AB
DAInf: 4 : 2 : 156
DA : DRAM ready!
EMMC: 70010045483845453801164FAB7165ED
EMMC: VEN : KINGSTON | OEM : 01 | DEV : EH8EE8
EMMC:
USER : 0x1C8000000 [ 7.13 GB ]
DRAM: 0x40000000 [ 1.00 GB ]
RNID : 9F99DC5C34720D5F504D59DBE9457BBE
Boot done!
Patch Level : O11019
Display ID : F1-VP510EFG-GO-180903V4
Ver. CodeName : REL
Ver. Release : 8.1.0
Sec. Patch : 2018-08-05
Build Time : 1535962940
Product Model : TECNO F1
Product Brand : TECNO
Product Name : VP510
Product Device : TECNO-F1-PRO
Product Manfct : TECNO MOBILE LIMITED
Product Info : k80_bsp
Product Board : F1
Board Platform : mt6580
IMEI[0] : XXXXXXXXXXXXXXX
IMEI[1] : XXXXXXXXXXXXXXX
IMEI[2] : XXXXXXXXXXXXXXX
NVRAM check : Passed!
Done!
Elapsed: 00:00:20
Operation : Reset Settings/Format FS [ v2.08 ]
Mode : FRP [ RESET PROTECTION ]
PORT : 18
BROM : Init BROM
BROM init passed!
TYPE : LEGACY MTK
BROM : DA sent
DA : AGENT started!
eMMC : OK
DAInf: 4 : 2 : 156
DA : DRAM ready!
EMMC:
Boot done!
Done!
Elapsed: 00:00:17
Old 03-03-2020, 09:50   #62682 (permalink)
yuranc8's Avatar
Member: 2680008
Thanks Meter: 1,639
Thumbs up Doogee N10 SC9863A FRP Done
Card found : 9EF826E0 , v0139
Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.04
Load IDBase v1119 Ok!
Operation : Identify [ v2.04 ]
BootMode : FLASH
1. Power off device, wait 10-15 seconds
2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- )
3. Insert cable in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : 0_SC9863x_BASE : SC9863_eMMC_3GB_RS
Sending Init Boot ...
Boot sent!
Kick FDL ...
BootVersion : Spreadtrum Boot Block version 1.1
Protocol setup ...
Port speed : 921600
Sending Flash Boot ...
Boot sent!
Kick FLASH FDL ...
FDL : Control transfered!
Boot Done!
Device info :
Patch Level    : OPM2.171019.012
Display ID     : DOOGEE_N10_Android8.1-20190712
Ver. Incmt     : 20190712
Ver. CodeName  : REL
Sec. Patch     : 2019-05-05
Build Time     : 1565607437
Product Model  : N10
Product Brand  : DOOGEE
Product Name   : N10
Product Device : Y7
Product Manfct : DOOGEE
Product Info   : N10
Product Board  : sp9863a_1h10
Board Platform : sp9863a
Update DataBase ...
Platform Version: MOCORTM_18B_W18.45.3_Debug
Project Version:   sharkl3_pub
BASE  Version:    FM_BASE_18B_W18.45.3
HW Version:        sc9863A_modem
CMP_Time : 11-07-2018 03:17:51
MODEM TAG : MOCORTM_18B_W18.45.3_Debug_FM_BASE_18B_W18.45.3_sc9863A_modem_sharkl3_pub
UserData : STATE : ENCRYPTION
Done!
Elapsed: 00:02:34
Operation : Format FS / Reset Settings [ v2.04 ]
Mode : Default [ Reset Settings + FRP ]
BootMode : FLASH
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
Boot Done!
Wipe Ok : UserData
Wipe Ok : Cache
Wipe Ok : FRP
Done!
Elapsed: 00:00:57
The Following 2 Users Say Thank You to yuranc8 For This Useful Post:
Old 03-03-2020, 10:01   #62683 (permalink)
localizator's Avatar
Member: 2550141
Thanks Meter: 1,115
Cool Asus Zenfone Go (Z00VD) Reset FRP & Flash Firmware Done
PTFN : MTK USB Port (COM54)
MODE : BOOTROM
PORT : 54
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
     TYPE : LEGACY MTK
BROM : BOOTROM
MODE : 0_base : BASE_v1952 | Manual : Enabled
BROM : DA sent
     DA : AGENT started!
eMMC : OK
eMMC : 484A019065314738B829070591527FDD
DAInf: 4 : 2 : 156
DA : EXT_RAM NOT initialized!
eMMC : OK
eMMC : 90014A4838473165050729B8DD7F5291
     EMI : DEV : MT6752
     EMI : SRC : preloader_aw806.bin
     EMI : CNT : 0004
     EMI : [00] : ID : 90014A483847316505 : VEN : HYNIX     | DEV : H8G1e : RAM : [ 2,00 GB ]
     EMI : [01] : ID : 90014A484147326505 : VEN : HYNIX     | DEV : HAG2e : RAM : [ 2,00 GB ]
     EMI : [02] : ID : 13014E52314A39364E : VEN : MICRON    | DEV : R1J96N : RAM : [ 2,00 GB ]
     EMI : [03] : ID : FE014E50314A39354B : VEN : MICRON    | DEV : P1J95K : RAM : [ 1,00 GB ]
     EMI : Init EMI from PRELOADER
INIT : 0xBC : DRAM [ 0x00000000 :  [ 0 B ] ]
DRAM : DRAM: 0x80000000 [ 2,00 GB ]
     DA : DRAM ready!
        EMMC: 90014A483847316550729B8DD7F5291
        EMMC: VEN : HYNIX | OEM : 4A01 | DEV : H8G1e
        EMMC:
              RPMB   : 0x00400000 [ 4,00 MB ]
        RNID : 4AE1B31BD5646648577E279841484F72
DA : USB : FULL-SPEED
DA : USB : Change Port Speed
PTFN : DA USB VCOM Port (COM60)
PORT : 60
Boot done!
Patch Level    : LMY47I
Display ID     : WW_Phone-user 5.1 LMY47I WW_Phone-12.1.0.51-20160825 release-keys
Ver. CodeName  : REL
Ver. Release   : 5.1
Sec. Patch     : 2016-06-01
Build Time     : 1472131480
Product Model  : ASUS_Z00VD
Product Brand  : asus
Product Name   : WW_Phone
Product Device : ASUS_Z00VD
Product Board  : ASUS_Z00VD
Product Manfct : asus
Product Info   : ASUS_Z00VD
USERDATA : PLAIN
NVRAM check : Failed! NVRAM empty!
Backup path : Backup\MT6580__4AE1B31BD5646648577E279841484F72\
[3] Read : NVRAM
[14] Read : NVDATA
[2] Read : PROINFO
[7] Read : LK
[4] Read : PROTECT1
[5] Read : PROTECT2
Backup done!
Done!
Elapsed: 00:00:38
Mode : FULL FACTORY ( FORCED + FRP )
MODE : BOOTROM
PORT : 54
BROM : Init BROM
BROM init passed!
     TYPE : LEGACY MTK
BROM : BOOTROM
BROM : DA sent
     DA : AGENT started!
eMMC : OK
DAInf: 4 : 2 : 156
eMMC : OK
     EMI : DEV :
     EMI : SRC :
     EMI : CNT : 0000
     DA : DRAM ready!
        EMMC:
PORT : 60
Boot done!
Format Ok : CACHE
Done!
Elapsed: 00:00:46
Operation : Write Flash [ v2.08 ]
Repartition   : Enabled
Flash Verify  : Disabled
Reg.Pre-Erase : Enabled
Verify HW/SW  : Enabled
SData Backup  : Disabled
Safe UserData : Disabled
Flash Format  : Disabled
Files :11
[FL] : Set : preloader_aw806.bin
[FL] : Set : lk-sign.bin
[FL] : Set : boot-sign.img
[FL] : Set : recovery-sign.img
[FL] : Set : logo-sign.bin
[FL] : Set : secro-sign.img
[FL] : Set : adf-sign.img
[FL] : Set : apd-sign.img
[FL] : Set : system-sign.img
[FL] : Set : cache-sign.img
[FL] : Set : userdata-sign.img
[FL] : Total size : 0x72F4BA3C [ 1,80 GB ]
MODE : BOOTROM
PORT : 54
BROM : Init BROM
BROM init passed!
     TYPE : LEGACY MTK
BROM : BOOTROM
BROM : DA sent
     DA : AGENT started!
eMMC : OK
DAInf: 4 : 2 : 156
eMMC : OK
     EMI : DEV :
     EMI : SRC :
     EMI : CNT : 0000
     DA : DRAM ready!
        EMMC:
PORT : 60
Boot done!
[FL] : HW verification passed!
SEC_DL : True (CUST)
SEC_DL : SECURE USB DL ENABLED
SEC_ID : 0x65313830313934626563316235326366
[FL] : Pre-Erase
Erase : 0x0000000000000000 : 0x0000000000080000
Erase : 0x0000000001C80000 : 0x0000000008B80000
Erase : 0x000000000B200000 : 0x0000000127800000
[FL] : RePartition
[FL] : RePartition Ok!
SecInit : LK
SecInit : BOOT
SecInit : RECOVERY
SecInit : LOGO
SecInit : SECRO
SecInit : ADF
SecInit : APD
SecInit : SYSTEM
SecInit : CACHE
SecInit : USERDATA
[FL] : Flashing now ...
Write : PRELOADER
Update bootloader code ...
Update bootloader Ok!
Write : LK
Write : BOOT
Write : RECOVERY
Write : LOGO
Write : SECRO
Write : ADF
Write : APD
Write : SYSTEM
Write : CACHE
Write : USERDATA
SEC_DL : WRITE INFO : OK
[FL] : RePartition
[FL] : Flashing finished!
Done!
Elapsed: 00:03:49
The Following 2 Users Say Thank You to localizator For This Useful Post:
Old 03-03-2020, 11:48   #62684 (permalink)
Member: 395389
Sonork: no idi
Thanks Meter: 193
Lt360 frp remove successfully
Mode : Reset FRP
BootMode : FLASH
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : 0_SC9850x_BASE : SC9850_eMMC_1GB_RS
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
Boot Done!
Wipe Ok : FRP
Done!
Elapsed: 00:00:34
The Following 3 Users Say Thank You to szktk For This Useful Post:
Old 03-03-2020, 13:22   #62685 (permalink)
limonbogra's Avatar
Member: 2856614
Sonork: 100.650600
Thanks Meter: 252
symphony i20, v155, formate done by cm2
eMMC Flash : 90014A4838473165050753320D909389
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , e1G8
[eMMC] : FLASH_CID : 90014A4838473165050753320D909389
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID : 0x7A4636214FCABD341DD17E9A2CABC3A5
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:44
The Following User Says Thank You to limonbogra For This Useful Post:
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Page generated in 0.51797 seconds with 10 queries
