03-10-2020, 09:16 | #62761 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Africa.uganda
Member: 562975 Status: Offline Sonork: better tomorow Thanks Meter: 247 | Itel A16 frp 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:54 |
The Following 2 Users Say Thank You to ibrajinja For This Useful Post: |
03-10-2020, 10:43 | #62762 (permalink) |
No Life Poster Join Date: Jul 2009 Location: SINDH PAKISTAN
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Vgotel ocean9 pattern lock remove done Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 11 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC983x eMMC Loader v5.0 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x00000001037F7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:31 Reconnect Power/Cable! |
The Following User Says Thank You to Nadeem Waris For This Useful Post: |
03-10-2020, 11:12 | #62763 (permalink) |
Product Supporter Join Date: Aug 2007 Location: karachi
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | xcell zoom firmware READ DONE Code: Operation : Identify [ v2.09 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM192) MODE : BOOTROM PORT : 192 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BOOTROM MODE : 0_base : BASE_v1952 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6735 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 90014A484147346132A44CE36A348D51 DAInf: 4 : 2 : 155 DA : EXT_RAM NOT initialized! eMMC : OK eMMC : 484A019061344741E34CA432518D346A NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 EMI : DEV : INFINITY EMI : SRC : INFINITY-BOX_INTERNAL_EMIDB_v0 INIT : 0xBC : eMMC [ 0x00000000 : [ 0 B ] ] DRAM : DRAM: 0x80000000 [ 2.00 GB ] DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 90014A484147346132A44CE36A343451 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HAG4a2 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3AB800000 [ 14.68 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 3A8B4B3C5FAFEC99846E78A299FE0F29 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : FULL-SPEED DA : USB : Change Port Speed PTFN : MTK DA USB VCOM (Android) (COM359) MODE : PRELOADER PORT PORT : 359 Boot done! Patch Level : NRD90M Display ID : F9G62B.LTXI.Xcell.HB.H.SSXSJS5MHMYP1HK.0420.V3.04 Ver. CodeName : REL Ver. Release : 7.0 Sec. Patch : 2018-04-05 Build Time : 1524212991 Product Model : Zoom Product Brand : Xcell Product Name : Xcell_Zoom Product Device : Xcell_Zoom Product Manfct : coosea Board Platform : mt6737m Product Info : pri6737m_65_n USERDATA : ENCRYPTED Done! Elapsed: 00:00:16 Operation : Read Firmware [ v2.09 ] ExtSparse : Enabled ForceRead : Disabled 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM192) MODE : BOOTROM PORT : 192 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BOOTROM MODE : 0_base : BASE_v1952 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6735 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 90014A484147346132A44CE36A348D51 DAInf: 4 : 2 : 155 DA : EXT_RAM NOT initialized! eMMC : OK eMMC : 484A019061344741E34CA432518D346A NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 EMI : DEV : INFINITY EMI : SRC : INFINITY-BOX_INTERNAL_EMIDB_v0 INIT : 0xBC : eMMC [ 0x00000000 : [ 0 B ] ] DRAM : DRAM: 0x80000000 [ 2.00 GB ] DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 90014A484147346132A44CE36A343451 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HAG4a2 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3AB800000 [ 14.68 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 3A8B4B3C5FAFEC99846E78A299FE0F29 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : FULL-SPEED DA : USB : Change Port Speed PTFN : MTK DA USB VCOM (Android) (COM359) MODE : PRELOADER PORT PORT : 359 Boot done! Patch Level : NRD90M Display ID : F9G62B.LTXI.Xcell.HB.H.SSXSJS5MHMYP1HK.0420.V3.04 Ver. CodeName : REL Ver. Release : 7.0 Sec. Patch : 2018-04-05 Build Time : 1524212991 Product Model : Zoom Product Brand : Xcell Product Name : Xcell_Zoom Product Device : Xcell_Zoom Product Manfct : coosea Board Platform : mt6737m Product Info : pri6737m_65_n MT6737M__coosea__Zoom__7.0__F9G62B.LTXI.Xcell.HB.H.SSXSJS5MHMYP1HK.0420.V3.04__NRD90M__pri6737m_65_n SecureDevice : Paired type! -> INFO : That device WILL dead after ReadOut Flashing! -> INFO : Only partial flashing ( f.e. SYSTEM, VENDOR and etc. ) available! -> INFO : In most cases you can "unsecure" device in Engineer mode Read : preloader.bin Read : proinfo.img Read : nvram.bin Read : lk.bin Read : boot.img Read : recovery.img Read : logo.bin Read : secro.img Read : tz.img Read : system.img ExtSparse : Compression ratio : 15% Read : cache.img Read : userdata.img FW Size : 2.63 GB Android Info saved : _Android_info.txt Scatter : MT6737_Android_scatter.txt Saved to : C:\Users\SAEED\Desktop\MT6737M__coosea__Zoom__7.0__F9G62B.LTXI.Xcell.HB.H.SSXSJS5MHMYP1HK.0420.V3.04__NRD90M__pri6737m_65_n\ Done! Elapsed: 00:08:08 |
The Following 2 Users Say Thank You to saeedullah_khan For This Useful Post: |
03-10-2020, 12:24 | #62764 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Oppo A37F FRP Reset Done With King Infinity CM2 Card found : A19EC787 , v0138 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 410 [MSM8916] ID_BLOCK_S : 24BE2895 ID_BLOCK_L : 12D28876E14D7A755207C9D61168E8E0 ID_BLOCK_L : 95E856F9FA65D55E734217CCC629C704 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:17 Reconnect Power/Cable! |
The Following User Says Thank You to azhergoga007 For This Useful Post: |
03-10-2020, 13:16 | #62765 (permalink) |
No Life Poster Join Date: Mar 2016 Location: Ukraine
Member: 2550141 Status: Offline Thanks Meter: 1,115 | Lenovo X3 Lite Pro (A7010A48) Reset FRP Done Lenovo X3 Lite Pro (A7010A48) Reset FRP Done Code: Update configuration ... Update Ok! Load IDBase v36128 Ok! Operation : Identify [ v2.09 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM22) MODE : PRELOADER PORT PORT : 22 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6753 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000001 BROM : SecMode : SBC BROM : PRELOADER PORT MODE : 0_base : BASE_v1952 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6753 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 15010051345A334D4202D7C7CCAE2BD7 DAInf: 4 : 2 : 155 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 15010051345A334D4202D7C7CCAEA2D7 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : Q4Z3MB EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00400000 [ 4,00 MB ] USER : 0x747C00000 [ 29,12 GB ] SRAM: 0x00020000 [ 128,00 KB ] DRAM: 0x80000000 [ 2,00 GB ] CHIP : MT6753 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : B32C31F785CCE0CE19224FCC9F40E6CE STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Patch Level : MRA58K Display ID : A7010a48_S230_161129_ROW Ver. CodeName : REL Ver. Release : 6.0 Sec. Patch : 2016-08-05 Build Time : 1480427359 Product Model : Lenovo A7010a48 Product Brand : Lenovo Product Name : k5fpr Product Device : A7010a48 Product Manfct : LENOVO Board Platform : mt6753 Product Info : A7010a48 USERDATA : PLAIN Done! Elapsed: 00:05:57 Code: Operation : Reset Settings/Format FS [ v2.09 ] Mode : FULL FACTORY ( FORCED + FRP ) 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM22) MODE : PRELOADER PORT PORT : 22 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6753 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000001 BROM : SecMode : SBC BROM : PRELOADER PORT MODE : 0_base : BASE_v1952 | Manual : Disabled BROM : Change Configuration settings for target AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6753 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 15010051345A334D4202D7C7CCAE2BD7 DAInf: 4 : 2 : 155 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 15010051345A334D4202D7C7CCAEA2D7 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : Q4Z3MB EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00400000 [ 4,00 MB ] USER : 0x747C00000 [ 29,12 GB ] SRAM: 0x00020000 [ 128,00 KB ] DRAM: 0x80000000 [ 2,00 GB ] CHIP : MT6753 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : B32C31F785CCE0CE19224FCC9F40E6CE STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Format Ok : USERDATA Done! Elapsed: 00:00:43 |
The Following User Says Thank You to localizator For This Useful Post: |
03-10-2020, 15:49 | #62766 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile X75 MT6580 FRP Reset Done With King Infinity CM2 Card found : S/N : A19EC787 , v0138 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100513858534142064718DCA89223 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BASX8 [eMMC] : FLASH_CID : 150100513858534142064718DCA89223 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xD9C8F395FFD979211C8B824D9BAC5C0F INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:48 Reconnect Power/Cable! |
03-11-2020, 07:45 | #62767 (permalink) |
No Life Poster Join Date: Apr 2015 Location: LOOLCANO Taba Day.
Member: 2385819 Status: Offline Sonork: No More Used Thanks Meter: 827 | Moto C Network Lock Done In Few Secends. Operation : Identify [ v2.09 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM89) MODE : PRELOADER PORT PORT : 89 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : PRELOADER PORT MODE : Moto : XT17[54][55][56][58] | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_SWSEC.bin AGENT : Found MT6735 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 150100464536324D42039551D8751D7B DAInf: 4 : 2 : 147 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 150100464536324D42039551D875947B EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FE62MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3A3E00000 [ 14.56 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : BAB31E81B672F11CE4C774A3C8A79353 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Patch Level : NRD90M.061 Display ID : NRD90M.061 Ver. CodeName : REL Ver. Release : 7.0 Sec. Patch : 2018-01-05 Build Time : 1517899250 Product Model : Moto C Product Brand : motorola Product Name : namath_54 Product Device : namath Product Manfct : motorola Board Platform : mt6737m Product Info : namath USERDATA : PLAIN Done! Elapsed: 00:00:14 Operation : SP Unlock [ v2.09 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM89) MODE : PRELOADER PORT PORT : 89 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : PRELOADER PORT MODE : Moto : XT17[54][55][56][58] | Manual : Disabled BROM : Change Configuration settings for target AGENT : Look for suitable BootChain in DA ... AGENT : DA_SWSEC.bin AGENT : Found MT6735 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 150100464536324D42039551D8751D7B DAInf: 4 : 2 : 147 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 150100464536324D42039551D875947B EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FE62MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3A3E00000 [ 14.56 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : BAB31E81B672F11CE4C774A3C8A79353 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! ID0 : Lock : Locked! | MNC : 256 | CNT : 65 | CODE : 1289159440641961 ID1 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : ID2 : Lock : Not Locked | MNC : 0 | CNT : 10 | CODE : 11112222 ID3 : Lock : Not Locked | MNC : 0 | CNT : 10 | CODE : 33334444 ID4 : Lock : Not Locked | MNC : 0 | CNT : 10 | CODE : 55556666 ID5 : Lock : Not Locked | MNC : 0 | CNT : 10 | CODE : 77778888 ID6 : Lock : Not Locked | MNC : 0 | CNT : 10 | CODE : 99990000 Direct unlock done! Done! Elapsed: 00:00:19 |
The Following 4 Users Say Thank You to ahmer5050 For This Useful Post: |
03-11-2020, 07:59 | #62768 (permalink) |
Banned Join Date: Oct 2017 Location: pakistan kpk mansehra Age: 26
Member: 2765424 Status: Offline Thanks Meter: 1,039 | oppo a37m flash done cm2 mT2 oppo a37m flash done cm2 mT2 Oppo A37M-MT6750 Fix Hang on logo flash done |
The Following 3 Users Say Thank You to taimur-ahmad For This Useful Post: |
03-11-2020, 08:09 | #62769 (permalink) |
No Life Poster Join Date: Jun 2014 Location: Infinity Box Team
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Qmobile G3 read user code done Operation : Read UserCode [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 390 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CA02 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : E8532926126C5AD47A18ECB0449923A8 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0112 , [MXIC] MX25L3291FWJI_09 [0] : FLASH_DIE : 00C2 0020 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Read ExtData Sorting ExtData Reading UserCode Active : Yes , Code : 197966 PLock|MobTrack : Not active Done! Elapsed: 00:00:05 Reconnect Power/Cable! |
The Following User Says Thank You to Luckey1 For This Useful Post: |
03-11-2020, 09:04 | #62770 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Qmobile LT 300 pattern lock & frp done Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 11 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC983x eMMC Loader v5.0 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x00000001163F7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:24 Reconnect Power/Cable! |
03-11-2020, 13:48 | #62771 (permalink) |
No Life Poster Join Date: Feb 2005 Location: GSM WORLD
Member: 118520 Status: Offline Thanks Meter: 3,551 | VIVO Y91I 1820 AND:8.1.0 MT6765 BRUSH Done SUCCESSFULLY BRUSH DONE(VIVO Y91I 1820 AND:8.1.0 MT6765)USB THANKS INFINITY-BOX TEAM |
The Following 2 Users Say Thank You to gracy_elec For This Useful Post: |
03-11-2020, 14:38 | #62772 (permalink) | |
Major Poster Join Date: May 2012 Location: KPK Kohat Peshawer
Member: 1758710 Status: Offline Thanks Meter: 17 | Quote:
03-11-2020, 16:35 | #62773 (permalink) |
No Life Poster Join Date: Feb 2017 Location: Quelimane Mz Age: 26
Member: 2680008 Status: Offline Thanks Meter: 1,639 | Movitel M9103 SP Unlock Done META MODE Code: Card found : 9EF826E0 , v0140 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.09 Load IDBase v36128 Ok! Operation : SP Unlock [ v2.09 ] Mode : META 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM6) MODE : PRELOADER PORT PORT : 6 Waiting BOOT ack ... PRELOADER : ACK confirmed! INIT : META confirmed! Boot done! AP_CHIP : MT6739,S01 AP_SWVR : Movitel_M9103_1.0_201907080234 MD_CHIP : MT6739 MD_SWVR : TK_MD_BASIC_HW IMEI[1] : 354 ID0 : Lock : Locked! | MNC : 2816 | CNT : 5 | CODE : 12345678 ID1 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 56781234 ID2 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 11112222 ID3 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 33334444 ID4 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 55556666 ID5 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 77778888 ID6 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 99990000 IMEI[2] : 3546 ID0 : Lock : Locked! | MNC : 2816 | CNT : 5 | CODE : 12345678 ID1 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 56781234 ID2 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 11112222 ID3 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 33334444 ID4 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 55556666 ID5 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 77778888 ID6 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 99990000 Done! Elapsed: 00:04:54 |
The Following 2 Users Say Thank You to yuranc8 For This Useful Post: |
03-11-2020, 18:01 | #62774 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Itel it1409 frp reset done Operation : Identify [ v2.04 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731x_BASE : SC7731C_eMMC_512MB_NS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... ProtoEx : : TRCC not supported! FDL : Control transfered! Boot Done! Device info : Patch Level : MRA58K Display ID : it1409-W406A-6.0-OP-V017-20170118 Ver. Incmt : eng.admn.20170118.192917 Ver. CodeName : REL Ver. Release : 6.0 Sec. Patch : 2016-12-05 Build Time : 1484739063 Product Model : itel it1409 Product Brand : Itel Product Name : itel_it1409 Product Device : itel_it1409 Product Board : sp7731ceb_it1409 Product Manfct : Itel Board Platform : sc8830 Product Info : itel_it1409 Update DataBase ... SecInfo : IMEI[1] : XXXXXXXXXXXXXXX IMEI[2] : XXXXXXXXXXXXXXX IMEI[3] : XXXXXXXXXXXXXXX WIFIMAC : 9CAF6F93112C BT_MAC : 2801936FAF9C Platform Version: MOCORTM_W16.34.2_P2_Debug Project Version: sc7731C_CP0_modem BASE Version: TM_BASE_W16.34.2_P2 MMI Version: sc7731C_modem HW Version: sc7731C_CP0_modem CMP_Time : 11-25-2016 21:00:16 MODEM TAG : MOCORTM_W16.34.2_P2_Debug_TM_BASE_W16.34.2_P2_sc77 31C_CP0_modem_sc7731C_CP0_modem_sc7731C_modem UserData : STATE : PLAIN Done! Elapsed: 00:01:15 Operation : Format FS / Reset Settings [ v2.04 ] Mode : Reset FRP BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731x_BASE : SC7731C_eMMC_512MB_NS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... ProtoEx : : TRCC not supported! FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:01:19 |
The Following User Says Thank You to Yusuf Lawal For This Useful Post: |
03-11-2020, 19:04 | #62775 (permalink) |
No Life Poster Join Date: Feb 2019 Location: Madagascar
Member: 2897012 Status: Offline Thanks Meter: 400 | Orange rise 55 sp unlock done Operation : SP Unlock [ v2.09 ] Mode : META 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM119) MODE : PRELOADER PORT PORT : 119 Waiting BOOT ack ... PRELOADER : ACK confirmed! INIT : META confirmed! Boot done! AP_CHIP : MT6739 AP_SWTM : Tue May 28 15:36:03 CST 2019 AP_SWVR : Orange_Rise55_DS_O_T_L_V01.5_190525_MP MD_CHIP : MT6739 MD_SWVR : TK_MD_BASIC_HW IMEI[1] : 3xxxxxxxxxxxxx4 ID0 : Lock : Locked! | MNC : 4864 | CNT : 255 | CODE : 12345678 ID1 : Lock : Not Locked | MNC : 0 | CNT : 255 | CODE : 56781234 ID2 : Lock : Not Locked | MNC : 0 | CNT : 255 | CODE : 11112222 ID3 : Lock : Not Locked | MNC : 0 | CNT : 255 | CODE : 33334444 ID4 : Lock : Not Locked | MNC : 0 | CNT : 255 | CODE : 55556666 ID5 : Lock : Not Locked | MNC : 0 | CNT : 255 | CODE : 77778888 ID6 : Lock : Not Locked | MNC : 0 | CNT : 255 | CODE : 99990000 IMEI[2] : 3xxxxxxxxxxxx2 ID0 : Lock : Locked! | MNC : 4864 | CNT : 255 | CODE : 12345678 ID1 : Lock : Not Locked | MNC : 0 | CNT : 255 | CODE : 56781234 ID2 : Lock : Not Locked | MNC : 0 | CNT : 255 | CODE : 11112222 ID3 : Lock : Not Locked | MNC : 0 | CNT : 255 | CODE : 33334444 ID4 : Lock : Not Locked | MNC : 0 | CNT : 255 | CODE : 55556666 ID5 : Lock : Not Locked | MNC : 0 | CNT : 255 | CODE : 77778888 ID6 : Lock : Not Locked | MNC : 0 | CNT : 255 | CODE : 99990000 Done! Elapsed: 00:01:03 |
The Following 2 Users Say Thank You to Manikanika81 For This Useful Post: |
