07-23-2020, 07:49 | #63856 (permalink) |
No Life Poster Join Date: Jul 2009 Location: SINDH PAKISTAN
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Q Mobile Infinity C FRP Reset Don with CM2 SPD Set mode to : SP [SC773x] eMMC [Android 7.x] Start at : [7/23/2020 / 11:38:04 AM] Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 26 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x eMMC Loader v7 InfinityBox Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x00000002CA5F7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:22 Reconnect Power/Cable! |
07-23-2020, 07:57 | #63857 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile I6 Metal 1 MT6580 FRP Reset Done With King Infinity CM2 Code: Card found : S/N : A19EC787 , v0144 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 11 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4838473165050730C9DC77B3E1 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e1G8 [eMMC] : FLASH_CID : 90014A4838473165050730C9DC77B3E1 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xD9C8F395DC2FBD2DA886512F09671E59 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:39 Reconnect Power/Cable! |
07-23-2020, 08:39 | #63858 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,772 | Qmobile x2 hang on logo done by cm2 Card found : S/N : 73CA70CC , v0144 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 22 ] Sync... Inital Boot Ok! BB_CPU_PID : 6571 BB_CPU_NME : [MediaTek] MT6571_S00 BB_CPU_EXT : 0xCA00 , 0x8D00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8B NAND Flash : 009800BC009000660076001600080000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0011 , [KINGSTON] KTN0403CS_TCR1 [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0016 0008 [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 1000/0040/01/NIM_Px-1 DEV RID : 0xD9C8F395FA9226AFC42AE3F08A713D70 INT RAM : 0x00020000 EXT RAM : 0x10000000 [256 MiB] BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:13 Reconnect Power/Cable! |
The Following User Says Thank You to A.G.Shahid For This Useful Post: |
07-23-2020, 08:42 | #63859 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,772 | Telenor infinity 4g reset frp done by cm2 Card found : S/N : 73CA70CC , v0144 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 22 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 460001154D323145719A0D42AF030EF0 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM21E [eMMC] : FLASH_CID : 150100464531324D420D9A71F00E54AF [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xB9E2EB7762AD1D063AAA91073A68F2A0 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:52 Reconnect Power/Cable! |
07-23-2020, 09:51 | #63860 (permalink) |
Major Poster Join Date: May 2020 Location: pakistan
Member: 2956389 Status: Offline Thanks Meter: 124 | KING CM2 Vivo 1823 pettran%password Reset Settings/Format FS DONE IN META Operation : Reset Settings/Format FS [ v2.13 ] Mode : META 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM19) MODE : BOOTROM PORT : 19 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+ARB BROM : BOOTROM BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 0000 0000 [0200] V0: 0000 0000 [0001] BROM : SOCID : D3E8EFE2B35B0584B0E3B460EF65FD49F27B94E0E2636946B6 A1BD275C3819CD BROM : Configuring target for META BROM : META configured! INIT : META confirmed! Boot done! AP_CHIP : MT6765,S01 AP_SWVR : alps-mp-o1.mp6.tc19sp-V2_k62v1.64.bsp_P293 AP_HWVR : S01 Format Ok : UserData Done! Elapsed: 00:00:39 Reconnect Power/Cable! |
The Following 4 Users Say Thank You to MAHER GEE For This Useful Post: |
07-23-2020, 13:36 | #63861 (permalink) |
Freak Poster Join Date: Aug 2018 Location: bagbari bogra dhaka bangladesh
Member: 2856614 Status: Offline Sonork: 100.650600 Thanks Meter: 252 | SP9863A__itel a46 w5503l ver 9 formate by cm2 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Itel : itel L5503L Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:30 |
The Following 5 Users Say Thank You to limonbogra For This Useful Post: |
07-23-2020, 14:30 | #63862 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Oppo A37F QLM Read PAttren Code Done With King Infinity CM2 Code: Operation : Read PatternLock [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 410 [MSM8916] ID_BLOCK_S : 26E10B8A ID_BLOCK_L : 1FE9837BDA404D78271CF4D9267DF5D5 ID_BLOCK_L : B8CB75D4D948F27396612AE3E10C1A21 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Read Ok! Trying decrypt ... PatternLock sequence : 5478 Done! Elapsed: 00:00:22 Reconnect Power/Cable! |
07-23-2020, 14:44 | #63863 (permalink) | |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,419 | Infinix X609 F.R.p & Factory Reset Done Quote:
Operation : Reset Settings/Format FS [ v2.13 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : PreLoader USB VCOM Port (COM216) MODE : PRELOADER PORT PORT : 216 Waiting BOOT ack ... PRELOADER : ACK confirm FAIL! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x01 BROM : PRELOADER PORT MODE : TECNO : SEC_MIXED | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 460001154D323645AC340342C3B537F2 DAInf: 4 : 2 : 156 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 150100464536324D420334ACF237B5C3 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FE62MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3A3E00000 [ 14.56 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 8979C3FB1263FEBD8CB897FC4DB9046A STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:19 Reconnect Power/Cable! | |
07-24-2020, 06:19 | #63864 (permalink) |
Freak Poster Join Date: Nov 2011 Location: Bahawal nager pakistan
Member: 1698141 Status: Offline Sonork: 1617901 Thanks Meter: 155 | tecno cd7 android 10.0 read flash file with cm2 Operation : Read Firmware [ v2.13 ] ExtSparse : Enabled ForceRead : Disabled 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM17) MODE : PRELOADER PORT PORT : 17 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT MODE : TECNO : SEC_MIXED | Manual : Disabled BROM : SOCID : AEDCBE7266FC0DC651BC15A5B08965117EA9CF72485A7E3A63 1075BBBD1DFD6F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: 150100445036444142039B9F68A747B1 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : DP6DAB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 1F1DD2B38AB68BAB21DCC8EB8F1BC33A DA : USB : HIGH-SPEED Boot done! Patch Level : QP1A.190711.020 Display ID : CD7-H6214ABDE-Q-GL-200515V508 Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2020-05-05 Build Time : 1589472150 Product Info : cd7_h6214 Product Board : TECNO-CD7 Board Platform : mt6765 MT6765__10__CD7-H6214ABDE-Q-GL-200515V508__QP1A.190711.020__cd7_h6214 Read : preloader.bin Read : proinfo.img Read : persist.img ExtSparse : Compression ratio : 92% Read : tkv.img Read : recovery.img Read : md1rom.img Read : spmfw.img Read : tinysys-scp.bin Read : tinysys-sspm.bin Read : nvram.bin Read : lk.bin Read : boot.img Read : logo.bin Read : dtbo.img Read : tz.img Read : vbmeta.img Read : vbmeta_system.img Read : vbmeta_vendor.img Read : super.img ExtSparse : Compression ratio : 7% Read : cache.img Read : tranfs.img Read : userdata.img FW Size : 4.04 GB Android Info saved : _Android_info.txt Scatter : MT6765_Android_scatter.txt Saved to : C:\Users\Ideal\Desktop\MT6765__10__CD7-H6214ABDE-Q-GL-200515V508__QP1A.190711.020__cd7_h6214\ Done! Elapsed: 00:05:19 |
The Following User Says Thank You to nasiraslam For This Useful Post: |
07-24-2020, 06:37 | #63865 (permalink) |
No Life Poster Join Date: Apr 2011 Location: Pakistan
Member: 1555233 Status: Offline Thanks Meter: 2,192 | KING CM2 Q Infinity E FRP REMOVE SUCCESSFULLY Card found : A9EC786B , v0144 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.05 Load IDBase v42913 Ok! Operation : Identify [ v2.05 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731x_BASE : SC7731C_eMMC_1GB_NS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Device info : Patch Level : MRA58K Display ID : S21_HB_C10F_QMobile_432_V01_20190909 Ver. Incmt : S21_HB_C10F_QMobile_432_V01_20190909 Ver. CodeName : REL Ver. Release : 6.0 Sec. Patch : 2018-05-05 Build Time : 1568031199 Product Model : Q Infinity E Product Brand : HB Product Name : S21_C10F_QMOBILE Product Device : S21_C10F Product Board : S21_C10F Product Manfct : HB Board Platform : sc8830 Product Info : S21_C10F Product Model : KC1 Platform Version: MOCORTM_14B_7731C_W16.xx.x_Debug Project Version: sc7731C_CP0_modem BASE Version: TM_BASE_W16.xx.x MMI Version: sc7731C_modem HW Version: sc7731C_CP0_modem CMP_Time : 07-04-2016 13:42:20 MODEM TAG : MOCORTM_14B_7731C_W16.xx.x_Debug_TM_BASE_W16.xx.x_ sc7731C_CP0_modem_sc7731C_CP0_modem_sc7731C_modem UserData : STATE : PLAIN [EXTFS] Done! Elapsed: 00:02:56 Operation : Format FS / Reset Settings [ v2.05 ] Mode : Reset FRP BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731x_BASE : SC7731C_eMMC_1GB_NS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:01:38 |
The Following 5 Users Say Thank You to amjadnona For This Useful Post: |
07-24-2020, 06:42 | #63866 (permalink) |
Member: 1555233 Status: Offline Thanks Meter: 2,192 | KING CM2 CALME C18 sc6531efm_ security code reset done without boot key svc mode Card found : A9EC786B , v0144 Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.06 SCRD mode : AUTO SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ] Operation : Format FileSystem [ v1.06 ] 1. Power off device 2. Not hold any key on device! 3. Insert cable and battery in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! Format FFS Done! Done! Elapsed: 00:00:48 Reconnect Power/Cable! |
The Following 4 Users Say Thank You to amjadnona For This Useful Post: |
07-24-2020, 06:48 | #63867 (permalink) |
Member: 1555233 Status: Offline Thanks Meter: 2,192 | KING CM2 Infinix Smart 4 (X653c) FRP REMOVE SUCCESSFULLY Card found : A9EC786B , v0144 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.13 Load IDBase v714150 Ok! Operation : Identify [ v2.13 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM7) MODE : PRELOADER PORT PORT : 7 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT MODE : INFINIX : SECURE_BASE | Manual : Disabled BROM : SOCID : DCC03AA7D1A19D2150F9BD0F5A4DDF56A22FE5E3A5EF027111 7541112BCC53B9 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_SWSEC.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: 150100514436334D42017D50D2DB47A9 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QD63MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : A4BF711E75CBEF1012D2AC9E8D6C512C DA : USB : HIGH-SPEED Boot done! Patch Level : PPR1.180610.011 Display ID : X653C-H6114GH-PGo-200328V225 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2020-04-05 Build Time : 1585337636 Product Model : Infinix X653C Product Brand : Infinix Product Name : H6114 Product Device : Infinix-X653C Product Manfct : INFINIX MOBILITY LIMITED Product Info : x653c_h6114go Product Board : Infinix-X653C Board Platform : mt6761 USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption **) STORAGE : LifeStatus : Verify NOT supported by DA/HW! Done! Elapsed: 00:00:37 Operation : Reset Settings/Format FS [ v2.13 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM7) MODE : PRELOADER PORT PORT : 7 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT MODE : INFINIX : SECURE_BASE | Manual : Disabled BROM : SOCID : DCC03AA7D1A19D2150F9BD0F5A4DDF56A22FE5E3A5EF027111 7541112BCC53B9 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_SWSEC.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: 150100514436334D42017D50D2DB47A9 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QD63MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : A4BF711E75CBEF1012D2AC9E8D6C512C DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:35 Reconnect Power/Cable! |
07-24-2020, 06:56 | #63868 (permalink) |
Member: 1555233 Status: Offline Thanks Meter: 2,192 | KING CM2 TECNO CAMON 12 Air kc3 FRP REMOVE SUCCESSFULLY Card found : A9EC786B , v0144 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.13 Load IDBase v714150 Ok! Operation : Identify [ v2.13 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM7) MODE : PRELOADER PORT PORT : 7 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT MODE : 0_base : BASE_v1712 | Manual : Enabled BROM : SOCID : F8E69D29C35E832F7657B2562187C91FA1CEC421C588E272A2 B4119721DE7DF1 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: 90014A6843396150330196319995C645 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : hC9aP3 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 8FB46AA775A731136DEC015C713F376B DA : USB : HIGH-SPEED Boot done! Patch Level : PPR1.180610.011 Display ID : KC3-H627G-P-200617V305 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2020-06-05 Build Time : 1592385718 Product Model : TECNO KC3 Product Brand : TECNO Product Name : H627 Product Device : TECNO-KC3 Product Manfct : TECNO MOBILE LIMITED Product Info : kc3_h627mt62 Product Board : TECNO-KC3 Board Platform : mt6765 USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption *) STORAGE : LifeStatus : Verify NOT supported by DA/HW! Done! Elapsed: 00:00:33 Operation : Reset Settings/Format FS [ v2.13 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM7) MODE : PRELOADER PORT PORT : 7 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT MODE : 0_base : BASE_v1712 | Manual : Enabled BROM : SOCID : F8E69D29C35E832F7657B2562187C91FA1CEC421C588E272A2 B4119721DE7DF1 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: 90014A6843396150330196319995C645 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : hC9aP3 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 8FB46AA775A731136DEC015C713F376B DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:35 Reconnect Power/Cable! |
07-24-2020, 10:29 | #63869 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Redmi Note 5A Remove FRP Lock Done :) Code: Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 425 [MSM8917] ID_BLOCK_S : 7059C90C ID_BLOCK_L : 024FDCFA4241B7EAEBFD4B3AAE1CFCD3 ID_BLOCK_L : 23DD970EC1E8FA302FBE5B4E299D493C Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8917 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x90 , VENDOR : HYNIX , NAME : HAG4a2 Boot Ok! Brand : xiaomi ProdName : ugglite ProdModel : Redmi Note 5A Device : ugglite AndroidVer: 7.1.2 Manufact. : Xiaomi SysPatch : N2G47H DevComTime: 7/9/2019 3:06:38 AM QLMxCPU : MSM8937 USERData : ENCRYPTED GCSec : NORMAL Done! Elapsed: 00:00:10 Reconnect Power/Cable! Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 425 [MSM8917] ID_BLOCK_S : 7059C90C ID_BLOCK_L : 024FDCFA4241B7EAEBFD4B3AAE1CFCD3 ID_BLOCK_L : 23DD970EC1E8FA302FBE5B4E299D493C Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8917 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x90 , VENDOR : HYNIX , NAME : HAG4a2 Boot Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:11 Reconnect Power/Cable! |
The Following User Says Thank You to syed tuqeer For This Useful Post: |
07-24-2020, 13:17 | #63870 (permalink) |
Banned Join Date: May 2013 Location: Hacked by Hackflax on tiktok
Member: 1941705 Status: Offline Thanks Meter: 1,248 | Load IDBase v714142 Ok! Update configuration ... Update Ok! Load IDBase v714142 Ok! Operation : Identify [ v2.13 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM316) MODE : PRELOADER PORT PORT : 316 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT MODE : 0_base : BASE_v1712 | Manual : Disabled BROM : SOCID : 7811D6EC85E1E1C0A61B510AA5856CBDFC2F8EC5C49099BB0F 1297C8A32560A3 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6763 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256,00 KB ] DRAM: 0x30000000 [ 768,00 MB ] EMMC: 150100524836344D420299921022443D EMMC: VEN : SAMSUNG | OEM : 01 | DEV : RH64MB EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00400000 [ 4,00 MB ] USER : 0xE8F800000 [ 58,24 GB ] CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : E129F27C5103BC5CC44BCDF0A15E160D DA : USB : HIGH-SPEED Boot done! Patch Level : O11019 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2018-08-05 Build Time : 1536129409 Product Model : X-TREME_PQ37 Product Brand : Sigma_mobile Product Name : X-TREME_PQ37 Product Device : X-TREME_PQ37 Product Manfct : Fortune Ship Display ID : X-treme_PQ37_Sigma_mobile_V0.0.7_05_09_18 Product Info : rs802_64 Product Board : rs802_64 Board Platform : mt6763 USERDATA : FILESYSTEM : EXT4 with FDE ( Full Disk Encryption *) NVRAM check : Passed! NVRAM : SEC NORMAL [ No extra security ] STORAGE : LifeStatus : Verify NOT supported by DA/HW! Done! Elapsed: 00:00:47 |
