07-31-2021, 16:11 | #67412 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Card found : 73CA70CC , v0150 Infinity-Box Android Service Tool [AST] v1.03 Operation : Identify [ v1.03 ] Waiting for device in fastboot mode ... 1. Power off device. Press and hold 'VOL DOWN' button 2. Insert USB cable, hold button until device will be found! Connect Ok! Main Info ============ CPU : MSM8916 CID : 0x0002 IMEI : 354142071706867 UID : 46470A1E00000000000000000000 Model Info ============ DevModel : XT1609 IntName : harpia SW Info ============ DevSWVer : Blur_Version.26.21.48.harpia_vzw.verizon.en.US DevQCVer : LA.BR.1.2.9-01810-8x16.0 BaseBand : M8916_20250106.08.05.23R HARPIA_NA_CUST BootLDRv : moto-msm8916-81.12 HW Info ============ eMMCInfo : 16GB SKHynix REV=07 PRV=08 TYPE=57 DRAMInfo : 2GB Hynix S8 SDRAM DIE=8Gb Lock Info ============ BLUnlock : no WarrantyVoid : no FRP Lock : protected (77) Done! Elapsed: 00:00:12 Operation : Moto ADB Enable [ v1.03 ] Mode : Enable Factory Waiting for device in fastboot mode ... 1. Power off device. Press and hold 'VOL DOWN' button 2. Insert USB cable, hold button until device will be found! Connect Ok! Operation done! -- > Info : Wait till device boot, make "Enable ADB" operation after -- > Info : Don't forget DISABLE "FACTORY MODE" after make "RESET FRP"! Done! Elapsed: 00:00:05 Operation : Moto ADB Enable [ v1.03 ] Mode : Enable ADB Waiting for NetInterface arrival ... 1. Power off device. Press and hold 'VOL DOWN' and 'POWER ON' buttons 2. Select by 'VOL DOWN' or 'VOL UP' FACTORY MODE , press 'POWER ON' 3. Connect USB cable, when device boot complete! Connect Ok! Waiting ... Trying link with : 192.168.137.2 Connected to device! Device : XT1609 Switching to FACTORY ... Setting Unsecure mode Waiting device ... Connect Ok! Trying link with : 192.168.137.2 Connected to device! Device : XT1609 Setting ADB ... Waiting device ... Connect Ok! Trying link with : 192.168.137.2 Connected to device! Device : XT1609 Setting ADB ... 1. Disconnect cable from device, wait device reboot 2. Make "Reset FRP" 3. Disable "FACTORY MODE" after operations done! Done! Elapsed: 00:00:55 Operation : Reset FRP (ADB) [ v1.03 ] Waiting for device in ADB mode ... 1. Connect device, enable 'DEVELOPER MODE' and 'USB DEBUG', if need! 2. Insert USB cable, accept AUTH on PhoneScreen, if software ask! Connect Ok! Device : harpia_vzw Model : XT1609 FRP reset passed! Make FACTORY RESET from menu! -- > MOTO FRP : Don't forget to DISABLE FACTORY MODE! Done! Elapsed: 00:00:14 Operation : Moto ADB Enable [ v1.03 ] Mode : Disable Factory Waiting for device in fastboot mode ... 1. Power off device. Press and hold 'VOL DOWN' button 2. Insert USB cable, hold button until device will be found! Connect Ok! Operation done! Done! Elapsed: 00:00:05 |
07-31-2021, 16:14 | #67413 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Vgo tel four 22 read password done by cm2 Card found : S/N : 73CA70CC , v0150 Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 5 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CA02 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 18FAD6550CD43811F1B31131DAD79CC3 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 File_Info : FISE61D_11C_PCB01_gprs_MT6261_S00.B1907_VGOTEL_V05 _20201105.bin FileVersion : B1907_Vgotel_V05_20201105 Done! Elapsed: 00:00:07 Reconnect Power/Cable! Operation : Read UserCode [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 5 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CA02 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 18FAD6550CD43811F1B31131DAD79CC3 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Read ExtData Sorting ExtData Reading UserCode Active : Yes , Code : 0852 PLock|MobTrack : Not active Done! Elapsed: 00:00:06 Reconnect Power/Cable! |
07-31-2021, 16:16 | #67414 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Vivo v2026 remove frp done by cm2 Card found : 73CA70CC , v0150 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.27 Load IDBase v718267 Ok! Update configuration ... Update Ok! Load IDBase v718267 Ok! Operation : Identify [ v2.27 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM22) MODE : BOOTROM PORT : 22 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 52BD253D9B090D574C8304802E36FF58 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : E5AC03B9F2EF357BCFF0882D4C365A206763018C6A6ADDF626 B1AA35CF47D036 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Look for EMI BROM : SLA : EMI found! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_k65v1_64_bsp.bin EMI : CNT : 0009 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID : 90014A6843396150330110113DD818E3 EMMC: VEN : HYNIX : OEM : 74 : ID : 684339615033 EMMC: VEN : HYNIX : hC9aP3 EMMC: SNN : 269565400 ( 0x10113DD8) , MF : 1/2021 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 2AEC7105801133F022A4FEC68C784C4 DA : USB : HIGH-SPEED Boot done! Product Brand : vivo Product Device : 2026 Product Model : V2026 Product Name : 2026 Patch Level : RP1A.200720.012 Display ID : RP1A.200720.012 release-keys Product Info : k65v1_64_bsp Ver. CodeName : REL Ver. Release : 11 Sec. Patch : 2021-05-01 Build Time : 07.06.2021 Product Board : k65v1_64_bsp Board Platform : mt6765 Product Manfct : vivo USERDATA : FILESYSTEM : EXT4 with FBE ( File-Base Encryption ) NVRAM check : Passed! NVRAM : SEC NORMAL [ No extra security ] Backup sensetive data [ 14 ] Backup path : Backup\MT6765__52BD253D9B090D574C8304802E36FF58\ [35] Read : NVRAM [10] Read : NVDATA [25] Read : PROINFO [36] Read : LK [9] Read : NVCFG [20] Read : PROTECT1 [21] Read : PROTECT2 [23] Read : PERSIST [0] Read : PRELOADER [22] Read : SECCFG Backup done! STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : UNLOCKED! Done! Elapsed: 00:00:41 Operation : Reset Settings/Format FS [ v2.27 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM22) MODE : BOOTROM PORT : 22 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 52BD253D9B090D574C8304802E36FF58 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : E5AC03B9F2EF357BCFF0882D4C365A206763018C6A6ADDF626 B1AA35CF47D036 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_k65v1_64_bsp.bin EMI : CNT : 0009 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID : 90014A6843396150330110113DD818E3 EMMC: VEN : HYNIX : OEM : 74 : ID : 684339615033 EMMC: VEN : HYNIX : hC9aP3 EMMC: SNN : 269565400 ( 0x10113DD8) , MF : 1/2021 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 2AEC7105801133F022A4FEC68C784C4 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x835757 Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Format Ok : USERDATA Done! Elapsed: 00:00:33 Reconnect Power/Cable! |
07-31-2021, 19:38 | #67415 (permalink) |
Freak Poster Join Date: Dec 2017 Location: venezuela caracas
Member: 2790129 Status: Offline Thanks Meter: 64 | Unlock bootloader REDMI 9 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM7) MODE : BOOTROM PORT : 7 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Talbot TYPE : MODERN [RAPHAEL] BROM : MEID : 32926822F4E4F33DA2F70091F2DF3DD6 BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 4DBFBB239FC7B1F7F46D8A2C3FC5580AE8AAFBECD7C7B3D20D 1BEB5E2FE5839C BROM : Sending FireFly FireFly : Starting ... FireFly : Init Core FireFly : Core init done! FireFly : Running : v03.04.03 on MT6768 FireFly : eMMC init passed! EMMC: CSD : D02701320F5903FFF6DBFFEF8E40400D EMMC: CSD : TEMP_WRITE_PROTECT: False EMMC: CSD : PERM_WRITE_PROTECT: False EMMC: CID : 15010044503644414203D18990CB5775 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 445036444142 EMMC: VEN : SAMSUNG : DP6DAB EMMC: SNN : 3515453643 ( 0xD18990CB) , MF : 5/2020 EMMC: EXTCSD : rev1.8 ( eMMC 5.1 ) EMMC: EXTCSD [BOOT_BUS_WIDTH] : 0x02 EMMC: EXTCSD [PARTITION_CONFIG] : 0x48 EMMC: EXTCSD [SIZE] : Market : 64 GB EMMC: EXTCSD [SIZE] : Actual : 0xE8F800000 [ 58.24 GB ] EMMC: EXTCSD [EOL] : EOL status : Normal ( Less than 80% reserved blocks used ) EMMC: EXTCSD [EOL_A] : SLC status : 0% - 10% used EMMC: EXTCSD [EOL_B] : MLC status : 0% - 10% used EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] DA : USB : HIGH-SPEED Boot done! Product Brand : Redmi Product Device : lancelot Product Model : lancelot Product Name : lancelot_global Patch Level : QP1A.190711.020 Display ID : build-20210331141959 Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2021-03-01 Build Time : 31.03.2021 Product Info : lancelot Product Manfct : Xiaomi Product Board : lancelot Board Platform : mt6768 BootLoader State : Locked! BootLoader State : Unlocked! Done! |
The Following 4 Users Say Thank You to jeremyxps For This Useful Post: |
08-01-2021, 09:36 | #67416 (permalink) |
Product Supporter Join Date: Jul 2008 Location: iran-shiraz
Member: 814775 Status: Offline Sonork: 100.1587334 Thanks Meter: 973 | Xiaomi Redmi Note 9 (Merlin) Bootloader Unlock Done Xiaomi Redmi Note 9 (Merlin) Bootloader Unlock Done Code: 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM14) MODE : BOOTROM PORT : 14 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Talbot TYPE : MODERN [RAPHAEL] BROM : MEID : 772FC3E40131CA14FB97D3EDB347DD41 BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 0D99995E96C8E4D80657C47FF97BB52A449D0095023F7F3190C0AA46A2545C93 BROM : Sending FireFly FireFly : Starting ... FireFly : Init Core FireFly : Core init done! FireFly : Running : v03.04.03 on MT6768 FireFly : eMMC init passed! EMMC: CSD : D04F01328F5913FFFFFFFFEF8A400083 EMMC: CSD : TEMP_WRITE_PROTECT: False EMMC: CSD : PERM_WRITE_PROTECT: False EMMC: CID : 13014E47314A3953391003A035F4574F EMMC: VEN : MICRON : OEM : 78 : ID : 47314A395339 EMMC: VEN : MICRON : G1J9S9 EMMC: SNN : 60831220 ( 0x03A035F4) , MF : 5/2020 EMMC: EXTCSD : rev1.8 ( eMMC 5.1 ) EMMC: EXTCSD [BOOT_BUS_WIDTH] : 0x02 EMMC: EXTCSD [PARTITION_CONFIG] : 0x48 EMMC: EXTCSD [SIZE] : Market : 128 GB EMMC: EXTCSD [SIZE] : Actual : 0x1D1F000000 [ 116.48 GB ] EMMC: EXTCSD [EOL] : EOL status : Normal ( Less than 80% reserved blocks used ) EMMC: EXTCSD [EOL_A] : SLC status : 0% - 10% used EMMC: EXTCSD [EOL_B] : MLC status : 0% - 10% used EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] USER : 0x1D1F000000 [ 116.48 GB ] DA : USB : HIGH-SPEED Boot done! Product Brand : Redmi Product Device : merlin Product Model : M2003J15SC Product Name : merlin_global Patch Level : QP1A.190711.020 Display ID : AL2522-Merlin-V101-Q-0517 Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2021-05-01 Build Time : 17.05.2021 Product Info : merlin Product Manfct : Xiaomi Product Board : merlin Board Platform : mt6768 BootLoader State : Locked! BootLoader State : Unlocked! Done! Elapsed: 00:01:05 Reconnect Power/Cable! |
The Following 4 Users Say Thank You to dr_moosavi For This Useful Post: |
08-01-2021, 09:38 | #67417 (permalink) |
Freak Poster Join Date: Jun 2009 Location: Nepal
Member: 1050365 Status: Offline Thanks Meter: 210 | Samsung M017F Read Firmware Done Samsung M017F Read Firmware Done Read Info: Operation : Identify [ v2.27 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1633 (Android) (COM11) MODE : PRELOADER PORT PORT : 11 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : Reset Interface! PTFN : MediaTek USB Port_V1633 (COM10) MODE : BOOTROM PORT : 10 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 3B27D679035C488E068549A8C9D6BA45 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 37E28EEDC8554AFABC05EC68D3A76C9F7AAC3A263C945A0586 47A7D04FE12ECE BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Look for EMI BROM : SLA : EMI found! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_s96116ca1.bin EMI : CNT : 0008 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: CID : 1501004758364241420067E1D350874F EMMC: VEN : SAMSUNG : OEM : 0 : ID : 475836424142 EMMC: VEN : SAMSUNG : GX6BAB EMMC: SNN : 1742852944 ( 0x67E1D350) , MF : 8/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 2D85E8E51959581680419802EEA92581 DA : USB : HIGH-SPEED Boot done! Product Brand : samsung Product Model : SM-M017F Product Name : a10sins Product Device : a10s Patch Level : QP1A.190711.020 Display ID : QP1A.190711.020.M017FXXS2BUC1 Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2021-03-01 Build Time : 10.03.2021 Product Info : a10s Product Board : S96116CA1 Board Platform : mt6765 Product Manfct : samsung NVRAM check : Passed! NVRAM : SEC SIGNED [ IMEI RSA SIGNED ] Backup sensetive data [ 16 ] Backup path : Backup\MT6765__3B27D679035C488E068549A8C9D6BA45\ [5] Read : NVRAM [14] Read : NVDATA [23] Read : PROINFO [28] Read : LK [13] Read : NVCFG [16] Read : PROTECT1 [17] Read : PROTECT2 [1] Read : PGPT [19] Read : PERSIST [0] Read : PRELOADER [6] Read : EFS [7] Read : SEC_EFS [20] Read : PERSISTENT Backup done! STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : NOT Enabled! Done! Elapsed: 00:01:25 Read Firmware: Operation : Read Firmware [ v2.27 ] ExtSparse : Enabled ForceRead : Disabled 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1633 (Android) (COM11) MODE : PRELOADER PORT PORT : 11 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : Reset Interface! PTFN : MediaTek USB Port_V1633 (COM10) MODE : BOOTROM PORT : 10 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 3B27D679035C488E068549A8C9D6BA45 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 37E28EEDC8554AFABC05EC68D3A76C9F7AAC3A263C945A0586 47A7D04FE12ECE BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_s96116ca1.bin EMI : CNT : 0008 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: CID : 1501004758364241420067E1D350874F EMMC: VEN : SAMSUNG : OEM : 0 : ID : 475836424142 EMMC: VEN : SAMSUNG : GX6BAB EMMC: SNN : 1742852944 ( 0x67E1D350) , MF : 8/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 2D85E8E51959581680419802EEA92581 DA : USB : HIGH-SPEED Boot done! Product Brand : samsung Product Model : SM-M017F Product Name : a10sins Product Device : a10s Patch Level : QP1A.190711.020 Display ID : QP1A.190711.020.M017FXXS2BUC1 Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2021-03-01 Build Time : 10.03.2021 Product Info : a10s Product Board : S96116CA1 Board Platform : mt6765 Product Manfct : samsung MT6765__samsung__SM-M017F__10__QP1A.190711.020.M017FXXS2BUC1__QP1A.190 711.020__a10s Read : preloader.bin Read : efuse.img Read : nvram.bin Read : efs.img ExtSparse : Compression ratio : 93% Read : sec_efs.img ExtSparse : Compression ratio : 33% Read : param.img Read : up_param.img Read : persist.img ExtSparse : Compression ratio : 91% Read : persistent.img Read : proinfo.img Read : md1rom.img Read : spmfw.img Read : tinysys-scp.bin Read : sspm.img Read : lk.bin Read : steady.img Read : boot.img Read : recovery.img Read : dtbo.img Read : tz.img Read : vendor.img ExtSparse : Compression ratio : 32% Read : product.img ExtSparse : Compression ratio : 35% Read : system.img ExtSparse : Compression ratio : 12% Read : vbmeta.img Read : cache.img Read : omr.img Read : userdata.img FW Size : 3.85 GB Android Info saved : _Android_info.txt Scatter : MT6765_Android_scatter.txt Saved to : C:\Users\bimal\Desktop\MT6765__samsung__SM-M017F__10__QP1A.190711.020.M017FXXS2BUC1__QP1A.190 711.020__a10s\ Done! Elapsed: 00:07:01 |
The Following 4 Users Say Thank You to Bimal Shah For This Useful Post: |
08-01-2021, 15:04 | #67418 (permalink) |
No Life Poster Join Date: Dec 2013 Location: Uzbekistan/Tashkent
Member: 2082192 Status: Offline Sonork: not Thanks Meter: 1,119 | Samsung A12 SM-A125F Read Info & FW done ! Samsung A12 SM-A125F Read Info & FW done! need TP. Read Info : Code: Operation : Identify [ v2.27 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1633 (COM43) MODE : BOOTROM PORT : 43 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : D969A40EFD330095EB8A2D9B3DE2635E BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 6B84AFE45252FF4769C8EE1A9AF7B168F801FFF225C600E6264E3E45AB21C07D BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0001 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: CID : 150100445836384D4200BFE6CE0FC7B5 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 445836384D42 EMMC: VEN : SAMSUNG : DX68MB EMMC: SNN : 3219574287 ( 0xBFE6CE0F) , MF : 12/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : A1E42AADED780A35B84FE672BB7C51 DA : USB : HIGH-SPEED Boot done! Product Brand : samsung Product Model : SM-A125F Product Name : a12nsxx Product Device : a12 Patch Level : QP1A.190711.020 Display ID : QP1A.190711.020.A125FXXU1AUC3 Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2021-02-01 Build Time : 15.03.2021 Product Info : a12 Product Board : k65v1_64_bsp_titan_rat Board Platform : mt6765 Product Manfct : samsung NVRAM check : Passed! NVRAM : SEC NORMAL [ No extra security ] Backup sensetive data [ 16 ] Backup path : Backup\MT6765__D969A40EFD330095EB8A2D9B3DE2635E\ Backup done! STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : NOT Enabled! PRELOADER : DEVICE : DEV : MT6765 NME : preloader_k65v1_64_bsp_titan_rat.bin CNT : 000A EMI : [00] : eMMC : LP_DDR4X : ID : 150100445836384D42 : VEN : SAMSUNG | DEV : DX68MB : RAM : [ 3.00 GB ] EMI : [01] : eMMC : LP_DDR4X : ID : 150100444836444142 : VEN : SAMSUNG | DEV : DH6DAB : RAM : [ 4.00 GB ] EMI : [02] : eMMC : LP_DDR4X : ID : 150100445036444142 : VEN : SAMSUNG | DEV : DP6DAB : RAM : [ 4.00 GB ] EMI : [03] : eMMC : LP_DDR4X : ID : 150100335636434142 : VEN : SAMSUNG | DEV : 3V6CAB : RAM : [ 6.00 GB ] EMI : [04] : eMMC : LP_DDR4X : ID : 150100445636444142 : VEN : SAMSUNG | DEV : DV6DAB : RAM : [ 4.00 GB ] EMI : [05] : eMMC : LP_DDR4X : ID : 150100445636444D42 : VEN : SAMSUNG | DEV : DV6DMB : RAM : [ 4.00 GB ] EMI : [06] : eMMC : LP_DDR4X : ID : 150100335636434D42 : VEN : SAMSUNG | DEV : 3V6CMB : RAM : [ 6.00 GB ] EMI : [07] : eMMC : LP_DDR4X : ID : 90014A684238455030 : VEN : HYNIX | DEV : hB8EP0 : RAM : [ 3.00 GB ] EMI : [08] : eMMC : LP_DDR4X : ID : 13014E47314A395238 : VEN : MICRON | DEV : G1J9R8 : RAM : [ 4.00 GB ] EMI : [09] : eMMC : LP_DDR4X : ID : 13014E47314A395339 : VEN : MICRON | DEV : G1J9S9 : RAM : [ 4.00 GB ] Done! Elapsed: 00:00:22 Code: Operation : Read Firmware [ v2.27 ] ExtSparse : Enabled ForceRead : Disabled 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1633 (COM43) MODE : BOOTROM PORT : 43 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : D969A40EFD330095EB8A2D9B3DE2635E BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 6B84AFE45252FF4769C8EE1A9AF7B168F801FFF225C600E6264E3E45AB21C07D BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0001 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: CID : 150100445836384D4200BFE6CE0FC7B5 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 445836384D42 EMMC: VEN : SAMSUNG : DX68MB EMMC: SNN : 3219574287 ( 0xBFE6CE0F) , MF : 12/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : A1E42AADED780A35B84FE672BB7C51 DA : USB : HIGH-SPEED Boot done! Product Brand : samsung Product Model : SM-A125F Product Name : a12nsxx Product Device : a12 Patch Level : QP1A.190711.020 Display ID : QP1A.190711.020.A125FXXU1AUC3 Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2021-02-01 Build Time : 15.03.2021 Product Info : a12 Product Board : k65v1_64_bsp_titan_rat Board Platform : mt6765 Product Manfct : samsung MT6765__samsung__SM-A125F__10__QP1A.190711.020.A125FXXU1AUC3__QP1A.190711.020__a12 Read : preloader.bin Read : efs.img Read : sec_efs.img Read : steady.img Read : nvram.bin Read : spmfw.img Read : tinysys-scp.bin Read : sspm.img Read : uh.img Read : tz.img Read : tzar.img Read : gz.img Read : lk.bin Read : dtbo.img Read : vbmeta.img Read : btd.img Read : persistent.img Read : md1rom.img Read : param.img Read : up_param.img Read : boot.img Read : recovery.img Read : vbmeta_samsung.img Read : efuse.img Read : super.img ExtSparse : Compression ratio : 16% Read : prism.img ExtSparse : Compression ratio : 5% Read : optics.img ExtSparse : Compression ratio : 83% Read : cache.img Read : omr.img Read : spu.img Read : userdata.img FW Size : 5.54 GB Android Info saved : _Android_info.txt Scatter : MT6765_Android_scatter.txt Saved to : C:\1.TEMP\MT6765__samsung__SM-A125F__10__QP1A.190711.020.A125FXXU1AUC3__QP1A.190711.020__a12\ Done! Elapsed: 00:08:31 |
The Following 6 Users Say Thank You to ddilshod93 For This Useful Post: |
08-01-2021, 15:12 | #67419 (permalink) |
Freak Poster Join Date: Dec 2015 Location: MansehrA KPK (Pakistan) Age: 29
Member: 2505147 Status: Offline Sonork: [email protected] Thanks Meter: 183 | redmi9 dead recover and imei repair also done Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.27 Load IDBase v718267 Ok! Update configuration ... Update Ok! Load IDBase v718267 Ok! Operation : Restore backup [ v2.27 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM27) MODE : BOOTROM PORT : 27 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Talbot TYPE : MODERN [RAPHAEL] BROM : MEID : 9457C8EF20EAC1367705B3AF9F708C7C BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : ED2E6D81051290B702C38C619A067FA83D140AAADEF89DD526 79493B5292FAD1 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Xiaomi : 6A | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6768 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_lancelot.bin EMI : CNT : 0009 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00070000 [ 448.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID : 150100444436384D420983E9E44267FB EMMC: VEN : SAMSUNG : OEM : 0 : ID : 444436384D42 EMMC: VEN : SAMSUNG : DD68MB EMMC: SNN : 2213143618 ( 0x83E9E442) , MF : 6/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0001 , EVOL : 0x0000 RNID : 79A9A43D149D61071C3560BA1C43CAAD DA : USB : HIGH-SPEED Boot done! Restore : lk Restore : nvcfg ExtSparse : Compression ratio : 58% Restore : nvdata ExtSparse : Compression ratio : 86% Fail to restore : nvdata , SEC : WRITE DATA NOT ALLOWED Restore : nvram Restore : persist ExtSparse : Compression ratio : 92% Restore : pgpt Restore : proinfo Restore : protect1 ExtSparse : Compression ratio : 45% Restore : protect2 ExtSparse : Compression ratio : 61% Done! Elapsed: 00:03:16 Reconnect Power/Cable! Preloader [HW DEV] Info : EMI : DEV : MT6752 EMI : SRC : preloader_lancelot.bin EMI : CNT : 0009 EMI : [00] : eMMC : LP_DDR4X : ID : 150100444436384D42 : VEN : SAMSUNG | DEV : DD68MB : RAM : [ 3.00 GB ] EMI : [01] : eMMC : LP_DDR4X : ID : 13014E53304A394A38 : VEN : MICRON | DEV : S0J9J8 : RAM : [ 3.00 GB ] EMI : [02] : eMMC : LP_DDR4X : ID : 150100445636444D42 : VEN : SAMSUNG | DEV : DV6DMB : RAM : [ 4.00 GB ] EMI : [03] : eMMC : LP_DDR4X : ID : 150100445036444142 : VEN : SAMSUNG | DEV : DP6DAB : RAM : [ 4.00 GB ] EMI : [04] : eMMC : LP_DDR4X : ID : 13014E47314A395238 : VEN : MICRON | DEV : G1J9R8 : RAM : [ 4.00 GB ] EMI : [05] : eMMC : LP_DDR4X : ID : 90014A684445615033 : VEN : HYNIX | DEV : hDEaP3 : RAM : [ 6.00 GB ] EMI : [06] : eMMC : LP_DDR4X : ID : 150100335036434D42 : VEN : SAMSUNG | DEV : 3P6CMB : RAM : [ 6.00 GB ] EMI : [07] : eMMC : LP_DDR4X : ID : 13014E47314A395339 : VEN : MICRON | DEV : G1J9S9 : RAM : [ 4.00 GB ] EMI : [08] : eMMC : LP_DDR4X : ID : 90014A68423861503E : VEN : HYNIX | DEV : hB8aP> : RAM : [ 3.00 GB ] Operation : Write Flash [ v2.27 ] Repartition : Enabled Flash Verify : Disabled Reg.Pre-Erase : Enabled Verify HW/SW : Enabled SData Backup : Disabled Safe UserData : Disabled Flash Format : Disabled Files :23 [FL] : Set : preloader_lancelot.bin [FL] : Set : recovery.img [FL] : Set : vbmeta.img [FL] : Set : vbmeta_system.img [FL] : Set : vbmeta_vendor.img [FL] : Set : logo.bin [FL] : Set : md1img.img [FL] : Set : spmfw.img [FL] : Set : scp.img [FL] : Set : scp.img [FL] : Set : sspm.img [FL] : Set : sspm.img [FL] : Set : lk.img [FL] : Set : lk.img [FL] : Set : boot.img [FL] : Set : dtbo.img [FL] : Set : tee.img [FL] : Set : tee.img [FL] : Set : exaid.img [FL] : Set : cust.img [FL] : Set : super.img [FL] : Set : cache.img [FL] : Set : userdata.img [FL] : Total size : 0x1B8099658 [ 6.88 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM27) MODE : BOOTROM PORT : 27 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Talbot TYPE : MODERN [RAPHAEL] BROM : MEID : 9457C8EF20EAC1367705B3AF9F708C7C BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : ED2E6D81051290B702C38C619A067FA83D140AAADEF89DD526 79493B5292FAD1 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Xiaomi : 6A | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6768 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6752 EMI : SRC : preloader_lancelot.bin EMI : CNT : 0009 EMI : [00] : eMMC : LP_DDR4X : ID : 150100444436384D42 : VEN : SAMSUNG | DEV : DD68MB : RAM : [ 3.00 GB ] EMI : [01] : eMMC : LP_DDR4X : ID : 13014E53304A394A38 : VEN : MICRON | DEV : S0J9J8 : RAM : [ 3.00 GB ] EMI : [02] : eMMC : LP_DDR4X : ID : 150100445636444D42 : VEN : SAMSUNG | DEV : DV6DMB : RAM : [ 4.00 GB ] EMI : [03] : eMMC : LP_DDR4X : ID : 150100445036444142 : VEN : SAMSUNG | DEV : DP6DAB : RAM : [ 4.00 GB ] EMI : [04] : eMMC : LP_DDR4X : ID : 13014E47314A395238 : VEN : MICRON | DEV : G1J9R8 : RAM : [ 4.00 GB ] EMI : [05] : eMMC : LP_DDR4X : ID : 90014A684445615033 : VEN : HYNIX | DEV : hDEaP3 : RAM : [ 6.00 GB ] EMI : [06] : eMMC : LP_DDR4X : ID : 150100335036434D42 : VEN : SAMSUNG | DEV : 3P6CMB : RAM : [ 6.00 GB ] EMI : [07] : eMMC : LP_DDR4X : ID : 13014E47314A395339 : VEN : MICRON | DEV : G1J9S9 : RAM : [ 4.00 GB ] EMI : [08] : eMMC : LP_DDR4X : ID : 90014A68423861503E : VEN : HYNIX | DEV : hB8aP> : RAM : [ 3.00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00070000 [ 448.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID : 150100444436384D420983E9E44267FB EMMC: VEN : SAMSUNG : OEM : 0 : ID : 444436384D42 EMMC: VEN : SAMSUNG : DD68MB EMMC: SNN : 2213143618 ( 0x83E9E442) , MF : 6/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0001 , EVOL : 0x0000 RNID : 79A9A43D149D61071C3560BA1C43CAAD DA : USB : HIGH-SPEED Boot done! [FL] : HW verification passed! SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : Pre-Erase Erase : 0x0000000000000000 : 0x000000000A4A2000 Erase : 0x000000000C4A2000 : 0x0000000004000000 Erase : 0x0000000017800000 : 0x0000000000A00000 Erase : 0x0000000018500000 : 0x0000000001A00000 Erase : 0x000000001DF00000 : 0x000000030E900000 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing now ... Write : PRELOADER Update bootloader backup copy ... Update bootloader backup copy Ok! Write : RECOVERY Write : VBMETA Write : VBMETA_SYSTEM Write : VBMETA_VENDOR Write : LOGO Write : MD1IMG Write : SPMFW Write : SCP1 Write : SCP2 Write : SSPM_1 Write : SSPM_2 Write : LK Write : LK2 Write : BOOT Write : DTBO Write : TEE1 Write : TEE2 Write : EXAID FAIL : SEC : IMG TOO LARGE Write : CUST FAIL : SEC : IMG TOO LARGE Write : SUPER Write : CACHE Write : USERDATA Ultra : OK! [ All failed parts successfully flashed ] SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing finished! Done! Elapsed: 00:05:11 Reconnect Power/Cable! Operation : Read Security [ v2.27 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM27) MODE : BOOTROM PORT : 27 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Talbot TYPE : MODERN [RAPHAEL] BROM : MEID : 9457C8EF20EAC1367705B3AF9F708C7C BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : ED2E6D81051290B702C38C619A067FA83D140AAADEF89DD526 79493B5292FAD1 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Xiaomi : 6A | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6768 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_lancelot.bin EMI : CNT : 0009 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00070000 [ 448.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID : 150100444436384D420983E9E44267FB EMMC: VEN : SAMSUNG : OEM : 0 : ID : 444436384D42 EMMC: VEN : SAMSUNG : DD68MB EMMC: SNN : 2213143618 ( 0x83E9E442) , MF : 6/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0001 , EVOL : 0x0000 RNID : 79A9A43D149D61071C3560BA1C43CAAD DA : USB : HIGH-SPEED Boot done! NVRAM check : Passed! NVRAM : SEC SIGNED [ IMEI RSA SIGNED ] NVM saved as : MT6768__eMMC__.mt_sec NVM saved to : C:\Users\Awan\Desktop\ Done! Elapsed: 00:00:42 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to awanbrother For This Useful Post: |
08-01-2021, 16:27 | #67420 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Oppo CPH1729 A83 FRP/Pattren Reset Done With King Infinity CM2 Code: Card found : A19EC787 , v0150 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.27 Load IDBase v718267 Ok! UserName and/or Password not set! Can't continue! Update failed! Check settings and/or internet connection! Operation : Identify [ v2.27 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Preloader And Gadget Serial (COM225) MODE : PRELOADER PORT PORT : 225 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 CODE : Bianco TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x02 BROM : PRELOADER PORT AGENT : Oppo : F5 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_PL_CRYPTO.bin AGENT : Found MT6763 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00002001 : DA SEND ERROR! ERROR : SECURE BOOT : MISMATCH BOOT SIGNATURE! INFO : PRELOADER Level : CORRECT DA required : PL/PL_CRYPTO/SWSEC Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.27 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM135) MODE : BOOTROM PORT : 135 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 CODE : Bianco TYPE : MODERN [RAPHAEL] BROM : MEID : D193B04845F88F7B7F403947AB6C0BEC BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : A4C566249B85F35FEBDB269B8DC77D692CDB9A6F35EC5976DEBA8E104D2A07F5 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Look for EMI BROM : SLA : EMI not found BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Oppo : F5 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_PL_CRYPTO.bin AGENT : Found MT6763 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6763 EMI : SRC : preloader_oppo6763_17031.bin EMI : CNT : 000F EMI : [00] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 0 B ] EMI : [01] : eMMC : LP_DDR4X : ID : 150100444836444D42 : VEN : SAMSUNG | DEV : DH6DMB : RAM : [ 4.00 GB ] EMI : [02] : eMMC : DDR3 : ID : 150100525836344D42 : VEN : SAMSUNG | DEV : RX64MB : RAM : [ 4.00 GB ] EMI : [03] : eMMC : DDR3 : ID : 150100524836344142 : VEN : SAMSUNG | DEV : RH64AB : RAM : [ 4.00 GB ] EMI : [04] : eMMC : LP_DDR4X : ID : 150100334836434D42 : VEN : SAMSUNG | DEV : 3H6CMB : RAM : [ 6.00 GB ] EMI : [05] : eMMC : DDR3 : ID : 150100524836344D42 : VEN : SAMSUNG | DEV : RH64MB : RAM : [ 4.00 GB ] EMI : [06] : eMMC : DDR3 : ID : 150100474436424D42 : VEN : SAMSUNG | DEV : GD6BMB : RAM : [ 3.00 GB ] EMI : [07] : eMMC : DDR3 : ID : 150100475836424D42 : VEN : SAMSUNG | DEV : GX6BMB : RAM : [ 3.00 GB ] EMI : [08] : eMMC : DDR3 : ID : 150100474536424D42 : VEN : SAMSUNG | DEV : GE6BMB : RAM : [ 3.00 GB ] EMI : [09] : eMMC : DDR3 : ID : 150100524436344D42 : VEN : SAMSUNG | DEV : RD64MB : RAM : [ 4.00 GB ] EMI : [0A] : eMMC : DDR3 : ID : 13014E53304A394237 : VEN : MICRON | DEV : S0J9B7 : RAM : [ 3.00 GB ] EMI : [0B] : DRAM : DDR3 : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4.00 GB ] EMI : [0C] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4.00 GB ] EMI : [0D] : DRAM : DDR3 : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 3.00 GB ] EMI : [0E] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 6.00 GB ] EMI : Init EMI from PRELOADER DA : SETUP EMI PARAMS FAILED! ERROR : ABORT Error : Fail to init protocol! >>> Internal EMI : Select other EMI number! External Preloader - make sure it correct for connected device! Reconnect Power/Cable! Operation : Reset Settings/Format FS [ v2.27 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM135) MODE : BOOTROM PORT : 135 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 CODE : Bianco TYPE : MODERN [RAPHAEL] BROM : MEID : D193B04845F88F7B7F403947AB6C0BEC BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : A4C566249B85F35FEBDB269B8DC77D692CDB9A6F35EC5976DEBA8E104D2A07F5 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Look for EMI BROM : SLA : EMI not found BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Oppo : F5 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_PL_CRYPTO.bin AGENT : Found MT6763 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6763 EMI : SRC : preloader_oppo6763_17031.bin EMI : CNT : 000F EMI : [00] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 0 B ] EMI : [01] : eMMC : LP_DDR4X : ID : 150100444836444D42 : VEN : SAMSUNG | DEV : DH6DMB : RAM : [ 4.00 GB ] EMI : [02] : eMMC : DDR3 : ID : 150100525836344D42 : VEN : SAMSUNG | DEV : RX64MB : RAM : [ 4.00 GB ] EMI : [03] : eMMC : DDR3 : ID : 150100524836344142 : VEN : SAMSUNG | DEV : RH64AB : RAM : [ 4.00 GB ] EMI : [04] : eMMC : LP_DDR4X : ID : 150100334836434D42 : VEN : SAMSUNG | DEV : 3H6CMB : RAM : [ 6.00 GB ] EMI : [05] : eMMC : DDR3 : ID : 150100524836344D42 : VEN : SAMSUNG | DEV : RH64MB : RAM : [ 4.00 GB ] EMI : [06] : eMMC : DDR3 : ID : 150100474436424D42 : VEN : SAMSUNG | DEV : GD6BMB : RAM : [ 3.00 GB ] EMI : [07] : eMMC : DDR3 : ID : 150100475836424D42 : VEN : SAMSUNG | DEV : GX6BMB : RAM : [ 3.00 GB ] EMI : [08] : eMMC : DDR3 : ID : 150100474536424D42 : VEN : SAMSUNG | DEV : GE6BMB : RAM : [ 3.00 GB ] EMI : [09] : eMMC : DDR3 : ID : 150100524436344D42 : VEN : SAMSUNG | DEV : RD64MB : RAM : [ 4.00 GB ] EMI : [0A] : eMMC : DDR3 : ID : 13014E53304A394237 : VEN : MICRON | DEV : S0J9B7 : RAM : [ 3.00 GB ] EMI : [0B] : DRAM : DDR3 : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4.00 GB ] EMI : [0C] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4.00 GB ] EMI : [0D] : DRAM : DDR3 : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 3.00 GB ] EMI : [0E] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 6.00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: CID : 90014A484247346132A5C73181D34537 EMMC: VEN : HYNIX : OEM : 74 : ID : 484247346132 EMMC: VEN : HYNIX : HBG4a2 EMMC: SNN : 3341910483 ( 0xC73181D3) , MF : 4/2018 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 80E083EFCDA957635497F7679FEA3AB9 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x8F5454 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Done! Elapsed: 00:00:52 Reconnect Power/Cable! |
The Following User Says Thank You to azhergoga007 For This Useful Post: |
08-02-2021, 07:44 | #67421 (permalink) |
Freak Poster Join Date: Aug 2018 Location: bagbari bogra dhaka bangladesh
Member: 2856614 Status: Offline Sonork: 100.650600 Thanks Meter: 252 | redmi 10x 4g bootloadear unlock done(hold vol+-&power batton) Operation : Unlock BootLoader [ v2.27 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM16) MODE : BOOTROM PORT : 16 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Talbot TYPE : MODERN [RAPHAEL] BROM : MEID : 6DD390256EACBAE220DAD4EC767D6A0E BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : FCCED4B4B37A9A4556AE85633D31EB0D42D7FC5B3299284519 E48AF4B65334CD BROM : Sending FireFly FireFly : Starting ... FireFly : Init Core FireFly : Core init done! FireFly : Running : v03.04.03 on MT6768 FireFly : eMMC init passed! EMMC: CSD : D04F01328F5913FFFFFFFFEF8A400083 EMMC: CSD : TEMP_WRITE_PROTECT: False EMMC: CSD : PERM_WRITE_PROTECT: False EMMC: CID : 13014E47314A39533910054624EB5701 EMMC: VEN : MICRON : OEM : 78 : ID : 47314A395339 EMMC: VEN : MICRON : G1J9S9 EMMC: SNN : 88483051 ( 0x054624EB) , MF : 5/2020 EMMC: EXTCSD : rev1.8 ( eMMC 5.1 ) EMMC: EXTCSD [BOOT_BUS_WIDTH] : 0x02 EMMC: EXTCSD [PARTITION_CONFIG] : 0x48 EMMC: EXTCSD [SIZE] : Market : 128 GB EMMC: EXTCSD [SIZE] : Actual : 0x1D1F000000 [ 116.48 GB ] EMMC: EXTCSD [EOL] : EOL status : Normal ( Less than 80% reserved blocks used ) EMMC: EXTCSD [EOL_A] : SLC status : 0% - 10% used EMMC: EXTCSD [EOL_B] : MLC status : 0% - 10% used EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] USER : 0x1D1F000000 [ 116.48 GB ] DA : USB : HIGH-SPEED Boot done! Product Brand : Redmi Product Device : merlin Product Model : M2003J15SC Product Name : merlin Patch Level : RP1A.200720.011 Display ID : RP1A.200720.011 Ver. CodeName : REL Ver. Release : 11 Sec. Patch : 2021-06-01 Build Time : 05.07.2021 Product Info : merlin Product Manfct : Xiaomi Product Board : merlin Board Platform : mt6768 BootLoader State : Locked! BootLoader State : Unlocked! Done! Elapsed: 00:01:01 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to limonbogra For This Useful Post: |
08-02-2021, 11:19 | #67423 (permalink) |
No Life Poster Join Date: Apr 2001 Location: AGADIR Morocco
Member: 3936 Status: Offline Thanks Meter: 237 | redmi note 8 RFP done Operation : Reset Settings/Format FS [ v2.27 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM103) MODE : BOOTROM PORT : 103 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Talbot TYPE : MODERN [RAPHAEL] BROM : MEID : 451E87EAF846B77151A9C87F59F3477E BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : C7F39CD29E71B2EC860FC3156DF9BEE79ED6C753B2AD0040E3 7F1BB5943E73F3 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6768 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_k69v1_64.bin EMI : CNT : 0009 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00070000 [ 448,00 KB ] DRAM: 0x100000000 [ 4,00 GB ] EMMC: CID : 90014A68433861503E0310268F25A733 EMMC: VEN : HYNIX : OEM : 74 : ID : 68433861503E EMMC: VEN : HYNIX : hC8aP> EMMC: SNN : 270962469 ( 0x10268F25) , MF : 10/2020 EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x01000000 [ 16,00 MB ] USER : 0xE8F800000 [ 58,24 GB ] CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0001 , EVOL : 0x0000 RNID : 36A00A011B0370368C631E523EAD5E1F DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:27 |
