12-18-2021, 06:13 | #69001 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile I6 Metal 1 MT6580 FRP/Pattren Reset Done With King Infinity CM2 Code: Card found : S/N : A19EC787 , v0151 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 120 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4838473165050730C21878B325 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e1G8 [eMMC] : FLASH_CID : 90014A4838473165050730C21878B325 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xD9C8F395E0476BA4CD1494E9B63F75B1 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:32 Reconnect Power/Cable! |
12-18-2021, 06:38 | #69002 (permalink) |
No Life Poster Join Date: Jul 2009 Location: SINDH PAKISTAN
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Qmobile sl100 lite reset code done Operation : Reset UserCode [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 4 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CA02 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 12D10D92C619E40EA8E87DBF1BEAD8F0 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Backup done Read ExtData Sorting ExtData Sort Ok, Rebuild Ok Restore ExtData All done UserCode request removed UserCode set to default ( 0000 or 1122 ) Done! Elapsed: 00:00:11 Reconnect Power/Cable! |
12-18-2021, 07:24 | #69003 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Vgotel ocean pattern & frp done Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 98 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC983x eMMC Loader v5.0 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x00000001037F7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:41 Reconnect Power/Cable! |
12-18-2021, 10:10 | #69004 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile X700 Pro V2 MT6580 FRP/Pattren Reset Done With King Infinity CM2 Code: Card found : S/N : A19EC787 , v0151 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 17 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100464A32374D420273BAD3622393 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM72J [eMMC] : FLASH_CID : 150100464A32374D420273BAD3622393 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xD9C8F395A400A836B0401CD4E20BA3A1 INT RAM : 0x00020000 EXT RAM : 0x30000000 [768 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:26 Reconnect Power/Cable! |
12-18-2021, 11:12 | #69005 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Oppo F11 MT6771 FRP/Pattren Reset Done With King Infinity CM2 Code: Card found : A19EC787 , v0151 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.31 Load IDBase v1121431 Ok! UserName and/or Password not set! Can't continue! Load IDBase v1121431 Ok! Operation : Reset Settings/Format FS [ v2.31 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM16) MODE : BOOTROM PORT : 16 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Sylvia TYPE : MODERN [RAPHAEL] BROM : MEID : 80DF5066DCE1EFD9A1DB361071BA5E88 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 968793C5EE8B83B3666E39C56850182F11EE4F8C3745CF439345F8F573B32F4D BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : FF : Look for EMI BROM : FF : EMI found! BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6771 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_oppo6771.bin EMI : CNT : 001A EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00039000 [ 228.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID : 90014A68433861503E0349FA850CC57F EMMC: VEN : HYNIX : OEM : 74 : ID : 68433861503E EMMC: VEN : HYNIX : hC8aP> EMMC: SNN : 1241154828 ( 0x49FA850C) , MF : 12/2018 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 288959C8331D92B793FD28D1AEADAF DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x8F5754 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Done! Elapsed: 00:00:40 Reconnect Power/Cable! |
12-18-2021, 11:22 | #69006 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | VegoTell Samrt 5 SPD9863X FRP/Pattren Reset Done With King Infinity CM2 Code: Card found : A19EC787 , v0151 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.04 Load IDBase v1119 Ok! Operation : Format FS / Reset Settings [ v2.04 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC9863x_BASE : SC9863_eMMC_3GB_RS Sending Init Boot ... Boot sent! Kick FDL ... ERROR : FDL NOT started! Error : Fail to boot FDL! Unsupported device with selected fdl! Change settings! Reconnect Power/Cable! Operation : Format FS / Reset Settings [ v2.04 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC9863x_BASE : SC9863_eMMC_2GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:28 |
12-18-2021, 12:19 | #69007 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,772 | Hope s8 reset password done by cm2 Card found : S/N : 73CA70CC , v0151 Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 10 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 53E7EAB4A9106E7DFC30E9AC356C8FB3 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00400000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 File_Info : MOBA61D_11C_PCB01_gprs_MT6261_S00.KC6122_QSD_F10_S 8_V01_20170420.bin FileVersion : KC6122_QSD_F10_S8_V01_20170420 Done! Elapsed: 00:00:06 Reconnect Power/Cable! Operation : Reset UserCode [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 10 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 53E7EAB4A9106E7DFC30E9AC356C8FB3 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00400000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Backup done Read ExtData Sorting ExtData Sort Ok, Rebuild Ok Restore ExtData All done UserCode request removed UserCode set to default ( 0000 or 1122 ) Done! Elapsed: 00:00:10 Reconnect Power/Cable! |
12-18-2021, 12:19 | #69008 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,772 | Kv k500 hang on logo done by cm2 Card found : S/N : 73CA70CC , v0151 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 10 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CA02 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 854E0DEC8E726E5A130BC1E100BB2384 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0112 , [MXIC] MX25L3291FWJI_09 [0] : FLASH_DIE : 00C2 0020 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Backup done Executing FFS FORMAT now... FAT_RANGE : 0x003B3000-0x003FDFFF , LEN : 0x0004B000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Done! Elapsed: 00:00:08 Reconnect Power/Cable! |
12-18-2021, 12:28 | #69009 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,772 | Qmobile m200 reset password done by cm2 Card found : 73CA70CC , v0151 Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.07 SCRD mode : AUTO SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ] SPRD mode : SC6531 : REV : E001 : NOR : [ 4MB-8MB ] Operation : Identify [ v1.07 ] BootMode : FLASH 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR 6531EFM v2.0 (c)2019 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ] IMEI[1] : IMEI[2] : Done! Elapsed: 00:00:14 Reconnect Power/Cable! Operation : Format FileSystem [ v1.07 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR 6531EFM v2.0 (c)2019 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ] Make backup of sensetive data Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_0D7 3A1FE2D90_NVM.nv Executing FormatFFS ... Format FFS Done! Done! Elapsed: 00:00:18 Reconnect Power/Cable! |
12-18-2021, 12:30 | #69010 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,772 | Oppo a12 cph2083 reset pattern done by cm2 Card found : 73CA70CC , v0151 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.31 Load IDBase v1121431 Ok! Update configuration ... Load IDBase v1121431 Ok! Operation : Reset Settings/Format FS [ v2.31 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM16) MODE : BOOTROM PORT : 16 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 32F603F25408A02BE43B05B0C2D5FFD4 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : C280BAFF3B4D8F5FC9167E2F4B866C1514DE83290AEC3B6B96 7014DE33C85C29 BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_oppo6765_19451.bin EMI : CNT : 000A EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: CID : 1501003458364B4D42033A30DCF687E1 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 3458364B4D42 EMMC: VEN : SAMSUNG : 4X6KMB EMMC: SNN : 976280822 ( 0x3A30DCF6) , MF : 8/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 99C65CECA5F5EC9EFBED79BE756F442E DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x815757 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Done! Elapsed: 00:00:37 Reconnect Power/Cable! |
12-18-2021, 12:31 | #69011 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,772 | Oppo reno 3 cph 2043 reset frf done by cm2 Card found : 73CA70CC , v0151 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.31 Load IDBase v1121431 Ok! Update configuration ... Load IDBase v1121431 Ok! Operation : Reset Settings/Format FS [ v2.31 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM16) MODE : BOOTROM PORT : 16 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6779 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 CODE : Lafite TYPE : MODERN [RAPHAEL] BROM : MEID : 713C7658519936797342219F5A2A14C7 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 3E48093967EBA62152DCBCC398C88449D7BA0356D3D396A818 C0716B66C8C291 BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6779 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0001 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512.00 KB ] DRAM: 0x200000000 [ 8.00 GB ] UFS: CE014B4D3856383030314A4D2D423831 UFS: VEN : 0x01CE VID : KM8V8001JM-B81 IFW : 1000 LU0 : 0x00400000 [ 4.00 MB ] LU1 : 0x00400000 [ 4.00 MB ] LU2 : 0x1DCB000000 [ 119.17 GB ] FSN : 3cfbea00640d REG : 0x101010000 CHIP : MT6779 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : DFE7542C67CC90B9C731E551D84CABC6 DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:20 |
12-18-2021, 18:39 | #69012 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Infinix-X650 Frp Code: Patch Level : O11019 Display ID : X650-H8029AB-OGo-210319V468 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2021-04-05 Build Time : 19.03.2021 Product Brand : Infinix Product Name : H8029 Product Device : Infinix-X650 Product Info : Infinix-X650 Product Model : Infinix X650 Product Manfct : INFINIX MOBILITY LIMITED Product Board : Infinix-X650 Board Platform : mt6580 USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption ***) NVRAM : 0x770297DE NVRAM : State : Ok! INFO : WiFi MAC : AA0037003600 INFO : BlTh MAC : 74C17DF2DEF7 INFO : IMEI[1] : INFO : IMEI[2] : Done! Elapsed: 00:00:29 Operation : Reset Settings/Format FS [ v2.28 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM9) MODE : BOOTROM PORT : 9 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY [MTK] BROM : MEID : 5A4621337540D2AA1B8D1E0D9FC2E700 BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x000000FE BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 460001704543424DD52F204189C6E3B7 DAInf: 4 : 2 : 156 DA : EXT_RAM NOT initialized! eMMC : OK eMMC : 700100464D42434541202FD5B7E3C689 NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 DRAM : 0x0178 EMI : DEV : FireFly EMI : SRC : preloader_x650_h8029.bin EMI : CNT : 0008 EMI : [00] : ID : 150100514536334D42 : VEN : SAMSUNG | DEV : QE63MB : RAM : [ 0 B ] EMI : [01] : ID : 150100464536324D42 : VEN : SAMSUNG | DEV : FE62MB : RAM : [ 0 B ] EMI : [02] : ID : 90014A484247346132 : VEN : HYNIX | DEV : HBG4a2 : RAM : [ 2.00 GB ] EMI : [03] : ID : 700100464D41454538 : VEN : KINGSTON | DEV : FMAEE8 : RAM : [ 1.00 GB ] EMI : [04] : ID : 700100464D42434541 : VEN : KINGSTON | DEV : FMBCEA : RAM : [ 0 B ] EMI : [05] : ID : 90014A68423861503E : VEN : HYNIX | DEV : hB8aP> : RAM : [ 0 B ] EMI : [06] : ID : 150100514436334D42 : VEN : SAMSUNG | DEV : QD63MB : RAM : [ 0 B ] EMI : [07] : ID : 150100515836334142 : VEN : SAMSUNG | DEV : QX63AB : RAM : [ 0 B ] EMI : Init EMI from PRELOADER INIT : 0xBC : DRAM [ 0x00000000 : [ 0 B ] ] DRAM : DRAM: 0x80000000 [ 2.00 GB ] DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: CID : 700100464D42434541202FD5B7E3C689 EMMC: VEN : KINGSTON : OEM : 0 : ID : 464D42434541 EMMC: VEN : KINGSTON : FMBCEA EMMC: SNN : 802535395 ( 0x2FD5B7E3) , MF : 12/2019 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x74A000000 [ 29.16 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 802E38F56601C316AA0990DAF7609104 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : FULL-SPEED DA : USB : Change Port Speed PTFN : MediaTek DA USB VCOM (Android) (COM38) MODE : PRELOADER PORT PORT : 38 Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:47 Reconnect Power/Cable! |
12-18-2021, 18:41 | #69013 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | QMobile Gli Frp Code: Patch Level : OPM2.171019.012 Display ID : OPM2.171019.012 release-keys Ver. Incmt : 1573123675 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2019-11-05 Build Time : 07.11.2019 Product Info : GLi Product Model : GLi Product Brand : QSmart Product Name : GLi Product Device : GLi Product Manfct : QMobile Product Board : k110 Board Platform : sp7731e NVMng : SecurityInfo IMEI[1] : IMEI[2] : IMEI[3] : WIFIMAC : FFFFFFFFFFFF BT_MAC : FFFFFFFFFFFF SEC : SLS:0, SKS:0, SKV:4 Platform Version: MOCORTM_17C_W18.23.4_P22_Debug Project Version: pike2_pub BASE Version: FM_BASE_17C_W18.23.4_P22 HW Version: sc7731e_modem CMP_Time : 04-23-2019 15:44:41 MODEM TAG : MOCORTM_17C_W18.23.4_P22_Debug_FM_BASE_17C_W18.23.4_P22_sc7731e_modem_pike2_pub USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption ***) - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:00:48 Operation : Format FS / Reset Settings [ v2.14 ] Mode : Reset FRP BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0002 FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:31 |
12-18-2021, 18:42 | #69014 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Infinix HOT 4 Frp Code: Brand : Infinix ProdName : X557A1 ProdModel : Infinix HOT 4 Device : X557 AndroidVer: 6.0 MTKxCPU : MT6580 MTKxPRJ : X557-H807A1D1-M-170110V194 Done! Elapsed: 00:00:30 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 10 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100514531334D420DF5EAB8F6C32F Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM31E [eMMC] : FLASH_CID : 150100514531334D420DF5EAB8F6C32F [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xD5229C25BDA3670F34484B94B47C316C INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:11 Reconnect Power/Cable! |
12-18-2021, 18:43 | #69015 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Lenovo A1000 Format Code: Model Name : A1000 Model Brand : Lenovo Model Device: A1000 AndrVersion : 5.0 BaseBand CPU: A1000 CompileDate : 11/21/2016 6:59:56 AM Project Ver : A1000_USR_S30666_1611211455_SPRD7731_ROW Model Ext : Lenovo A1000 ExtraInfo : HWInfo not exists, normal phone Elapsed: 00:00:21 Reconnect Power/Cable! Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 13 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SPRD 773x eMMC loader v3 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x000000012E5FC000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Done! Elapsed: 00:00:25 Reconnect Power/Cable! |
