12-22-2021, 11:42 | #69076 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Qmobile b18 hang on logo done by cm2 Card found : S/N : 73CA70CC , v0151 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 6 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : 823EBD32BAD37F90DFA18E2D7A0FB8F0 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C200 2500 3600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00DB , [MX] MX25U3235E [0] : FLASH_DIE : 00C2 0025 0036 0000 [0] : FLASH_LEN : 0x00300000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Backup done Executing FFS FORMAT now... FAT_RANGE : 0x002B6000-0x002FFFFF , LEN : 0x0004A000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Done! Elapsed: 00:00:28 Reconnect Power/Cable! |
12-22-2021, 11:44 | #69077 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Inifnix x650c remove frp done by cm2 Card found : 73CA70CC , v0151 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.31 Load IDBase v1121431 Ok! Update configuration ... Load IDBase v1121431 Ok! Operation : Reset Settings/Format FS [ v2.31 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM16) MODE : BOOTROM PORT : 16 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 2EF36DC588ADB32B66A2602B51A33318 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 179F93A874DA8D1B93BA6E84C27DEB008F52A72263CA27A48D 183E78ABAAF03F BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : FF : Look for EMI BROM : FF : EMI found! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_x650c_h626.bin EMI : CNT : 000A EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID : 90014A684339615033015177E2119659 EMMC: VEN : HYNIX : OEM : 74 : ID : 684339615033 EMMC: VEN : HYNIX : hC9aP3 EMMC: SNN : 1366811153 ( 0x5177E211) , MF : 9/2019 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 90838FABF9FAD5C2E0B44B24ED0153B3 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x815657 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Done! Elapsed: 00:00:31 Reconnect Power/Cable! |
12-22-2021, 11:46 | #69078 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Oppo a12 cph2083 reset frp done by cm2 Card found : 73CA70CC , v0151 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.31 Load IDBase v1121431 Ok! Update configuration ... Load IDBase v1121431 Ok! Operation : Reset Settings/Format FS [ v2.31 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM16) MODE : BOOTROM PORT : 16 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : DB98B0459CBD7290C709393B4424EC65 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : D6E5DECDBDB7988C772801B4BDD2498E18D4973C620EBBC63B DB9C7E282E36BF BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_oppo6765_19451.bin EMI : CNT : 000A EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID : 1501004448364441420247B76AA427CF EMMC: VEN : SAMSUNG : OEM : 0 : ID : 444836444142 EMMC: VEN : SAMSUNG : DH6DAB EMMC: SNN : 1203202724 ( 0x47B76AA4) , MF : 2/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : E6DFD7B7B3D824ACA087AC936C04AF1F DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:21 Reconnect Power/Cable! |
12-22-2021, 11:52 | #69079 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | vivo V2026 Format & Frp Code: Product Brand : vivo Product Device : 2026 Product Model : V2026 Product Name : 2026 Patch Level : RP1A.200720.012 Display ID : RP1A.200720.012 release-keys Product Info : k65v1_64_bsp Ver. CodeName : REL Ver. Release : 11 Sec. Patch : 2021-10-01 Build Time : 12.10.2021 Product Board : k65v1_64_bsp Board Platform : mt6765 Product Manfct : vivo USERDATA : FILESYSTEM : EXT4 with FBE ( File-Base Encryption ) NVRAM : BBK_R0MP1_K65V1_64_BSP_MDBIN_PCB01_MT6765_S00.MOLY_LR12A_R3_MP_V136_6_P57 NVRAM : 0xB61250C6 NVRAM : State : Ok! INFO : WiFi MAC : BC3ECBD9FCE7 INFO : BlTh MAC : BC3ECBD9FCE6 INFO : IMEI[1] : INFO : IMEI[2] : STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : UNLOCKED! Done! Elapsed: 00:00:35 Operation : Reset Settings/Format FS [ v2.28 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM25) MODE : BOOTROM PORT : 25 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 266D1260E4A0B297560AFBAD4478359E BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 6E1C223A3DC4DA356B64166C5DC393CC92B427C83F28DC6F00FF5D3CB74E20AF BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_k65v1_64_bsp.bin EMI : CNT : 0009 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID : 90014A68433961503301102ECA9BB79B EMMC: VEN : HYNIX : OEM : 74 : ID : 684339615033 EMMC: VEN : HYNIX : hC9aP3 EMMC: SNN : 271501979 ( 0x102ECA9B) , MF : 11/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : B78A62A18A3CB09974D21B165CE8D503 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x835757 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Done! Elapsed: 00:00:43 Reconnect Power/Cable! |
12-22-2021, 11:53 | #69080 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Infinix X650C Format & Frp Code: Patch Level : PPR1.180610.011 Display ID : X650C-H626DEJ-P-210525V327 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2021-06-05 Build Time : 25.05.2021 Product Model : Infinix X650C Product Brand : Infinix Product Name : H626 Product Device : Infinix-X650C Product Manfct : INFINIX MOBILITY LIMITED Product Info : x650c_h626 Product Board : Infinix-X650C Board Platform : mt6765 USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption *) NVRAM : TK_MD_BASIC_MDBIN_PCB01_MT6765_S00.MOLY_LR12A_R3_MP_V66_11_P35 NVRAM : 0xA210197E NVRAM : State : Ok! INFO : WiFi MAC : AA0036004400 INFO : BlTh MAC : 80795DDB7BC8 INFO : IMEI[1] : INFO : IMEI[2] : STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : UNLOCKED! Done! Elapsed: 00:00:34 Operation : Reset Settings/Format FS [ v2.28 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM25) MODE : BOOTROM PORT : 25 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 415CF05614743AF36AB02347C07C3BF7 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 56818C5C727C98E01A39E51D23AE6698D291EB7C32330989C47C7DBE0595F1FF BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_x650c_h626.bin EMI : CNT : 000C EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID : 1501004448364441420298B090023769 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 444836444142 EMMC: VEN : SAMSUNG : DH6DAB EMMC: SNN : 2561708034 ( 0x98B09002) , MF : 3/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : B64BD86E7897588B6D638706A29F53CF DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x815657 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Done! Elapsed: 00:00:48 Reconnect Power/Cable! |
12-22-2021, 11:54 | #69081 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | GFive Gold Pasword Code: Operation : Read UserCode [ v1.07 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR 6531EFM v2.0 (c)2019 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ] Reading data ... STATE : NOT ACTIVE : CODE : 8523 Done! Elapsed: 00:00:21 Reconnect Power/Cable! |
12-22-2021, 11:56 | #69082 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Xcell_Zoom Format Code: Patch Level : NRD90M Display ID : F9G62B.LTXI.Xcell.HB.H.SSXSJS5MHMYP1HK.0420.V3.04 Ver. CodeName : REL Ver. Release : 7.0 Sec. Patch : 2018-04-05 Build Time : 20.04.2018 Product Model : Zoom Product Brand : Xcell Product Name : Xcell_Zoom Product Device : Xcell_Zoom Product Manfct : coosea Board Platform : mt6737m Product Info : pri6737m_65_n IMEI[1] : IMEI[2] : Done! Elapsed: 00:01:29 Operation : Reset Settings/Format FS [ v2.28 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM10) MODE : PRELOADER PORT PORT : 10 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY [MTK] BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN BROM : BROM|BL : 0xFF|0x01 BROM : PRELOADER PORT BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6735 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : Reset Interface! PTFN : MTK USB Port (COM9) MODE : BOOTROM PORT : 9 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY [MTK] BROM : MEID : 56B1362288C4B78373643BD8777A8E38 BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6735 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 90014A484147346132A44CE36A348D51 DAInf: 4 : 2 : 155 DA : EXT_RAM NOT initialized! eMMC : OK eMMC : 484A019061344741E34CA432518D346A NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 DRAM : 0x0178 EMI : DEV : FireFly EMI : SRC : preloader_pri6737m_65_n.bin EMI : CNT : 0007 EMI : [00] : ID : 150100513832334D42 : VEN : SAMSUNG | DEV : Q823MB : RAM : [ 2.00 GB ] EMI : [01] : ID : 150100523832314D42 : VEN : SAMSUNG | DEV : R821MB : RAM : [ 2.00 GB ] EMI : [02] : ID : 150100514531334D42 : VEN : SAMSUNG | DEV : QE13MB : RAM : [ 2.00 GB ] EMI : [03] : ID : 13014E51324A333643 : VEN : MICRON | DEV : Q2J36C : RAM : [ 2.00 GB ] EMI : [04] : ID : 13014E51334A393652 : VEN : MICRON | DEV : Q3J96R : RAM : [ 2.00 GB ] EMI : [05] : ID : 13014E51324A333643 : VEN : MICRON | DEV : Q2J36C : RAM : [ 2.00 GB ] EMI : [06] : ID : 90014A484147346132 : VEN : HYNIX | DEV : HAG4a2 : RAM : [ 2.00 GB ] EMI : Init EMI from PRELOADER INIT : 0xBC : DRAM [ 0x00000000 : [ 0 B ] ] DRAM : DRAM: 0x80000000 [ 2.00 GB ] DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: CID : 90014A484147346132A44CE36A343451 EMMC: VEN : HYNIX : OEM : 74 : ID : 484147346132 EMMC: VEN : HYNIX : HAG4a2 EMMC: SNN : 1289972276 ( 0x4CE36A34) , MF : 3/2017 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3AB800000 [ 14.68 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : D35B4FA646C17F8969B61D4710BDD5FB STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : FULL-SPEED DA : USB : Change Port Speed PTFN : MediaTek DA USB VCOM (Android) (COM38) MODE : PRELOADER PORT PORT : 38 Boot done! SmartInfo : 0x8F5454 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Done! Elapsed: 00:00:50 |
12-22-2021, 11:58 | #69083 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | VGOTEL NEW_7 Frp Code: Brand : VGOTEL ProdName : NEW_7 ProdModel : NEW 7 Device : NEW_7 AndroidVer: 8.1.0 Done! Elapsed: 00:00:15 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 10 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 45010044463430313601AAF2CD10C655 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x45 , OEM : 0100 [eMMC] : FLASH_INF : [SANDISK] , 6104F [eMMC] : FLASH_CID : 45010044463430313601AAF2CD10C655 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB400000 [eMMC] : FLASH_UCP : 15028 MiB [eMMC 16 GiB] DEV RID : 0xD5229C25DCA75AD68C0F7289DE198A25 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:17 Reconnect Power/Cable! |
12-22-2021, 12:00 | #69084 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | HUAWEI LUA-U22 Format & Frp Fix DL Code: Patch Level : HUAWEILUA-U22 Display ID : LUA-U22C328B014 Ver. CodeName : REL Ver. Release : 5.1 Sec. Patch : 2017-12-05 Build Time : 28.12.2017 Product Model : HUAWEI LUA-U22 Product Brand : HUAWEI Product Name : LUA-U22 Product Device : HWLUA-U6582 Product Board : LUA-U22 Product Manfct : HUAWEI Board Platform : mt6582 Product Info : HWLUA-U6582 USERDATA : FILESYSTEM : EXT4 NVRAM : 0x78029084 NVRAM : State : Ok! INFO : WiFi MAC : 10B1F8BCC437 INFO : BlTh MAC : 10B1F8BCC438 INFO : IMEI[1] : INFO : IMEI[2] : Done! Elapsed: 00:00:29 Operation : Reset Settings/Format FS [ v2.28 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM128) MODE : PRELOADER PORT PORT : 128 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6582 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 TYPE : LEGACY [MTK] BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN BROM : BROM|BL : 0xFF|0x01 BROM : PRELOADER PORT BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : 0_base : BASE_v1844 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6582 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : Reset Interface! PTFN : MTK USB Port (COM9) MODE : BOOTROM PORT : 9 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6582 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 TYPE : LEGACY [MTK] BROM : MEID : 77F9CDEFAD143E0F99FA3D6A58D9D72B BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : 0_base : BASE_v1844 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6582 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 484A019065314738A04E07056F44FFB8 DAInf: 4 : 2 : 135 DA : EXT_RAM NOT initialized! eMMC : OK eMMC : 90014A483847316505074EA0B8FF446F NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 DRAM : 0x0178 EMI : DEV : FireFly EMI : SRC : preloader_wt96582_s96582aa51.bin EMI : CNT : 0003 EMI : [00] : ID : 90014A483847316505 : VEN : HYNIX | DEV : H8G1e : RAM : [ 1.00 GB ] EMI : [01] : ID : 150100464E31324D42 : VEN : SAMSUNG | DEV : FN12MB : RAM : [ 1.00 GB ] EMI : [02] : ID : 110100303038473730 : VEN : TOSHIBA | DEV : 008G70 : RAM : [ 1.00 GB ] EMI : Init EMI from PRELOADER INIT : 0xBC : eMMC [ 0x40000000 : [ 1.00 GB ] ] DRAM : DRAM: 0x40000000 [ 1.00 GB ] DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: CID : 90014A483847316505074EA0B8FF446F EMMC: VEN : HYNIX : OEM : 74 : ID : 483847316505 EMMC: VEN : HYNIX : H8G1e EMMC: SNN : 1319155967 ( 0x4EA0B8FF) , MF : 4/2017 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x1D2000000 [ 7.28 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6582 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 , EVOL : 0x0000 RNID : DFBD1738402E4C77338B054B8C4D1CE1 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : FULL-SPEED DA : USB : Change Port Speed PTFN : MediaTek DA USB VCOM (Android) (COM38) MODE : PRELOADER PORT PORT : 38 Boot done! SmartInfo : 0x8D5454 Format Ok : RESET PROTECTION Format Ok : CACHE Format Ok : USRDATA Done! Elapsed: 00:00:48 Reconnect Power/Cable! Operation : Fix DL [ v2.28 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM128) MODE : PRELOADER PORT PORT : 128 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6582 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 TYPE : LEGACY [MTK] BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN BROM : BROM|BL : 0xFF|0x01 BROM : PRELOADER PORT BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : 0_base : BASE_v1844 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6582 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : Reset Interface! PTFN : MTK USB Port (COM9) MODE : BOOTROM PORT : 9 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6582 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 TYPE : LEGACY [MTK] BROM : MEID : 77F9CDEFAD143E0F99FA3D6A58D9D72B BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : 0_base : BASE_v1844 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6582 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 484A019065314738A04E07056F44FFB8 DAInf: 4 : 2 : 135 DA : EXT_RAM NOT initialized! eMMC : OK eMMC : 90014A483847316505074EA0B8FF446F NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 DRAM : 0x0178 EMI : DEV : FireFly EMI : SRC : preloader_wt96582_s96582aa51.bin EMI : CNT : 0003 EMI : [00] : ID : 90014A483847316505 : VEN : HYNIX | DEV : H8G1e : RAM : [ 1.00 GB ] EMI : [01] : ID : 150100464E31324D42 : VEN : SAMSUNG | DEV : FN12MB : RAM : [ 1.00 GB ] EMI : [02] : ID : 110100303038473730 : VEN : TOSHIBA | DEV : 008G70 : RAM : [ 1.00 GB ] EMI : Init EMI from PRELOADER INIT : 0xBC : eMMC [ 0x40000000 : [ 1.00 GB ] ] DRAM : DRAM: 0x40000000 [ 1.00 GB ] DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: CID : 90014A483847316505074EA0B8FF446F EMMC: VEN : HYNIX : OEM : 74 : ID : 483847316505 EMMC: VEN : HYNIX : H8G1e EMMC: SNN : 1319155967 ( 0x4EA0B8FF) , MF : 4/2017 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x1D2000000 [ 7.28 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6582 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 , EVOL : 0x0000 RNID : DFBD1738402E4C77338B054B8C4D1CE1 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : FULL-SPEED DA : USB : Change Port Speed PTFN : MediaTek DA USB VCOM (Android) (COM38) MODE : PRELOADER PORT PORT : 38 Boot done! DLFix : Init DLFix : Prepare ... DLFix : Process ... Done! Elapsed: 00:00:33 Reconnect Power/Cable! |
12-22-2021, 12:11 | #69085 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Infinix-X650 Frp Code: Patch Level : O11019 Display ID : X650-H8029AB-OGo-200529V345 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2020-06-05 Build Time : 29.05.2020 Product Brand : Infinix Product Name : H8029 Product Device : Infinix-X650 Product Info : Infinix-X650 Product Model : Infinix X650 Product Manfct : INFINIX MOBILITY LIMITED Product Board : Infinix-X650 Board Platform : mt6580 USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption ***) NVRAM : 0x770297DE NVRAM : State : Ok! INFO : WiFi MAC : 74C17DC2EA66 INFO : BlTh MAC : 74C17DBFDD26 INFO : IMEI[1] : INFO : IMEI[2] : Done! Elapsed: 00:00:51 Operation : Reset Settings/Format FS [ v2.28 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM9) MODE : BOOTROM PORT : 9 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY [MTK] BROM : MEID : 305234CC63BE16BB605C51CE60ECB85F BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x000000FE BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 460001704543424DDB1820418F9606E0 DAInf: 4 : 2 : 156 DA : EXT_RAM NOT initialized! eMMC : OK eMMC : 700100464D424345412018DBE006968F NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 DRAM : 0x0178 EMI : DEV : FireFly EMI : SRC : preloader_x650_h8029.bin EMI : CNT : 0007 EMI : [00] : ID : 150100514536334D42 : VEN : SAMSUNG | DEV : QE63MB : RAM : [ 0 B ] EMI : [01] : ID : 150100464536324D42 : VEN : SAMSUNG | DEV : FE62MB : RAM : [ 0 B ] EMI : [02] : ID : 90014A484247346132 : VEN : HYNIX | DEV : HBG4a2 : RAM : [ 2.00 GB ] EMI : [03] : ID : 700100464D41454538 : VEN : KINGSTON | DEV : FMAEE8 : RAM : [ 1.00 GB ] EMI : [04] : ID : 700100464D42434541 : VEN : KINGSTON | DEV : FMBCEA : RAM : [ 0 B ] EMI : [05] : ID : 90014A68423861503E : VEN : HYNIX | DEV : hB8aP> : RAM : [ 0 B ] EMI : [06] : ID : 150100514436334D42 : VEN : SAMSUNG | DEV : QD63MB : RAM : [ 0 B ] EMI : Init EMI from PRELOADER INIT : 0xBC : DRAM [ 0x00000000 : [ 0 B ] ] DRAM : DRAM: 0x80000000 [ 2.00 GB ] DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: CID : 700100464D424345412018DBE006968F EMMC: VEN : KINGSTON : OEM : 0 : ID : 464D42434541 EMMC: VEN : KINGSTON : FMBCEA EMMC: SNN : 417062918 ( 0x18DBE006) , MF : 9/2019 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x74A000000 [ 29.16 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : DF2B867EEEC9B82470D52B2A874EBF93 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : FULL-SPEED DA : USB : Change Port Speed PTFN : MediaTek DA USB VCOM (Android) (COM38) MODE : PRELOADER PORT PORT : 38 Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:28 Reconnect Power/Cable! |
12-22-2021, 12:12 | #69086 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Infinix X559C Frp Code: Patch Level : NRD90M Display ID : X559-H8015C-N-180623V135 Ver. CodeName : REL Ver. Release : 7.0 Sec. Patch : 2018-05-05 Build Time : 22.06.2018 Product Model : Infinix X559C Product Brand : Infinix Product Device : Infinix-X559C Product Name : H8015 Product Manfct : Infinix Board Platform : mt6580 Product Info : Infinix-X559 USERDATA : FILESYSTEM : EXT4 with FDE ( Full Disk Encryption ***) NVRAM : 0x75029322 NVRAM : State : Ok! INFO : WiFi MAC : BC91B5319C7C INFO : BlTh MAC : BC91B53015DC INFO : IMEI[1] : INFO : IMEI[2] : Done! Elapsed: 00:00:34 Operation : Reset Settings/Format FS [ v2.28 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM11) MODE : BOOTROM PORT : 11 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY [MTK] BROM : MEID : 83E3F9D8EA262A1AF30DCDE0BB224EF4 BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 510001154D333645CE9A034285155190 DAInf: 4 : 2 : 156 DA : EXT_RAM NOT initialized! eMMC : OK eMMC : 150100514536334D42039ACE90511585 NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 DRAM : 0x0178 EMI : DEV : FireFly EMI : SRC : preloader_rlk6580_weg_n.bin EMI : CNT : 0004 EMI : [00] : ID : 150100514531334D42 : VEN : SAMSUNG | DEV : QE13MB : RAM : [ 2.00 GB ] EMI : [01] : ID : 150100464531324D42 : VEN : SAMSUNG | DEV : FE12MB : RAM : [ 1.00 GB ] EMI : [02] : ID : 150100464536324D42 : VEN : SAMSUNG | DEV : FE62MB : RAM : [ 1.00 GB ] EMI : [03] : ID : 150100514536334D42 : VEN : SAMSUNG | DEV : QE63MB : RAM : [ 2.00 GB ] EMI : Init EMI from PRELOADER INIT : 0xBC : DRAM [ 0x00000000 : [ 0 B ] ] DRAM : DRAM: 0x80000000 [ 2.00 GB ] DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: CID : 150100514536334D42039ACE90511585 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 514536334D42 EMMC: VEN : SAMSUNG : QE63MB EMMC: SNN : 2597228625 ( 0x9ACE9051) , MF : 1/2018 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3A3E00000 [ 14.56 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : BDB9C332D0C62198F37423CD40460AB4 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : FULL-SPEED DA : USB : Change Port Speed PTFN : MediaTek DA USB VCOM (Android) (COM120) MODE : PRELOADER PORT PORT : 120 Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:28 Reconnect Power/Cable! |
12-22-2021, 12:16 | #69087 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Motorola XT1700 Frp Code: Patch Level : MRA58K Display ID : XT1700_S303_160829_UK Ver. CodeName : REL Ver. Release : 6.0 Sec. Patch : 2016-06-01 Build Time : 08.09.2016 Product Model : XT1700 Product Brand : motorola Product Name : taidos_row Product Device : taidos_row Product Manfct : motorola Board Platform : mt6735m Product Info : taidos_row USERDATA : FILESYSTEM : EXT4 with FDE ( Full Disk Encryption ***) NVRAM : 0x12F067812 NVRAM : State : Ok! INFO : WiFi MAC : 4888CABF6A02 INFO : BlTh MAC : 4888CABB6A02 INFO : IMEI[1] : INFO : IMEI[2] : FFFFFFFFFFFFFFF Done! Elapsed: 00:00:20 Operation : Reset Settings/Format FS [ v2.28 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM10) MODE : PRELOADER PORT PORT : 10 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 TYPE : LEGACY [MTK] BROM : SecLevel : 0x00000001 BROM : SecMode : SBC BROM : BROM|BL : 0xFF|0x01 BROM : PRELOADER PORT BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6735 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 150100464E58324D42012164DCD8367D DAInf: 4 : 2 : 155 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: CID : 150100464E58324D42012164DCD8347D EMMC: VEN : SAMSUNG : OEM : 0 : ID : 464E58324D42 EMMC: VEN : SAMSUNG : FNX2MB EMMC: SNN : 560258264 ( 0x2164DCD8) , MF : 3/2017 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00080000 [ 512.00 KB ] USER : 0x1D2000000 [ 7.28 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 3134DFCB6101DAB31A1AECEF65342DC STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:23 Reconnect Power/Cable! |
12-22-2021, 12:17 | #69088 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | OPPO CPH1923 Format & Frp Code: Patch Level : PPR1.180610.011 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2021-05-05 Product Manfct : OPPO Build Time : 06.05.2021 Product Brand : OPPO Product Model : CPH1923 Product Info : CPH1923 Product Name : CPH1923 Product Device : OP486C SW OTA Version : CPH1923EX_11.A.40_0400_202105061633 Display ID : CPH1923EX_11_A.40 Kernel Info : 4.9.117 USERDATA : FILESYSTEM : EXT4 with FBE ( File-Base Encryption ) NVRAM : OPPO6762_18540_MDBIN_PCB01_MT6765_S00.MOLY_LR12A_R2_PIE_P22_PR3_TC16_SP_V1_P4 NVRAM : 0xBB0ACAB4 NVRAM : State : Ok! INFO : WiFi MAC : C4E1A14151CD INFO : BlTh MAC : C4E1A14151CC STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : UNLOCKED! Done! Elapsed: 00:00:34 Operation : Reset Settings/Format FS [ v2.28 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM9) MODE : BOOTROM PORT : 9 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 75C7274DF18AA958B2592F552598C368 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : B3EE2C8345F30E4BDFAF5C09320683C9903B6362D237D2922DFCF0A5B44CDCA4 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_oppo6762_18540.bin EMI : CNT : 0009 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: CID : 150100514436334D42031A049B8876F3 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 514436334D42 EMMC: VEN : SAMSUNG : QD63MB EMMC: SNN : 436509576 ( 0x1A049B88) , MF : 7/2019 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 14394D6723FEB7A7FAE7813F884A552A DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x815757 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Done! Elapsed: 00:00:43 Reconnect Power/Cable! |
12-22-2021, 12:18 | #69089 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | OPPO CPH1909 Format & Frp Code: Patch Level : O11019 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2021-04-05 Product Manfct : OPPO Build Time : 19.03.2021 Product Brand : OPPO Product Model : CPH1909 Product Info : CPH1909 Product Device : CPH1909 Product Name : CPH1909 SW OTA Version : CPH1909EX_11.A.46_0460_202103191930 Display ID : CPH1909EX_11_A.46 Kernel Info : 4.9.77 USERDATA : FILESYSTEM : EXT4 with FDE ( Full Disk Encryption *) NVRAM : OPPO6765_18511_MDBIN_PCB01_MT6765_S00.MOLY_LR12A_R2_TC16_SP_V50_5_P97 NVRAM : 0xBC0ACB13 NVRAM : State : Ok! INFO : WiFi MAC : D81EDDB5C661 INFO : BlTh MAC : D81EDDB5C660 STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : UNLOCKED! Done! Elapsed: 00:00:45 Operation : Reset Settings/Format FS [ v2.28 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM9) MODE : BOOTROM PORT : 9 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : FA54B3AE5F22BB65EC7A08E22E312F95 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 39D08E80F556056DC01A542ADAB7C921B2581D846C53CDB49F796D9969869BA8 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_oppo6765_18511.bin EMI : CNT : 0009 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID : 90014A484347386134A5DFC8700EC555 EMMC: VEN : HYNIX : OEM : 74 : ID : 484347386134 EMMC: VEN : HYNIX : HCG8a4 EMMC: SNN : 3754455054 ( 0xDFC8700E) , MF : 12/2018 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 49EB9CE912F81A4917D9573B6388FC74 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x805757 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Done! Elapsed: 00:00:43 Reconnect Power/Cable! |
12-22-2021, 12:21 | #69090 (permalink) |
No Life Poster Join Date: Jul 2009 Location: SINDH PAKISTAN
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | qmobile i8i formate done Set mode to : SP [SC773x] eMMC [Android 6.x] Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 60 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x0000000133CF7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:30 Reconnect Power/Cable! |
