09-30-2022, 06:27 | #72211 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Qmobile : XLi Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Qmobile : XLi Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0002 FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:05:35 |
09-30-2022, 06:58 | #72212 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | TECNO : KG5k Operation : Format FS / Reset Settings [ v2.14 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : TECNO : KG5k Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0020 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:16 |
09-30-2022, 08:29 | #72213 (permalink) |
No Life Poster Join Date: Jun 2014 Location: Infinity Box Team
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Vgotel i252 read user code done Operation : Read UserCode [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 3 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : F72828FA1D70D5BE68FDA34C64D92E84 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0112 , [MXIC] MX25L3291FWJI_09 [0] : FLASH_DIE : 00C2 0020 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Read ExtData Sorting ExtData Reading UserCode Active : Yes , Code : 9852 Privacy Lock := Done! Elapsed: 00:00:05 Reconnect Power/Cable! |
09-30-2022, 09:29 | #72214 (permalink) |
No Life Poster Join Date: Aug 2020 Location: Mozambique Age: 20
Member: 2965136 Status: Offline Sonork: 58846 Thanks Meter: 1,202 | Nokia 105 4G TA-1385 SP Unlock Done Code: Card found : 46828B86 , v0153 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : Identify [ v2.14 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : UniSoc ( E-family and Modern ) BuildInfo : Platform Version: MOCOR_20A_MP_KN4_W21.30.6_Release Software Version: 13.00.17.01 BASE Version: FM_BASE_20A_THIN_MODEM_KN4_W21.30.6 HW Version: UMS9117 buildtime:08-06-2021 03:48:40 Platform Version: MOCOR_20A_MP_KN4_W21.30.6_Release BASE Version: FM_BASE_20A_THIN_MODEM_KN4_W21.30.6 HW Version: UMS9117 MODEM TAG : MOCOR_20A_MP_KN4_W21.30.6_Release_FM_BASE_20A_THIN_MODEM_KN4_W21.30.6_UMS9117 PSN1 : A93EAABLU PSN2 : A93EAABLU NVMng : SecurityInfo IMEI[1] : 358530925171492 IMEI[2] : 358530925671491 WIFIMAC : FFFFFFFFFFFF BT_MAC : FFFFFFFFFFFF SEC : SLS:2, SKS:0, SKV:4 Done! Elapsed: 00:00:27 Code: Operation : SP Unlock [ v2.14 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : UniSoc ( E-family and Modern ) BuildInfo : Platform Version: MOCOR_20A_MP_KN4_W21.30.6_Release Software Version: 13.00.17.01 BASE Version: FM_BASE_20A_THIN_MODEM_KN4_W21.30.6 HW Version: UMS9117 buildtime:08-06-2021 03:48:40 Platform Version: MOCOR_20A_MP_KN4_W21.30.6_Release BASE Version: FM_BASE_20A_THIN_MODEM_KN4_W21.30.6 HW Version: UMS9117 MODEM TAG : MOCOR_20A_MP_KN4_W21.30.6_Release_FM_BASE_20A_THIN_MODEM_KN4_W21.30.6_UMS9117 NVMng : SecurityInfo IMEI[1] : 358530925171492 IMEI[2] : 358530925671491 WIFIMAC : FFFFFFFFFFFF BT_MAC : FFFFFFFFFFFF SEC : SLS:2, SKS:0, SKV:4 SLStatus : 2C Status : Locked! Server unlock required! Connecting to server... Connected Init... Init: Ok Authenticating... Authenticated Checking Client version... Client version Ok Balance: 5, price:5 Process... Finished Unlocking device ... Sync data ... Device unlocked! Done! Elapsed: 00:00:39 |
The Following User Says Thank You to tayobjoy1 For This Useful Post: |
09-30-2022, 11:30 | #72215 (permalink) |
No Life Poster Join Date: Sep 2021 Location: Germany
Member: 2996196 Status: Offline Thanks Meter: 632 | HUAWEI P20 Pro CLONE READ FIRMWARE DONE Load IDBase v723487 Ok! Update configuration... Socket Error # 11001 Host not found. Finished Load IDBase v723487 Ok! Operation : Identify Device [ v2.35 ] Mode : FLASH Deep Info: On Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device Waiting for device connection... PTFN : MediaTek PreLoader USB VCOM (Android) (COM5) MODE : PRELOADER PORT PORT : 5 Waiting BOOT ack... PRELOADER : ACK confirmed BROM : Init BROM BROM init passed CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY [MTK] BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN BROM : BROM|BL : 0xFF|0x01 BROM : PRELOADER PORT Mode: 0 State: 6 Core: 0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Looking for suitable BootChain in DA... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA... BROM : DA sent BROM : Transfer control to DA... DA : AGENT started NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 3000011145473430E28E0130BF92E6C7 DAInf: 4 : 2 : 156 DA : DRAM ready DA : BOOT to 2nd DA... DA : Receiving HW info EMMC: CID : 110100303034474530018EE2C7E692BF EMMC: VEN : TOSHIBA : OEM : 0 : ID : 303034474530 : PRV : 0x01 EMMC: VEN : TOSHIBA : 004GE0 EMMC: SNN : 2397226982 ( 0x8EE2C7E6 ) , MF : 9/2015 EMMC: BOOT1 : 0x00200000 [ 2.00 MB ] BOOT2 : 0x00200000 [ 2.00 MB ] RPMB : 0x00080000 [ 512.00 KB ] USER : 0xEC000000 [ 3.69 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x20000000 [ 512.00 MB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 3C26D1A636A6963F7A9A9A83FCF4B1A1 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done Patch Level : LMY47I Display ID : l100_lyx_h100_welcome_480x960_en_YL_v10 Ver. CodeName : REL Ver. Release : 6.0 Sec. Patch : 2017-03-05 Build Time : 26.04.2019 Product Model : P20 Pro Product Brand : Android Product Name : P20 Pro Product Device : P20 Pro Product Manfct : Android Board Platform : mt6580 Product Info : aeon6580_weg_l_l100 USERDATA : FILESYSTEM : EXT4 NVRAM : 0x6A02864E NVRAM : State : Ok INFO : WiFi MAC : E8D5ED4D8729 INFO : BlTh MAC : 7E4546658011 INFO : IMEI[1] : 358623431991477 INFO : IMEI[2] : 358623431991485 Backup critical data [18] to backup\MT6580__3C26D1A636A6963F7A9A9A83FCF4B1A1\ [3] Read : NVRAM [14] Read : NVDATA [2] Read : PROINFO [7] Read : LK [4] Read : PROTECT1 [0] Read : PRELOADER Backup done Scan preloader... PRELOADER: MT6752 preloader_aeon6580_weg_l_l100.bin with 17 memory type(s) supported EMI : [00] : eMMC : DDR2 : ID : 700100533130303034 : VEN : KINGSTON | DEV : S10004 : RAM : [ 512.00 MB ] EMI : [01] : eMMC : DDR2 : ID : 110100303034474530 : VEN : TOSHIBA | DEV : 004GE0 : RAM : [ 512.00 MB ] EMI : [02] : eMMC : DDR2 : ID : 1501004E35585A4D42 : VEN : SAMSUNG | DEV : N5XZMB : RAM : [ 512.00 MB ] EMI : [03] : eMMC : DDR2 : ID : 90014A483447316404 : VEN : HYNIX | DEV : H4G1d : RAM : [ 512.00 MB ] EMI : [04] : eMMC : DDR2 : ID : 110100303034473930 : VEN : TOSHIBA | DEV : 004G90 : RAM : [ 512.00 MB ] EMI : [05] : eMMC : DDR3 : ID : 8801034E4361726420 : VEN : FORESEE | DEV : NCard : RAM : [ 1.00 GB ] EMI : [06] : eMMC : DDR3 : ID : 700100543232373038 : VEN : KINGSTON | DEV : T22708 : RAM : [ 1.00 GB ] EMI : [07] : eMMC : DDR3 : ID : 15010038574D423352 : VEN : SAMSUNG | DEV : 8WMB3R : RAM : [ 1.00 GB ] EMI : [08] : eMMC : DDR3 : ID : 8801034D3842313647 : VEN : FORESEE | DEV : M8B16G : RAM : [ 1.00 GB ] EMI : [09] : eMMC : DDR2 : ID : 1501004E4A325A4D42 : VEN : SAMSUNG | DEV : NJ2ZMB : RAM : [ 512.00 MB ] EMI : [0A] : eMMC : DDR3 : ID : 90014A483847316505 : VEN : HYNIX | DEV : H8G1e : RAM : [ 1.00 GB ] EMI : [0B] : eMMC : DDR3 : ID : 150100385750443352 : VEN : SAMSUNG | DEV : 8WPD3R : RAM : [ 1.00 GB ] EMI : [0C] : eMMC : DDR3 : ID : 15010038474E443352 : VEN : SAMSUNG | DEV : 8GND3R : RAM : [ 1.00 GB ] EMI : [0D] : eMMC : DDR3 : ID : 90014A483847346192 : VEN : HYNIX | DEV : H8G4a? : RAM : [ 1.00 GB ] EMI : [0E] : eMMC : DDR3 : ID : 90014A483847326404 : VEN : HYNIX | DEV : H8G2d : RAM : [ 1.00 GB ] EMI : [0F] : eMMC : DDR3 : ID : 110100303038474530 : VEN : TOSHIBA | DEV : 008GE0 : RAM : [ 1.00 GB ] EMI : [10] : eMMC : DDR3 : ID : 110100303038473330 : VEN : TOSHIBA | DEV : 008G30 : RAM : [ 1.00 GB ] Store preloader: PRELOADER saved to: backup\PRELOADER\preloader_aeon6580_weg_l_l100.bin Verify backup\PRELOADER\preloader_aeon6580_weg_l_l100.bin with hash 26421776 Socket Error # 11001 Host not found. Finished Done Elapsed: 00:00:29 Operation : Read Firmware [ v2.35 ] ExtSparse : Enabled ForceRead : Disabled 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device Waiting for device connection... PTFN : MediaTek PreLoader USB VCOM (Android) (COM5) MODE : PRELOADER PORT PORT : 5 Waiting BOOT ack... PRELOADER : ACK confirmed BROM : Init BROM BROM init passed CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY [MTK] BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN BROM : BROM|BL : 0xFF|0x01 BROM : PRELOADER PORT Mode: 0 State: 6 Core: 0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Looking for suitable BootChain in DA... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA... BROM : DA sent BROM : Transfer control to DA... DA : AGENT started NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 3000011145473430E28E0130BF92E6C7 DAInf: 4 : 2 : 156 DA : DRAM ready DA : BOOT to 2nd DA... DA : Receiving HW info EMMC: CID : 110100303034474530018EE2C7E692BF EMMC: VEN : TOSHIBA : OEM : 0 : ID : 303034474530 : PRV : 0x01 EMMC: VEN : TOSHIBA : 004GE0 EMMC: SNN : 2397226982 ( 0x8EE2C7E6 ) , MF : 9/2015 EMMC: BOOT1 : 0x00200000 [ 2.00 MB ] BOOT2 : 0x00200000 [ 2.00 MB ] RPMB : 0x00080000 [ 512.00 KB ] USER : 0xEC000000 [ 3.69 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x20000000 [ 512.00 MB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 3C26D1A636A6963F7A9A9A83FCF4B1A1 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done Patch Level : LMY47I Display ID : l100_lyx_h100_welcome_480x960_en_YL_v10 Ver. CodeName : REL Ver. Release : 6.0 Sec. Patch : 2017-03-05 Build Time : 26.04.2019 Product Model : P20 Pro Product Brand : Android Product Name : P20 Pro Product Device : P20 Pro Product Manfct : Android Board Platform : mt6580 Product Info : aeon6580_weg_l_l100 MT6580__Android__P20_Pro__6.0__l100_lyx_h100_welco me_480x960_en_YL_v10__LMY47I__aeon6580_weg_l_l100 Read : preloader.bin Read : proinfo.img Read : nvram.bin Read : lk.bin Read : boot.img Read : recovery.img Read : logo.bin Read : secro.img Read : system.img ExtSparse : Compression ratio : 13% Read : cache.img Read : userdata.img FW Size : 1.37 GB Android Info saved : _Android_info.txt Scatter : MT6580_Android_scatter.txt Saved to : D:\FL TOOLS\Firmwares\huawei\MT6580__Android__P20_Pro__6 .0__l100_lyx_h100_welcome_480x960_en_YL_v10__LMY47 I__aeon6580_weg_l_l100\ Check firmware [MT6580__Android__P20_Pro__6.0__l100_lyx_h100_welco me_480x960_en_YL_v10__LMY47I__aeon6580_weg_l_l100]... Can not check Done Elapsed: 00:06:56 |
The Following User Says Thank You to Jacobkamudyariw For This Useful Post: |
09-30-2022, 11:35 | #72216 (permalink) |
Member: 2996196 Status: Offline Thanks Meter: 632 | HUAWEI G628-TL00 UI SYSTEM UNFORTUNATELY STOPPED FIXED By CM2 Chinese Miracle II : MediaTek Service Module Created by Infinity-Box (c) 2022 Creation time : 2022/08/02 Module version : 2.34 Device Info file : _Android_info.txt Patch Level : HUAWEIG628-TL00 Display ID : G628-TL00V100R001CHNC01B202 Ver. CodeName : REL Ver. Release : 4.4.4 Build Time : 18.11.2015 Product Model : HUAWEI G628-TL00 Product Brand : HUAWEI Product Name : G628-TL00 Product Device : HWG628-TL Product Board : G628-TL00 Product Manfct : HUAWEI Product Info : HWG628-TL Preloader [HW DEV] Info : EMI : DEV : MT6752 EMI : SRC : preloader_wt96629.bin EMI : CNT : 0004 EMI : [00] : eMMC : DDR3 : ID : 150100513758534142 : VEN : SAMSUNG | DEV : Q7XSAB : RAM : [ 1.00 GB ] EMI : [01] : eMMC : DDR3 : ID : 90014A483847326404 : VEN : HYNIX | DEV : H8G2d : RAM : [ 1.00 GB ] EMI : [02] : eMMC : DDR3 : ID : 110100303038474530 : VEN : TOSHIBA | DEV : 008GE0 : RAM : [ 1.00 GB ] EMI : [03] : eMMC : DDR3 : ID : 150100514E31534D42 : VEN : SAMSUNG | DEV : QN1SMB : RAM : [ 1.00 GB ] Operation : Write Flash [ v2.35 ] Repartition : Enabled Flash Verify : Disabled Reg.Pre-Erase : Enabled Verify HW/SW : Enabled SData Backup : Enabled Safe UserData : Disabled Flash Format : Disabled Files :10 [FL] : Set : lk.bin [FL] : Set : boot.img [FL] : Set : recovery.img [FL] : Set : secro.img [FL] : Set : logo.bin [FL] : Set : tz.img [FL] : Set : tz.img [FL] : Set : system.img [FL] : Set : cache.img [FL] : Set : userdata.img [FL] : Total size : 0x44CE3798 [ 1.08 GB ] 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device Waiting for device connection... PTFN : MediaTek USB Port (COM8) MODE : BOOTROM PORT : 8 Waiting BOOT ack... BROM : Skip ACK verify BROM : Init BROM BROM init passed CHIP : MT6752 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 TYPE : LEGACY [MTK] BROM : MEID : 6789DA79606F86A6948D635914014D7C BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM Mode: 0 State: 6 Core: 0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Looking for suitable BootChain in DA... AGENT : MTK_AllInOne_DA.bin AGENT : CHANGE : v1844 AGENT : Found MT6752 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA... BROM : DA sent BROM : Transfer control to DA... DA : AGENT started NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 484A019064324738A20305047D525EBA DAInf: 4 : 2 : 143 DA : EXT_RAM NOT initialized eMMC : OK eMMC : 90014A4838473264040503A2BA5E527D NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 DRAM : 0x0160 EMI : DEV : FireFly EMI : SRC : preloader_wt96629.bin EMI : CNT : 0003 EMI : [00] : ID : 150100513758534142 : VEN : SAMSUNG | DEV : Q7XSAB : RAM : [ 1.00 GB ] EMI : [01] : ID : 90014A483847326404 : VEN : HYNIX | DEV : H8G2d : RAM : [ 1.00 GB ] EMI : [02] : ID : 110100303038474530 : VEN : TOSHIBA | DEV : 008GE0 : RAM : [ 1.00 GB ] EMI : Init EMI from PRELOADER INIT : 0xB0 : DRAM [ 0x00000000 : [ 0 B ] ] DRAM : DRAM: 0x40000000 [ 1.00 GB ] DA : DRAM ready DA : BOOT to 2nd DA... DA : Receiving HW info EMMC: CID : 90014A4838473264040503A2BA5E527D EMMC: VEN : HYNIX : OEM : 74 : ID : 483847326404 : PRV : 0x05 EMMC: VEN : HYNIX : H8G2d EMMC: SNN : 60996190 ( 0x03A2BA5E ) , MF : 5/2015 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x1D2000000 [ 7.28 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6752 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 , EVOL : 0x0000 RNID : 45694A98B37468ED74D578468E3747FD STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : FULL-SPEED DA : USB : Change Port Speed PTFN : MediaTek DA USB VCOM (Android) (COM17) MODE : PRELOADER PORT PORT : 17 Boot done [FL] : HW verification passed [FL] : Pre-Flash backup Backup critical data [18] to backup\MT6752__6789DA79606F86A6948D635914014D7C\ Backup done [FL] : Pre-Flash backup passed SEC_DL : False (CUST) SEC_DL : SECURE USB DL DISABLED SEC_ID : 0x35464646304237304435444533464335 [FL] : Pre-Erase Erase : 0x0000000000000000 : 0x0000000000080000 Erase : 0x0000000001C80000 : 0x0000000003920000 Erase : 0x00000000059A0000 : 0x00000000DBE60000 [FL] : RePartition [FL] : RePartition Ok [FL] : Flashing now... Write : LK Write : BOOT Write : RECOVERY Write : SECRO Write : LOGO Write : TEE1 Write : TEE2 Write : SYSTEM Write : CACHE Write : USERDATA [FL] : RePartition [FL] : RePartition Ok [FL] : Flashing finished Done Elapsed: 00:02:18 Reconnect Power/Cable now |
09-30-2022, 14:26 | #72217 (permalink) |
No Life Poster Join Date: Mar 2015 Location: Islam Age: 35
Member: 2371500 Status: Offline Thanks Meter: 5,802 | C2 CONDOR IMEI REPAIR done ORIGINAL POSTER BelkacemGhezzaz DZGSM Last edited by profkefah; 09-30-2022 at 14:34. Reason: C2 CONDOR IMEI REPAIR done |
The Following User Says Thank You to profkefah For This Useful Post: |
09-30-2022, 14:28 | #72218 (permalink) |
Member: 2371500 Status: Offline Thanks Meter: 5,802 | w375 motorola UNLOCK done ORIGINAL POSTER halfa40gsm DZGSM Action: unlock Device: W375 Checking data, wait... Connect... Press and HOLD Power button... rom version: 0411 Connecting... rom code version: 0411 initial boot phase complete Release Power button ! Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... SW version: 0.0.73 HW version: MOTOROLA_H80S LP ver: 0073_001 Flex ver: FLEX_D4_009 cpu id: 08B6 imei eeprom: 3530030152977710 required SW version: 0.0.73 sp-locked: 20801. Check Flash-1 Done Check Flash-2... reading ... file saved: C:\InfinityBox\Moto01\backup_eeprom_calibration_35 300301529777_20131026-104446.34E.bin unlock step-1 Ok unlock step-2 Ok unlock step-3 Ok unlock step-4 Ok unlock step-5 Ok finished Ok Finished, time used: 42 sec Remove/Install battery now ! |
09-30-2022, 20:06 | #72219 (permalink) |
Member: 2965136 Status: Offline Sonork: 58846 Thanks Meter: 1,202 | Nokia TA-1352 SP Unlock Done Code: Card found : 46828B86 , v0153 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.12 Load IDBase v8331 Ok! Operation : Identify [ v2.12 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : UniSoc ( E-family and Modern ) BuildInfo : Cosmo_00WW-user 11 RP1A.201005.001 V1.270_B01 release-keys MemoryInfo : EMMC : 16 GB ; DRAM : 1 GB Platform Version: MOCORTM_20A_W21.15.3_P7_Debug Project Version: sharkl3_pub BASE Version: 4G_MODEM_20A_W21.15.3_P7 HW Version: sc9863A_modem CMP_Time : 06-08-2021 11:05:19 MODEM TAG : MOCORTM_20A_W21.15.3_P7_Debug_4G_MODEM_20A_W21.15.3_P7_sc9863A_modem_sharkl3_pub PSN1 : E645400190708566 PSN1 : E286655849B91300336 NVMng : SecurityInfo IMEI[1] : 356748979757220 IMEI[2] : 356748979757238 WIFIMAC : 44917C2395F5 BT_MAC : 44917C2395F4 SEC : SLS:2, SKS:0, SKV:4 Done! Elapsed: 00:00:23 Code: Operation : SP Unlock [ v2.12 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : UniSoc ( E-family and Modern ) BuildInfo : Cosmo_00WW-user 11 RP1A.201005.001 V1.270_B01 release-keys Platform Version: MOCORTM_20A_W21.15.3_P7_Debug Project Version: sharkl3_pub BASE Version: 4G_MODEM_20A_W21.15.3_P7 HW Version: sc9863A_modem CMP_Time : 06-08-2021 11:05:19 MODEM TAG : MOCORTM_20A_W21.15.3_P7_Debug_4G_MODEM_20A_W21.15.3_P7_sc9863A_modem_sharkl3_pub NVMng : SecurityInfo IMEI[1] : 356748979757220 IMEI[2] : 356748979757238 WIFIMAC : 44917C2395F5 BT_MAC : 44917C2395F4 SEC : SLS:2, SKS:0, SKV:4 SLStatus : 2C Status : Locked! Server unlock required! Connecting to server... Connected Init... Init: Ok Authenticating... Authenticated Checking Client version... Client version Ok Balance: 70, price:5 Process... Finished Unlocking device ... Sync data ... Device unlocked! Done! Elapsed: 00:00:38 |
10-01-2022, 07:07 | #72220 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Oppo A5s (AX5s) Smart Reset Done Operation : Reset Settings/Format FS [ v2.34 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM3) MODE : BOOTROM PORT : 3 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : F71E295824504A4A7A617992F5679AC9 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 83C9151E1EFCFA3D5650EE42956EEA5712EF70DBC908A26406 EAFE14AB7B75ED BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : FF : Look for EMI BROM : FF : EMI found! BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMMC: CID : 90014A68423861503E032AA2753227C5 EMMC: VEN : HYNIX : OEM : 74 : ID : 68423861503E : PRV : 0x03 EMMC: VEN : HYNIX : hB8aP> EMMC: SNN : 715289906 ( 0x2AA27532 ) , MF : 2/2020 EMI : DEV : FireFly EMI : SRC : preloader_oppo6765_18511.bin EMI : CNT : 0009 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: CID : 90014A68423861503E032AA2753227C5 EMMC: VEN : HYNIX : OEM : 74 : ID : 68423861503E : PRV : 0x03 EMMC: VEN : HYNIX : hB8aP> EMMC: SNN : 715289906 ( 0x2AA27532 ) , MF : 2/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : E7749EC21E2134FCB6A8CF9624108FD DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x805757 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Done! Elapsed: 00:00:30 Reconnect Power/Cable! |
10-01-2022, 07:44 | #72221 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Digit4G Shine Chinese Miracle II : MediaTek Service Module Created by Infinity-Box (c) 2022 Creation time : 2022/06/07 Module version : 2.34 Device Info file : _Android_info.txt Patch Level : MRA58K Display ID : Digit_M42433DG_SW02_20211220_2017 Ver. CodeName : REL Ver. Release : 6.0 Sec. Patch : 2015-10-01 Build Time : 20.12.2021 Product Model : Digit4G Shine Product Brand : Digit Product Name : Digit4G_Shine Product Device : Digit4G_Shine Product Manfct : alps Board Platform : mt6739 Product Info : Digit4G_Shine Product Model : V1.0 Preloader [HW DEV] Info : EMI : DEV : MT6739 EMI : SRC : preloader_fise6731_kaio_m.bin EMI : CNT : 0006 EMI : [00] : eMMC : DDR3 : ID : 700100454534454434 : VEN : KINGSTON | DEV : EE4ED4 : RAM : [ 512.00 MB ] EMI : [01] : eMMC : DDR3 : ID : F40122426977696E20 : VEN : BIWIN | DEV : Biwin : RAM : [ 512.00 MB ] EMI : [02] : eMMC : DDR3 : ID : 150100463558354342 : VEN : SAMSUNG | DEV : F5X5CB : RAM : [ 512.00 MB ] EMI : [03] : eMMC : DDR3 : ID : 150100464A32354142 : VEN : SAMSUNG | DEV : FJ25AB : RAM : [ 512.00 MB ] EMI : [04] : eMMC : DDR3 : ID : FE014E50314A39344D : VEN : MICRON | DEV : P1J94M : RAM : [ 512.00 MB ] EMI : [05] : eMMC : DDR3 : ID : 90014A483447326111 : VEN : HYNIX | DEV : H4G2a : RAM : [ 512.00 MB ] Operation : Write Flash [ v2.34 ] Repartition : Disabled Flash Verify : Disabled Reg.Pre-Erase : Disabled Verify HW/SW : Disabled SData Backup : Disabled Safe UserData : Disabled Flash Format : Disabled Files :3 [FL] : Set : system.img [FL] : Set : cache.img [FL] : Set : userdata.img [FL] : Total size : 0x1C05C39C [ 448.36 MB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM3) MODE : BOOTROM PORT : 3 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Zion TYPE : MODERN [RAPHAEL] BROM : MEID : 16F73D69C86D5C0639336A47ACD7A403 BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 2F4A7E113CA8C2584E7A5282B486BEA1C5E2FC0B0EA6042903 035778310249FD AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_fise6731_kaio_m.bin EMI : CNT : 0006 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x20000000 [ 512.00 MB ] EMMC: CID : 90014A4834473261110211001014B4E1 EMMC: VEN : HYNIX : OEM : 74 : ID : 483447326111 : PRV : 0x02 EMMC: VEN : HYNIX : H4G2a EMMC: SNN : 285216788 ( 0x11001014 ) , MF : 11/2017 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0xE9000000 [ 3.64 GB ] CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : B627E2428C3D96DEA32B38DBB7BD6EE5 DA : USB : HIGH-SPEED Boot done! SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : Flashing now ... Write : SYSTEM Write : CACHE Write : USERDATA [FL] : Flashing finished! Done! Elapsed: 00:01:05 Reconnect Power/Cable! |
10-01-2022, 07:54 | #72222 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Oppo F1s MT6750 FRP/Pattren Reset Done With King Infinity CM2 Code: S/N: A19EC787 v0153 Infinity [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.35 Load IDBase v312457 Ok! Can not get data from server Username or Password is wrong, set it at Settings tab How to configure server access https://infinity-box.com/?r=100166 Load IDBase v312457 Ok! Operation : Reset Settings/Format FS [ v2.35 ] Mode : SMART RESET 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device Waiting for device connection... PTFN : MediaTek USB Port_V1632 (COM161) MODE : BOOTROM PORT : 161 Waiting BOOT ack... BROM : Skip ACK verify BROM : Init BROM BROM init passed CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN [RAPHAEL] BROM : MEID : 5A77F1B94CCD681F76629993B1AA4432 BROM : SecLevel : 0x00000001 BROM : SecMode : SBC BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : EMI : Search BROM : EMI : Found AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Looking for suitable BootChain in DA... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6755 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA... BROM : DA sent BROM : Transfer control to DA... DA : AGENT started DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized EMI : DEV : FireFly EMI : SRC : preloader_oppo6750_15131.bin EMI : CNT : 0006 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed DA : BOOT to 2nd DA... DA : 2ND stage confirmed DA : SYNC with DA passed DA : Receiving HW info SRAM: 0x00038000 [ 224.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID : 150100525831344D4207AECECE211483 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 525831344D42 : PRV : 0x07 EMMC: VEN : SAMSUNG : RX14MB EMMC: SNN : 2932788769 ( 0xAECECE21 ) , MF : 1/2017 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6750 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 9057FEB290A935E381C1BEEFF251F5EF DA : USB : FULL-SPEED DA : USB : Change Port Speed PTFN : MediaTek DA USB VCOM (Android) (COM183) MODE : PRELOADER PORT PORT : 183 Boot done SmartInfo : 0x8D5454 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Done Elapsed: 00:01:24 Reconnect Power/Cable now |
10-01-2022, 12:45 | #72223 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Jazz Digit 4G Smart Reset Done Operation : Reset Settings/Format FS [ v2.34 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM3) MODE : BOOTROM PORT : 3 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 CODE : Zion TYPE : MODERN [RAPHAEL] BROM : MEID : F8154F958CBAAA5222ECDC03E83A304B BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 868330DD1221FD9B7A9B8F8DE8135FC7588F94AC108F197949 0B2B698D3BC3FE BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : FF : Look for EMI BROM : FF : EMI found! BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_fise6731_kaio_m.bin EMI : CNT : 0006 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x20000000 [ 512.00 MB ] EMMC: CID : 90014A483447326111024232A8511523 EMMC: VEN : HYNIX : OEM : 74 : ID : 483447326111 : PRV : 0x02 EMMC: VEN : HYNIX : H4G2a EMMC: SNN : 1110616145 ( 0x4232A851 ) , MF : 1/2018 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0xE9000000 [ 3.64 GB ] CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 , EVOL : 0x0000 RNID : 320371EDB1EAEE975CDFDC1E540307B DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x8E5454 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Done! Elapsed: 00:01:05 Reconnect Power/Cable! |
10-01-2022, 13:32 | #72224 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Itel A571L SPD77xx FRP/Pattren Reset Done With King Infinity CM2 Code: Card found : A19EC787 , v0153 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : Format FS / Reset Settings [ v2.14 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Itel : A571L Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... FDL : SEC : RSA auth passed! FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:23 |
10-01-2022, 14:15 | #72225 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Infinix smart hd reset frp done by cm2 Card found : 73CA70CC , v0153 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.34 Load IDBase v723487 Ok! Update configuration ... Load IDBase v723487 Ok! Operation : Reset Settings/Format FS [ v2.34 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM15) MODE : PRELOADER PORT PORT : 15 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 CODE : Merlot TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : Reset Interface! PTFN : MediaTek USB Port (COM16) MODE : BOOTROM PORT : 16 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 CODE : Merlot TYPE : MODERN [RAPHAEL] BROM : MEID : A7579E30CF29FAA18C08689D824E56CC BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 9B9EED0A30B427D45E4B9E674E12E05625563845592662C987 BABAAF5D050B70 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_infinix_x612b.bin EMI : CNT : 0009 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A400 [ 233.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: CID : 150100515836334142033F39BA1AC75F EMMC: VEN : SAMSUNG : OEM : 0 : ID : 515836334142 EMMC: VEN : SAMSUNG : QX63AB EMMC: SNN : 1060747802 ( 0x3F39BA1A) , MF : 12/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 3CB7F27098107097DDAFB6BB9CDA376B DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x825657 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Format Ok : USERDATA Done! Elapsed: 00:00:43 Reconnect Power/Cable! |
