GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   Infinity-Box (https://forum.gsmhosting.com/vbb/f296/)
-   -   Successfully unlocked/repaired phones by Infinity-Box (https://forum.gsmhosting.com/vbb/f296/successfully-unlocked-repaired-phones-infinity-box-725574/)
sege 01-10-2008 09:20
dead phone still not perfect more dead more dead phone
systemworm 01-11-2008 20:28
Repaired one Chinese 6500 which was restarting.Formatting didn't help so I flashed phone with
CM_Nokia-N6500_MTK26_05C_MASTER_PCB01_GPRS_MT6226_S01.MAUI_ 05C_W06_16_16m_En_Ru_Fr_Es_Th_Vn_Pt_Ar.B0M
Here is the log
COM4 [Serial2] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: write NOR flash
write: Firmware
skip: Customization
skip: Language Pack
skip: Eeprom/ffs
Boot...
Connecting, wait...
Initializing[6226:8A02:8A01]...
CPU: MT6226
chip: 0031:58C6:C5CB
high speed disabled
boot step size: 0002
Release Power button now !
Boot Done
Initialize...
flash: 01227E22202200:29EA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
921600
Set baud Done
Identification...
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area#1 is Ok
security area#1 backup saved: D:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.E188537E.[MTK26_05C_MASTER_PCB01_GPRS_MT6226_S01.MAUI_05C_W0 6_16.BIN_EA09F55F].rpl
identification#1 detection finished
device-id: E188537E
identification#1 protocol ver: 04
ver. sw1: MTK26_05C_MASTER_PCB01_GPRS_MT6226_S01.MAUI_05C_W0 6_16.BIN
ver. sw2: MAUI.05C.W06.16
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information not found
detect device identification#2 finished
detecting languages...
language parameters detected
detected languages: En Ru Fr Es Th Vn Pt Ar
Identification Done
Manipulation...
Manipulation Done
Finalization...
Finalization Done
Write...
security area#1 calculation...
done
file saved: D:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _E188537E_MTK26_05C_MASTER_PCB01_GPRS_MT6226_S01.M AUI_05C_W06_16.BIN_EA09F55F_20080111-224314.B0X.bin
Area: Firmware
Write: Firmware
Write Done
file saved: D:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _E188537E_MTK26_05C_MASTER_PCB01_GPRS_MT6226_S01.M AUI_05C_W06_16.BIN_EA09F55F_20080111-225056.B0X.bin
Finished, time used: 523 sec
Remove/Install battery now !
cellbhai 01-17-2008 03:05
Its a money making machine.Very fast reply,they r helping new users with smiling face,they r working round a clock.USers are very happy with INFINITY TEAM.VERY GOOD SUPPORT TEAM.
alfox 01-17-2008 03:26
ok now heres my first success story for chinese miracle and hope more to come.thanks infinity plus for the support.more power....
heres a common scenario for china phones.problem hangs/turns off when inserted with simcard.this is a reference for us all....
first step disassemble the unit and look for the pinouts of the unit....in my case N95 dualsim not sliding china phone...
then connect the phone and now read full flash for back up purposes
LOGS
COM60 [VCP0] selected
advanced flash detection active
Action: read NOR flash
Boot...
baud autodetection active
19200
Connecting, wait...
chip: 0031:D5F3:82FA
high speed disabled
Boot Done
Initialize...
flash: EC257E25082501:29EA0000000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
Initialize Done
Set baud...
921600
Set baud Done
Identification...
device parameters autodetection in progress..
it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
security area#1 Ok
security area backup saved:
id.88D480C6.[E553_B2ARAB_E553_GPRS_MT6226_S01.01_1.BIN_4A49BC24].rpl
New firmware detected:
- make "Repair security area" operation
- send "backup_system_log_..." file to support
- make "Read full flash" operation
- send flash backup file(s) to support
- include in your e-mail full text from phone back label (phone name etc.)
device-id: alfox
ver. sw1: E553_B2ARAB_E553_GPRS_MT6226_S01.01_1.BIN
ver. sw2: E553_B2ARAB.01.1
ffs offset/size: 00800000/001FF000
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00800000
checking area[00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
Detected eeprom/ffs address is non-standard: 00E00000
Posible reasons:
1. eeprom is Ok but address is non-standard
2. eeprom damaged and can't be detected
3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure)
If you are not sure that detected address is correct:
1. press "NO" (and select standard address or terminate current operation)
2. make flash backup for emergency case
3. repeat required operation
Are you sure that detected eeprom address is correct ?
autodetected eeprom/ffs address[00E00000] confirmed by user
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
reading [flash[E553_B2ARAB_E553_GPRS_MT6226_S01.01_1.BIN]]...
file saved: C:\Program
Files\InfinityBox\ChineseMiracle\backup_flashN95du alGood[E553_B2ARAB_E553_GP
RS_MT6226_S01.01_1.BIN]_20080110-122857.B0M.bin
file saved:
backup_system_log_88D480C6_E553_B2ARAB_E553_GPRS_M T6226_S01.01_1.BIN_4A49BC2
4_20080110-122919.B0X.bin
Finished, time used: 630 sec
then after back up now format the phone
LOGS
Action: reset settings
Model: Autodetect 6205-6227 NOR
19200
Connecting, wait...
Phone detected, wait...
Hardware: MT6226,E02
Date: 2005.04.12
Version: 1.0
Version: E553_B2ARAB.01.1_26S01
Version: M500Z_05C_HW
detecting structure #2...
done
imei: 35543501019827
connection Ok
building list...
done
items to clear: 194
172 of 194 items cleared
building list...
done
4 items remains
Finished, time used: 137 sec
then after formatting write the original imei
LOGS
Action: imei
Phone should be Switched ON !
Connecting, wait...
Hardware version: MT6226, E02
Hardware version: M500Z_05C_HW
Software version: E553_B2ARAB.01.1_26S
Software date: 2005.04.12
Barcode: MT012345678901234567
imei: 135790246811220
imei write method: mode-1
new imei: 355435010198272
imei verified Ok
Finished, time used: 52 sec
Power off phone now !
then change the language to english and now the phone is alright
cellbhai 02-02-2008 16:23
N 98 I Restart complaint.2*5 pin.I use N77i pin ou connection and formate set.see log.
==== log opened: [2/1/2008 8:15:51 PM] ====
Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e
Loading data, wait...
[Infinity Box] v2.24
S/N: 08A6***xx
Wait...
Done
Action: read information
Connecting, wait...
Hardware version: BR26_05C_HW
Software version: AIDEHE_SSD1289_OV767
imei: 354442573045100
Finished, time used: 9 sec
WARNING ! Settings will be cleared, user data erased, Imei set to default value !
Make flash backup before this procedure !
Do you want to continue ?
COM4 [VCP0] selected
eeprom backup enabled, it may takes several minutes !
Action: reset
Boot...
19200
Connecting, wait...
CPU: MT6226
chip: 0031:0041:99C0
high speed disabled
Boot Done
Initialize...
Initialize Done
Set baud...
slowest
Set baud Done
Identification...
security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.25F2DB6B.[BR26_05C_PCB01_GPRS_MT6226_S01.BR26_35_25.BIN_D4D9 0094].rpl
device-id: 25F2DB6B
ver. sw1: BR26_05C_PCB01_GPRS_MT6226_S01.BR26_35_25.BIN
ver. sw2: BR26_35.25, 6BFF262B
standard eeprom/ffs offset detected: 00E00000
ffs chip: 00
reading [eeprom[BR26_05C_PCB01_GPRS_MT6226_S01.BR26_35_25.BIN]]...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_eeprom[BR26_05C_PCB01_GPRS_MT6226_S01.BR26_35_25.BIN]_20080201-203719.B0E.bin
Identification Done
Manipulation...
Manipulation Done
Finalization...
Finalization Done
Write...
formatting...
Write Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _25F2DB6B_BR26_05C_PCB01_GPRS_MT6226_S01.BR26_35_2 5.BIN_D4D90094_20080201-203749.B0X.bin
Finished, time used: 1248 sec
GsmXplorer 02-02-2008 20:14
Hey thanx for CM infinity
successfully flash CECT V180
RGDS
shripalkawdia 02-02-2008 23:01
RGDS
which flash file u select
can u explain more
GsmXplorer 02-03-2008 16:31
Successfully Format China N95 with new Picture help from Infinity Team
Thanks
B.Regards
alfox 02-07-2008 05:23
heres my bwena mano for today.another china phone.i guess it really is chinese new year.kung hei fat choi
pinout here:
logs here:
back up process:
Boot...
19200
Connecting, wait...
CPU: MT6226
chip: 0031:C9BC:429A
high speed disabled
Boot Done
Initialize...
Initialize Done
Set baud...
921600
Set baud Done
Identification...
Files\InfinityBox\ChineseMiracle\backup_security\i d.6A2C4497.[T6226_05C_PCB0
1_GPRS_MT6226_S01.A7_NOKIA_ALLLANG_V0627A.BIN_F52B 6C0A].rpl
device-id: 6A2C4497
ver. sw1: T6226_05C_PCB01_GPRS_MT6226_S01.A7_NOKIA_ALLLANG_V 0627A.BIN
ver. sw2: A7_NOKIA_ALLLANG_V0627A, F593D40A
ffs chip: 00
reading
[flash[T6226_05C_PCB01_GPRS_MT6226_S01.A7_NOKIA_ALLLANG_V 0627A.BIN]]...
Files\InfinityBox\ChineseMiracle\backup_flash[T6226_05C_PCB01_GPRS_MT6226_S0
1.A7_NOKIA_ALLLANG_V0627A.BIN]_6300autoOff20080207-094139.B0M.bin
Files\InfinityBox\ChineseMiracle\backup_system_log _6A2C4497_T6226_05C_PCB01_
GPRS_MT6226_S01.A7_NOKIA_ALLLANG_V0627A.BIN_F52B6C 0A_20080207-094231.B0X.bin
Finished, time used: 606 sec
format process:
19200
CPU: MT6226
Connecting, wait...
Date: 2005.04.12
Version: 1.0
Version: A7_NOKIA_ALLLANG_V0627A
Version:
done
60 byte(s) read
imei: 35619801240211
connection Ok
building list...
done
items to clear: 199
157 of 199 items cleared
0 items remains
Finished, time used: 225 sec
restore imei:
Action: imei
Connecting, wait...
Software version: A7_NOKIA_ALLLANG_V06
new imei: 356198012402113
imei verified Ok
Finished, time used: 31 sec
after all the process phone is now working well
fethi 02-07-2008 15:19
4 lines is very little to write about this
Originally Posted by Infinity-Box (Post 2841585)
Dear Customers,
As we all have experienced the miracle our chinese miracle software can produce to service Chinese Made Phones we would like to you to post your success storys here
Some Guideline
1) Not more than 4 lines
2) How you were benfited by Infinity Box Chinese miracle software
3) How our support has been this is your comment for our future customers
i used 2 deferent boxes for chines phone, they not good Enough like infinity and i never fail to repair any chines phone with infinity (may be i am lucky) and the support is open source to me, i can help to add new FW,new phones,.... and the most important they are very helpfull pll
jbbasha 02-08-2008 13:15
hai to all mem
thanks to infinity team for good s/w.
i need help china phone is dead, flashing ok but set is nort switching on
i have flashed n95 slide,ztc a898 pls pls can any one give the working solution
thx in adv
nasermmx 02-29-2008 20:37
lovely good very good box
GsmXplorer 03-06-2008 08:57
NCKIA -5700+ successfully repaired restart with SIM
Thanks Infinity team
Regards
19200 autodetect
CPU: MT6226
high speed boot disabled
chip: 0031:EB76:1520
Connecting, wait...
Date: 2005.04.12
Version: 1.0
Version: E558_MY1AF.01.2_26S01
done
60 byte(s) read
imei: 35869300008514
connection Ok
building list...
done
items to clear: 212
warning: wrong packet cs
209 of 212 items cleared
building list...
done
3 items remains
Finished, time used: 57 sec
alimuamin 03-20-2008 08:18
Yes The Infinity Box Is A Realy A ' Miracle ' , We Clear Many Phones With Infi. And One Think Before 2 Months We Have Get A 7 Peace Chinece Phone From A Second Sailer One Of Them Is Working But Call Not Allowed ,we Try To Format That One And Is Ok . And Copy That Flash And Try To Write Other Dead Phones, All Phones Is Okay. Costomer Is Afraid ,because People Said That Money Is Dead . We Told The Costomer .one Miracle Is Happened On Software Service Section Of Mobile Phones Called ------infinity!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! (sorry For Exit Out Of 4line)
GsmXplorer 03-20-2008 10:02
A6-Successfully Repaired from Dead Condition
really Great work Infinity team
Thank You Very Much
Regards
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 7.94928 seconds with 6 queries
