Huawei-G7002 unlock done COM10 [VCP1] selected module v3.66 Action: "sp-unlock" unlock method: smart fast Model: Huawei-G7002 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:7D03:0006 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: G5.2EG01V02.11 Version: P2 67 byte(s) read imei: 35645603071326 connection Ok 178 byte(s) read reading data... reading data #2... building new data... writing data... 166 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 43 sec Remove/Install battery now ! |
Vodafone 225 unlock ok COM9 [VCP1] selected module v1.78 Device: Vodafone-225 Checking data, wait... Action: "sp-unlock" unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 00EC:257E Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: -SA-P108A2V1.0.0B08 VDF-P108A2B07-RoFr-SA03 g3dBV2.0 Aug 10 2007 Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-225_eeprom-static_20101124-130355.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-225_eeprom-security_20101124-130357.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-225_eeprom-complete_20101124-130403.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-225_lock-area_20101124-130416.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 54 sec Remove/Install battery now ! |
unlocked orange lisbon with gw300 cable, took about 15 secs. please update pinout . thanx. sorry no log. |
TS352F08Apr 23 2010 LG RD-3520 version 8 selected.. offline.. downloading mode.. sending boot.. patching in progress.. patching in progress 50%.. patching in progress 100%.. Done.. Finished, time used: 33 sec |
LG 3610 unlock done COM41 [LGSIDIAG1] selected module v1.38 Device: LG-3610 operation: SP-unlock Phone should be Switched ON ! connecting... OFFLINE... sending boot... sending command... patching in progress... patching in progress 50%... patching in progress 100%... Done... Phones should be restarting now... Finished, time used: 23 sec |
kg 195 fone cord read done COM4 [VCP0] selected module v3.59 Action: read unlock codes unlock method: read codes Model: LG-KG195 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 chip: 0031:3DAC:8A39 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: 7S7332SA00-001-R1D Version: FP_0620 60 byte(s) read imei: 35673201356561 connection Ok 208 byte(s) read 156 byte(s) read Phone lock: On Network lock: Off Network subset lock: Off Service provider lock: Off Corporate lock: Off IMSI lock: Off Auto lock: Off Phone code: 6234 Finished, time used: 10 sec Remove/Install battery now ! |
Successfully unlock Huawei G7002 COM9 [VCP1] selected module v3.61 Action: "sp-unlock" unlock method: smart fast Model: Huawei-G7002 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:DE03:0005 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: G5.2EG01V02.11 Version: P2 67 byte(s) read imei: 35645603141459 connection Ok 178 byte(s) read reading data... reading data #2... building new data... writing data... 166 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 42 sec Remove/Install battery now ! |
ALCATEL 363x SPunlock ok THX TO INFINITY TEAM! COM6 [VCP0] selected module v3.64 Device: Alcatel-363X, 363A Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:8E80:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (05), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.53EE3 713.[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V9.BIN_A8A98349].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 53EE3713 rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V9.BIN project-id: MAUI.08A.W08.36.SP1.V9, 4983A9A8 code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: 26B provider: 363X-2BRGRO1 customization: CI26CJ30 customization: XI26CJ30 TCL-ID identification done rom info structure: [protected] type (05), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 00C00000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XI26CJ30 customization name adjusted flash: 98000300000001:2BEA0000000000 flash: 98000300000001:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98000300000001:2BEA0000000000 flash: 98000300000001:2BEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 359xx:cool: flash: 98000300000001:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98000300000001:2BEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-363X,363A_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08 A_W08_36_SP1_V9__system_log_53EE3713_A8A98349_2010 1124-110318.B0X.bin Finished, time used: 2 min 42 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
Vodafone 541 unlock don!!! Quote:
X2 done with 1.10 Code: Connect phone on selected interface... |
Action: read/check information Code: Model: Autodetect 6228-6253 NAND Code: Model: Autodetect 6228-6253 NAND Code: Model: Autodetect 6228-6253 NAND |
motorola c113 unlocked successfuly Action: unlock Device: C113(a),C114,C115,C116,C117,C118 Checking data, wait... Connect... Press and HOLD Power button... connection mode: 00 Release Power button ! Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... SW version: 1.0.65.E. HW version: _E88 imei otp: 353607017191326 Check Flash-1 Done Check Flash-2... reading ... file saved: C:\Program Files\InfinityBox\Moto01\backup_eeprom_calibration _353607017191326_20101124-015525.18E.bin imei eeprom: 353607017191326 Check Flash-2 Done Write... Write Done Finished, time used: 25 sec Remove/Install battery now ! |
ht mobile g19 restart COM3 [VCP0] selected module v3.25 Action: reset settings ("format ffs") Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:7903:0003 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: CBM68C_XJ_V17 Version: CBM68C_25_08B_GEMINI_HW detecting structure #2... 1 2 3 5 7 8 9 11 13 done 80 byte(s) read imei: 00000000000000 connection Ok building list... done items total: 167 items to clear: 167 warning: wrong packet cs warning: wrong packet cs items cleared: 163 of 167 items remains: 0 Finished, time used: 58 sec Remove/Install battery now ! write imei Action: "repair imei" Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... imei-1: 000000000000000 imei write method: mode-1 imei write channel: imei #1 for dual sim/mono CPU new imei-1: 352191001011213 verification Ok Finished, time used: 36 sec Remove/Install battery now ! Action: read/check information Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6225, E05 Hardware version: CBM68C_25_08B_GEMINI_HW Software version: CBM68C_XJ_V17" Software date: 2006.06.14 Barcode: MT012345678901234567 imei-1: 352191001011213 imei-2: 352191001011213 imei-3: 352191001011213 Finished, time used: 2 sec Remove/Install battery now ! thx infy |
COM4 [VCP0] selected module v1.38 Device: Huawei-C2906 operation: SP-unlock Phone should be Switched ON ! connecting... checking version... C2906C53B108 C2906C53B108 Huawei C2906 version B108 selected.. OFFLINE... downloading mode... erasing... patching in progress... patching in progress 20%... patching in progress 40%... patching in progress 60%... patching in progress 80%... patching in progress 100%... DONE... Phones should be restarting now... Finished, time used: 56 sec |
Hello! I would ask with that box I can use this program. I currently use phoenix with the key fls-4. Compatible? Thank you |
