huawei c3308 unlocked http://img257.imageshack.us/img257/9990/c3308.jpg |
zte s100 unlocked http://img43.imageshack.us/img43/431/cdmaf.jpg |
China E71 IMEI repaired COM6 [VCP3] selected module v3.25 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: "repair imei" imei write channel: imei #1 (default imei inside firmware) new imei: 359502007669015 ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:9803:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is absent rom info detection finished rom info ver: 05 sw version: HEXING25_08B_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_08B _W08_52_MP_V2_090905.BIN project-id: MAUI.08B.W08.52.MP.V2.090905, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [standard] type (05) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF detecting startup code area #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... startup code area #2 is absent sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 2088C4FFFFFFFF:2088C400000000 Backup required data Done ====> Patch required data ... detecting ffs/eeprom structure pass 2... ............................ ffs/eeprom: detect std location pass #1... .................................................. .. ffs/eeprom: detect standard offset pass #1... ffs/eeprom record offset detected ffs/eeprom: detect standard data... ffs/eeprom record size detected ffs/eeprom layout detection complete ffs/eeprom detected ok element #2 imei default found: 35169501989882 Patch required data Done ====> Special operation ... Special operation Done ====> Write ... flash: 2088C4FFFFFFFF:2088C400000000 flash: 2088C4FFFFFFFF:2088C400000000 Write: imei Write Done ====> Finalization ... ffs formatting... flash: 2088C4FFFFFFFF:2088C400000000 Finalization Done Finished, time used: 2 min 15 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
MOTOROLA-WX181 UNLOCKED module v3.70 Device: Motorola-WX181 Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:401E:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088BAFFFFFFFF:2088BA00000000 flash: ST Intel std [def 003Fx010000 0008x002000] 4Mb otp offset: 003F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info ver: 05 sw version: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN project-id: MAUI.08A.W08.36.SP1.V28.F1, 00000000 code offset: 00000000 ffs offset/size [01]: 003A0000/00058000 TCL-ID identification version: 564 provider: M181X-CARGAP5 customization: CM56DD10 customization: XM56DD10 TCL-ID identification done rom info structure: [standard] type (05) TCL-ID is present ffs/eeprom address assigned: 003A0000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XM56DD10 customization name adjusted flash: 2088BAFFFFFFFF:2088BA00000000 flash: 2088BAFFFFFFFF:2088BA00000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... max address is too big, should be recalculated: 0827D124->0826B790 ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 2088BAFFFFFFFF:2088BA00000000 flash: 2088BAFFFFFFFF:2088BA00000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 00003C11C255CB flash: 2088BAFFFFFFFF:2088BA00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 2088BAFFFFFFFF:2088BA00000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Motorola-WX181_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_ W08_36_SP1_V28_F1__system_log__00000000_20101219-225302.B0X.bin Finished, time used: 1 min 58 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
NOKIA L600i USERCODE CLEARED BY FORMATING module v3.25 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:9A27:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 208810FFFFFFFF:20881000000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb otp offset: 007F0000 detecting chip #01 in region #00... flash: 208810FFFFFFFF:20881000000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb otp offset: 007F0000 detecting chip #02 in region #00... flash: 208810FFFFFFFF:20881000000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb otp offset: 007F0000 detecting chip #03 in region #00... flash: 208810FFFFFFFF:20881000000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb otp offset: 007F0000 detecting chip #04 in region #00... flash: 208810FFFFFFFF:20881000000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb otp offset: 007F0000 detecting chip #05 in region #00... flash: 208810FFFFFFFF:20881000000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb otp offset: 007F0000 detecting chip #06 in region #00... flash: 208810FFFFFFFF:20881000000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb otp offset: 007F0000 detecting chip #07 in region #00... flash: 208810FFFFFFFF:20881000000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb otp offset: 007F0000 number of flash chip/regions detected: 08/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 208810FFFFFFFF:20881000000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb otp offset: 007F0000 detecting chip #01 in region #00... flash: 208810FFFFFFFF:20881000000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb otp offset: 007F0000 it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00800000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent ==================== New firmware found (v.3.25, database date: 30.11.2010): M623C_6432_PCB01_GPRS_MT6223P_S00.M623C-P5-ZJ-GC-V747-L89-ST10-100428.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 04 sw version: M623C_6432_PCB01_GPRS_MT6223P_S00.M623C-P5-ZJ-GC-V747-L89-ST10-100428.BIN project-id: M623C-P5-ZJ-GC-V747-L89-ST10-100428, 00000000 code offset: 00000000 ffs offset/size [01]: 00750000/000B0000 rom info structure: [standard] type (04) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00750000 standard ffs/eeprom offset confirmed: 00750000 detecting ffs/eeprom size... ffs/eeprom size: 000B0000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00750000-007FFFFF firmware area: 00000000-0074FFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: M623C_6432_PCB01_GPRS_MT6223P_S00.M623C-P5-ZJ-GC-V747-L89-ST10-100428__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\M623C_6432_PCB01_ GPRS_MT6223P_S00.M623C-P5-ZJ-GC-V747-L89-ST10-100428__ffs_20101219-231817.B0E.bin flash: 208810FFFFFFFF:20881000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 208810FFFFFFFF:20881000000000 Finalization Done Finished, time used: 3 min 44 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
COM61 [LGSIDIAG1] selected module v1.41 Device: LG-3530 operation: SP-unlock Phone should be Switched ON ! connecting... OFFLINE... sending boot... sending command... patching in progress... patching in progress 50%... patching in progress 100%... Done... Phones should be restarting now... Finished, time used: 23 sec :):):) |
MOTOROLA- WX181 UNLOCKED Device: Motorola-WX181 Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:56C7:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088BAFFFFFFFF:2088BA00000000 flash: ST Intel std [def 003Fx010000 0008x002000] 4Mb otp offset: 003F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info ver: 05 sw version: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN project-id: MAUI.08A.W08.36.SP1.V28.F1, 00000000 code offset: 00000000 ffs offset/size [01]: 003A0000/00058000 TCL-ID identification version: 564 provider: M181X-CARGAP5 customization: CM56DD10 customization: XM56DD10 TCL-ID identification done rom info structure: [standard] type (05) TCL-ID is present ffs/eeprom address assigned: 003A0000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XM56DD10 customization name adjusted flash: 2088BAFFFFFFFF:2088BA00000000 flash: 2088BAFFFFFFFF:2088BA00000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... max address is too big, should be recalculated: 0827D124->0826B790 ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 2088BAFFFFFFFF:2088BA00000000 flash: 2088BAFFFFFFFF:2088BA00000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 000017E0D3F2E8 flash: 2088BAFFFFFFFF:2088BA00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 2088BAFFFFFFFF:2088BA00000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Motorola-WX181_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_ W08_36_SP1_V28_F1__system_log__00000000_20101220-003648.B0X.bin Finished, time used: 1 min 58 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
CIK.4.01Aug 20 2010 MICROMAX C111 20 August 2010 selected.. Offline.. Downloading mode.. patching in progress.. patching in progress 50%... patching in progress 100%.. Done.. Finished, time used: 19 sec |
COM2 [VCP0] selected module v1.41 Device: Huawei-C2905 operation: SP-unlock Phone should be Switched ON ! connecting... OFFLINE... disable minlock... Phones should be restarting now... Finished, time used: 5 sec :):):) |
Alcatel OT-505 unlock done ! COM6 [VCP0] selected module v3.70 Device: Alcatel-505X Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:ACAE:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC240200000000:2BEA0000000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (05), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.420F1 531.[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN_59B64033].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 420F1531 rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN project-id: MAUI.08A.W08.36.SP1.V34, 3340B659 code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: 268 provider: 505X-2CBYFR1 customization: CP26CJ23 customization: XP26CJ23 TCL-ID identification done rom info structure: [protected] type (05), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 00C00000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XP26CJ23 customization name adjusted flash: EC240200000000:2BEA0000000000 flash: EC240200000000:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: EC240200000000:2BEA0000000000 flash: EC240200000000:2BEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: FFFFFFFFFFFFFF flash: EC240200000000:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: EC240200000000:2BEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-505X_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08 _36_SP1_V34__system_log_420F1531_59B64033_20101219-211209.B0X.bin Finished, time used: 3 min 15 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
nokia 3110c success full flash card found: S/N ------:------ registered to: NILOY Connect phone on selected interface... UFS S/N ------- boot - Ok Connect phone on selected interface... Read and Check phone data... Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006010C192101001101 CMT EM0 ID : 00000232 CMT EM1 ID : 00000353 CMT PUB ID : 22000119821D7F568C0EAB49942D3262183F6AA6 CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 191EC665DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg CMT Loader sent, Boot Ok MCU Configuration FLASHID : 89810089 , CMT , NOR CMT Flash ID : 89810089 < INTEL => NU48F256 FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg CMT Algo sent CMT PAPUB : E691EA16A7593A9BB28832D7312A39F7ED668D0500 Transmission mode : Dual (Ddr, TX2) Boot Done! Init Service mode... Wait... Init Service Mode Failed, can't proceed checking... :( Connect phone on selected interface... Selected FlashSettings : FullFlash Files Set for Flashing : MCU : rm237__07.30.mcusw PPM : rm237__07.30.ppm_c CNT : rm237__07.30.image_c_tr_blue Check FlashFiles, Please, wait... Backup enabled, Will read Certificates now... Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006010C192101001101 CMT EM0 ID : 00000232 CMT EM1 ID : 00000353 CMT PUB ID : 22000119821D7F568C0EAB49942D3262183F6AA6 CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 191EC665DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg CMT Loader sent, Boot Ok MCU Configuration FLASHID : 89810089 , CMT , NOR CMT Flash ID : 89810089 < INTEL => NU48F256 FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg CMT Algo sent CMT PAPUB : E691EA16A7593A9BB28832D7312A39F7ED668D0500 Transmission mode : Dual (Ddr, TX2) Boot Done! CMT : Read NPC certificate... Cert size : 12288 byte(s) IMEI : 356029032407016 CMT : Read CCC certificate... Cert size : 8192 byte(s) CMT : Read HWC certificate... Cert size : 12288 byte(s) CMT : Read VARIANT certificate... Cert size : 20480 byte(s) Cert Read done! Init Service mode... Wait... Init Service Mode Failed! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\Best_v1.11\BEST_v1.11\Backup\Cert\3560290324070 16_CRT.rpl Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006010C192101001101 CMT EM0 ID : 00000232 CMT EM1 ID : 00000353 CMT PUB ID : 22000119821D7F568C0EAB49942D3262183F6AA6 CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 191EC665DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg CMT Loader sent, Boot Ok MCU Configuration FLASHID : 89810089 , CMT , NOR CMT Flash ID : 89810089 < INTEL => NU48F256 FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg CMT Algo sent CMT PAPUB : E691EA16A7593A9BB28832D7312A39F7ED668D0500 Transmission mode : Dual (Ddr, TX2) Boot Done! Transmission mode : Dual (Ddr, TX2) Erase : Processing rm237__07.30.mcusw Found 9 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x00000000 - 0x000006BF CMT , NOR , Area : 0x000006C0 - 0x0001FFFF CMT , NOR , Area : 0x00020000 - 0x0007FFFF CMT , NOR , Area : 0x00080000 - 0x000DFFFF CMT , NOR , Area : 0x00100000 - 0x001FFFFF CMT , NOR , Area : 0x00200000 - 0x0031FFFF CMT , NOR , Area : 0x00320000 - 0x0105FFFF CMT , NOR , Area : 0x01060000 - 0x01067FFF CMT , NOR , Area : 0x01068000 - 0x0107FFFF Using TimeOut : 5 min ( 300 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:01:37 Transmission mode : Dual (Ddr, TX2) Write : Processing rm237__07.30.mcusw CMT: Writing Hash CERT [NOLO] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [PMM_CONF] CMT: Writing Hash CERT [SBIF_CONF] Total writen 943 blocks TIME : Write time : 00:02:02 Transmission mode : Dual (Ddr, TX2) Erase : Processing rm237__07.30.ppm_c Found 1 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01080000 - 0x0151FFFF Using TimeOut : 5 min ( 300 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:24 Transmission mode : Dual (Ddr, TX2) Write : Processing rm237__07.30.ppm_c Total writen 240 blocks TIME : Write time : 00:00:30 Transmission mode : Dual (Ddr, TX2) Erase : Processing rm237__07.30.image_c_tr_blue Found 1 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01520000 - 0x01FDFFFF Using TimeOut : 5 min ( 300 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:32 Transmission mode : Dual (Ddr, TX2) Write : Processing rm237__07.30.image_c_tr_blue Total writen 236 blocks TIME : Write time : 00:00:29 Init Service mode... Wait... Reading Phone Info.... Connected phone - Nokia 3110c Software Info: V 07.30 07-05-09 RM-237 (c) Nokia. IMEI: 356029032407016 Product code: 0581437 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Product code update... Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done... Reconnect, wait... Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
COM1 [VCP0] selected module v1.41 Device: Samsung-SCH-F309, F679 operation: SP-unlock Phone should be Switched ON ! connecting... Connecting, wait... Phone detected, wait... step-1 done step-2 done step-3 done operation finished Finished, time used: 17 sec |
check version... ZTF285MRV05.01 ZTF285MRV05.01 ZTE F285 version 5.01 selected.. OFFLINE... sending command... ESN(hex) : 8070C271 sending spc... disabling minlock... Done... Phones should be restarting now... Finished, time used: 15 sec :):):) |
huawei c5005 unlock successfully COM82 [QCUSB_COM82_2] selected module v1.41 Device: Huawei-C5005 operation: SP-unlock Phone should be Switched ON ! connecting... checking version... C5005C53B115 Huawei C5005 version B115 selected.. downloading mode... wait conecting... sending command... patching in progres... patching in progres 10%... patching in progres 20%... patching in progres 30%... patching in progres 40%... patching in progres 50%... patching in progres 60%... patching in progres 70%... patching in progres 80%... patching in progres 90%... pls wait... Done... Phones should be restarting now... Finished, time used: 57 sec :):):) |
COM6 [VCP0] selected Action: unlock Device: V175,V176,V177 Checking data, wait... Connect... Press and HOLD Power button... rom version: 0411 Connecting... initial boot phase complete Release Power button ! Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... SW version: 6.6.61 HW version: MOTOROLA_E58S LP ver: LPNA_6661 Flex ver: W !,a Q TG Z cpu id: 08B6 imei eeprom: 0109130025578505 required SW version: 6.6.61 user confirmed unlock for non-locked phone Check Flash-1 Done Check Flash-2... reading ... file saved: C:\Program Files\InfinityBox\Moto01\backup_eeprom_calibration _01091300255785_20101217-180117.34E.bin unlock step-1 Ok unlock step-2 Ok unlock step-3 Ok unlock step-4 Ok unlock step-5 Ok finished Ok Finished, time used: 42 sec Remove/Install battery now ! |
