12-11-2009, 18:21 | #1486 (permalink) |
Freak Poster Join Date: Aug 2007 Location: Earth Age: 43
Member: 573588 Status: Offline Thanks Meter: 33 | module v2.99 Device: Alcatel-B331 Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:3FDD:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info protocol ver: 05 ver. sw 1: JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36_SP 1_V25.BIN ver. sw 2: MAUI.07A.W07.36.SP1.V25, 00000000 code offset: 00000000 ffs offset/size: 00C00000/00400000 TCL-ID identification version: 665 provider: B331X-2AVDES1 customization: CH66CB32 customization: XH66CB32 TCL-ID identification done ffs/eeprom address assigned: 00C00000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, part #2) calculation... identification header detected customization: XH66CB32 customization name adjusted flash: 98004900000002:2AEA0000000000 flash: 98004900000002:2AEA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... use default security area (sec info, part #1) pattern ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98004900000002:2AEA0000000000 flash: 98004900000002:2AEA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 98004900000002:2AEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98004900000002:2AEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-B331_JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_ 36_SP1_V25__system_log__00000000_20091211-162437.B0X.bin Finished, time used: 219 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to allali For This Useful Post: |
12-11-2009, 19:00 | #1487 (permalink) | |
Insane Poster Join Date: Jul 2006
Member: 318886 Status: Offline Thanks Meter: 28 | ALCATEL OT-203 Bemobile Lock.. UNLOCK DONE ALCATEL OT-203 Bemobile Lock.. UNLOCK DONE ALCATEL OT-203 TOOL's - Infinity box MModule.exe v.2.96 - pin out PROCEDURE - Phone should be Switched OFF - Select model - back up eeprom & fullflash for security measure - click UNLOCK - Done LOG's Quote:
br.Tsamabakolteam. Last edited by tolits; 12-11-2009 at 19:09. | |
The Following User Says Thank You to tolits For This Useful Post: |
12-12-2009, 08:17 | #1488 (permalink) |
No Life Poster Join Date: Dec 2005 Location: Al-Madina Communication Age: 46
Member: 206532 Status: Offline Sonork: 100.1622270 Thanks Meter: 875 | COM5 [VCP0] selected module v1.38 Device: LG-KG110 Checking data, wait... advanced flash detection enabled Action: reset Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud ... 460800 Set baud Done Check flash ... current eeprom imei: 355311015268966 current otp imei: 355311015268966 file saved: C:\Program Files\InfinityBox\LGA\eeprom_355311015268966_LG-KG110_20091212-115637.B1E.bin ................................ reading _eeprom-ffs_355311015268966... file saved: C:\Program Files\InfinityBox\LGA\_eeprom-ffs_355311015268966_LG-KG110_20091212-115817.B1E.bin Check flash Done Check space ... Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write Done Finished, time used: 558 sec Remove/Install battery now ! |
The Following User Says Thank You to alis For This Useful Post: |
12-12-2009, 08:58 | #1489 (permalink) |
Temporary banned !! Join Date: Apr 2007
Member: 482214 Status: Offline Sonork: 100.1617896 Thanks Meter: 316 | LG KP170 UNLOCK DONE COM6 [VCP0] selected module v1.39 Device: LG-KP170 Checking data, wait... advanced flash detection enabled Action: unlock unlock method: standard Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E223C2200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb id: 00005283 Boot Done Set baud ... 115200 Set baud Done Check flash ... current eeprom imei: 350305260000001 file saved: C:\Program Files\InfinityBox\LGA\eeprom_350305260000001_LG-KP170_20091211-145443.B1E.bin .................................................. .............. Check flash Done Check space ... current eeprom imei: 350305260000001 .................................................. .............. finalization done Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... write: lock area-1 Write Done Finished, time used: 63 sec Remove/Install battery now ! UNLOCK DONE |
The Following User Says Thank You to m_tahir1 For This Useful Post: |
12-12-2009, 09:35 | #1490 (permalink) |
No Life Poster Join Date: Apr 2009 Location: HM unlock fone mandi bahauddin
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | Sony-Ericsson-T250i unlock done COM4 [VCP0] selected module v1.30 Device: Sony-Ericsson-T250i "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 89880900010001:89880900000000 flash: Intel Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb Check hardware done Read data ... reading Sony-Ericsson-T250i_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-T250i_eeprom_calibration-1_20090510-115707.80E.bin Read data done Check data ... Check data done Write ... .......... flash: 89880900010001:89880900000000 Write: simlock Write done Finished, time used: 116 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to naveedbutt For This Useful Post: |
12-12-2009, 09:36 | #1491 (permalink) |
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | Sagem-my226 unlock done COM4 [VCP0] selected module v1.60 Device: Sagem-my226 Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: 009 EBI_IS_141207_1009 EBI_IS Thhmm Dddmmmyyyy 0123456789ABCDEF Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my226_eeprom-static_20090617-083039.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my226_eeprom-security_20090617-083040.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my226_eeprom-complete_20090617-083045.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my226_lock-area_20090617-083110.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 81 sec Remove/Install battery now ! |
12-12-2009, 09:43 | #1492 (permalink) |
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | Sony-Ericsson-J132 unlock done COM4 [VCP0] selected module v1.30 Device: Sony-Ericsson-J132 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 2088C0FFFFFFFF:2088C000000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb Check hardware done Read data ... reading Sony-Ericsson-J132_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-J132_eeprom_calibration-1_20090606-161004.80E.bin Read data done Check data ... Check data done Write ... ..... flash: 2088C0FFFFFFFF:2088C000000000 Write: simlock Write done Finished, time used: 76 sec Remove/Install battery now ! |
12-12-2009, 10:53 | #1493 (permalink) |
No Life Poster Join Date: Aug 2005 Location: Ena Neray Na Ho Dildar Ve Age: 38
Member: 171512 Status: Offline Thanks Meter: 1,034 | NKTEL C6000 REPAIR DONE COM6 [VCP0] selected module v3.00 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" Do you want to make ffs/eeprom backup before format ? ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:6103:0000 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000000:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000000:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #02 in region #00... flash: 98000300000000:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #03 in region #00... flash: 98000300000000:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98000300000000:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000000:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.5938AE7F.[N78_PCB01_GPRS_MT6225_S00.N78_0828_V1_5.BIN_01FE62 C1].rpl rom info detection finished device-id: 5938AE7F rom info protocol ver: 04 ver. sw 1: N78_PCB01_GPRS_MT6225_S00.N78_0828_V1_5.BIN ver. sw 2: N78_0828_V1.5, C162FE01 address offset: 00000000 ffs offset/size: 00E00000/00200000 detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 98000300000000:18E59F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98000300000000:18E59F00000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\N 78_PCB01_GPRS_MT6225_S00.N78_0828_V1_5__system_log _5938AE7F_01FE62C1_20091212-144341.B0X.bin Finished, time used: 41 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to ehsas_ghum For This Useful Post: |
12-12-2009, 12:09 | #1494 (permalink) |
No Life Poster Join Date: Jan 2008 Location: Kabul Afghanistan
Member: 687312 Status: Offline Thanks Meter: 290 | ZTE-R213 successfully unlocked: [QUOTE]COM40 [VCP0] selected module v2.94 Action: unlock unlock method: smart fast Model: ZTE-R231 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: ORANGE_ENG_EN_P107A1V1.0.4B02 Version: 08BZTENJ35_OG_08B 80 byte(s) read imei: 35424903021763 connection Ok 186 byte(s) read reading data... warning: wrong packet cs building new data... writing data... 174 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 14 sec Remove/Install battery now ! |
The Following User Says Thank You to NawabN Sahoo For This Useful Post: |
12-12-2009, 13:06 | #1495 (permalink) |
Registered User Join Date: Jan 2007 Location: South Africa/Pakistan
Member: 437195 Status: Offline Thanks Meter: 1,734 | COM4 [VCP0] selected module v1.72 Device: Zong-A136 Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 00EC:257E Connecting Done Check hardware ... sw version: PAK-P108A2V1.0.0B01 CMPAK-P108A2B07-En-PK01 g3dBV2.0 Apr 24 2008 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-static_20091210-152142.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-security_20091210-152143.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-complete_20091210-152149.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_lock-area_20091210-152203.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 64 sec Remove/Install battery now ! |
The Following User Says Thank You to Shakeel_pattoki For This Useful Post: |
12-12-2009, 13:50 | #1496 (permalink) |
No Life Poster Join Date: Jan 2009 Location: M_B_Din-PK
Member: 950201 Status: Offline Thanks Meter: 1,928 | COM3 [VCP0] selected module v3.02 Device: Autodetect 6228-6229 NAND Checking data, wait... Action: erase NAND flash chip Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6227:8A02:8A01]... CPU: MT6227 high speed boot On chip: 0031:0B79260 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... version: 3.02 cpu-id: 08 loader: 3.0840.00.00 NAND: Toshiba TC58DVM92A1FT 512+16 32 pages, 66Mb NAND id: 9876A5C0 page size: 200+10 pages/block: 20 bits i/o: 08 address cycles: 04 blocks: 1000 external ram: 00800000 finalize connection... done NOR: 0098:004900000000 [01000000] NAND: 0098:007600A500C0 [04200000] Initialize Done Set baud ... 921600 Set baud Done Identification ... ram test... pass 1... pass 2... pass 3... pass 4... done reading bootloader structure area (00010000 bytes)... detecting bootloader structure (chip)... warning: incorrect header: 77B58DF89BD00494BAFDA61D6110B7D1 nfi area detection finished: failed warning: can not detect chip parameters, default values assigned usb bootloader (chip) is absent Identification Done Write ... formatting... .................................................. .................................................. Write Done Finished, time used: 52 sec Remove/Install battery now ! |
The Following User Says Thank You to cel_phon For This Useful Post: |
12-12-2009, 15:23 | #1497 (permalink) |
Member: 482214 Status: Offline Sonork: 100.1617896 Thanks Meter: 316 | ZTE A316G+ NOT UNLOCK => module version: v.1.72PANA01 => operation (3) started: COM6 ==> get_dll_version dll version: 38.0i ==> set_com_port ==> set_baud_rate ==> set_v24_mode ==> set_baud_rate ==> check_comm_link ==> set_v24_mode ==> check_comm_link ==> get_ms_id imei: 354354030242815 ==> get_sw_version sw ver: EUZ-PK-CMPAK-P108E2FM(G)(S)V1.0.0B09 ==> get_sec_version sec ver: 00.323Et(4242) ==> get_eep_version eep version: 0001 ==> get_eep_revision eep revision: 0000 ==> reading... access result: 00 access level: 00 code verification result: 05 access result: 00 access level: 00 This model can not be unlocked yet last error: No errors => operation finished Please, send operation.log file to support Include in your mail phone name and full text from phone back label DO NOT run this test many times, it's enough to read information only once ! ==> close_com_port Finished, time used: 17 sec Power Off/On phone now ! |
12-12-2009, 23:39 | #1498 (permalink) |
No Life Poster Join Date: Jan 2008 Location: Uruguay
Member: 679135 Status: Offline Sonork: 100.1606448 Thanks Meter: 436 | SCiPhone i9+++ COM3 [VCP2] selected module v3.02 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:9C03:000E status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 208818FFFFFFFF:20881800000000 flash: ST ST [def 0080x040000] 32Mb detecting chip #01 in region #00... flash: 208818FFFFFFFF:20881800000000 flash: ST ST [def 0080x040000] 32Mb number of flash chip/regions detected: 02/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 208818FFFFFFFF:20881800000000 flash: ST ST [def 0080x040000] 32Mb detecting chip #01 in region #00... flash: 208818FFFFFFFF:20881800000000 flash: ST ST [def 0080x040000] 32Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 02000000 .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished rom info protocol ver: 04 ver. sw 1: L01_GEMINI_07B_PCB01_GPRS_MT6225_S00.MAUI_07B_W08_ 16_MP_V4_F1.BIN ver. sw 2: MAUI.07B.W08.16.MP.V4.F1, 00000000 code offset: 00000000 ffs offset/size: 01C00000/00400000 detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 01C00000 standard ffs/eeprom offset confirmed: 01C00000 detecting ffs/eeprom size... ffs/eeprom size: 00400000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:01C00000-01FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: L01_GEMINI_07B_PCB01_GPRS_MT6225_S00.MAUI_07B_W08_ 16_MP_V4_F1__ffs... file saved: C:\Archivos de programa\InfinityBox\ChineseMiracle\L01_GEMINI_07B _PCB01_GPRS_MT6225_S00.MAUI_07B_W08_16_MP_V4_F1__f fs_20091212-172110.B0E.bin flash: 208818FFFFFFFF:20881800000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 208818FFFFFFFF:20881800000000 Finalization Done Finished, time used: 292 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! Action: imei Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... imei-1: 135790246811220 imei write method: mode-1 imei write channel: imei #1 for dual sim/mono CPU new imei-1: 356296180358586 verification Ok Finished, time used: 10 sec Power off phone now ! |
The Following User Says Thank You to hvalero2001 For This Useful Post: |
12-13-2009, 06:50 | #1500 (permalink) |
Member: 950201 Status: Offline Thanks Meter: 1,928 | COM3 [VCP0] selected Action: unlock Device: C261 Checking data, wait... Connect... Press and HOLD Power button... rom version: 0411 Connecting... initial boot phase complete Release Power button ! Connect Done Boot... Boot Done Set Baud... 921600 Set Baud Done Check Flash-1... SW version: 0.1.76 HW version: MOTOROLA_E58S LP ver: LPNA_0176 Flex ver: FLEX_90_64_5009 cpu id: 08B6 imei eeprom: 0109110076222663 required SW version: 0.1.76 sp-locked: 302720302370 Check Flash-1 Done Check Flash-2... reading ... file saved: C:\Program Files\InfinityBox\Moto01\backup_eeprom_calibration _01091100762226_20091214-224838.34E.bin unlock step-1 Ok unlock step-2 Ok unlock step-3 Ok unlock step-4 Ok unlock step-5 Ok finished Ok Finished, time used: 28 sec Remove/Install battery now ! |
