12-18-2011, 15:08 | #15032 (permalink) |
No Life Poster Join Date: May 2008 Location: persian Age: 43
Member: 777729 Status: Offline Sonork: 100.1616470 Thanks Meter: 824 | Core version : 1.30 Rev : 1.1 Selected FlashSettings : Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-555_30.0.004_prd.core.C00 PPM : RM-555_30.0.004_prd.rofs2.V46 PPM2 : RM-555_30.0.004_C01_prd.rofs3.fpsx CNT : RM-555_30.0.004_uda_5_001.uda.fpsx APE : RM555_APE_ONLY_ENO_09w40_v0.032.fpsx Flashing phone now... Check files done... -> Check SW version... FlashFile version : 30.0.004 Phone version : v 11.0.102 -> Error on SW version check... Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... ok SL3 Simlock Sign read ... ok WMDRM read ... ok SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : E:\BEST\Backup\Cert\351979042490151_SIM_2nd.rpl Check communication with phone.... ADL req restart Communication verify done... Preparing... Gathering phone info... Check communication with phone... Reboot.... Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000010000022600010006400C192101051103 CPU ID : RAPIDOv11 , Features : Dead-Test, USBRPL, WR/ER-USB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 10B0010BF18F00523B0C0B16DCDF034743BBCA38 ASIC MODE ID: 00 ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 ROM ID: 4B9B75103E691FF8 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing RAP3NAND ... Processing PASUBTOC ... Processing PAPUBKEYS... Processing UPDAPP ... Boot Done! TIME : Boot time : 00:00:04 Reopening the connection... Waiting for response: 30 Waiting for response: 29 Waiting for response: 28 Waiting for response: 27 Waiting for response: 26 Waiting for response: 25 Waiting for response: 24 Waiting for response: 23 Waiting for response: 22 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Auth done... ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing RM-555_30.0.004_prd.core.C00 Found 4 areas to erase Erasing area 0x00040000 - 0x00082FFF, NAND, CMT Result: 0000 Erasing area 0x00083400 - 0x003FFFFF, NAND, CMT Result: 0000 Erasing area 0x00800000 - 0x00D5FFFF, NAND, CMT Result: 0000 Erasing area 0x00D60000 - 0x0D39FFFF, NAND, CMT Result: 0000 Erase partition 0x0A Partition erase Ok Partitioning : Ok [5] TIME : Erase time : 00:00:01 Write : Processing RM-555_30.0.004_prd.core.C00 Total 517 [517/0/0] blocks to write, writing... CMT : Writing Hash CERT [ADA] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [RAP3NAND] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [SOS*UPDAPP] CMT : Writing Hash CERT [SOS*DSP0] CMT : Writing Hash CERT [SOS*ISASW] CMT : Writing Hash CERT [SOS+CORE] CMT : Writing Hash CERT [SOS+ROFS1] TIME : Write time : 00:00:38 MCU Write done ===Flashing [PPM]=== Erase : Processing RM-555_30.0.004_prd.rofs2.V46 Found 1 areas to erase Erasing area 0x094A0000 - 0x0C49FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-555_30.0.004_prd.rofs2.V46 Total 87 [87/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS2] TIME : Write time : 00:00:06 PPM Write done ===Flashing [PPM2]=== Erase : Processing RM-555_30.0.004_C01_prd.rofs3.fpsx Found 1 areas to erase Erasing area 0x0C4A0000 - 0x0D39FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-555_30.0.004_C01_prd.rofs3.fpsx Total 7 [7/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS3] TIME : Write time : 00:00:00 PPM Write done ===Flashing [CNT]=== Erase : Processing RM-555_30.0.004_uda_5_001.uda.fpsx Found 1 areas to erase Erasing area 0x0D3A0000 - 0x1EF7FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-555_30.0.004_uda_5_001.uda.fpsx Total 3 [3/0/0] blocks to write, writing... TIME : Write time : 00:00:00 CNT Write done ===Flashing [APE]=== Erase : Processing RM555_APE_ONLY_ENO_09w40_v0.032.fpsx Found 1 areas to erase Erasing area 0x00400000 - 0x007FFFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM555_APE_ONLY_ENO_09w40_v0.032.fpsx Total 17 [17/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS*ENO] TIME : Write time : 00:00:00 APE Write done ================= ADL : End flashing ADL : Finalize... Flashing done! Total flash time : 00:00:47 Reboot phone now... Reading Phone Info.... Connected phone - Nokia N97 mini Software Info: V ICPR72_11w18 09-05-11 RM-555 (c) Nokia IMEI: 351979042490151 Ape Version: v 30.0.004 Product code: 0585264 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Set phone to Normal mode... AfterFlash operations done ;D Done! Elapsed: 00:01:31 Connect phone on selected interface... |
The Following User Says Thank You to sirnavid2010 For This Useful Post: |
12-19-2011, 12:23 | #15033 (permalink) |
No Life Poster Join Date: Apr 2010 Location: (GSM CITY)
Member: 1294131 Status: Offline Sonork: 16919899 Thanks Meter: 579 | sagam my 150 unlock COM3 [VCP0] selected module v1.77 Device: Sagem-my150x Checking data, wait... Action: "sp-unlock" unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820010 loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: 8 EAI_IC_251207_1558 251207_1558 EAI_IC Ag Bh ` Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my150x_eeprom-static_20111219-155935.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my150x_eeprom-security_20111219-155936.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my150x_eeprom-complete_20111219-155937.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my150x_lock-area_20111219-155941.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 5 min 32 sec Remove/Install battery now ! |
The Following User Says Thank You to ..::\/\/::.. For This Useful Post: |
12-19-2011, 15:11 | #15034 (permalink) |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 61
Member: 4813 Status: Offline Thanks Meter: 401 | Core version : 1.33 Rev : 1.0 Selected FlashSettings : FullFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-559_21.0.004_prd.core.C00 PPM : RM-559_21.0.004_prd.rofs2.V05 PPM2 : RM-559_21.0.004_C03_prd.rofs3.fpsx CNT : RM-559_21.0.004_001_000_U001.uda.fpsx Flashing phone now... Check files done... -> Check SW version... FlashFile version : 21.0.004 Phone version : V 20.0.005 -> Check SW version : Upgrade Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... ok SL3 Simlock Sign read ... ok WMDRM read ... ok SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\356046035924706_SI M_2nd.rpl Check communication with phone.... ADL req restart Communication verify done... Preparing... Gathering phone info... Check communication with phone... Batery valtage : 3790 mV -> Batery voltage less, than 3,8V (3790mV). Continue at user risk Reboot.... Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000010000022600010006400C192101051103 CPU ID : RAPIDOv11 , Features : Dead-Test, USBRPL, WR/ER-USB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 1F700011E18C00527AC3662554E60EE07B37031A ASIC MODE ID: 00 ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 ROM ID: 4B9B75103E691FF8 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing RAP3NAND ... Processing PASUBTOC ... Processing PAPUBKEYS... Processing UPDAPP ... Boot Done! TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 Waiting for response: 29 Waiting for response: 28 Waiting for response: 27 Waiting for response: 26 Waiting for response: 25 Waiting for response: 24 Waiting for response: 23 Waiting for response: 22 Waiting for response: 21 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Auth done... ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing RM-559_21.0.004_prd.core.C00 Found 4 areas to erase Erasing area 0x00040000 - 0x00082FFF, NAND, CMT Result: 0000 Erasing area 0x00083400 - 0x003FFFFF, NAND, CMT Result: 0000 Erasing area 0x00800000 - 0x00D5FFFF, NAND, CMT Result: 0000 Erasing area 0x00D60000 - 0x0B71FFFF, NAND, CMT Result: 0000 Erase partition 0x0A Partition erase Ok Partitioning : Ok [5] TIME : Erase time : 00:00:00 Write : Processing RM-559_21.0.004_prd.core.C00 Total 477 [477/0/0] blocks to write, writing... CMT : Writing Hash CERT [ADA] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [RAP3NAND] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [SOS*UPDAPP] CMT : Writing Hash CERT [SOS*DSP0] CMT : Writing Hash CERT [SOS*ISASW] CMT : Writing Hash CERT [SOS+CORE] CMT : Writing Hash CERT [SOS+ROFS1] TIME : Write time : 00:00:35 MCU Write done ===Flashing [PPM]=== Erase : Processing RM-559_21.0.004_prd.rofs2.V05 Found 1 areas to erase Erasing area 0x07920000 - 0x0A2FFFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-559_21.0.004_prd.rofs2.V05 Total 118 [118/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS2] TIME : Write time : 00:00:09 PPM Write done ===Flashing [PPM2]=== Erase : Processing RM-559_21.0.004_C03_prd.rofs3.fpsx Found 1 areas to erase Erasing area 0x0A300000 - 0x0B71FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-559_21.0.004_C03_prd.rofs3.fpsx Total 27 [27/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS3] TIME : Write time : 00:00:01 PPM Write done ===Flashing [CNT]=== Erase : Processing RM-559_21.0.004_001_000_U001.uda.fpsx Found 1 areas to erase Erasing area 0x0B720000 - 0x1EF7FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-559_21.0.004_001_000_U001.uda.fpsx Total 35 [35/0/0] blocks to write, writing... TIME : Write time : 00:00:03 CNT Write done ================= ADL : End flashing ADL : Finalize... Flashing done! Total flash time : 00:00:52 Reboot phone now... Reading Phone Info.... Connected phone - Nokia X6-00 Software Info: V ICPR72_10w21.1 26-05-10 RM-559 (c) Nokia IMEI: 356046035924706 Ape Version: V 21.0.004 Product code: 0598909 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Product code update... Set phone to Normal mode... AfterFlash operations done ;D Done! Elapsed: 00:01:32 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok |
The Following User Says Thank You to raychevski For This Useful Post: |
12-19-2011, 15:39 | #15035 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Bulgaria,Assenovgrad Age: 46
Member: 591325 Status: Offline Thanks Meter: 151 | COM6 [VCP0] selected module v3.95 Device: Motorola-WX295 Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:B5DB:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (05), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\PROGRA~1\INFINI~1\MModule\backup_security\id.89 5F8250.[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V40_F5.BIN_DB033498].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 895F8250 rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V40_F5.BIN project-id: MAUI.08A.W08.36.SP1.V40.F5, 983403DB code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: 569 provider: M295X-2ATBHR1 customization: CP56BJ31 customization: XP56BJ31 TCL-ID identification done rom info structure: [protected] type (05), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 00C00000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XP56BJ31 customization name adjusted flash: 98000300000001:2BEA0000000000 flash: 98000300000001:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98000300000001:2BEA0000000000 flash: 98000300000001:2BEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35835003354070 flash: 98000300000001:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98000300000001:2BEA0000000000 Finalization Done file saved: C:\PROGRA~1\INFINI~1\MModule\backup_security\Motor ola-WX295_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W0 8_36_SP1_V40_F5__system_log_895F8250_DB033498_2011 1219-163833.B0X.bin Finished, time used: 4 min 15 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to dimityr.milev For This Useful Post: |
12-20-2011, 02:01 | #15036 (permalink) |
No Life Poster Join Date: Jan 2008
Member: 679135 Status: Offline Sonork: 100.1606448 Thanks Meter: 436 | COM3 [VCP6] selected module v1.78 Device: Huawei-T201-HW-A Checking data, wait... Action: "sp-unlock" unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Boxes\InfinityBox\Pana01\Huawei-T201-HW-A_eeprom-static_20111219-161859.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Boxes\InfinityBox\Pana01\Huawei-T201-HW-A_eeprom-security_20111219-161859.B1E.bin reading eeprom-complete... file saved: C:\Boxes\InfinityBox\Pana01\Huawei-T201-HW-A_eeprom-complete_20111219-161901.B1E.bin reading additional data... file saved: C:\Boxes\InfinityBox\Pana01\Huawei-T201-HW-A_lock-area_20111219-161904.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 22 sec Remove/Install battery now ! |
The Following User Says Thank You to hvalero2001 For This Useful Post: |
12-20-2011, 12:04 | #15037 (permalink) |
No Life Poster Join Date: Nov 2008 Location: U.S.A.
Member: 893209 Status: Offline Thanks Meter: 274 | Done by BEST,,,,,,,, Code: card found: S/N VAH-777 registered to: Rhyan Connect phone on selected interface... UFS S/N Twister boot - Ok Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Core version : 1.33 Rev : 1.0 Selected FlashSettings : Manual Files Set for Flashing : MCU : rm303__10.10.mcusw PPM : rm303__10.10.ppm_i CNT : rm303__10.10.image_i_blue Check FlashFiles, Please, wait... -> SWversion check skipped : Manual mode selected Backup enabled, Will read Certificates now... SLx Simlock Data read ... ok SL2 Simlock read ... ok WMDRM read ... ok CRT308 Backup Created Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006010C192101013000 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 04100218C44A7D56B78568FD98511A6D22CEFF7B CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 003F0001 , CMT , NOR CMT Flash ID : 003F0001 < SPANSION => 72NS512P FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent CMT PAPUB : 3E96DE4212587183E5E16BB2C79692A53C19875DBD Transmission mode : Dual (Ddr, TX2) Boot Done! CMT : Read NPC certificate... Cert size : 20480 byte(s) IMEI : 356870023395508 CMT : Read CCC certificate... Cert size : 30600 byte(s) CMT : Read HWC certificate... Cert size : 20480 byte(s) CMT : Read VARIANT certificate... Cert size : 0 byte(s) Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\356870023395508_2nd.rpl Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006010C192101013000 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 04100218C44A7D56B78568FD98511A6D22CEFF7B CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 003F0001 , CMT , NOR CMT Flash ID : 003F0001 < SPANSION => 72NS512P FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent CMT PAPUB : 3E96DE4212587183E5E16BB2C79692A53C19875DBD Transmission mode : Dual (Ddr, TX2) Boot Done! Transmission mode : Dual (Ddr, TX2) Erase : Processing rm303__10.10.mcusw Found 6 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x00000000 - 0x000006BF CMT , NOR , Area : 0x000006C0 - 0x0001FFFF CMT , NOR , Area : 0x00040000 - 0x000BFFFF CMT , NOR , Area : 0x000C0000 - 0x0013FFFF CMT , NOR , Area : 0x00140000 - 0x010DFFFF CMT , NOR , Area : 0x010E0000 - 0x0121FFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:01:12 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Write : Processing rm303__10.10.mcusw CMT: Writing Hash CERT [NOLO] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] Total writen 1098 blocks TIME : Write time : 00:02:04 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Erase : Processing rm303__10.10.ppm_i Found 1 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01220000 - 0x0189FFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:26 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Write : Processing rm303__10.10.ppm_i Total writen 387 blocks TIME : Write time : 00:00:43 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Erase : Processing rm303__10.10.image_i_blue Found 2 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x018A0000 - 0x01B1FFFF CMT , NOR , Area : 0x01B20000 - 0x03FBFFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:05:14 PrReq : NOR , 00 Transmission mode : Dual (Ddr, TX2) Write : Processing rm303__10.10.image_i_blue Total writen 552 blocks TIME : Write time : 00:01:16 PrReq : NOR , 00 Init Service mode... Wait... Reading Phone Info.... Connected phone - Nokia 5310 XpressMusic Software Info: V 10.10 23-03-09 RM-303 (c) Nokia IMEI: VAH-777 Product code: 0556852 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done ;D Connect phone on selected interface... Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok BEST is the BEST,,,,,,,,, Br,. Rhyan |
The Following User Says Thank You to Rhyan777 For This Useful Post: |
12-20-2011, 16:17 | #15038 (permalink) |
Product Supporter Join Date: Aug 2007 Location: karachi
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | Core version : 1.33 Rev : 1.0 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm495__07.97.mcusw PPM : rm495__07.97.ppm_mena_a1 CNT : rm495__07.97.image_mena_a1_red Flashing phone now... Check files done... -> SWversion check skipped : Manual mode selected Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... ok SL3 Simlock Sign read ... ok WMDRM read ... ok SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : D:\InfinityBox_install_BEST_v1.33\Backup\Cert\3552 32034038810_SIM.rpl Getting product info... -> No RootKey Asic! Unable to continue flashing... -> Error while flashing... Phone disconected! Connect phone on selected interface... Core version : 1.33 Rev : 1.0 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm495__07.97.mcusw PPM : rm495__07.97.ppm_mena_a1 CNT : rm495__07.97.image_mena_a1_red Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000010000022600010006030C192101033000 CPU ID : RAP3Gv3 , Features : No any extended features RAP_PUB: 0F300005B74D7F56B57F5BA3251F49B97AD8D921 CMT_ROOT: 9DDBFCFE6E73CED7D8C6268C8EB85723 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:00 Reopening the connection... Waiting for response: 30 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm495__07.97.mcusw Found 6 areas to erase Erasing area 0x00000000 - 0x000006BF, NOR, CMT Result: 0000 Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT Result: 0000 Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT Result: 0000 Erasing area 0x00140000 - 0x0137FFFF, NOR, CMT Result: 0000 Erasing area 0x01380000 - 0x0151FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:02:43 Write : Processing rm495__07.97.mcusw Total 1178 [1178/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] TIME : Write time : 00:01:01 MCU Write done ===Flashing [PPM]=== Erase : Processing rm495__07.97.ppm_mena_a1 Found 1 areas to erase Erasing area 0x01520000 - 0x01DBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:10 Write : Processing rm495__07.97.ppm_mena_a1 Total 388 [388/0/0] blocks to write, writing... TIME : Write time : 00:00:20 PPM Write done ===Flashing [CNT]=== Erase : Processing rm495__07.97.image_mena_a1_red Found 2 areas to erase Erasing area 0x01DC0000 - 0x0215FFFF, NOR, CMT Result: 0000 Erasing area 0x02160000 - 0x03FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:06:05 Checking content info... Check Image : Content size is 128k, use direct write mode Write : Processing rm495__07.97.image_mena_a1_red Total 656 [656/0/0] blocks to write, writing... TIME : Write time : 00:00:34 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:11:55 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 5130 Software Info: V 07.97 13-09-10 RM-495 (c) Nokia IMEI: 355232034038810 PPM version : V 07.97 13-09-10 RM-495 (c) Nokia MEN Product code: 0571951 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done ;D Done! Elapsed: 00:12:38 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
The Following User Says Thank You to saeedullah_khan For This Useful Post: |
12-20-2011, 16:22 | #15039 (permalink) |
Member: 4813 Status: Offline Thanks Meter: 401 | Core version : 1.33 Rev : 1.0 Selected FlashSettings : FullFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm411__05.20.mcusw PPM : rm411__05.20.ppm_i CNT : rm411__05.20.image_i_red Flashing phone now... Check files done... -> Check SW version... FlashFile version : 05.20 Phone version : 04.92 03-09-08 RM-411 (c) Nokia -> Check SW version : Upgrade Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... ok SL2 Simlock read ... ok WMDRM read ... ok SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\355717028413979_SI M.rpl Getting product info... RAP_BOOT: 0803000302010000 RAP_PUBLIC: 1A40020DE5CC5850F2EE48460F7DD2AFCBED0058 CMT_ROOTKEY: 9DDBFCFE6E73CED7D8C6268C8EB85723 RAP_PAPUBKEY: D93826B23E9B093BE4DD7304FBAA6778996AE60B Checking CNT sector PN<>FL PN CNT sector : 128 kb ConvertImage: Processing rm411__05.20.image_i_red ConvertImage: Page Size is 128K, no need convert Loader len: 302784, CHK: F3ED ADL -> Sending loader... Update Server code succesfully sent to phone! TIME : Boot time : 00:00:04 Reopening the connection... Waiting for response: 30 Waiting for response: 29 Waiting for response: 28 Waiting for response: 27 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm411__05.20.mcusw Found 6 areas to erase Erasing area 0x00000000 - 0x000006BF, NOR, CMT Result: 0000 Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT Result: 0000 Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT Result: 0000 Erasing area 0x00140000 - 0x0137FFFF, NOR, CMT Result: 0000 Erasing area 0x01380000 - 0x0151FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:30 Write : Processing rm411__05.20.mcusw Total 1285 [1285/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] TIME : Write time : 00:01:02 MCU Write done ===Flashing [PPM]=== Erase : Processing rm411__05.20.ppm_i Found 1 areas to erase Erasing area 0x01520000 - 0x01DBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:31 Write : Processing rm411__05.20.ppm_i Total 480 [480/0/0] blocks to write, writing... TIME : Write time : 00:00:23 PPM Write done ===Flashing [CNT]=== Erase : Processing rm411__05.20.image_i_red Found 2 areas to erase Erasing area 0x01DC0000 - 0x0215FFFF, NOR, CMT Result: 0000 Erasing area 0x02160000 - 0x03FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:03:27 Write : Processing rm411__05.20.image_i_red Total 672 [672/0/0] blocks to write, writing... TIME : Write time : 00:00:32 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:07:27 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 5220 XpressMusic Software Info: V 05.20 15-10-08 RM-411 (c) Nokia IMEI: 355717028413979 PPM version : V 05.20 15-10-08 RM-411 (c) Nokia I Product code: 0568500 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Product code update... Set phone to Normal mode... AfterFlash operations done ;D Done! Elapsed: 00:08:20 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
12-21-2011, 10:04 | #15040 (permalink) |
Member: 591325 Status: Offline Thanks Meter: 151 | COM6 [VCP0] selected module v3.95 Action: read unlock codes unlock method: read codes Model: ZTE-R221_16mb Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A08]... CPU: MT6223 high speed boot On chip: 0011:6269:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E08 Date: 2000.00.00 Version: 1.0 Version: BG-MTEL-R9SM-P109A17V1.0.0B01 Version: ZTENJ23D_09A_HW ==================== New firmware found (v.3.95, database date: 20.06.2011): BG-MTEL-R9SM-P109A17V1.0.0B01 This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare ? Secure Data Logistics or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== 86 byte(s) read imei: 86853300404430 connection Ok 192 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1234 180 byte(s) read reading data... 972 byte(s) read lock[1] code: + 226172222846 lock[2] code: + default lock[3] code: + 1122 lock[4] code: - default lock[5] code: - default lock[6] code: + default lock[7] code: + default if phone do not ask for a code try: *983*8284# if code is not accepted by phone: - make full flash backup for emergency case - flash phone with good eeprom file - Power-On phone without sim-card - Power-Off phone (do not remove battery) - read unlock codes - restore original imei Finished, time used: 1 min 20 sec Remove/Install battery now ! |
12-21-2011, 10:55 | #15041 (permalink) |
Member: 4813 Status: Offline Thanks Meter: 401 | Core version : 1.33 Rev : 1.0 Selected FlashSettings : FullFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm367_05.16_prd_core.fpsx PPM : rm367_05.16_prd_v05_01_russian.fpsx PPM2 : rm367_05.16_prd_vc00_01_Navigator.fpsx CNT : rm367_05.16_prd_uda.fpsx Flashing phone now... Check files done... -> Check SW version... FlashFile version : 05.16 Phone version : 05.16 -> Check SW version : Reflash Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... ok SL2 Simlock read ... ok WMDRM read ... ok SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\356788024500969_SI M_2nd.rpl Check communication with phone.... ADL req restart Communication verify done... Preparing... Gathering phone info... Check communication with phone... Batery valtage : 3788 mV -> Batery voltage less, than 3,8V (3788mV). Continue at user risk Reboot.... Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000010000022600010006400C192101031103 CPU ID : RAPIDOv11 , Features : Dead-Test, USBRPL, WR/ER-USB EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 1CD0011004760052E660AD0C0805B2185244F13A ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing RAP3NAND ... Processing PASUBTOC ... Processing PAPUBKEYS... Processing UPDAPP ... Boot Done! TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm367_05.16_prd_core.fpsx Found 3 areas to erase Erasing area 0x00040000 - 0x00082FFF, NAND, CMT Result: 0000 Erasing area 0x00083400 - 0x0087FFFF, NAND, CMT Result: 0000 Erasing area 0x00B80000 - 0x080FFFFF, NAND, CMT Result: 0000 Erase partition 0x0A Partition erase Ok Partitioning : Ok [5] TIME : Erase time : 00:00:00 Write : Processing rm367_05.16_prd_core.fpsx Total 602 [602/0/0] blocks to write, writing... CMT : Writing Hash CERT [ADA] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [RAP3NAND] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [SOS*UPDAPP] CMT : Writing Hash CERT [SOS*DSP0] CMT : Writing Hash CERT [SOS*ISASW] CMT : Writing Hash CERT [SOS+CORE] CMT : Writing Hash CERT [SOS+ROFS1] TIME : Write time : 00:00:20 MCU Write done ===Flashing [PPM]=== Erase : Processing rm367_05.16_prd_v05_01_russian.fpsx Found 1 areas to erase Erasing area 0x053E0000 - 0x078FFFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing rm367_05.16_prd_v05_01_russian.fpsx Total 281 [281/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS2] TIME : Write time : 00:00:10 PPM Write done ===Flashing [PPM2]=== Erase : Processing rm367_05.16_prd_vc00_01_Navigator.fpsx Found 1 areas to erase Erasing area 0x07900000 - 0x080FFFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing rm367_05.16_prd_vc00_01_Navigator.fpsx Total 2 [2/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS3] TIME : Write time : 00:00:00 PPM Write done ===Flashing [CNT]=== Erase : Processing rm367_05.16_prd_uda.fpsx Found 1 areas to erase Erasing area 0x08100000 - 0x0F8BFFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing rm367_05.16_prd_uda.fpsx Total 1 [1/0/0] blocks to write, writing... TIME : Write time : 00:00:00 CNT Write done ================= ADL : End flashing ADL : Finalize... Flashing done! Total flash time : 00:00:31 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 6210 Navigator Software Info: V ICPR71_09w12.1 31-03-09 RM-367 (c) Nokia IMEI: 356788024500969 Ape Version: 05.16 Product code: 0568522 Checking... SimLock status : Can't get status Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Product code update... Set phone to Normal mode... AfterFlash operations done ;D Done! Elapsed: 00:01:10 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok |
12-21-2011, 13:22 | #15042 (permalink) |
No Life Poster Join Date: Feb 2003 Location: Tanzania Age: 62
Member: 22542 Status: Offline Sonork: 100.1660285 Thanks Meter: 102 | UNLOCKED SUCCESSFULLY VODAFONE 345: COM35 [VCP0] selected module v4.12 Device: Vodafone-345 Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A08]... CPU: MT6223 high speed boot On chip: 0011:6BE7:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088BAFFFFFFFF:2088BA00000000 flash: ST Intel std [def 003Fx010000 0008x002000] 4Mb otp offset: 003F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info ver: 05 sw version: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN project-id: MAUI.08A.W08.36.SP1.V28.F1, 00000000 code offset: 00000000 ffs offset/size [01]: 003A0000/00058000 TCL-ID identification version: 865 provider: V345X-2AVDGB1 customization: CM86FE30 customization: XM86FE30 TCL-ID identification done rom info structure: [standard] type (05) TCL-ID is present ffs/eeprom address assigned: 003A0000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XM86FE30 customization name adjusted flash: 2088BAFFFFFFFF:2088BA00000000 flash: 2088BAFFFFFFFF:2088BA00000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 2088BAFFFFFFFF:2088BA00000000 flash: 2088BAFFFFFFFF:2088BA00000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 00006721E4A5D6 flash: 2088BAFFFFFFFF:2088BA00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 2088BAFFFFFFFF:2088BA00000000 Finalization Done file saved: C:\InfinityBox\MModule\backup_security\Vodafone-345_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W0 8_36_SP1_V28_F1__system_log__00000000_20111221-151656.B0X.bin Finished, time used: 1 min 29 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to benny Haraba For This Useful Post: |
12-21-2011, 17:04 | #15043 (permalink) |
Member: 4813 Status: Offline Thanks Meter: 401 | Core version : 1.33 Rev : 1.0 Selected FlashSettings : FullFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm346_200.21.118_prd.c00 PPM : rm346_200.21.118_prd.v14 CNT : rm346_200.21.118.02U APE : RM346_ENO_0741.10.N32.fpsx CNT3 : leevi_erase_y_drive.fpsx Flashing phone now... Check files done... -> Check SW version... FlashFile version : 200.21.118 Phone version : 110.07.127 -> Check SW version : Upgrade Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... ok SL2 Simlock read ... ok WMDRM read ... ok SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\352924022373679_SI M.rpl Check communication with phone.... ADL req restart Communication verify done... Preparing... Gathering phone info... Check communication with phone... Reboot.... Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000010000022600010006400C192101031103 CPU ID : RAPIDOv11 , Features : Dead-Test, USBRPL, WR/ER-USB EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 150002061670005209DE00F589893939C3CE12AE ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP ... Processing PASUBTOC ... Boot Done! TIME : Boot time : 00:00:04 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL Server confirm flashmode! Get req info : empty ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm346_200.21.118_prd.c00 Found 3 areas to erase Erasing area 0x00040000 - 0x007FFFFF, NAND, CMT Result: 0000 Erasing area 0x00A00000 - 0x0759FFFF, NAND, CMT Result: 0000 Erasing area 0x0F1C0000 - 0x0F8BFFFF, NAND, CMT Result: 0000 Partition erase not allowed by loader Partition erase not allowed by loader Partition erase not allowed by loader Partitioning : Ok [7] TIME : Erase time : 00:00:00 Write : Processing rm346_200.21.118_prd.c00 Total 537 [537/0/0] blocks to write, writing... CMT : Writing Hash CERT [ADA] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [RAP3NAND] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [SOS*UPDAPP] CMT : Writing Hash CERT [SOS*DSP0] CMT : Writing Hash CERT [SOS*ISASW] CMT : Writing Hash CERT [SOS*CORE] CMT : Writing Hash CERT [SOS+ROFS] TIME : Write time : 00:01:27 MCU Write done ===Flashing [PPM]=== Erase : Processing rm346_200.21.118_prd.v14 Found 1 areas to erase Erasing area 0x05420000 - 0x0759FFFF, NAND, CMT Result: 0000 Partition erase not allowed by loader TIME : Erase time : 00:00:00 Write : Processing rm346_200.21.118_prd.v14 Total 221 [221/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFX] TIME : Write time : 00:00:38 PPM Write done ===Flashing [CNT]=== Erase : Processing rm346_200.21.118.02U Partition erase not allowed by loader TIME : Erase time : 00:00:00 Write : Processing rm346_200.21.118.02U Total 63 [63/0/0] blocks to write, writing... TIME : Write time : 00:00:11 CNT Write done ===Flashing [APE]=== Erase : Processing RM346_ENO_0741.10.N32.fpsx TIME : Erase time : 00:00:00 Write : Processing RM346_ENO_0741.10.N32.fpsx Total 16 [16/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS*ENO] TIME : Write time : 00:00:02 APE Write done ===Flashing [CNT3]=== Erase : Processing leevi_erase_y_drive.fpsx Found 1 areas to erase Erasing area 0x0F020000 - 0x0F1BFFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing leevi_erase_y_drive.fpsx No any data for write, skip write CNT Write done ================= ADL : End flashing ADL : Finalize... Flashing done! Total flash time : 00:02:20 Reboot phone now... Reading Phone Info.... Connected phone - Nokia E71 Software Info: V ICPR71_08w44.2 19-11-08 RM-346 (c) Nokia IMEI: 352924022373679 Ape Version: 200.21.118 Product code: 0569999 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Product code update... Set phone to Normal mode... AfterFlash operations done ;D Done! Elapsed: 00:03:01 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok |
12-21-2011, 19:18 | #15044 (permalink) |
Freak Poster Join Date: Mar 2007 Location: Lanzarote Canary Island, Spain
Member: 463207 Status: Offline Thanks Meter: 22 | Alcatel V570 Success unlock Thks Team..you are the beest..!! COM34 [VCP0] selected module v4.01 Device: Alcatel-V570X, V570A Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:5203:A009 status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22442200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x008000 007Ex020000 0004x008000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (05), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\InfinityBox\MModule\backup_security\id.0AC208EB .[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN_574864C8].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 0AC208EB rom info ver: 05 sw version: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN project-id: MAUI.06B.W07.28.SP1.V34, C8644857 code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: 744 provider: V570X-2BALES1 customization: CD74AC00 customization: XD74AC00 TCL-ID identification done rom info structure: [protected] type (05), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 00C00000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: disabled product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XD74AC00 customization name adjusted flash: 01227E22442200:18E59F00000000 flash: 01227E22442200:18E59F00000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 01227E22442200:18E59F00000000 flash: 01227E22442200:18E59F00000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35402902079268 flash: 01227E22442200:18E59F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 01227E22442200:18E59F00000000 Finalization Done file saved: C:\InfinityBox\MModule\backup_security\Alcatel-V570X,V570A_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_0 6B_W07_28_SP1_V34__system_log_0AC208EB_574864C8_20 111221-181121.B0X.bin Finished, time used: 4 min 24 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to lucamensi For This Useful Post: |
12-21-2011, 22:08 | #15045 (permalink) |
No Life Poster Join Date: Dec 2009 Location: CIEGO DE AVILA ,CUBA
Member: 1176958 Status: Offline Thanks Meter: 158 | vodafone 340 unlock done Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: BM35A1.V2.22.M00.02.42 Version: FOXLINK25_08B_HW 81 byte(s) read imei: 35xxxxxxxxxxxxxxxx connection Ok 186 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 0000 174 byte(s) read reading data... 972 byte(s) read lock[1] code: + 07262704 lock[2] code: - 03093050 lock[3] code: - 02863409 lock[4] code: - 49822904 lock[5] code: - 64827897 lock[6] code: - 79603407 lock[7] code: - 41887455 if phone do not ask for a code try: *983*8284# if code is not accepted by phone: - make full flash backup for emergency case - flash phone with good eeprom file - Power-On phone without sim-card - Power-Off phone (do not remove battery) - read unlock codes - restore original imei Finished, time used: 23 sec Remove/Install battery now ! |
The Following User Says Thank You to yaro_rguez For This Useful Post: |
