Old 12-14-2009, 17:27   #1516 (permalink)
alis's Avatar
Member: 206532
Sonork: 100.1622270
Thanks Meter: 875
COM5 [VCP0] selected
module v1.72
Device: Zong-A136
Checking data, wait...
Action: unlock
unlock method-1
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud ...
921600
Set Baud Done
Connecting ...
flash: 00EC:257E
Connecting Done
Check hardware ...
sw version: -PE-P108A8 Z V1.0.0B02 12 09 06 CLARO-P108A8 Z B01-EnEs-PE02 g3d
Check hardware Done
Check parameters ...
Check parameters Done
backup critical area ...
reading eeprom-static...
file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-static_20091214-212226.B1E.bin
loading data...
data loaded
reading eeprom-security...
file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-security_20091214-212226.B1E.bin
reading eeprom-complete...
file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-complete_20091214-212227.B1E.bin
reading additional data...
file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_lock-area_20091214-212230.B1E.bin
backup critical area Done
Check memory ...
lock found
lock type #1 found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Finished, time used: 20 sec
Remove/Install battery now !
The Following User Says Thank You to alis For This Useful Post:
Old 12-14-2009, 22:23   #1517 (permalink)
Member: 679135
Sonork: 100.1606448
Thanks Meter: 436
Bx n1000+
COM3 [VCP1] selected
module v3.02
Device: Autodetect 6205-6227 NOR
Action: "format ffs"
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:9D03:0005
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 98000300000000:18E59F00000000
flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
921600
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: 2nd [standard] generation
TCL-ID is absent
New firmware detected (v.3.02, database date: 10.12.2009):
LC6225_GEMINI_PCB01_GPRS_MT6225_S00.F692+_FOREIGN_ BL_V1_62.BIN
This firmware is missing in support area. If this phone is good and working:
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com
- include in your e-mail full text from phone back label (phone name etc.)
rom info detection finished
rom info protocol ver: 04
ver. sw 1: LC6225_GEMINI_PCB01_GPRS_MT6225_S00.F692+_FOREIGN_ BL_V1_62.BIN
ver. sw 2: F692+_Foreign_BL_V1.62, 00000000
code offset: 00000000
ffs offset/size: 00E00000/00200000
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
standard ffs/eeprom offset confirmed: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
reading: LC6225_GEMINI_PCB01_GPRS_MT6225_S00.F692+_FOREIGN_ BL_V1_62__ffs...
file saved: C:\Archivos de programa\InfinityBox\ChineseMiracle\LC6225_GEMINI_ PCB01_GPRS_MT6225_S00.F692+_FOREIGN_BL_V1_62__ffs_ 20091214-161118.B0E.bin
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
Finished, time used: 136 sec
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Action: imei
Model: Autodetect 6205-6227 NOR
Phone should be Switched ON !
Connecting, wait...
Phone detected, wait...
imei-1: 135790246811220
imei write method: mode-1
imei write channel: imei #1 for dual sim/mono CPU
new imei-1: 354101001001997
verification Ok
Finished, time used: 6 sec
Power off phone now !
Old 12-15-2009, 07:35   #1518 (permalink)
akhtar416786's Avatar
Member: 342708
Thanks Meter: 29
Alcatel-E201-----done
COM4 [VCP3] selected
module v1.34
Device: Alcatel-E201
"advanced chip detection" active
Action: unlock
Boot ...
Press Power button now !
rom version: 0502
Connecting...
booting...
finalizing...
Boot done
Check connection ...
Check connection done
Set baud ...
812500
Set baud done
Check hardware ...
flash: 012A7E2A242A00:54000000000000
flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb
Check hardware done
Read data ...
reading Alcatel-E201_eeprom_calibration-1...
file saved: C:\Documents and Settings\akhtar\Desktop\Alcatel-E201_eeprom_calibration-1_20081214-161819.80E.bin
Read data done
Check data ...
Check data done
Write ...
Write: simlock
Write done
Finished, time used: 124 sec
The Following 2 Users Say Thank You to akhtar416786 For This Useful Post:
Old 12-15-2009, 07:38   #1519 (permalink)
Member: 355565
Sonork: 1597522
Thanks Meter: 95
zte a136 zong unlock done
COM6 [VCP1] selected
module v1.71
Device: ZTE-A136
Action: unlock
unlock method-1
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
slowest
Set Baud Done
Connecting ...
flash: 00EC:257E
Connecting Done
Check hardware ...
sw version: PAK-P108A2V1.0.0B01 CMPAK-P108A2B07-En-PK01 g3dBV2.0 Apr 24 2008
Check hardware Done
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A136_eeprom-static_20091215-113651.B1E.bin
loading data...
data loaded
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A136_eeprom-security_20091215-113652.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A136_eeprom-complete_20091215-113659.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A136_lock-area_20091215-113711.B1E.bin
Check memory ...
lock found
lock type #1 found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Finished, time used: 48 sec
The Following User Says Thank You to super decent For This Useful Post:
Old 12-15-2009, 08:02   #1520 (permalink)
alis's Avatar
Member: 206532
Sonork: 100.1622270
Thanks Meter: 875
module v1.72
Device: Zong-A136
Action: unlock
unlock method-1
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
921600
Set Baud Done
Connecting ...
flash: 00EC:257E
Connecting Done
Check hardware ...
Check hardware Done
file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-static_20091215-115842.B1E.bin
loading data...
data loaded
file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-security_20091215-115842.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-complete_20091215-115844.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_lock-area_20091215-115847.B1E.bin
Check memory ...
lock found
lock type #1 found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Finished, time used: 25 sec
Old 12-15-2009, 09:17   #1521 (permalink)
Tadiwa's Avatar
Member: 46042
Sonork: 100.1575650
Thanks Meter: 93
COM4 [VCP0] selected
module v2.76
Device: ZTE-X760
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
chip: 0001:A203:000C
status: FF
Boot Done
Initialize ...
flash: 01227E22312200:18E59F00000000
flash: Amd AMD/Fujitsu std [D 0004x008000 007Ex020000 0004x008000] 16Mb
Initialize Done
Set baud ...
460800
Set baud Done
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area (code #1) is Ok
security area (code #1) backup saved: D:\Program Files\InfinityBox\MModule\backup_security\id.F3E2F BCA.[ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X760_Z10NL_GD_B0 7A104.BIN_9B3259AB].rpl
identification#1 detection finished
device-id: F3E2FBCA
identification#1 protocol ver: 04
ver. sw 1: ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X760_Z10NL_GD_B0 7A104.BIN
ver. sw 2: X760_Z10NL_GD_B07A104, 54A6CD64
ffs offset/size: 00D00000/00300000
detect device identification#2...
detect device identification#2 finished
sim-lock status: unknown
Write ...
Write Done
Finalization ...
formatting...
Finalization Done
file saved: D:\Program Files\InfinityBox\MModule\backup_security\ZTE-X760_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X760_Z10NL_ GD_B07A104__system_log_F3E2FBCA_9B3259AB_20090716-174100.B0X.bin
Finished, time used: 41 sec
The Following User Says Thank You to Tadiwa For This Useful Post:
Old 12-15-2009, 10:11   #1522 (permalink)
cel_phon's Avatar
Member: 950201
Thanks Meter: 1,928
module v2.75
Action: touchscreen calibration
mode: 2
19200 autodetect
CPU: MT6225
high speed boot On
chip: 0001:3003:0008
Connecting, wait...
Hardware: MT6225,E03
Date: 2006.06.14
Version: 1.0
Version: BB13_BLE_L7EN_205_080429_HRILI9320_SIV0_TO75_CTF_B T_FM
Version: BET25_06B_HW
detecting structure #2...
0 done
44 byte(s) read
imei: 13579024681122
warning: current phone imei is incorrect !
It's need to repair imei for correct phone functionality !
connection Ok
detecting structure #5 (mode-3)...
0 1 2 3 4 5 6 7 8 9error:
detection failed (10 tries)
What to do:
Try another calibration method, if still no luck:
1. make full flash backup for emergency case
2. make "format ffs"
3. Power-On phone
4. Power-Off phone by "Power" button (do NOT remove battery)
5. Repeat "Calibration" operation again
6. if still no luck read full flash and send to support with subject: touchscreen calibration failed
error: can't read required data
error: operation failed !
Finished, time used: 26 sec
The Following User Says Thank You to cel_phon For This Useful Post:
Old 12-15-2009, 14:14   #1523 (permalink)
Member: 977491
Thanks Meter: 82
GB102 unlock done report here
COM20 [VCP0] selected
module v1.71
Device: LG-GB102
Action: unlock
read unlock codes
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 007F:22F6
Connecting Done
Check hardware ...
sw version: .01 ULC2GL SPAIN TLF GB102 01 FL 34 V10c 214-07 MAY-11-2009 +
Check hardware Done
file saved: C:\Program Files\InfinityBox\Pana01\LG-GB102_eeprom-static_20091215-060749.B1E.bin
loading data...
data loaded
imei: 35399903425191400
reading eeprom-security_35399903425191400...
file saved: C:\Program Files\InfinityBox\Pana01\LG-GB102_eeprom-security_35399903425191400_20091215-060750.B1E.bin
reading eeprom-complete_35399903425191400...
file saved: C:\Program Files\InfinityBox\Pana01\LG-GB102_eeprom-complete_35399903425191400_20091215-060757.B1E.bin
Check memory ...
loading data...
data loaded
code: 07014154
Finished, time used: 21 sec
The Following User Says Thank You to themobileshop For This Useful Post:
Old 12-15-2009, 16:15   #1524 (permalink)
Temporary banned !!
Member: 482214
Sonork: 100.1617896
Thanks Meter: 316
Post Motorola c261 unlock done
COM6 [VCP0] selected
Action: unlock
Device: C261
Connect...
Press and HOLD Power button...
rom version: 0411
Connecting...
initial boot phase complete
Release Power button !
Connect Done
Boot...
Boot Done
Set Baud...
115200
Set Baud Done
Check Flash-1...
SW version: 6.6.61
HW version: MOTOROLA_E58S
LP ver: LPNA_6661
Flex ver: C 73'DAF n
cpu id: 08B6
imei eeprom: 3591930068180820
required SW version: 6.6.61
user confirmed unlock for non-locked phone
Check Flash-1 Done
Check Flash-2...
reading ...
file saved: C:\Program Files\InfinityBox\Moto01\backup_eeprom_calibration _35919300681808_20091215-200256.34E.bin
unlock step-1 Ok
unlock step-2 Ok
unlock step-3 Ok
unlock step-4 Ok
unlock step-5 Ok
finished Ok
Finished, time used: 42 sec
The Following User Says Thank You to m_tahir1 For This Useful Post:
Old 12-15-2009, 16:16   #1525 (permalink)
Temporary banned !!
Member: 482214
Sonork: 100.1617896
Thanks Meter: 316
Action: unlock
Device: C261
Connect...
rom version: 0411
Connecting...
Connect Done
Boot...
Boot Done
Set Baud...
115200
Set Baud Done
Check Flash-1...
SW version: 6.6.61
LP ver: LPNA_6661
cpu id: 08B6
Check Flash-1 Done
Check Flash-2...
reading ...
unlock step-1 Ok
unlock step-2 Ok
unlock step-3 Ok
unlock step-4 Ok
unlock step-5 Ok
finished Ok
The Following 2 Users Say Thank You to m_tahir1 For This Useful Post:
Old 12-15-2009, 16:34   #1526 (permalink)
faisal4friend's Avatar
Member: 262523
Sonork: 100.1611482
Thanks Meter: 288
Thumbs up sucessful unlock t156 100%
thanx infintiy team today i have unlock t156 done
here is log :
=> module version: 1.72
=> operation started: COM3
==> set_com_port
==> set_baud_rate
==> check_comm_link
==> set_v24_mode
==> set_baud_rate
==> check_comm_link
==> get_ms_id
imei: 353081035046732
==> get_sw_version
sw ver: P1.2PU01V01.01
==> get_sec_version
sec ver: 00.31Et(4242)
==> reading...
access result: 00
access level: 03
verification result: F0600100561200FF00040105020503050405000000000000
last error: No errors
==> close_com_port
=> operation finished
Finished, time used: 7 sec
Power Off/On phone now
unlock done
The Following User Says Thank You to faisal4friend For This Useful Post:
Old 12-15-2009, 16:39   #1527 (permalink)
alis's Avatar
Member: 206532
Sonork: 100.1622270
Thanks Meter: 875
module v1.72
Device: Zong-A136
Action: unlock
unlock method-1
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
921600
Set Baud Done
Connecting ...
flash: 00EC:257E
Connecting Done
Check hardware ...
Check hardware Done
file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-static_20091215-203818.B1E.bin
loading data...
data loaded
file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-security_20091215-203819.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-complete_20091215-203820.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_lock-area_20091215-203823.B1E.bin
Check memory ...
lock found
lock type #1 found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Finished, time used: 22 sec
Old 12-15-2009, 16:54   #1528 (permalink)
alis's Avatar
Member: 206532
Sonork: 100.1622270
Thanks Meter: 875
module v2.99
Action: reset settings
Model: LG-KG300
19200 autodetect
Initializing [6227:8A02:8A01]...
CPU: MT6227
chip: 0031:5C27:6F46
status: FF
Connecting at 19200, wait...
Hardware: MT6227,E02
Date: 2005.04.12
Version: 1.0
Version: 7S7312SA00-001
Version: EP1
60 byte(s) read
imei: 35044800000000
connection Ok
building list...
done
items total: 182
items to clear: 182
warning: wrong packet cs
items cleared: 182 of 182
building list...
done
items remains: 0
Finished, time used: 60 sec
Old 12-15-2009, 19:00   #1529 (permalink)
amanvir's Avatar
Member: 231737
Sonork: 100.1606447
Thanks Meter: 163
COM3 selected
Device: Toshiba-TS10
Action: Unlock
Boot...
Press and HOLD Power button !
Connecting, wait...
flash: 01227E22212200:98E59F00000000
flash: Amd S29PL129J,S71PL129JC0,S71PL129JB0,S71PL129JA0 T 8Mb
Boot Done
Set baud...
115200
Set baud Done
Check Flash...
Check Flash Done
Check space...
file saved: C:\Program Files\InfinityBox\QModule\backup_eeprom_unlock-1_20091215-174401.39E.bin
file saved: C:\Program Files\InfinityBox\QModule\backup_eeprom_unlock-2_20091215-174406.39E.bin
Check space Done
Check parameters...
Format file system...
area-01...
area requested/selected: 02/02
Format file system Done
Write...
Preparing...
Finalizing...
Write Done
Finished
Time used: 50 sec
The Following User Says Thank You to amanvir For This Useful Post:
Old 12-16-2009, 05:29   #1530 (permalink)
69eyes's Avatar
Member: 942693
Sonork: 1592619
Thanks Meter: 2,204
VODAFONE 225 UNLOCK DONE! Select Module ZTE
COM208 [VCP0] selected
module v1.72
Device: ZTE-125
Action: unlock
unlock method-1
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 0001:22C4
Connecting Done
Check hardware ...
sw version: TEL-P108A7 V V1.0.0B03 04.12.00 18.26.11 08.02.00 16 25 09 ENTEL
Check hardware Done
file saved: C:\Archivos de programa\InfinityBox\Pana01\ZTE-125_eeprom-static_20091216-010943.B1E.bin
loading data...
data loaded
file saved: C:\Archivos de programa\InfinityBox\Pana01\ZTE-125_eeprom-security_20091216-010945.B1E.bin
file saved: C:\Archivos de programa\InfinityBox\Pana01\ZTE-125_eeprom-complete_20091216-010951.B1E.bin
file saved: C:\Archivos de programa\InfinityBox\Pana01\ZTE-125_lock-area_20091216-011010.B1E.bin
Check memory ...
lock found
lock type #1 found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Finished, time used: 64 sec
The Following User Says Thank You to 69eyes For This Useful Post:
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Page generated in 0.57191 seconds with 10 queries
