12-20-2009, 14:12 | #1576 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Heart of Islam Age: 41
Member: 762034 Status: Offline Sonork: 100.1585274 Thanks Meter: 1,448 | COM4 [VCP0] selected Device: Siemens-CL75 Checking data, wait... Action: Unlock Boot... Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22202200:98E59F00000000 flash: Amd PL127J D 16Mb id: 0000527A Boot Done Set baud... 115200 Set baud Done Check Flash... Check Flash Done Check space... file saved: C:\Program Files\InfinityBox\QModule\backup_eeprom_unlock-1_20091219-110505.21E.bin file saved: C:\Program Files\InfinityBox\QModule\backup_eeprom_unlock-2_20091219-110509.21E.bin Check space Done Check parameters... Check parameters Done Format file system... area-01... area requested/selected: 02/03 Format file system Done Write... Preparing... area requested/selected: 02/03 Finalizing... area requested/selected: 02/03 Write Done Finished Remove/Install battery now ! Time used: 41 sec |
The Following User Says Thank You to guljee786 For This Useful Post: |
12-20-2009, 16:30 | #1577 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Al-Ahsa Saudi Arabia Age: 35
Member: 253510 Status: Offline Sonork: 100.1672352 Thanks Meter: 3,534 | unlock ok t156 => module version: v. => operation (3) started: COM6 ==> get_dll_version dll version: 38.0i ==> set_com_port ==> set_baud_rate ==> set_v24_mode ==> set_baud_rate ==> check_comm_link ==> get_ms_id imei: 359428010375491 ==> get_sw_version sw ver: P1.2nV01.05:ULC2GL ==> get_sec_version sec ver: 00.31Et(4242) ==> get_eep_version eep version: 000C ==> get_eep_revision eep revision: 0000 ==> reading... access result: 00 access level: 03 ==> set required mode... ==> reboot... ==> reading... lock result: 00 lock status: 020A ==> unlock... verification result: F0600100561200FF00040105020503050405000000000000 verification result: F0600100561200FF00040105020503050405000000000000 verification result: F0600100561200FF00040105020503050405000000000000 verification result: F0600100561200FF00040105020503050405000000000000 verification result: F0600100561200FF00040105020503050405000000000000 ==> restore original mode... last error: No errors => operation finished ==> close_com_port Finished, time used: 19 sec Power Off/On phone now ! |
The Following User Says Thank You to .::M Irfan::. For This Useful Post: |
12-20-2009, 17:56 | #1578 (permalink) |
Freak Poster Join Date: Apr 2006 Location: EARTH
Member: 259397 Status: Offline Thanks Meter: 76 | Succefully repaird chines fone .. thnx infiniy ==== log: [12/20/2009 4:54:43 PM] ==== COM4 [VCP0] selected module v3.02 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" Do you want to make ffs/eeprom backup before format ? ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:3B03:0007 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #02 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #03 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished rom info protocol ver: 04 ver. sw 1: KCM25_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_W08 _12.BIN ver. sw 2: MAUI.GEMINI.W08.12, 00000000 code offset: 00000000 ffs offset/size: 00E00000/00200000 detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 01227E22202200:18E59F00000000 checking area [00000000]: 00080000-00FFFFFF... ffs/eeprom found near: 00E40000 Detected ffs/eeprom address is non-standard: 00E40000 Posible reasons: 1. ffs/eeprom is Ok but address is non-standard 2. ffs/eeprom is damaged and can't be detected 3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make full flash backup for emergency case 3. repeat required operation Are you sure that detected ffs/eeprom address is correct ? autodetected ffs/eeprom address confirmed by user: 00E40000 detecting ffs/eeprom size... ffs/eeprom size: 001C0000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E40000-00FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 01227E22202200:18E59F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 01227E22202200:18E59F00000000 Finalization Done Finished, time used: 47 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to Tanveer_city01 For This Useful Post: |
12-20-2009, 23:10 | #1579 (permalink) |
No Life Poster Join Date: Feb 2008
Member: 712887 Status: Offline Sonork: gokuu2011 Thanks Meter: 349 | ot203 ==== log: [12/20/2009 3:25:56 PM] ==== COM4 [VCP0] selected modulo v2.99 Servicio: Alcatel-203X, 203A, 203E Checkeando datos, espere... Habilitada la deteccion avanzada del chip Action: rebuild security area ====> Boot ... Mantenga Presionado el boton Power ! 19200 fixed Conectando, espere... Iniciando [6223:8A05:8A00]... CPU: MT6223 chip: 0011:5EE4:A00C status: 01 Tamaño del boot packet: 0400 Deje de presionar el boton power ahora ! Boot Done ====> Iniciar ... detecting chip #00 in region #00... Flash 01227E221A2201:2BEA0000000000 Flash Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb numero de flash chip/regiones detectadas: 01/01 Iniciar Done ====> Seleccionar velocidad ... 921600 Seleccionar velocidad Done ====> Iniciar bootcode ... Iniciar bootcode Done ====> Comprobar la integridad del firmware ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info protocol ver: 05 ver. sw 1: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN ver. sw 2: MAUI.08A.W08.36.SP1.V28.F1, 00000000 code offset: 00000000 ffs offset/size: 003A0000/00058000 TCL-ID identification Version: 37E provider: 203A-2DCECO3 Personalización CM37NG37 Personalización XM37NG37 TCL-ID identification done ffs/eeprom address assigned: 003A0000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished Estado sim-lock: enabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, part #2) calculation... identification header detected Personalización XM37NG37 customization name adjusted Flash 01227E221A2201:2BEA0000000000 Flash 01227E221A2201:2BEA0000000000 Escribir security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... Listo Flash 01227E221A2201:2BEA0000000000 Flash 01227E221A2201:2BEA0000000000 Escribir security area (sec info, part #1) security area (sec info, part #1) calculation done Comprobar la integridad del firmware Done ====> Comprobar el contenido del firmware ... Comprobar el contenido del firmware Done ====> Backup de datos requeridos ... Flash 01227E221A2201:2BEA0000000000 Backup de datos requeridos Done ====> Revisión de datos requeridos ... Revisión de datos requeridos Done ====> Operacion Especial ... Operacion Especial Done ====> Escribir ... Escribir Done ====> Finalizado ... FFS formatting... Flash 01227E221A2201:2BEA0000000000 Finalizado Done Archivo guardado: H:\InfinityBox\MModule\backup_security\Alcatel-203X,203A,203E_JRD23_NEP_08A_PCB01_GSM_MT6223_S00. MAUI_08A_W08_36_SP1_V28_F1__system_log__00000000_2 0091220-152744.B0X.bin Finalizado, tiempo usado: 89 sec Quite/coloque la bateria ahora |
The Following User Says Thank You to Gokuu2007 For This Useful Post: |
12-20-2009, 23:26 | #1580 (permalink) |
Member: 712887 Status: Offline Sonork: gokuu2011 Thanks Meter: 349 | repair dead vki410 after unlock with infinity ==== log: [12/19/2009 7:58:39 PM] ==== COM4 [VCP0] selected modulo v2.99 Servicio: Verykool-i410 Checkeando datos, espere... Habilitada la deteccion avanzada del chip Action: write NOR flash "smart write" activado "formateo de ffs" activo Escribir Firmware Verykool-i410_LCBJ25_07B_GEMINI_PMWY_PCB01_GPRS_MT6225_S01. LBLAE01_1_0_1_4T28M0403_M401_En_Es.B0M.bin saltar: Customization/Language Pack saltar: Customization saltar: Eeprom/ffs ====> Boot ... Mantenga Presionado el boton Power ! 19200 fixed Conectando, espere... Iniciando [6225:8A03:8A00]... CPU: MT6225 chip: 0001:2103:0008 status: FF Tamaño del boot packet: 0400 Deje de presionar el boton power ahora ! Boot Done ====> Iniciar ... detecting chip #00 in region #00... Flash 01227E22202200:FFFFFF00000000 Flash Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb numero de flash chip/regiones detectadas: 01/01 Iniciar Done ====> Seleccionar velocidad ... 921600 Seleccionar velocidad Done ====> Iniciar bootcode ... Iniciar bootcode Done ====> Comprobar la integridad del firmware ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished Peligro: rom info information not found, possible reasons: .old firmware type w/o rom info data .damaged firmware .damaged hardware if phone works fine just ignore this warning ffs/eeprom address can not be detected, value from database assigned: 00C80000/00280000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Comprobar la integridad del firmware Done ====> Comprobar el contenido del firmware ... Comprobar el contenido del firmware Done ====> Backup de datos requeridos ... Backup de datos requeridos Done ====> Revisión de datos requeridos ... Revisión de datos requeridos Done ====> Operacion Especial ... Operacion Especial Done ====> Escribir ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished Peligro: rom info information not found, possible reasons: .old firmware type w/o rom info data .damaged firmware .damaged hardware if phone works fine just ignore this warning ffs/eeprom address can not be detected, value from database assigned: 00C80000/00280000 sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... startup code area #1 fixed Area: Firmware Flash 01227E22202200:FFFFFF00000000 Escribir Firmware sec info (fast) detection... searching sec info#1... . search sec info#1 finished Escribir Done ====> Finalizado ... FFS formatting... Flash 01227E22202200:29EA0000000000 Finalizado Done Finalizado, tiempo usado: 722 sec Quite/coloque la bateria ahora ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! ==== log: [12/19/2009 8:11:27 PM] ==== COM4 [VCP0] selected modulo v2.99 Servicio: Verykool-i410 Checkeando datos, espere... Habilitada la deteccion avanzada del chip Action: repair security area ====> Boot ... Mantenga Presionado el boton Power ! 19200 fixed Conectando, espere... Iniciando [6225:8A03:8A00]... CPU: MT6225 chip: 0001:2103:0008 status: FF Tamaño del boot packet: 0400 Deje de presionar el boton power ahora ! Boot Done ====> Iniciar ... detecting chip #00 in region #00... Flash 01227E22202200:29EA0000000000 Flash Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb numero de flash chip/regiones detectadas: 01/01 Iniciar Done ====> Seleccionar velocidad ... 921600 Seleccionar velocidad Done ====> Iniciar bootcode ... Iniciar bootcode Done ====> Comprobar la integridad del firmware ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished rom info protocol ver: 04 ver. sw 1: LCBJ25_07B_GEMINI_PMWY_PCB01_GPRS_MT6225_S01.LBLAE 01_1_0_1_4T28M0403_M401.BIN ver. sw 2: LBLAE01.1.0.1.4T28M0403_M401, 00000000 code offset: 00000000 ffs offset/size: 00C80000/00380000 ffs/eeprom address assigned: 00C80000 sec info (fast) detection... searching sec info#1... . search sec info#1 finished Comprobar la integridad del firmware Done ====> Comprobar el contenido del firmware ... Comprobar el contenido del firmware Done ====> Backup de datos requeridos ... Flash 01227E22202200:29EA0000000000 Backup de datos requeridos Done ====> Revisión de datos requeridos ... Revisión de datos requeridos Done ====> Operacion Especial ... Operacion Especial Done ====> Escribir ... Escribir Done ====> Finalizado ... FFS formatting... Flash 01227E22202200:29EA0000000000 Finalizado Done Finalizado, tiempo usado: 56 sec Quite/coloque la bateria ahora ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! ==== log: [12/19/2009 8:15:37 PM] ==== COM4 [VCP0] selected modulo v2.99 Servicio: Verykool-i410 Checkeando datos, espere... Habilitada la deteccion avanzada del chip Action: "sp-unlock" Metodo unlock: standard ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Mantenga Presionado el boton Power ! 19200 fixed Conectando, espere... Iniciando [6225:8A03:8A00]... CPU: MT6225 chip: 0001:2103:0008 status: FF Tamaño del boot packet: 0400 Deje de presionar el boton power ahora ! Boot Done ====> Iniciar ... detecting chip #00 in region #00... Flash 01227E22202200:29EA0000000000 Flash Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb numero de flash chip/regiones detectadas: 01/01 Iniciar Done ====> Seleccionar velocidad ... 921600 Seleccionar velocidad Done ====> Iniciar bootcode ... Iniciar bootcode Done ====> Comprobar la integridad del firmware ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished rom info protocol ver: 04 ver. sw 1: LCBJ25_07B_GEMINI_PMWY_PCB01_GPRS_MT6225_S01.LBLAE 01_1_0_1_4T28M0403_M401.BIN ver. sw 2: LBLAE01.1.0.1.4T28M0403_M401, 00000000 code offset: 00000000 ffs offset/size: 00C80000/00380000 ffs/eeprom address assigned: 00C80000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Comprobar la integridad del firmware Done ====> Comprobar el contenido del firmware ... Comprobar el contenido del firmware Done ====> Backup de datos requeridos ... leyendo Verykool-i410_LCBJ25_07B_GEMINI_PMWY_PCB01_GPRS_MT6225_S01. LBLAE01_1_0_1_4T28M0403_M401__ffs... Archivo guardado: H:\InfinityBox\MModule\Verykool-i410_LCBJ25_07B_GEMINI_PMWY_PCB01_GPRS_MT6225_S01. LBLAE01_1_0_1_4T28M0403_M401__ffs_20091219-201828.B0E.bin Flash 01227E22202200:29EA0000000000 Backup de datos requeridos Done ====> Revisión de datos requeridos ... detection procedure, wait... detection procedure completed detection procedure, wait... detection procedure completed Revisión de datos requeridos Done ====> Operacion Especial ... detecting parameters to apply patch area 1... ............................. required data found Flash 01227E22202200:29EA0000000000 Flash 01227E22202200:29EA0000000000 Escribir area 1 (pass 1) ................................... area 1 patch applied Ok detecting parameters to apply patch area 2... .................................................. .............. error: area 2 can not apply patch Operacion Especial Done ====> Escribir ... Flash 01227E22202200:29EA0000000000 Escribir eeprom Escribir Done ====> Finalizado ... Finalizado Done Finalizado, tiempo usado: 245 sec Quite/coloque la bateria ahora ! Check your country laws before use this option ! In some countries this operation may be prohibited ! You must think serious before continue ! Do you understand above text well and want to continue ? Action: imei Modelo: Verykool-i410 Checkeando datos, espere... El telefono deberia estar Encendido ! Conectando, espere... Telefono detectado, espere... imei-1: 135790246811220 Metodo de escritura de imei: modo-1 Canal de escritura de imei: imei #1 para dual sim/mono CPU new imei-1: 356336020045264 verificacion Ok Finalizado, tiempo usado: 21 sec Apage el telefono Ahora ! |
12-21-2009, 00:24 | #1581 (permalink) |
Freak Poster Join Date: Feb 2008 Location: Zambia
Member: 703394 Status: Offline Thanks Meter: 47 | Haier HG - M151 Successfully Unlocked by selecting zte A62+ Here is my log: COM6 [VCP0] selected module v1.72 Device: ZTE-A62+ Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 007F:22F6 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A62+_eeprom-static_20091221-004438.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A62+_eeprom-security_20091221-004439.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A62+_eeprom-complete_20091221-004445.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A62+_lock-area_20091221-004458.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 53 sec Remove/Install battery now ! Pls Note: The phone won't write the new network's names (e.g Telecel, MTN), instead will write invalid sim but will recieve and make calls, enjoy. |
The Following User Says Thank You to dkaluba74 For This Useful Post: |
12-21-2009, 00:31 | #1582 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @dkaluba74 please, read full flash from Haier HG - M151 and send full flash backup file and pinout to [email protected] Thank you ! |
12-21-2009, 05:50 | #1583 (permalink) |
No Life Poster Join Date: Jan 2009 Location: M_B_Din-PK
Member: 950201 Status: Offline Thanks Meter: 1,928 | COM3 [VCP0] selected module v1.72 Device: LG-KG270 Checking data, wait... Action: flash write Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: .00 ULC2GL KG271 P16 92 V10c XXX-XX Mar 28 2007 +0 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-static_20091222-104806.B1E.bin loading data... data loaded imei: 35558801354220900 reading eeprom-security_35558801354220900... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-security_35558801354220900_20091222-104806.B1E.bin reading eeprom-complete_35558801354220900... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-complete_35558801354220900_20091222-104808.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: Firmware Writing: Firmware Write Done Finished, time used: 90 sec Remove/Install battery now ! |
The Following User Says Thank You to cel_phon For This Useful Post: |
12-21-2009, 06:30 | #1584 (permalink) |
No Life Poster Join Date: Jul 2009 Location: philippines now here in U.A.E Age: 38
Member: 1070665 Status: Offline Sonork: 100.1636802 Thanks Meter: 572 | c139 unlock by infinity via convert here in logs complete . convert . COM10 [VCP0] selected Action: unlock Device: C139,C140 Checking data, wait... Connect... Press and HOLD Power button... connection mode: 00 Release Power button ! Connect Done Boot... Boot Done Set Baud... 921600 Set Baud Done Check Flash-1... SW version: 1.0.24 HW version: _E88 LP ver: LPN_C139_NA2_00X Flex ver: FFN_C139_4R_10X imei otp: 011088005620994 Check Flash-1 Done Check Flash-2... reading ... file saved: C:\Program Files\InfinityBox\Moto01\backup_eeprom_calibration _011088005620994_20091221-112950.31E.bin imei eeprom: 011088005620994 Check Flash-2 Done Write... Write Done Finished, time used: 20 sec Remove/Install battery now ! happy unlocking .................... |
The Following 2 Users Say Thank You to lilong_lee For This Useful Post: |
12-21-2009, 06:45 | #1585 (permalink) |
Member: 950201 Status: Offline Thanks Meter: 1,928 | COM3 [VCP0] selected module v1.72 Device: LG-KG270 Checking data, wait... Action: flash write Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: .00 ULC2GL CIS Open KG270 KG270 P16 07 V10h XXX-XX JAN 24 200 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-static_20091222-114151.B1E.bin loading data... data loaded imei: 35858101173080800 reading eeprom-security_35858101173080800... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-security_35858101173080800_20091222-114152.B1E.bin reading eeprom-complete_35858101173080800... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-complete_35858101173080800_20091222-114153.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... reset... done Erasing: Firmware Writing: Firmware Erasing: Language Pack Writing: Language Pack Erasing: FFS-2/File system Writing: FFS-2/File system Write Done Finished, time used: 155 sec Remove/Install battery now ! |
12-21-2009, 09:09 | #1586 (permalink) |
Member: 259397 Status: Offline Thanks Meter: 76 | successfully repaird chinnes fone .. thnx infinity team. ==== log: [12/21/2009 1:05:22 PM] ==== COM4 [VCP0] selected module v3.03 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") Do you want to make ffs/eeprom backup before format ? ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:8403:000A status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #02 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #03 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished ==================== New firmware detected (v.3.03, database date: 20.12.2009): LC6225_GEMINI_PCB01_GPRS_MT6225_S00.LBBKY07_8_12_1 _2T03M0730_M571.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info ver: 04 sw version: LC6225_GEMINI_PCB01_GPRS_MT6225_S00.LBBKY07_8_12_1 _2T03M0730_M571.BIN project-id: LBBKY07.8.12.1.2T03M0730_M571, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [standard] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: EC257E25082501:18E59F00000000 checking area [00000000]: 00080000-00FFFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: EC257E25082501:18E59F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: EC257E25082501:18E59F00000000 Finalization Done Finished, time used: 1 min 5 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following 2 Users Say Thank You to Tanveer_city01 For This Useful Post: |
12-21-2009, 11:19 | #1587 (permalink) |
No Life Poster Join Date: Oct 2007 Location: india
Member: 618404 Status: Offline Thanks Meter: 311 | sagem my220x unlocking done............. COM42 [Serial2] selected module v1.72 Device: Sagem-my220x Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820010 loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220x_eeprom-static_20091221-142348.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220x_eeprom-security_20091221-142349.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220x_eeprom-complete_20091221-142349.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220x_lock-area_20091221-142353.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 30 sec Remove/Install battery now ! wbr. rajesh ch. |
The Following User Says Thank You to rajesh_ch For This Useful Post: |
12-21-2009, 14:31 | #1588 (permalink) |
Member: 950201 Status: Offline Thanks Meter: 1,928 | COM5 [VCP0] selected module v2.75 Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:7403:0009 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: E100_TCD04_F11_L102_S22_Y12_V02 Version: LENTEK_GEMINI_HW detecting structure #2... 5 11 done 67 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok building list... done items to clear: 141 warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs items cleared: 139 of 141 building list... done items remains: 2 Finished, time used: 24 sec Remove/Install battery now ! |
12-21-2009, 15:55 | #1589 (permalink) |
No Life Poster Join Date: Dec 2005 Location: Al-Madina Communication Age: 45
Member: 206532 Status: Offline Sonork: 100.1622270 Thanks Meter: 874 | COM5 [VCP0] selected module v1.72 Device: LG-KG270 Checking data, wait... Action: reset Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: .00 ULC2GL KG270 P16 ARB V10f XXX-XX Jul 12 2007 +0 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-static_20091221-195029.B1E.bin loading data... data loaded imei: 35558801465380700 reading eeprom-security_35558801465380700... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-security_35558801465380700_20091221-195030.B1E.bin reading eeprom-complete_35558801465380700... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-complete_35558801465380700_20091221-195031.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... reset... done Write Done Finished, time used: 28 sec Remove/Install battery now ! |
The Following User Says Thank You to alis For This Useful Post: |
12-21-2009, 15:55 | #1590 (permalink) |
Member: 206532 Status: Offline Sonork: 100.1622270 Thanks Meter: 874 | COM5 [VCP0] selected module v1.72 Device: LG-KG270 Checking data, wait... Action: unlock read unlock codes Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: .00 ULC2GL KG270 P16 ARB V10f XXX-XX Jul 12 2007 +0 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-static_20091221-194930.B1E.bin loading data... data loaded imei: 35558801465380700 reading eeprom-security_35558801465380700... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-security_35558801465380700_20091221-194930.B1E.bin reading eeprom-complete_35558801465380700... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-complete_35558801465380700_20091221-194931.B1E.bin backup critical area Done Check memory ... loading data... data loaded code: 88025275 code: 0000000000000000 Finished, time used: 13 sec Remove/Install battery now ! |
